View Full Version : Honda Civic / Del Sol (1992 - 2000)
- just bought a 99 hatch shell need some help
- Picture of a B16A3 backside needed
- lsvtec or b16/b18c1
- ECU help
- 95 civic DX, stock 1.5L 4 door won't start, need advice
- replacing power steering pump bearing?
- K&N????
- MINI ME
- header fitment?
- better than the rest
- blown motor or what ???
- TEAM RICE song????????
- Car cranks but wont start (obd1 d16z6 in 1996 DX)
- **HELP!! HELP ** CAR STOLEN IN SAN DIEGO!
- you guys think this would be a write off?
- d16z6 oil pump install.
- Muffler Advice Needed.
- motor cranks but don't kick over
- Extra HP
- ODB2 B18C IN TO '94 CIVIC DX WIRING QUESTIONS
- Throttle body question
- b16a2
- vision vs password:jdm rear upper strut bars?
- EK headlight question...
- Headlight went out :-( please help asap!
- Timing Belt Replacement Gone Wrong
- 96-00 civic shocks on del Sol???
- DIY knock sensor wire up
- Eg6 Jdm rear wing with LED's
- EG idle problem.Please help
- Clutch issues, replacement suggestion
- ??muffler ???
- 1st gear "Q"
- 93 civic ex 4dr will not start! cranks but won't turn over!
- anyone know the WIRE for Power window/mirror/lock conversion for 92 - 95 civic EG?
- what should i use?
- B16 JDM turbo?
- 99-00 Climate Control Question...
- need 97 civic help
- skunk2 short throw
- How to lighten a Delsol Vtec basics and advanced?
- car wont start!!! need HELP!!
- Question about the 96-00 civic Chime buzzer
- Will 96-00 4 Door Sideskirts Fit A 2 Door?
- smog check didnt pass
- Will a 96 DX shocks fit a 00 EX?
- what are the options?
- gsr cluster in a civic???
- SOB ek clutch problems.
- Did the 99-00 Civic ever come with these type of wheels?????
- back pressure question.
- b-series swap mount?
- What is the procedure to break open the lights EG With TYC*Baked Them*Need help
- What seats are compatible with a 4Dr. front and back?
- What to use to remove baked on gaskets?
- FOR SALE: 1997 Civic Ex
- Does anyone else make roll bars other than autopower
- wHos Selling a Coupe in Socal????
- what engine i got
- Changed tranny fluid through vss now speedo doesnt work..
- still getting mad mileage after new 02 install and ECU reset?
- FItting GSR REAR LEATHER SEATS INTO AN EK
- GSR/EX ECU in a HX?
- del sol rhd?
- clutch problem
- Who makes the OB2 Cable for ur laptop ??
- brake line moving
- where to find CF front air splitters
- fitment of password 3pt and gsr booster?
- WIRE tuck
- Where can I buy/find a dashboard for a 92 Civic hatch?
- WTF IS UP WITH AF PERFORMANCE???
- tire question
- LS power!!!!!!!!!!
- Question? My car wont start.
- Please Please Help Me, My car wont start!!!!
- overheating
- Recaro replicas on JHPUSA? good?
- Conversion harness not fitting with wire harness?
- 94 civic auto tranny problems please help
- how do i put photos on here?
- can i Crvtec 6sp transmission!!
- wiring o2 sensor, 98 ex
- car in storage. how often should i start it?
- HX wheels over my 93si calipers
- engine swap, car starts but wont idle, questions??
- will d16z6 TB cable work on a d16y8 IM with a d16y7 head and block??
- After D16Y8 CAR NOW STARTS BUT WONT STAY ON?
- Slave Cyclinder / Clutch Cyclinder
- Mounts old or new
- I need some references on some clutches. Step inside please!
- integra sway bar on my 98 sedan...
- just fitted an b18c6 into eg5 and im throwing a cel 22 vtec pressure valve
- help finding thread: 96-98 Civic climate control swapped for 99-00 climate control
- Question on 92-95 Interior.
- 540 Virginia. Si or EK cluster for sale anyone?
- throwing codes in my EG
- QUESTION ON MUD/SPLASH GUARDS
- Internal axle seperation, how do I get it back in?
- injector sizes?
- injector size
- just crashed my car... be careful for this it might happen to you.
- is there a doctor in the house? anyone...? help...? please?
- Reverse is gone!!
- 92-95 civic cluster
- need some help.
- side marker problem PLEASE HELP
- Question on buying an EG coupe
- 500k 4 a ps 3?
- Dual Exhaust
- Del Sol Lighting Help
- !HELP! How is this happening?
- got the 3 main things. Car still wont start
- aem cold air down pipe
- k sport suspensions
- Type R Headlights...Good Buy?
- How can I fix this problem?
- Quick Question??
- 1.5k To Spend on my Swap.....Where to get most HP....?
- My first honda with 4 wheels, picking it up tomorrow...
- searched, need confirmation if this is correct
- Question: Do I need a ball joint remover?
