View Full Version : Honda Civic / Del Sol (1992 - 2000)
- ITR axle back on EM1
- Ek Battery relocation
- 2 problems for EK coupe.
- **Help** OBD2-A to OBD2-B??
- 95 civic bogging
- Exhaust Leak options
- 98 civic coupe ex power window problem
- Just swap in a GSR into my EJ1???look inside
- 14's too small?
- Mini me swap question
- Shops that will do engine swap for cheap in the San Jose bay area
- 99-00 civic rear lip
- EK vs. EG
- Taillight problem?
- EG Hatch rear speaker grille problems
- carbonfibercoupe/93redls = new hatch
- i just purchased a p28 with hondata s100 chip
- B16a3 dizzy
- gsr map senor wiring to ecu
- what to build EK hatch, coupe, or 4 dr?
- eg o2 sensor question
- clutch issue
- Headlight Connector
- REAR WASHER TRICK for the REAR NEGATIVE CAMBER Questions
- Does anyone have an exhaust picture from a 99-00 Si
- building a d16z6 transmission for turbo and nos
- Headlight Switch - How do I install this?
- 195,xxx on a 98 EK..what should be replaced ??
- seat height ???
- adjust clutch pedal
- d16y7 into EG HELP!!!!
- hids working sometimes??? help!!
- Car won't start after rebuild.
- B16A top speed?
- Struggles to stay on at idle, then dies!!!
- which lip?
- gas tank difference in EG chasis? missfire and lean cut
- Where is SRS crash sensor on a 94 Sol Si?
- swap question
- Short Shifter Questions?
- My 96 EJ8 Project/Show Build Thread
- 1995-2009 Before and After
- best d-series to build for turbo?
- Cheap projects/customizations, under $50?
- Crazy Electrical Problem! Help please
- Caster is out of wack..How do I fix
- Coming to LA county need help finding parts
- misfires?
- RPM guage freezing?? need help
- em1,b16a2. Trouble starting (electrical)
- GREDDY E-Mange (WORTH IT?)
- Code 6 - D15B2 in 92 Civic DX
- car acts like its not getting fuel, stuttering problem.
- VX o2 wiring
- problem with headers and o2
- y8 head problem?
- Hood Fix for my Daily Driver (Eagle Vision)
- vtec wont kick in
- Brakes Problem
- hondata 300 ecu
- Oil pressure
- What do u guys think
- WILL THIS FIT MY CAR???
- will EG exhaust fit EK?
- rpms keep getting lower!
- How Do I delete A Post from Last night about the Civic 4 dr?????
- Dummy lights - codes p1457, p0170, p0171
- Car running rich. and has wrong ecu
- Converting back to obd2 for emissions
- thinking Civic
- anyone have some insight onb this?
- NEED HELP!! crank no start
- dash swap help
- Bad spark plugs or wires
- another car wont start
- car jerks when i brake?
- Idle Problem. CEL code 14
- current build options...
- Dash Help on 98 Civic Ek
- h22 swap in my eg what best ecu to use
- Door Dings........More Door Dings....How to Cover it Up ?????????????????????????????
- Not Very Good With Fixing Things ==========> This Blondie Needs Your Expertise
- Replace the Valve Cover Gasket?
- cel. code 9 on boosted b16
- part #s for firewall plugs?
- need help headlight harness
- can a D16y8 auto manifold work on a D16y7 5 speed block
- Passenger side water leak
- EG A/C wiring?
- 4 disc brake swap questions for EK
- FD2 Type R swap into EG <-- LOOK HERE
- Del Sol GSR swap question
- mini me swap/eg question
- Exhaust fitment question
- 1999 Civic Si POWER STEERING PROBLEM
- anyone live in AZ?
- Having crank retarded?
- Type R Bad oil leak coming from driver side
- 1993 civic ex wont run
- rsx type s muffler flow
- eg6 gauge cluster question
- b18b cam shaft question
- Eg wiring harness question
- 97 civc ex (ej8) with h22 swap speed sensor
- misfire at 6500 and up rpms
- are the mugen active gate brakes the same as s2000 brakes???
- ignition timing reatarding itself?
- 99-00 bumper conversion question.
- b16a2 oil jet . need help!
- b series ring gear
- Real quick question on axel
- HID question
- rear speakercover removal in 99 civic
- 93 civic cx idle problems
- 98 hatch w/ 2000 conversion -- BUT GRILL DOES NOT FIT!! HELP!
- So I got an alignment and here are the results
- 92 hb muffler on 96 coupe HLP?
- 1992 Honda Civic
- Weird Wiring Problem In '94 Del Sol VTEC
- CTR Power folding mirrors
- Paint Opinions?
