View Full Version : Honda Civic / Del Sol (1992 - 2000)
- will a 93 b16a2 head fit on 1996 d16 sohc block?
- is it a thing you should really think about or not????
- Need help installing greddy oil pressure gauge and oil temp gauge!
- Are short Throws easy to install
- short shifter? which one?
- How do you remove the del sol rear bumper????
- should i buy them , amazing deal
- Boost Gauge Vac Line Through Firewall
- p28 and lsvtec?
- looks about the same, but bondoed!!!!!
- Taking Axles Out??!!??
- Installed my 99 SI Rear Sway Bar today!
- What Suspension Goodies Am I Missing Before Install Time ?
- How much is my car worth?
- What is sticking out of the front-bumper of this EG?
- Del Sol pics
- D16z6 head
- HELP: How do I open the hood if the cable release is broken?
- can't get the fuel filter off, whats the deal??
- ot: need somebody to install/weld exh in OC
- Tranny Gurus: Is a JDM CTR LSD a direct replacement diff for a USDM 2000 Civic SI?
- *PiX* Car work, and stuff keeping me up at night *PiX* 56k go home
- b18c5 in 97 civic hx
- Intergra springs(neuspeed) on my 92 hatch
- (96-98) will a sedan rear bumper fit on a coupe?
- Looking for a 92-95 civic hatch
- Yea my car gets looked at today
- Radio settings for EM1
- Anyone have problems running 80w/100w headlight bulbs?
- Best 4-1 header for sohc
- Shock Dissasembly
- after market civic header
- What do you guys think?
- high whistle sound from engine
- Quick ways to make your car faster with spending little or no money?
- maintenance???
- What fuel filter to use on hybrid?
- Engine swaps shops in South Florida--Anyone?
- busted my cv joint...
- fuse?
- shock mounts
- stock wheels that we can use .
- i need your opinion friends
- who did group buy on VIS hoods?
- Who makes the best rear swwaybar for the 96-00 hatchbacks
- what is a good ecu for a d16y8
- anyone going to da track tonight
- Zeal or Tein... for a 99 cx hb... your suggestions please
- where to buy a d16 motor?
- my speedometer...
- Swap info .... Please help..
- My car is running TOO rich...
- Various swap/rebuild questions
- doch vtec ecu on a soch vtec
- what would the compression be?
- Electrical Problems 97DX
- JDM civic type-R body kit
- 5 lug conversion
- 92-95 strut bar fit 97??
- Integra RS vs Integra LS swap
- Engine Mount Diagrams
- tranny fluids
- h22 ecu question
- Honda OEM Parts???
- good deal?
- Should I get this SI?
- Turbo or NA b16 sol???
- thinking of trading crx for civic hatch. where can i find model info for 92-95's?
- Where to hoist the D16y6 from?
- does anyone know what is going to happen with that pics forum
- Engine Swap?
- Roof Antenna Conversion for Hatch
- usdm type r header on b16a2
- new del sol
- Stock Radio and Clock Problem
- Calling all the Hx guys
- Skunk2 lower tie bar?
- VSS question--need help asap!!!
- will the 93 EX throttle cable work for a b18c1?
- HOw many post???
- will the b18c1 shift linkage fit a 93 coupe?
- any tips for a b18c1 into a 93 coupe? 93 wire harness too..
- Lower Control Arm?
- air conditioning swap
- OEM headlights for a 93 hatch
- What ECU does a 92VX hav?
- I dont Understand????
- Wheels weights
- This is XxDemonxX
- help me out with eg interior
- 97 DX Alternator removal?
- new EK suspension piece installed
- Spoon Sports N1 Axlebacks $335 Shipped with Free Silencer ...
- SOHC buildup need some ideas....
- 99-00 Si front sway bar bent?
- Key Replacement at the Dealership
- got $1400 for suspension...
- 96 D16Y8 SOHC VTEC into a 95 DX coupe
- install on city lights
- Good deal on Ek? yes or no
- h22 type-s whp?
- What would you guys buy???
- 92 CX head gasket recall??
- SOHC VTEC tuners ...need your help
- Need Engine Swap opinions
- What's the REAL law for Front Liscense Plates
- My civic is messed up :(
- 96 Civic Header & Exhaust ?
- Sunroof Removal
- squeeking at idle...
- Need people's opinion on how much of a shot of NOS to run?
- will this fit,and how do i install it
- PCV Valve have a stuttering effect on idle????
- need help fast !!!!!!!!!!!!!!!!!!
- Quick Release
- progress of the race car (pics)
- brake line fitment question...
- new tires!!!! YEAH!!!!
- my dilemma
- knocking noise under car
- Individual throttle bodies for K20 YUMMY...
- Wheels pics
- EG sedan exhaust options
- The latest taillights from TYC!
