View Full Version : Honda Civic / Del Sol (1992 - 2000)
- E-Brake light question
- apexi vafc2 and skunk2 cam gears worth it on 00 si?
- Drive master cylinder brace on an EK ~~ pic ~~
- b18c
- Fog light with headlight warning buzzer question?
- good jdm site?
- 1999 Civic Si Should I BUY it?!?!?!?
- JDM Headlights
- n1 coilovers.......
- What springs for H22 in my 95 Hatch? (searched)
- headlight question
- need help with itr sways.........
- Re-upholstering Del Sol Seats...?
- callin forall 92-95civic custom exhaust idea
- Catback exhaust on CX (cat on manifold)
- Hydrolics/Air Suspension
- b20a5 in a 95 civic?
- can't decide...
- ***SEIBON LIPS FOR SOLS***
- HELP, SI RIM or RH CYBER
- New to hatches
- New to forum
- intake mani problems! check engine light?! throwing codes! help!
- What does the immobilizer look like on a P72?
- Engine swap! please help
- Axle Problem
- NEED A VIN # RUN,CAN ANYONE HELP ME????
- This is the Read I got from the ECU , what should I do?
- Need Help hybrid SOHC VTEC
- I got a technical question!!! help!!!2002 civic EX
- ***mini me question*** help please
- Swap Help
- scat rods
- del sol coil overs...(good buy?)
- Can someone tell me where to find this bulb (city light bulb related)
- Short Shifters
- Any legal people? I need advice.
- Need help with rebuild
- tire size
- interchangeable exhaust question
- Axles and shift linkage for a b16 swap
- Odometers?
- (EG) Swaybar kits for car without factory swaybars?
- turbo for 97 4dr civic lx
- ecu help
- will it fit..........????
- AE86 help!!!
- Blew a head gasket on d16z6
- 92 SI Steering knuckle and direct fit for a 97 DX coupe?
- B20 question
- 95 Civic D16Z6 with aftermarket lightended pulley
- a good deal on ebay???
- will this tranny work in my friends dx
- Integra cluster in a EK?
- Cam shaft seal leak? Please help!
- newbi
- After Launchin my car its shackin really bad any idea?? AXles???
- chip in Carbon Fiber.
- mini pocket bikes
- WTB: JDM EK4 or EK9 clip
- Can a k20A2 motor fit into a 95civic?
- LS SWAP INTO EK NEED HELP!
- $11000 to make it do everything but fly
- 1993 Honda Civic DX Question
- Pinging Noise
- Swap Info for a 97 B18C Type R into an EK
- firewall wiring question...
- Internals ?uestion
- moldings
- need technical advice OEM injectors
- Hankook vs. Falken vs. Yoks ES100
- EX tranny onto D16Y7 engine
- What grit sandpaper to sand down spoon look mirrors? (ABS plastic)
- OEM replacment injectors CIVIC 2001 EX
- How Are The '96 Civic Hatchbacks?
- b16 swap shiftlinkage
- Foam Filter Oil
- IS a B16a oil pan the Same as a LS oil pan???
- Trouble with "Mini-Me" Swap
- speedo problemo
- D15B7 (92-95 DX) Interference Motor?
- 1994 Honda Civic DX 1.5
- Lookin for a nice front lip
- takin a part an ek headlight
- gsr dashboard conversion in eg wiringg problems help
- smoked clutch in my ek
- How do you check if you have a pM?
- Long Armrest for 92 EG
- eg lip???
- keyless entry not working.
- Caught Streetracing!!! eek!!!
- Tranny problem
- head
- question about alternator
- Door panels
- Rims have a goey adhesive type strip on the edge.
- QUICK QUESTION does your needles light up>?
- My little D series, what should i expect?
- Need advice on a trade
- rear control arm bushing help
- ADVICE ON NEW CLUTCH???
- how do I know if I have a 96 CX or DX EK hatch?
- need help wit my gsr dash conversion wiring...
- Where to get longer bolts for rear camber fix.
- Smaller steering wheel = faster steering response???
- How much money to swap a B16 into a 98excoupe?
- Do civics with airbags have different sized hubs then ones with out(EG civics)?
- as a last resort
- Headlight vertical adjustment won't work
- 1998 honda civic coupe EX v-tec or not?
- B16A enigne mounts?
- 130 mph
- liqui-moly oils
- Airbag sensors on a 99LX???
- my troubles with my rear suspension
- how to replace third brake light bulb on 98 ex? dumb question
- wtb: fuel pump relay for ls swapped hatch
- JDM EG moldings?!?!?! are they the same as USDM
- can anyone get the civic el or domani front end???
- WTB: 92 civic MOONROOF VISOR!!! ANYONE!?!?!
- vafc tuning....help plz!
- a DIYS to install coilovers?
- need help.. vtec doesnt work..
- Car randomly dying?
- type r question... yes yes another one
- 93 Civic horn how to replace with off the shelf one?
