View Full Version : Honda Civic / Del Sol (1992 - 2000)
- outside noise?
- Car is stuttering like crazy at low rpms, just installed blue box.
- Exhaust for a 04 civic
- Big suspension probs
- Resetting 96' Civic EX Factory Alarm
- overheating problem
- sound from back at 1k rpm and 2k rpm
- Replaced timing belt...now car screeches?
- Weird noise when driving
- AEM CAI rubbed a hole right through
- installing 4 point harness without roll cage
- what do you guys think of this ported mani
- a few stupid questions =(
- best way to route intercooler piping in 97CIVICGSR
- 4.4 final drive in ls tranny
- 97 civic coupe gsr, best way to route intercooler piping?
- whats next for my sol?
- B Series Header Question?
- d16 Powerhouse??
- Must be absolutely positive - 92-95 Civic seat rails in 94-01 Integra
- removing dipstick thingy.
- In need of a 2000 civic type r
- ECU Connection
- i need a page out of a 99-00 civic si service manual help!!!!!
- MAP sensor wiring help!!!
- what is your guys input on this motor yay or nay?
- Need information on Swapping a b18c5 into my 96 civic
- HELP!! what an fitting size is this?
- MINIME d16y7 d16y8: how do you get rid of CODE 91: Fuel tank pressure sensor??
- 00 Si, parts compatibility (bumpers, lights, suspension)
- Need more HP output, suggestion please.
- Beaks kit and Progress rear bar
- Civic T-belt noise-tech tip
- Which has better flow spec z6 or y8
- EF Seats Into EG.... How hard
- SPARK PLUGS??
- audio console for an eg
- honda tech help
- Headlights not working, please help!
- Intake manifold question
- No CFK densor on JDM engines?
- Any Kaiten Karui Reviews?
- cyclone fuel saver
- will gsr panels fit and work in a 92-95 civic coupe
- what do you guys spend on axles
- What's a cheap but decent exhaust for a eg hatch?
- 8 lug help
- Custom Rims
- Air Condition Problem? Expert Help Please?
- Video monitor for Guages
- 93 dx not starting, need help asap!
- 98+ b18c1
- What to do first?
- Emissions help!!
- Cold start problem...Help please...
- oil pressure gauge
- what shocks to use?
- painting rims
- Looking for 93-95 Civic HB and or 95-98 Accord!
- i need a swapped civic! bad!
- How many tranny bolts on a b16a2
- Driver door ajar dome light question.
- EG civic won't go into gear (AT tranny)
- How do you remove shift forks?
- Question about Cat Converters
- vss question
- h22a tiptronic shift 6th generation?
- Rocker Arm Assembly
- Hood Release Problem...
- motor questin..
- need help quickly
- HELP!!-I blew my D16Y8 tonight on my way home! ***Need a swap in Dallas, TX***
- Need opinions JDM H22a or USDM/JDM GSR
- Cel 48 LAF - lean air fuel sensor
- Dizzy question
- Two Questions...
- Will 99 Si knuckles fix the camber problem for my Gsr front disc brake conversion?
- got the new tranny (installation and syncro question)
- GSR seats in a 95 coupe?
- AC REMOVAL????
- rapid tapping noise after car shuts off.
- Quick Input Shaft Bearing question
- jdm itr steering wheel on 99ek civic
- Are my secondaries open or closed?
- What color is it?
- BOGGING on first crank?? running rich on high rpm?!?! O2 sensor???
- Code help
- H23 del sol swap?!@?
- GSR connector on LS distributor.... help me out please!! :)
- pulleys question.
- Need help: whining noise from tranny
- Fuel Pump... which to buy...
- ? new exhaust ?
- cd player fixed but no noice
- JDM Power Folding Mirrors
- CA BAR Certified Honda's ONLY!!! PLEASE HELP!!
- 95 Honda Civic surging please help!!!
- PIAA FOG LIGHT
- where to get lugnuts???
- which would be better to get first
- Cleaning ceramic headers
- auto/manual axle question. i searched for 20 minutes
- GSr rear seats?
- H&R Race spring rates?
- hydraulic shocks
- Ceramic header vs. stainless steel headers 4 D16z6???
- Auto to Stick
- thinkin about a motor..which one?
- Gearing
- honda-tech
- fuel upgrades
- INSURANCE TECH help
- Searched not the info I need.... tach dead
- Bad cv boot on my H22 civic???
- E-S oval exhaust......sound clips?
- Need a decision on a clutch
- lookin for b16 head
- alright well just did my brakes and tried searching
- Where to buy Action Clutches?
- obd-0 into an obd-1 car. Whos done it?
- please dont fail me now HondaTech
- 92 hatch POWER SUNROOF installation??????????
- Energy Suspension poly-urethane bushing review on EG
- spun rod bearing - where do i buy more - install ?
