View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 99 Civic Turbo, HELP PLEASE
- MY NEW EK ...
- wet carpet got pics!!
- Battery Light Is On, Car Cranks But No Start
- help car heating problem
- My Civic Keeps Shutting off while driving
- Skunk2 cams with Supertech question
- CTR Carpet Value
- ej6 questions
- ACT 4 VS 6 PUCK CLUTCH
- EVAP Charcoal canister problem
- cluster help!
- power steering opinions needed...
- Transmission issues
- need help on 94 civic dx
- NA Power w/ Vitaras?
- I Need help on MY EG6 SIR Cluster
- b18a1 into 93 del sol si, what am i missing?
- del sol hid fogs question...
- Clutch Experience
- Simple question about models of 95 civic
- code 43 (fuel supply) issue
- Random retarded TPS code
- Throttle Cable Question (searched)
- oil pressure problem
- What vacuum line is this?
- b16 no go
- Car won't start: oil in the distributor cap....
- EJ8 question
- 97 + Prelude type s axles
- Del Sol bride seat rails?
- How much does this cost to fix?
- cleaning engine
- (ej1) where should i run reverse light wires from center cons to trans?
- hello from the audi scene
- my 00si tailights leaking
- bad vibration and shaking with air conditioning AC on?
- type R suspension (not 5 bolt related) ek
- Put on some Konis
- Auto to Manual Mount problem for eg
- HELP!!!! Need details on taken out Ek Dash Please
- hi guys im looking for honda civic vi-rs clocks/dials???
- Thank You
- Should I buy this EM1
- Car shakes at low RPM 3K
- will the greddy muffler fit? dconto eg
- Fan Question...
- integra window motor on civic
- (EG) REPAIR ADVICE
- Gates Racing Timing Belt?
- JDM d15b idle air control valve problem (eacv)
- Help on Aircon surge
- Rear Bumper Pops Out On Sides Near Wheel-wells? (OEM EJ8 Coupe)
- headlight wiring?
- Any ideas on some electrical problems?
- type r/gsr air box
- valves? where? what kind?
- Help d15b not reving pass 3500 using p28 ecu
- OMG @ headlight harness
- LS/VTEC?
- what clusters will fit in a 95 civic dx
- Various Bolts for 95 Civic Coupe
- Which Rim You Think Is Better?
- What plug is this?
- Gsr In 97 Sedan
- swaping d to b
- em1 motor swap b18c1
- My Mini-Me Swap *PICS*
- Mini Me Swap Part
- Radiator choice
- Mounts
- 93 EG fog light pin out
- is this a good deal?
- JDM-R front onto EG hatch ?
- Need help Identifying part ???????????
- 98 EK sedan trunk leaks
- WTF Ideas PLZZZZ ASAP LIKE NOWWW!!!^&*( Lug Key Broke
- help eg b20 misfire
- Chargespeed kit
- How do I tell if my civic has US or California emissions?
- new here. getting a 95 si. new to honda yrs later
- NEED AN OBD1 vtec solenoid for my b16a del sol!!!!!
- Cluster Needles Die Out When I hit turn signals
- brakes issue
- One is side always lower than the other?
- possible rear main seal leak
- intake manifold studs
- EM1 BOGGING DOWN AND TEMP PROBLEMS. HELP!
- Running cold, strange temp needle
- What ECU should I use? Or what upgrades I need?
- Stock d16 Rod Weight
- Car doesnt want to start, but runs fine
- Need some help
- engine miss/ stutter during VTEC
- 95 Honda Civic Ex trasmission problem
- How much do you think my car is worth$$?
- Single-pass, aluminum half-sized radiator
- *** NEED HELP IDENTIFYING THESE WHEELS ***
- My 2nd EG, Future Plans
- 98 Ex Battery issues,crazy speedo,srs light
- Need help removing civic 92 Windshield?
- D16y8 Dizzy plugs different ?..
- obd2a civic with a jdm obd1 integra motor jerking/bogging problem
- Lambda Sensor Help..
- Oil light and engine knocking when warm
- will 2000 springs fit on my 97?
- whats this sound?? VIDEO
- ej1 and 14" wheels?
- How do you bar 98 gsr in 93 eg hatch?
- OBD2a Del Sol ; OBD1 B16A3
- 96-98 civic Power door lock conversion Question?
- need help.
- 93 civic no start???
- Wat you think????
- car vibrates
- Endtroducing...
- motor bogging/spuddering out...
- No power to radio, clock works, checked all fuses
- b16 del sol vs cobalt
- power steering bracket
- D16y7 to a D16z6. plus auto to manual swap
- last bolts of oil pan...how do you reach them...