- Driver side axle keeps separating from Intermediate shaft....
- question about paint jobs
- d16y8 problems.. need help
- AHHHH BLinker help!!!!!
- one more brake question? for a 93 coupe ex w/ rear drums
- z6 head onto ek cx bolck wiring???????
- turn signal
- abs and srs light
- why won't my obd1 conversion work right? harness? ecu?
- Speed sencor or what?
- What Cat To Buy?
- how do you replace rear brakes pad on a 92 ex sedan w/abs.
- what car should i get?
- D16Y7 compression numbers...
- c-pillar bar
- 2000 Si Block
- handbrake light won't turn off
- Neuspeed spark plugs
- ground question for my civic
- DSM turbo manifold
- JDM B16A (1st gen) in an EM1. Possible to pass emission?
- EJ1 axle nut stuck need advice
- EDM sites
- D-series valve cover/head ground?
- Gathers rear speaker covers question
- rings sealed, good compression...still smoking sometimes.
- help me im lost.
- quick rear disc question.
- Part number for valve cover studs rant
- FS/FT 15" Konig Helium
- GSR hatch problems
- jdm eg sidemarkers
- car wont start (keeps blowning the ecu fuse)
- intake fitment ?
- Springs for DD
- Signs of worn down clutch?
- best wheels that go on a ek
- Bad shocks??
- EJ1 Guage Cluster Help
- transmission trouble..
- Door Handle?
- radiator support fix???
- I Want your BLOWN block........
- fuel filter!!!!!
- Front Bumper
- Axle nut thread size
- Electrical problem?
- Power doors Dx HatchBack?
- How much does a D15B weigh?
- clutch problem
- FS: 93 white hatch
- d15b vtec
- RSX back seats into an ej1
- Kyb Gr-2's or Tokico blues... K sport?
- wrinkle paint?
- kill switches
- 1999 civic cluster gauge bulb replacement?
- 93 civic dx. brake problems
- Mass tuner needed
- Honda "brotherhood"
- motor swaps ( Where to the companies get the motors???)
- Lower Ball Joint???
- Parting Out Turbo EK!Best Parts!Cheap Prices!!
- Engine experts - Troubleshooting noise
- How to install rod, main and trust bearings D16Y7
- R.I.P EG Civic Aka Elvis :(
- is mini me worth it??
- Electrical Problems need suggestions please! Im stummped
- Bent valve? help!
- Compustar 2WSS ALarm help!!!
- Help!!!!
- what do this hoses ?
- Fog lights love to burn up the harness, nayone esle having this problem on 92-95?
- All Motor B20 Dyno Graph
- help with aftermarket stereo
- gsr turbo
- 93 Civic - Clutch Slave Bleed Screw
- what should i do to my car next? and when u tell me what brand is decent? (pics)
- Question with my Civic EG6 Exhurst PLEASE HELP~!!!!!!!!!!!
- Question about Intakes
- Anyone have a tein basic in a 96 coupe?????????
- dropzone? tokico?
- Help...need advise on muffler replacement??
- msd 6al hook up in a 95 civic eg D16Z6 any pictures?
- will power locks from a 92-95 civic ex coupe work in a del sol?
- What does the knock sensor kicking in "feel" like?
- 2000 CIVIC TOTALED AND WHAT TO SWAP PARTS TO MY 1993 CIVIC EX!!!
- T1R suspension
- Tranny Grinding
- Ecu question.
- D15 mini-me setup cam timing????
- Will CRX Si rear disc work on EG
- k series question?
- TIMING BELT NEED SOME PRO ADVICE!
- ENGINE CODE 22??
- afc neo install help...
- Trans interchange
- Trailing Arm Removal
- Lets discuss civic,(97 ex) power windows/why dont they stay in the da*n tracks!!!!!
- jdm civic side markers....HELP
- hasport gsr question
- Quick help Please!!! on exhuast
- ???about dash clock
- short shifters
- GSR rear discs on 94 EG coupe.....
- Need Honda Civic Help?
- Question will a 4 door civic gauge cluster w/ tackometer work in a 2dr coupe hatch? oem gauge cluste
- Throwing secondary 02 on a P28 wtf!
- A little swap help
- I'm looking for bolt-in kits for 3" harness
- Which Iacv?
- Hks Hi Power exhaust...........Opinion
- please help AXLE install problem
- Need EM1 Civic Si and EX for testing
- clutch install question
- suspension will it fit?
- 96 gsr swap in 97 ex
- S4C Rebuild Question (B16 Tranny)
- ITR steering rack into EK???
- Apexi Gt Spec Catback Exhaust on 99 si
- WHAT YOU GUYS THINK SHOULD I BUY THIS CAR*PICS*
- Ok guys,Your Exhaust,sounds and what u like,Looking to buy..
- idle problem
- Dizzy spinning freely?
- will this fit?
- B16A not working
- what spoiler is this for em1?
- D16Z6 into Del Sol S Question =)