- will 1997 integra brake master cylinder work for 1993 civic cx?
- B18c1..!!!!
- Wheel fitment! I guess thats what you would call it
- BYS Carbon Kevlar Parts
- battery relocation blowing 80amp fuse
- Difference is GSR spindle from Ex spindle?
- @@Hello@@ I am new to the forums i own an EG from Portland, Oregon
- whp im expecting
- Honda civic swapp broblem!
- 92 EG hesitation and stalling issue
- 95 honda del sol idle problem
- cylinder sensor
- wont hold idle when cold??
- Deleted
- Thought it was the main relay???
- my build
- wat to buy
- wat to buy
- really bad gas mileage on engine swap
- No vin sticker on the door jamb
- spoiler
- del sol lip
- valve lash correction question...
- s2k and del sol
- Valve cover seallant Locktite 567 PST???
- Suspicious 99 si part out
- .:HELP:. S2000 (f20c) engine swap into ej1 (95 civic) chassis
- PLEASE HELP LEAKING COOLANT
- Civic problem
- Loud thumping while reversing
- hey
- LETS see those spray painted civics!
- CKF question.
- Compression good, leakdown necessary?
- 96 ek 4dr window help (electrical)
- accelerator sticking
- 99 DX hatch w/ B20 swap header problem!?!
- ITR armrest pad fitment
- HELP!!! Overheating/stumbling problem!
- Release tension d16z6 alternator belt
- civic stumbles/studders on acceleration
- 5 lug conversion??
- gsr civic no spark
- replace mirror on a 98 ej!!
- No OBD2 Communication with B18C5 Swap
- Wanted: 99-00 Civic "Clear Lense" Passenger Headlight OEM
- Main Relay HUGE crack (pics inside!!!)
- Sway Bar Questions
- STOLEN: 94 Civic (White) Pasadena CC
- brakes loose preasure
- 92-95 Civic Exhaust compatibility
- Need some help!
- idle trouble
- 5w-30 to 10w30?
- Snap On Scan tool
- Best place to???
- APEXi V-AFC2 VTEC CONTROL AIRFLOW CONVERTER
- help code 4 crank angle sensor 98 civic
- whats the diff between these 2 ECUs
- what basic maintenance should i do for better mpg?
- throw code 1 only after engine fully warms up
- I NEED negative camber
- quick front lip question
- Help Identifying Part
- 95 CX 2dr D15B7 P06, pre-wired for Vtec??
- Starter Relay keeps blowing!!! =[
- Can anyone here run a Engine Serial ?
- name brand vs ebay intake manifold?
- 95 eg axel ?
- honda mtf?
- Where to get a good engine swap shop in CALI
- Help..No Spark
- What VTEC solenoids fit what motors?
- single cam dumpin fuel and wont start
- gauge cluster
- Putting the correct miles on the cluster i just bought...
- Does an MSD ignition system add much power?
- Axle Doesnt Stay In Place
- wont start - code 16
- time to convert
- quick ecu ?
- royal purple synchromax is 1 qt enough for my H22A Tranny?
- Highest mileage
- How do I no what headgasket to get on a swap?
- brake lights and blinkers
- cams idling? / blox stg3/crower stg2 sohc vtec
- EDM parts?
- Who has the highest mileage on a Honda?
- swap question
- 92-95 Fog Light Help
- Help! Stuck shifter fork
- quick question helppp!!!
- 99 honda civic trunk
- 94 Civic Main relay bench test
- IACV and idling problem
- Removing black plastic piece on a eg hatchies roof?
- where can i find this part?
- Rear Motor Mount
- 96 Civic DX exhaust manifold
- greddy sus header?
- OBD1 b18b into 99 ex
- How to remove this sensor
- hYPER-FLEX SYSTEM
- Transmission Leak
- Need helping choosing a new break system
- White smoke..... But civic not overheating need help
- im new here! EG6 CORDOBA , ARGENTINA
- rear upper control arms
- sparco 4 point harness into del slo
- new clutch - help me choose between these two...
- 97 civic auto tranny shifts hard at slow speeds
- apexi world sport II
- 93 civic Project Fake R
- ITR muffler fit my eg?
- Help Putting New Rear Mount on a EK Coupe
- Headlight Rubber Cap
- Cel Code 1 and Brown Liquid from exhaust
- Need help Please
- Brake Drum Bolt Size?
- will si exhaust fit my stock ex
- motor mounts
- Will a double din screen head unit fit in del sol?
- tranny problem, only car
- Stainless clutch line and shifter mods - opinions needed
- B16 build help
- obd2 non vtec d15b questions.