- turbo b16 issue
- Wiring v-tec solenoid
- Civic stays in Reverse no matter if in park or drive
- EL front end
- b16 knocking at low rpm... Help!!
- b7 and zc debate
- how much to update my paint
- battery relocation help
- 96 hatchback
- EG to B18b swap AND auto to 5 speed swap. HELP?!
- crasyyyyy smokee!!!! ????
- 97 civic ex horn not working
- Possible ISB problem
- Will a 92-95 civic timing belt bracket work with a b18c gsr swap
- egt temp reading
- Fuel Line from Tank to Filter Help Please!
- Clutch help
- b18a1 swap into 93 del sol...
- R.I.P. my del sol
- Painting the Interior..Flat or Gloss?
- O2 sensor fitment question
- D16 trouble
- Fog light lens fix?
- official update/questions on some stuff
- h-series balance shaft question
- header question
- Why am I still getting bad MPG?
- EDM EK4 - Immobilizer problems
- swaping in cali
- Just painted my eg, What rims go nice with the paint
- CEL Code 1: Replaced O2 sensor, now what?
- b18c-r swap question?
- What post bracket is needed for 98 gsr swap into 96 civic
- How To: OEM Honda S2000 AP2 (2004-2005) Steering Wheel on EK
- B16a2 blows alternator fuse instantly when I turn the key on.
- EJ2 Auto to manual Conversion
- VTEC Wire Harness
- Power Steering On A 95 DX
- b16a build question
- D16 timing
- Transmission Swap
- 93 civic dx fuse "diagram"
- 99 Civic EX, Will a d15b with triple vtec work
- NEW to H-T
- Keyless and Radio do not work on 97 EX
- New to HT
- Bulletproofing my D15B turbo setup
- fuel return line replacement (ej2)
- canadian-spec ek
- What year is my civic?
- hated swap
- 92 CX with b8/z6 mini me
- need help regarding exhaust set up
- H&r vs skunk2 vs eibach springs for del sol
- F20B Swap??? EK
- 92 civic smoking
- DELSOL & EF SHIFT LINKAGE?
- Snap-on valve compressor work on SOHC?
- where is the idle screw??
- EG sedan vs EK sedan need help!!!
- crazy question?
- 95 civic cutting out help!!
- over coming theft
- obd2 d15b
- axle back exhaust for a ej1?
- Need wheel help lpz
- stock lsv?
- ek and eg exhaust
- 99-00 grill fit 96-98
- Sun Visors
- what's the difference between gsr and ls pistons??
- 92-95 coupes/hatches door glass the same?
- 96 Civic LX auto tranny problems?
- civic 95 timing belt help
- GSR sway bar into EG6 ?
- what did you do to your civic today?
- Type R b series hydro tranny leaking fluid pealse help!
- JDM D15B valves compatible with D15B7
- Fan Not Working
- eg delete airbag tray ??
- engine dies from a 150F temp, Help
- Distributor and Firing Order Quuestion Please.
- Choosing a thermostat ?
- Help fuel pump not priming 94 hatch
- Tranny Problems
- Distruibutor compatability question Obd1-obd2
- fuel pump not turning on...
- How to set the timing on my D16z6
- Tach problems, Turbo B20b
- b18b swap into eg bracket questions!
- Intro
- Motor mount
- Help: Uneven drop on a 4dr EK
- VTEC Pressure Switch Broken- What to do?
- quick Timing question
- Knock sensor test
- 1 out of 100 times - car won't start
- Do you think there's hope for this Del Sol? Pics***
- Vafc? Only work on Hondas?
- coupe seats in hatch back?
- S2k in my EK
- '97 HX dies randomly, all stock
- Will headers from a D15 Fit my D16
- B&M precision sport shifter ?'s
- B16 No cold/fast idle, rich mixture code p0172.
- do i need a rack and pinion
- 95 bubble
- 95 bubble tell me what you think
- Ek Hatch B-series Motor Exhaust.
- 92/95 civic hb bumper on 92 civic 4 door
- header and exhaust
- overheating problem
- o2 sensor question
- What rod/main bearings for sohc ZC
- Planning boost D15B
- colormatched headlights
- Do I need to replace my rack?
- "ionized" Headlight issue
- ITR 5 lug conversion
- Error Code 43 '93 Del Sol Si
- Domani Rear end conversion?
- keep getting code 22 on s300
- heather hose sizes?
- Help ??
- can i use p28 on obd2 engine
- New to the site
- What could i do to...?
- Rack & pinion help
