View Full Version : Honda Civic / Del Sol (1992 - 2000)
- GS coilovers vs Eibach springs??
- Buying a D16 for my hatch
- Tranny Probs
- Clutch and trans. help
- GSRs parking brake cables???
- Can 215/45/16 Azenis clear a 96-00 coupe?
- Jdm Sir2 starter???
- Does Teg Type R Suspension fit EK hatch?
- Just making sure if I have a Auto ECU or a manual ECU??
- first car EG?
- d16y8 auto & manual engine harness the same?
- brake question!!!!! please help!!!!!!!!!!!!!!!
- abs or no in america si ek?
- Where to look for misc. parts for Civic.
- compressor has gone out -- question
- coilover LCA spacer?? question
- Integra into Civic Question
- Which model engine do i have in my civic??
- Any one knows what These are!???!
- GSR DASH QUESTION. PLEASE HELP. NEED ANSWER FAST
- Clutch line help.
- Sigh.. No Speedometer No vtec No Rpm, dim headlight, no stereo... died!
- o2 sensor problem (diagram needed)
- Installin new dizzy, need install tips
- Hood Fitment
- 92 civic B18b Hybrid swap
- turbo or all motor?
- V-AFC II SETTINGS
- what turbo should i use on my B18A1??/
- B series Turbo, Help Hooking up Manual boost controller SEARCHED ALREADY !
- 97 ex misfire, cel, no power
- B16 Swap: What CAI to use?
- 2000 Civic Si needs motor
- Honda engines
- CX exhaust question (searched)
- justice is served to thieves
- shipping cost?
- what comes first, shocks or tires.
- 1992 civic hatch swap info
- omnipower testpipe?
- VTEC Problem
- From what civic can i use a gas tank from????
- 1999-2000 Honda SIR (Canada) Production numbers?
- question on va inspection and lowered cars
- How many Ground wires do I need to replace in the engine bay?
- Will I pass inspection?
- questions about HID again
- Whats a P72, P27, etc...
- Car Stolen in Northern Va
- civic wont start---no spark any ideas
- Where to find a K20?
- HELP :where is the engine advance for the air conditioning found on a d15b vtec?
- how do I make this dash console work in my 98?
- 1995 honda civic
- Replacing HID ????
- exhaust hanging REALLY low?
- 99 civic front end question?
- jdmshit obd1 jumper
- pruledu injector size
- Avatars
- Mazda Mx-3? wtf?
- Didnt dyno yet... Any guesses on horsepower
- Hx Rims
- Can somebody help me with my EG H22A problem???
- Flywheel - HELP - Flywheel poll - HELP
- This is what happens when you let your girlfriend drive...
- Integra dash in Civic Speedometer Help
- radiator size fan?--94-97 delsol dual core
- Quick Bseries Question...
- Is my clutch going?
- Rims Repair
- Fuel Filters and lines?
- What vacume lines is it ok to not connect?
- DIY ek?
- how to get rid of power steering without any probs??
- Looking into a Type-R front lip for my EJ1, does anyone have any for sale?
- How to remove License plate trim on a ek hatch
- Need Help Painting my Lip/rocker panels
- help with o2 signal wire
- 94 Del Sol Headlight Q's
- 99-00 si bracket same as teg bracket?
- Need help with timing zc
- B18B1 into EK coupe
- Anyone got pics of the ARC rear diffuser?
- CAN i get a pic of your d series intake manifold?
- Apexi N1 question??
- 96-98 civic 4dr tail lights
- REAL WEIRD CEL light problem. **b18cR in an EG**
- B16a2 weight???
- civic jack points.
- enough is enough!
- future owner
- split fire spark plugs------good or bad?
- Where to check CEL's in VX hatch.
- steering cuplar.
- valve guides = bad emssion???
- PEDALs and WIRE HARNESS
- throwout bearing question HELP PLEASE!!!!
- hard to shift gears ...HELP!
- Advise
- what is automatic transmission lockup control valve
- ITR Intake Manifold onto a '99 Civic SI
- civic ferio
- Newbish question about my coolant overflow
- SRS Cable reel install?
- my b18c1 is smoking
- Please help: vtec having spasms
- Light short?
- more d16z6 problems
- need an advise really quick plz
- What's a good cam?
- Need a new clutch, any sugestions on a good aftermarket clutch? D16Z6.
- Tighten Up Steering
- Finally dyno'd the del sol (Stock P72 vs. Rechipped Kenji P28)
- d16y7 distributor on d16z6 head?
- Lost in a cloud of smoke...
- 2000 Civic GSR Trans Questions
- Taking off axel nut, WHICH WAY?!?!
- Rim question.
- Radiator specs on '91 civic
- Blown Head Gasket?
- how long to change tranny fluid?
- THE BEAST !!!!!!!!!
- new headlight harness, highbeam works lows dont.
- Hazed head lights
- Integra Radiator in EK With A/C
- Bearing size w/ Scat rods??
