- gearbox trouble
- Found GTECH Performance Meters For $64.99
- del Sol colors..
- TWM ITB's and throttle cable
- steering rack bushing
- RHD pedal assembly...
- 99Civic Si tranny in doubt
- valve help
- My newly installed turbo is killing my car....HELP!
- Rough shift into third
- belt broke--now what--need options please
- HELP!! No oil pressure!! =(
- Replaced PCV valve and MPG went up by 4!
- My car idles weird after fixing IACV! HELP!!
- integra oil filter work on b16?
- Is this the correct brake booster for the EG rear conversion?
- CRX 4-2-1 headers on an ek
- I need help
- P28 Z6 Tranny
- Oil, and gas light
- electrial load detector?
- 99 EM1 factory fog q
- B16A Exhaust Header
- Del Sol Engine Replacement
- em1 headlight q
- WTF is this nasty smell coming from my air vents?????
- What is AEM's CAI made out of?
- Overheating problem
- Need A Fuse box diagram for 1997 civic DX ASAP
- Injector ticking
- Too much air pressure on the motor?
- real deal skunk 2 manifold! how can you tell?
- 97 Civic EX...Dash lights out...tried mostly everything..help??
- 02 - 04 Civic Si Steering wheel
- Hcp Ek/H22 front crossmember and traction bars
- b16 and d series air box question
- throwing code 22?
- HELP A/C FAN NO WORKY
- Im not sure if this is the right place to post this but I'm having axle problems!
- rhd conversion eg $?
- Poor delivery of body kit
- problem with my tranny
- cams help
- modified airbox question
- 2dr Bumper on 4dr (92-95)
- power folding mirrors for eg6??????????help
- obd1 or obd2 ????
- Ek hatchbacks READ THIS!!!!
- Moroso Bseries oilpan capacity
- b16a or b18cR
- DOES ANYONE KNOW HOW TO INSTALL A MSD RPM ACTIVATOR TO HELP ENGAGE VTEC EARLY
- help on finding motor?
- B18c into a EJ8
- o2 sensor install??? I searched!
- searched but no help, Rear sway on VX...help!!
- How hard/easy is it to roll my fenders on my EG?
- Fogged windows in 92 VX
- Furious owner trashes new car
- 5th gen back window molding?
- Best place to buy SPOON products?
- ***WTB: B Series mounts for EK CIVIC.. Complete set... SOCAL PREFERRED
- Economic Tranny options
- EK coupes kick ass!
- my friend is selling me springs...
- DAMN THEIVES
- could find it in search... so...
- lighted needle kits??
- dnx catback any good?
- tranny noise
- Stock Manifold Bore???
- Cold Air Intake
- ignition problems
- GSR steering rack in EK?
- rear disc brake conversion (quik question)
- Car won't Start, Details Inside !!! <<<>>>
- Does anyone know 4sure if y8 alternator works on z6?
- yellow bulbs for del sol
- 350z Projectors + 350z HID setup + my hatch = Sweet' 56k?? Dunt think so'
- LS motor
- fuel cut off....
- EG hatch,coupe question?????
- Whats up guys. Please help!
- where they go..?
- Relocating hood latch for security purposes!!!!!!!!!!!!!!!
- Online Vendors never returning email?
- rear disc conversion: weight?
- swapin a k20a-r into a 96 4dr lx need help and have alot of questions
- Don't support THEFT.
- Taking off flywheel
- b16a1 into eg civic...please reply
- civic convertible
- calling all h22 in ek owners!
- Looking for Del Sol JDM Bumper w/ Moldings
- differance between dx an ex front brakes
- Foglight switch alternative
- code #8 civic eg
- H22 or k20
- How much should I sell my civic for
- can anyone get a radio code for a 99 civic ex
- auto to stick
- eg9 climate control
- newly built motor runs like crap d16 :(
- Problems with ABS Civic EG6
- PIAA Super Plasma GT-X Bulbs
- civic camber kit
- depo foglights for eg
- Mechanic work, is the est. Good?
- Starter problem
- Interior wiring
- Questions about a B16 or not...
- Antenna. Would this work?
- What size socket do I need for the motor mounts for d-series motor.
- Anyone have DIY gauges into dash install?
- switching non v-tech to v-tech
- d15b valve seal question.
- Del Sol 140MPH speedometer?
- What is this little "nozle"?
- Why most of the H-T guys don't like 17" rims? Planing to buy rims for my 00 civic.
- Where can I get this nipple IACV peice?
- Short ram or CAI
- clutches & axles
- 2001 ex
- How to remove finish off wheels?
- Brake Problems
- Bad gas mileage
- anyone ever REMOVE the tensioner bolt?