- clear gray or shimmer gray pillar pod??????
- **WTF IS WRONG?!?!?**
- something is wrong in my ride
- big problem help
- 98 dx y7 what can i do in the meantime...help
- Help finding decent looking 16's
- I just got a 96 H/B with a B18C1? Need help on certain things......
- ECM codes don't work??!?!
- Got jacked today, I need a new radio console
- Stock Alarm question....96 EX
- s2000 swap?
- 3500 and a stock cx
- Engine light on
- tranny problems
- What Alternator will work on a D16z6
- Can i switch obd1 and obd2 into differ cars??????
- HELP!!! short shifter install + poly bushings= super tight (almost impossible) shifting
- Car not wanting to run right after cleaning engine bay
- help shfting into reverse
- Need some help with cel #29
- State Referee Ticket. need help
- Need some help...
- Auto Door Lock Disable On A 97 Civic EX Coupe??
- ring job no machine shop
- Tranny Swap
- what wiring harness for b16
- Help with Code 48 Lean Air Fuel Sensor
- How do I take off my spoiler?
- h22 in civic?
- INCREDIBLY BAD PROBLEM WITH MY FRANKENSTEIN....CLUELESS...HELP...
- Removing Valve stems
- im new
- Are the 01 ex wheels the same as the 99-00 si wheels
- did japan have a 96-00 civic coupe
- torque specs
- Need help... stupid problem.
- 92 hatch gsr swao overheating???
- '96 del Sol Si brakes onto a '92 CX
- Vinnie in NoVa who used to work at Merchants
- eg civic rear susp. ?
- Which ECU chip would be best for d15b7+d16y8 mini-me
- Help: Air idle wire problem
- Cat like del sol
- LSD or hydro?
- Help !!! is my p30 socketed or chipped???
- Fiberglass??? CF???
- FIRING ORDER?
- bad axles
- universal muffler or straight pipe
- hi i wanted to know if any1 can run a carfax for me real quick
- kamikaze headers?
- best way to install lowering springs?
- Shift Linkage Question *HELP*
- D15b7 Oil Pan Compatible With A D16z6 Block?
- Stripped Spark Plug Hole
- tubular front end
- OBD0 B16a on a OBD1 car?
- jdm or mugen parts?
- GSR swap
- stripped valve cover
- tail light wiring woes... please help guys
- need help with v-tec not working!!!!
- tein question
- tiailights?
- weird overheating problem with 00 si with 00 gsr motor
- need 02 sensor for 00 civic si..
- Fog light help!! ('99+ EK)
- anyone have 99/00 EBP Si with Roto Slipstreams?
- Real ek9 cost..
- ***Del Sol Fog Lights***
- What settings for KYB adjustables?
- 00 Y8 manifold on a 96 y7 head. Not sealing properly?
- ECU wont throw code but car in limp mode?
- got check engine light: 1
- Thinking of getting a RS*R exmag Gt2 need opinons
- 99-00 EX/Si 92-98 EX exhaust differences
- what final drive for b16?
- do prelude seats fit in 95 civics?
- ek water in trunk
- type r conversion
- noise in b18b
- Computer tuning?
- yes! Got a JDM fog switch.
- B Series Flywheel?
- HID protection?
- auto-5speed in a 4dr 95 civic
- a/c question
- JDM EK9 rear lip label question POST QUICK!
- NEED HELP: How to change the stock radio from a 2001 civic(without damaging anything)
- installation of non-factory cd player??????
- clutch replacement..
- 1999 civic si possible starter problem? where is it too?
- bushings
- anyone kno how to do this?
- Winders wont roll up right!!! GRRR
- help anyone...............
- b18 &5 speed weight vs d15 & auto weight diff?
- CF Bumper
- swapped old d16y8 with another d16y8 and have a few probs/questions
- Not trying to rice out my car but...
- Confused with tie bars and sway bars???
- Awesome DIY site
- question about oil seperator
- 06 civic?
- going from chipped p28 to stock p28
- d15b cost swap
- will the dc o2 extension work on an HX's 5 wire o2 sensor?
- bought 99-00 si seats, wanna know if rears will bolt up in a 99 EK (searched)
- What do i need for a transmisson swap??
- Need help fast....coilover question...
- b20/vtec, ls/vtec, or rebuild the b16a into eg?
- ECU Tuning
- 94 LS automatic IN A 97 CIVIC DX PLEASE Help!!!
- civic swap
- dohc and sohc zc tranny?
- ripped cv boots
- What size is axel nut? 31mm? Where to get a socket this size?
- need help with my d16y6 swap HELP!!!!!!!!!!!!!!!!
- HID 'kit' bulb
- Tach seems off
- Rear Disc Question, Yeah Another One of them threads.
- black wheels, what lugs???
- D16z6 and D16y8 timing belts the same?
- 94 Civic Cruise Control Computer
