View Full Version : Honda Civic / Del Sol (1992 - 2000)
- NEWLY SWAPPED HEAD, NON RUNNING GSR CIVIC PLEASE HELP
- Rack and Pinion problems still
- should i spend the money for a zex 59300 cam on this set up?
- B18b into 92 Cx Hatchback
- B16 Idles at 100rpm, bogs with gas
- Trade your 4dr for My Bike??
- Honda Civic DX 1995
- bought 97 civic LX with swapped motor need help
- HOW TO ADJUST IDLE SCREW
- best parts store to buy belts
- Swap parts needed
- Ej1(eg)coupe with 2000si seats
- swap questions
- WHO/WHAT MAKES THE TRUNK SPOILER ON THIS?
- IAC (M/T) Valve issue
- EJ1/2 spoiler the same like EJ6/8 ?
- yes its about b18c1 or b18c5!
- auto ecu on my b18b1 manual!!
- tenzo r seat brackets?
- Ebay or OEM SI wing?
- swaping 01 b18c1 into 94 cx...help!
- Interior AC/Fan Noise
- new Project B16a3 or B18 gsr?? what to get?
- Car wont start... i suspect the worst... :( PLEASE HELP!!!!!!!
- How can i tell the difference between an s40 a000 an a b000???
- exhaust for my dx hatch
- cluster swap problem
- 5 speed 96
- OH GOD! BROKEN BOLT! with pics.
- Help with Suspension ideas!
- Del Sol compared to EG or EK civic
- CTR power folding mirrors on an EK sedan
- this nasty noise it makes in 2nd gear
- Del sol roll cage or bar
- transtop,rear fog conversion ,and s2000 cluster conversion
- 94 civic problems after removing abs,and srs systems
- new shit for my ej6
- CEL 3 (MAP) . JDM B16a w/ JDM p30 97 EX
- Speedometer help
- Hello I present myself (Many pics)
- master cylinder, brake booster question
- overflow reservoir
- 5 lug conversion question??
- 98 dx coupe 97 h22a4 swap distributor help!!..?
- how much hp would this give me?
- B18b1 looking for a little power.
- Tranny Swap
- overheating ??
- CAR STALLS.. BAD IDLE
- z6 y7 mini me help.
- question about civic exhaust
- 95 eg problems and ecu location?
- 95 cx hatch shift knob thread question
- How to fix this issue: CEL code 43 Fuel supply
- how much is this worth?
- Brakes Pedal Sinks
- camber kit & alignment ?
- Help w/ o2 sensor!!
- need help asap
- rear view mirror help
- Crazy Overheating problem on a 93 civic
- EK hatch owners.. Wing and bracket question
- 95 ej1...d15 into d16z6
- gsr wont start!!
- Driver Power Window F#*#$ed up
- p06 with a d16z6...?
- Compatible replacement ECUs for 97 EX MT coupe
- 94 GSR front and rears in my 00 coupe??
- D15B7 ???? 92 civic dx
- power windows problem
- buying a CF hood....
- interchangeable parts???
- Need a few things to finish my conversion.
- EG w/B18c1 Stock Inate Manifold: Option for Air Intake!! Help
- 5 speed only shifts with engine off?!
- 94 civic y8 swap vtec troubles
- 98 civic noob engine question
- NEW ENGINE HELP!!!!
- Pistons and rings without pulling the motor?
- Transmission question
- dizzy NOOB QUESTION
- Knock Sensor Delete
- Cowl entry Question how do I stop this???
- no clue?
- B18C Swap, Engine Prep
- cutting out and randomly dying
- ac help
- new to HT, my project
- just got an EJ1
- need helpp quick
- Automatic Tranny Civic lx 2000
- i luv My eg
- ebay quick release HELP
- my car acting up
- Project: First world Civic powered by Subaru
- Help me with Breather Piping connections
- brokin speedo question
- 92 civic dash lights dim and corner lights dim out,
- shift linkage ?'s
- Skunk2 intake fittment issue HELP ADVISE
- No tach signal
- bumper help
- What do i need to convert my 36mm ITR 5 Lug to 32mm?
- v-tec kicks in?
- <><><> Civic Type R cupholder Question <><><>
- let myself introduce... myself...
- Running codes on my civic help pls?
- Troubleshooting Tachometer.. (help)
- EK coupe and sedan windsheilds the same?
- Idle Adjust Screw question (slow idle problem)
- 92 cx hatch, cel wont come on at all HELP
- 99 EK stalled... won't run again... please help me
- code 12 check engine light issue
- Spool Valve help
- 96 to 2000 Honda OEM Factory options
- problem with v-tec
- need suggestions for mods on eg with b16.
- NSX brake conversion on an ek
- vtec solenoid????
- 92 civic won't go into gear after engine change
- Delay after turning key before car starts
- stupid piece of crap d15z1 head
- driver window comes off rail
- Funny thing happened this morning...