- skunk2 intake manifold installed
- rear sway endlink removal--AARRRRGGGGHHHH!!!
- HOW THE HELL DO I HOOK UP THIS GODDAMN A/f guage, automere
- Which tires for my EG
- New Results: Help me get my car driving!
- Wireing for auto -> manual help.
- EG and EK shock... Compatible?
- auto tranny swap
- What is that thing called?
- Am i getting ripped
- z6 oilpan on a y8?
- 7th Generation Civics
- 2000 Civic Si wheels?
- Compression/Leakdown Acceptability
- Suspension Question/Problem
- 98 civic intake
- STEREO BLOCK-OFF PLATE???
- poor hood enlignement
- help look out for a ctr motor (norcal area)
- Which booster and MC with fastbrakes 4-piston kit?
- b18c5 or h22a
- another BAR question
- Orange needles on stock 92-95 ex/si cluster?
- Does a 98 cx/dx/ex have a Crank Flux sensor???
- hooking up vtec .. p08 to d15b
- Engine in a CX ?
- Heater not working
- what kind of intake?
- Dyno Results
- b16 tranny
- Help with recaro's
- civic drop help please...
- after swap....code 22...
- Who's running a GSR muffler on thier EG hatch?
- Switching gauge clusters
- Ground Controls??
- cx 2 ex
- Anyone have a picture of a stock 99/00 Si engine bay?
- ZC pistons in a D16z6, How to
- Anyone have a the APC g2 seats???
- ls/vtec question:gsr head
- obd1 to obd2
- Dropping oil pan on D16Y7 - easy or hard?
- Brake upgrade quick question
- I dyno'ed my D16z6 del Sol saturday......
- torque specs b16sir2
- whats going on? CEL
- Will Hondata and VAFC do the same thing?
- What is Your Timing set at for Best performance D16z6
- Does a 92-95 Civic have a 5-volt Digital RPM signal??
- dash conversion
- strut question
- B18 swap in 93 civic dx???????
- Not all Honda seats are made by recaro right?
- need help with inspection in NOVA!
- PLZ HELP: suggestion on exhaust system
- wierd idle (not erratic)
- clicking coilovers?
- Civic Overheating Problem???
- Brake lines
- DEL SOL FOR CHEAP
- possible engine problem
- 3 wire to 2 wire iacv conversion help needed....
- 92 auto civic, help wiring vtec to p28
- 2 very quick questions (one is for 99-00 civic SI, the other is BAR related)
- HELP! BRAND X
- what intake will work better
- "Maintenance required" checked off with an orange box
- OS Valves w/Skunk2Stage2
- 90-93 Integra shift linkage in 95' Civic w/ b18b.Will it work?
- b20z ej coupe dynoed no vtec
- Just got a new Civic
- o2 sensor wires cut..please help
- Del Sol 5 speed swap question ? d-series
- EK Harness for B-series Q's
- suggestions for power
- D16z6 Power loss... fuel pump??
- searched: Y7 swap into EG chassis
- Slow into gettin' in gear!
- Looking for del Sol changes by year. I searched
- problem with e brake cables for rear disc swap
- HKS SAFR controller
- Transmission Question?
- will ek springs/shocks fit on a eg
- Clutch Problems, I searched! NEED HELP ASAP!
- just bought a 97 civic dx what upgrades can i do to it.....
- The Manual for PC is annoying...what page is the timing belt?
- DAP window sealant for motor mounts?
- Can't decide...need your help!
- looking for pics of heatshields (homemade too) for Short Ram Intake.
- Compression Test Results: ...i'm gonna guess this is bad.
- EG exhaust on EK
- Tach not working with my hybrid setup
- engine squeak!!
- AHH look what i got today
- Tranny question
- neuspeed front strut tower bar
- When is an exhaust too big?
- covertion question...
- GSR front sway bar install
- auto to manual conversion?
- p29 ecu help. I hate how hybrid cars came here!
- JDM type R header 4 -1. is it staing less steel?
- -------Tranny is Whining--------
- how to clean my EG clock? (the clear cover)
- CAR STOLEN PLEASE HELP
- what would be a normal price on this car would you say
- [FAQ] DIY How to polish tarnished rusted headers
- 1999 Civic & Remote Start Problem
- crappy idle, misfiring etc... help...
- lsd?
- Rear Shock Trouble
- b18c: jdm or usdm
- JDM Integra type R front end conversion on a 2000 civic si?
- GSR Sway bar install question
- How do i find out if i still have airbags
- b18c Swap, question.
- CTR rear lip
- Another semi noob question?
- CEL search video
- how much do these cars weigh
- How many watts b4 harness starts to melt???
- DIY head porting: How's mine look?
- DFW GSR theives!!!!!
- Eibach sportline or Neuspeed race?
- J's Racing Fat Body Intake...H22A Civic...Will It Fit