- BLOX Intake Manifold or Skunk2 Intake Manifold?
- Civic Lip?
- CEL #43 with Walbro 255?
- Civic 2000 SI cluth Question
- Good tires?
- Help me find my oil leak (PICS)
- Tanabe USA now looking for new contacts
- Openining Heat Vent
- Is this good tread wear and performance rating . . . . .
- Tuning for a supercharger
- Calling electrical guru's
- 18" rims on a civic
- Heater Core Removal
- how hard is it to install a vtec solenoid
- vafc vtec?
- Color Code for Main Bearings d16y7 from a 96 civic????
- oil pressure sensor.. what if i remove it in favor of a gauge...
- sqeaking noise EM1???
- Gotta make a decision on color for my eg.
- NEED HELP???? How much is my 93 dx Hatch worth?
- Newbie-Best project car
- Suspension settings. What do you guys have your tein set to.
- Some cool jdm shit i found.... but what is it?
- Koni Sport Kit, what else?
- 99-00 EK Fog light Question
- FAKE OR REAL please help
- PLEASE diagnose my car
- MadDogRacing head bolts?
- Anyone ever put teg seats in a del sol?
- Civic Type R B16b JDM
- auto manual swap no vtec
- where to get H4H HID bulbs?!!?!?
- EG6 and Del sol firewall?
- Intake resonator removal. Good or bad?
- stainless brake hoses
- mini-me questions
- Horrible question on where to find wire mesh?
- Turbo and tuning
- Transmision
- Just got my SI 2 weeks ago
- vtec cross over
- denji lights?
- Would a 94+ integra exhaust fit on a 95 civic coupe?
- stereo install..
- dave hickman racing
- eg with type r or si spoler
- JGTC Video
- B16 Head Gasket.... wich one?
- itr suspension question...
- Car won't start and main relay clicks
- h22a EG header clearance
- Found a problem... Missing pins in block for exhaust manifold.
- Type R Throttle Body On My D Series installation problem.
- Where did that Y8 intake manifold Swap thread go?
- D16Y8 dizzy doesn't bolt up to Z6..
- Loose Steering on Hatch? HELP
- 99-00 cluster problem
- Brake Noise related, pain in the but
- Strut bar fitment question........
- Cali Emissions Question
- Is there a way to tell if you need to Flush VS replace coolant?
- katzskin leather seats
- *different CLusters in DelsoL*
- good flasher bad blinker
- 99 Civic Trunk Rattle
- 99 Civic Si in EG Hatch.......
- lil help cel
- Where to buy a 99-00 Civic Si valve cover?
- all motor
- ls or si?
- wiring power doors????
- quick manifold install help
- fill driver side mount with polyuraten
- Will eg mudflaps fit an ej1?
- Question about posting and IMing?
- wrecked my ek hatch. need advice
- Are Eg Coup head lights the same as eg hatch?. worryed about fit ment?
- which exhaust muffler looks better?
- new bulbs but headlights don't work, need some help!!!
- just double checking: Y8 intake manifold question
- NEED HELP! Wiring Fog Lights
- Weird driveability issue with hatch
- '89 Civic upgrade chip
- Great exhaust for a 95 civic
- Who makes 99-00 OEM fog lamps? Are mine JDM or USDM?
- eg wiring harness question
- problems after putting on new head gasket
- How hard to convert auto del sol to stick
- radiator advise
- Headlight Harness Plug
- gsr throttle body on a civic
- high idle at cold start...
- anyone have vx diffuser pic and part ##.. cann't find in search...ASAP
- 99-00 Si Cluster Problem
- Problem Removing Cluster
- DC sports 4-2-1 header + 02 sensor info
- Exhuast help
- where can i buy floor harness and lock control box???
- what ecu do i need?
- Eng.Temp guage broke
- tach not working, HELP
- list of upgrades required for supercharger
- 99-00 Civic Fog Lights
- Will a roll bar for a 3 door hatch fit a coupe or sedan?
- Comments/Reviews on SSR full coilovers
- How do you like your DX TRANNY?
- chipped P28 and GSR secondaries.
- jdm vs usdm b16
- sounds like..
- CHIPED P 28 OR P 72????
- **Which cam gears**
- h22 in a civic
- Intake heat shield
- Lost for sure 2000 Civic SI
- what do i need for ek power window swap?
- Intake Manifold: Skunk2 or BLOX
- So do i buy new rotas or used gsr blades for my beater (daily driver hatch)
- can i use a gsr intake manifold on ls motor
- Easiest Model to swap
- Ticket extension??
- anybody need a P28 ECU?
- what coilovers
- wireing
- delSol Dash light help???