- CTR Steering wheel size dimensions....compared to RSX wheel...???
- 7th gen question about intake...
- old SkOOl
- GC Coilz . .
- headers ??????
- think i got scammed
- ek with hx wheels
- replacing a dented roof on EH2
- NX kit or ZEX kit?
- What size tire?
- A Crisply toasted MUFFLER
- have a question....
- DCR rear seats into my ek(?)
- 00 EK hatch + LS =
- Lex IS muffler on an EK or EG?
- 96-98 coupe stock wing installation, help please?
- Rust on rear quarter panels?
- GSr motor rev limits 6500
- HELP: Exam tommorow + car won't start
- autogage mounting question
- whats my car worth..... roughly.......
- cant find where to fill tranny up at
- I need help with an '01 tranny swap ASAP PLEASE HELP...
- Question: coilover install...already tried search
- ANY difference in Auto and Manual Axles?
- timing on a 97 civic dx with the timing gun
- ek rear sway bar setup...
- Leaky gasket?
- anyway to hard wire a shift lite?
- Goodridge SS brake line question!!
- how to do it yourself alinement
- Rear Lower Shock Bolt, ALWAYS SNAPS!!!!
- very stupid question
- CEl 1 o2 sensor
- Mounting Locations for V-AFC in an EK?
- Killer Eg find @ pick a part today
- 11"/11" Fastbrakes vs. ITR 5 lug
- Need Wiring Diagram for 98 ek
- 6th gen Civic engines
- Coilover Install
- just testing
- Del Sol Si wheels 14"
- Diff. between Thermal classic and Apex-i N1 exhausts
- Howling sound when in reverse?
- Best power window kit for 96-00 CX...Spal? Auto-Loc? OEM?
- toda spec a's on b16
- How often should you change your oil?
- ot: Hybrid Must Haves..
- Cleaning your EK's throttle body
- cv joint
- Best Place to get JDM engine?
- Taking axles off em2
- Need info on the difference between 95 and 97 Del Sols...
- Air Intake Temp Sensor
- My Exhaust Sounds Great
- EG/EK Project
- Question about exhausts for civics
- Apexi N1 Suspension Upgrade-Great Service!
- *** my 7 year old JDM wheel finally came out under the house ***
- Camber Kits...
- How ruff will koni yellows and GC coilovers with custom rats 375F/425R?
- Did some test fits for my homemade sohc turbo setup
- 93 with bad hesitaion
- 7th gen civic intake install question
- Eibach Sportlines vs. H&R Sports - Let's hear your opinion! (Pics encouraged)
- orderd my del sol vtec dual core today! and it was cheap!
- Alarm/Keyless install on 99 Civic - Need wiring diagram
- greddy kits fit jdm engines right?
- Clutch or Tranny?
- eg front sway bar question
- serpentine belt
- Parking Brake Help
- Dallas Shops
- 93 si vs. 2000 si
- need ideas and pictures of civic rims -16-17in.
- 98 Civic frost white turned into...CHAMPIONSHIP WHITE!
- What size cat to use after GSR swap?
- new here
- Wiring JDM Headlight and Wiper Switch...
- Putting Exhaust On Ek Pipping?
- eg toys
- best shocks/struts to go with eibach prokit for 95 coupe
- rear wiper
- Chassis harness swapping
- 00 Cluster in a 92 CX?
- Old trend ( civics with swaps ) New trend ( Built the engine that comes with the car )
- My new mandrel exhaust=)
- door moulding
- Del Sol Radiator in a EK
- eg+Civic/del sol
- Just broke bolt on rear shock/lca....
- where's a good place to pick up EG9 front clip
- anyone selling si bumper n lights>? WTB
- help doing 5lug conversion on eg
- Pedals?
- WTB: 92-95 Civic HB OEM Airbox
- RECOVERED 4 door civic!!
- 99 civic dx
- Single wire o2 to 4 wire o2
- si vs ctr sway and lca
- piston rings for JEs at a good price?? N-E1
- good deal?
- my car has been boggin lately got a ?
- Rain Covers on the Doors of a Civic
- 97 del sol non-vtec
- b series vs d series
- Auto Meter Guages
- just picked up a 99 black Si today
- building my SOHC
- need help on search
- Do you know your hoods?
- Will ITR Zeal B2 fit a 99 Civic Si?
- My car backfired and fire came out....
- d15 skunk 2 intake mani.
- Si seats in EK coupe
- b18b with nitrous....how much
- tranny broke, must change it on 2001 civic.. hlp plz
- EP3 seats in a EK coupe
- In light of my recent ricer install... (Headlight Bulbs)
- B16a eg's,need help!!!
- LS mtor swap
- seat combo question
- mini-me questions (did search)
- My time sucks
- Too Much Fuel??
- Anyone have a b18b in a hatch that can posta pic , please do.