- del sol that idel sol front clip
- Help! Engine has intermittant hesitation (for lack of a better term)
- quick help please!
- Looking for EG Civic pieces
- HELP...Car Won't Start! Not Battery, most likely not Starter, etc
- What kind of mods will it take to put EK side skirts on my EJ1?
- Looking for authentic JDM pieces
- 2005 Civic?
- window regulator compativility...
- eg with kyb agx's.....
- Upgrades?
- 98ex into 97 ex or dx, help
- Power steering and AC
- Radiator help!!!!
- Trans fluid....
- HX vs VX Wheels, Which Are Better?
- SRS light staying on
- SKUNK2 OR EIBOCH
- vtec activation for mini me swap?
- 2 questions
- help with jdm doors?
- Mugen style lip question
- Has anyone tried the Golden Eagle LS/Vtec full conversion kit yet?
- Phat SI on eBay?
- converting ecu auto to manual?
- new wheels?
- Heating troubles with my '99 Civic
- intake manifold
- How to get the stock CD player out
- eratic idle problem!
- Korbach Performance Frame Locks $ 50 Reward for a "Shooter"
- Very strange idle problem started...
- Parking question
- where can I get a new avatar?
- for sale rota 16's w/ yokohama
- TEZNO R (mugen) or Real Mugen???? pop quiz
- when a B16/B18 engine is swapped in, how much are the rpms off in the stock tach?
- guys w/ gutted interiors! what kind of stereo system are u running??!
- Tein SS
- Leaking rear strut 97 Civic
- TPS - P0122 - A Circuit Low Input
- Is it possible for the IACV (Idle air control valve) to buzz?
- question about mirrors
- Half shaft, Intermediate shaft help please
- stock brakes.
- I dont like double posts but its a good security measure my friends
- EX/GSR brakes on a EG hatch question
- msd ignition setups
- videos?
- zex 59100 cam?
- bent valve?
- RPM gauge needle calibration?
- Lowered car = wearing out CV boots faster?
- Yeah
- b16a1 or b16a2
- What Shot?
- d16z6 question
- Where to buy OE fitting parts / Pics? (bumper,fender,etc)
- Timing belt on 98 civic
- i need torque specs for b20 block abd b16 head
- is this the rear crossmember???? that is with the lca???? need to know fast!!!
- JDM LS Motor?
- Who makes a TRUE 63mm (2.5") cat-back
- civic conversion question
- Radiator Leak
- skunk2 ls intake manifold on a gsr?
- MemoryFab.com J's style intake installed
- Arm rest question?
- 15's or 17's and the drop issue
- ok... i got my hiflow cat in there is no SECONDARY O2 sensor *what to do**
- FYI: RX7 twin turbo fuel pumps are "almost" direct fit into an EG
- Crooked steering wheel..I want to center it.
- Put in LCA E.S. bushings, just need more info
- B series swap in a 96-00 hatch..what mounts do I need?
- what timing belt on a y7/y8 mini me?
- 13x5 tires size help
- Shock Tower Question
- ctr cams or skunk2 for jdm b16a and should i have valve train done?
- Lost password
- will 88-991 tranny parts fit into a newer d tranny?
- JDM honda motors
- Auto D16Y8 intake manifold onto D16Z6 ?'s
- 92 stock hubs?
- Check out this sweet spoon EG
- Help: Old school Rays Engineering rims data (Again)
- CIVIC Type R questions
- My EK9
- newb question.....what is this in my engine bay?
- radiator support??
- anyone have pics of an ek rsx dash swap?
- dome light , trunk light
- HELP!!! somebody plz do me a favor....
- What is the stock gear ratio in an EJ1?
- cable tranny or Hydraulic tranny
- slicks for EG hatch with H22?
- West LA in the house.
- anyone wtb some 93 ex parts?
- broke timing belt question
- Its almost done...96 ek hatch...:thumbup:
- My second Civic...still new to the game...
- Ground controls w/stock shocks?
- mugen chip for p28 9500rpm!
- questions on swap.
- itr 4 lug conversion an extensive project for my ej1?
- Electrical Problem?
- Old car was 1992 Civic HB Si D16Z6 NEW CAR is 1994 Civic Dx HB with stock motor
- ls motor swap questions on my eg
- MISFIRING PLEASE HELP!!!!
- 17in enkei's on 92 civic 4dr
- b16b 10.6 comp ratio how much nitrous
- ARC Replacement filter
- how do you take out a broken bolt/stud?
- Code 54 on ek
- Is rice really nice?
- ??PO6 vs. P28??
- b18 swap 02 sensor problem!
- does anyone know where to get EG hatch fog light brackets at?
- What Fabrications are necessary for B20 swap in 95 civic coupe?
- anyone has a 92-95 civic si/ex sohc vtec obd1 manual starter?
- help me choose a clutch and flywheel
- jdm d15b vtec ?
- tack wire problem!!!
- B16 Swap