- 92 hatchback dx getting no power
- EM1 Owners I need your Help
- k20 injectors
- Ghetto OR Creative Idea
- Does the EK hatch have rear multilink?
- s2000 projectors into EK
- D16Y7 Intake Manifold
- 94 civic rear brake disc conversion?
- need motor mount info
- piston clearance issues
- New to honda-tech
- b16 sol help???
- First rebuild finished, won't start!
- Seat swap / DC2 seats into EK/EJ
- need some help
- Car Dies When Slowing Down
- 1992 Civic DX Front End Vibration
- EK torque mounts question
- CTR rear seats do not fit: Need Advice
- obd2 ls into eg question
- GSR to EJ6 swap help
- dc5r steering wheel into del sol?
- K2 motor headers
- i need chassis engine harness pin outs for my 95 si
- Conversion on a DEL SOL??
- Approximately 30 to 35% MPG loss
- getting rid of the coupe for a hatch
- Replacement bushings for Omni-Power LCAs
- Bent Valves on JDM D15B
- ECU
- Ebay catback exhaust?
- 16x8 +0 offset on 98 prelude..
- Are 92-00 A/C the same?
- itr suspension on 95 Si
- D16Y8 - Is this the correct part for the PCV valve?
- gsr bogging at vtec??
- Magnetic transmission oil drain plugs are worth using.
- New Honda Civic Si Owner!
- Ground Control TOP HATS...
- how much can a roof rack hold???
- fuel pressure
- firewall plug questions?
- *opinions needed* Where to placed vac manifold
- 96 civic hatchback dx front lower control arm. need quick answer
- JDM B18b any info?
- Will 99 00 civic si rear seats fit in the back of my 94 civic dx coupe
- D16 rod cap help!
- CAR DIES WHILE DRIVING,,, mystery help...
- cel code 90???
- How Many Kill Switches Can You Have?
- Starting problems for a 92 Si Hatch
- D16y8 vs d16z6
- cabin harness cluster-f@ck
- 95 civic won't stay running/won't start
- code 14 high idle and stumbling
- are the fuel pump different from a 95 Si w/ d16 and a 99-00 Si w/ b16
- my black eg9..MAY be selling.
- mini me question
- side mouldings
- ->D.I.Y.: HP4 center console in EG/EJ civic
- shock help
- erratic idle speed on D16...
- 2000 Civic Si B16B misses/cuts out
- What coil over or spring/shock combo..
- ek-eg
- which 92-95 civic 4dr model came with leather?
- B16A1 TWIN TURBO?
- 95lx with GSR motor cause Wheel Hop..why?
- gsr swap
- CTR Door Panels
- CTR Door Panels
- negative battery cable?
- Weekend FUN!
- B20 feels like it is missing under steady acceleration.
- Average price for Integra GS-R Blades?
- Fresno ca
- blox IM into gsr eg help!!
- New ride
- 93 EG coupe brake line ???????
- Redlining to Early, Help Please!
- Cyberdyne digital boost gauge setup?
- Overheating Issue B series swapped 93 hatch
- Fitment issue with Innovative Mounts
- OBD2B Motor in OBD2A Car issues
- [b] Motor mount Question I need to find this bracket![/b]
- 2000 ex idle problems
- Direct swaps for 92 LX
- 1996 IAC questions
- Type R Oil Pump with B18B Boost Build?
- Center consol/Armrest Question
- Power outlet in my 98 civic doesnt work...
- Buying parts need help ek coupe
- E3 sparkplugs
- cooling for boost
- my new fuel rail...
- Bouncing Idle stops when A/C is on?
- odb1 alternator to obd2 motor
- 93 knuckle wont fit in a 95?
- Adjusting Automatic transmission civic 1.5 95
- Cel code crank position sensor, Replaced distributor and not fixed
- 1994 Civic DX Japanese import - Dead when key is turned!!
- 97 civic hx coupe b swap
- 15 inch or 16inch?
- question about shift linkage d series
- Snapped bolt on rear subframe 93 sedan
- D16Z6 No Start...Need Input!!!!
- Tips for BAR day
- 92 Vx sputters while driving
- Questions about swapping heads
- Trying to pass smog, HELP
- Bent Chassis Repair?
- 94 civic ex
- b16 engine shake. head prob?
- hesitation under 2000 rpm jerky throttle?
- 95 GSR engine into 97 civic EVAP purge solenoid question
- Honda Civic LX Axle Problem
- Sealing up a hole in the firewall?
- CAM IDENTIFICATION HELP NEEDED!!!
- front frame core support, pull or replace?
- Compression test results
- **98 y7 swap to y8 HELP LOOKED ALL OVER
- My del sol wont start helpppppp!
- Tonight's Findings/Exhaust Cam End Seal Replacement/Ractive Header Fitment Issue...
- Anybody ever replaced the CYP sensor IN the distributor?
- eprom burning problems
- Results from attempted install of Integra GSR brakes on 92-93 Si knuckles.
