View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Rear wiper problem: windshield fluid drips,and not sprays
- WINTER: Underheating (low temp reading)
- d16y8 rocker assembly question
- GReddy EVO on a Del Sol (pics?)
- Central Cali meet pics......
- does anyone know the steering gear ratio of a 99-00 civic si....steering rack
- What can be used
- Upgraded shifter bushings
- PICTURES!!
- Quick Head Question
- NEED YOUR OPINIONS!!!
- Bye bye lip... due to snow/ice
- civic dx at 10psi stock motor
- **HELP....Head lights and Dash Lights dont work
- Some pics of the Si after a cleaning...
- Air/fuel gauge????
- where to find SRR products???
- Ahh Leaking coolant car running rough please help diagnose....
- steering ratio??
- car will not start...'94 vx stock...
- I need to know anyone with a really quiet exhaust
- simple yes or no question
- Light Harness For 1993 Civic
- Rear Strut Bolts....won't come out!!! Help please.
- [FAQ] How-To: Take Apart a Transmission
- haynes or helms, which is better?
- Pics of my car
- will this bumper work?
- Found a perfect paint chip restorer for Rota bronze wheels.
- hood lock
- I need a used z6 timing belt
- cold air intake
- Question about hatch i found...
- D16 is bogging!!!
- Can anyone give me the part number?
- Civic dx 2000 HELP!!!!
- help!
- Suspension Techniques rear sway?!?!?!
- 96-00 Civic Hatchbacks with B swaps...what full cat-backs will match up???? Skunk2, Invidia, etc...?
- Twin Loop exhaust
- cheap homemeade intake system? 1998 dx
- Will a 2000 ITR head fit on a B16A2 2000 SIR engine block?
- Heres the deal.
- Newbie Civic Question...
- What size of wheel fits a del sol
- thermostat housing
- Hot damn!
- OT- anyone in Rochester NY area have a MIG welder?
- Just installed my Mugen pedals... *PICS*
- how can i clean greddy air filter?
- Who makes the real "JDM" Amber corners.
- Where to buy new wheels studs?
- anyone confirm 92-95 vx & si have same dizzy distributor...?
- racing hart c2s for si rims plus 400
- cHeck out my Mugen TatOo
- 92 acura 1.8L DOHC B18A motor and tranny for sell......NOT JUNK!...
- A friend wants to sell his hatch, how much do you think its worth...
- compression test results
- b16 throttle body on d series?
- Intake Temp Question
- any1 know any thing bout my exhaust problems
- Hatchback needed!
- EBay coil over Install Q's
- Knock Sensor Question
- Coolant leaking?
- JDM EG6 Foglights on ebay
- what colevers for an h22 eg
- Ls rear disc brakes on 98 Dx
- 00 ex, power window issue
- *Theoemmobile*
- How do i find the right swaybar?
- 00si rear discs on 92cx?(rear disc conversion, e-brake cables)
- Need the ECU information URGENT
- Help: Turbo Manifold
- Can anyone let me borrow a OBD1 LS Dizzy and ECU? only for a little
- kc,mo
- gauge installation
- Civic Intake Question
- QuickHatch Is Dead!! (The Real Post)
- Theft Appeal??? CTR 5 Lug
- Exhaust Question???
- Replacing rotor question
- will this work in my hatch?
- best place to buy apexi n1 universal muffler
- SEARCH is kicking my ass!! HELP.. 1 wire O2 to 4 wire O2
- Exhaust For 92-00 civics
- WTB: B series tranny for GSR
- New winter rims!
- How do i reset a ecu?
- anyone have 96-00 hatch w/HX wheels on them
- Just installed new igniter into dizzy...now the car isnt getting gas?
- crank pulley removal question for 94 civic cx
- CTR exhuast on a EG???
- "misfiring" sound and bogging during acceleration roughly around 1-3.2K RPMs...wut's going on??...PL
- full on the more problems with my auto tranny
- need help with parts and setup
- Possible new motor?
- Wiper problem
- picked up my 2.0
- Looking for the thread that had the fake JDM Recaros? (black w/ red stitch)
- Honda b16 engine diagram
- "misfiring" sound and bogging during acceleration roughly around 1-3.2K RPMs...what's the cause and
- Shifter installation question. ASAP
- mixing up obd2 jdm d15b and y7/8 block
- anyone in here have 92-95 sedan on 99-00 si wheels?
- ek.civic si ebrake cables
- JDM headlights
- HID's in del sol, anyone have them???
- wanted to know price?
- D15 vtec swap HELP!!!!
- motor blows
- More power
- tire rub
- Help...Slight Screech from engine bay
- What stock shifter is longer? 96+ or 92-95?
- Extended upper strut mount
- Anyone know a Micah Johnson? NC or WA
- CAR RADIO DIED: Dont know if this is the right forum
- teg dash into an EJ1....
- ANyone have 99-00 Black Projector headlights they want to sell? Storie inside
- eg hatch interior ?'s
- Can anyone help identify this lip on this eg?
- Resonator-back 2.25" press bent piping= performance???
- HID's in projectors
- ecu harness wiring
- Legacy Speakers (AnyGooD??)
- LS VTEC TURBO VS. B18C1 TURBO
- What do you think of my new exhaust setup? vids
- Loose intake pipe
- Thoughts/Ideas......I need to get rid of some gas.......
- apexi world sport exhaust sound clip request
- Car dies and i just dont know why...
- ecu trouble
- GSR on 99 EK
- ATTN: engine sensor GURU'S. Please help...long story
- roll cage
- Pics of white pearl paint
- Spring Rates Question/New Parts Pics :)
- eg civic with apexi gtr fmic
- cv joint
- Candian Si Motor
- where to get REAL type r lip
- someone help my identify the part..
- Is my ignitor bad?
- rpm speed question?
- Ripped Off My Exhaust!!
- Helpful tricks, tips, ideas etc thread
- So i did a 4 wheel disc conversion, but my pedal still travels down a lot! pic
- Difference between OBD2a and OBD2b?
- can there be a/c on h22a swap in an ek coupe?
- ZC into an eg?
- know where to find a tranny?
- gsr into a civic 93 si hatchback for 3000 in nor cal???
- Instant Gasket?
- ex rotors with dx caliper?
- Anyone have a trunk/cargo net?
- can i get a list of everything i need for a auto to 5 speed swap
- Cams?
- New Year's Eve @ R&D Motorsports :FIRE: (videos inside)
- somebody sell me some vx rods
- Code 21?
- need trans help badly
- 89 Integra Rear Disk on EJ1
- Back Firing problem
- how do i identify/difference between intake manifolds also throttle bodies
- Should this setup increase stopping power?
- Vortch on B16A1
- del sol rim size
- o2 issues
- Should I buy used shocks?
- Nitrous on a Auto D15 ?
- will 92-95 cx header fit 96-98 cx???
- Engine Swap now illegal???
- water problems
- Tires n rims
- Is this right?
- Difference between Ek and ej's?
- HELP! what is "IG2" is this wire diagram????
- JDM Taillights ???
- JDM EK bumpers
- DIY Amber Clock
- Key stuck in door/ignition????
- climate control backlight not workin on 95 coupe...help!
- hyperducktuning.com
- motor mounts for b-series into 2002 civic ex
- 18' Tenzo R shu gunmetal, body kit
- where to buy c&r?
- diameter or sizes pipes d16z6 engine
- is it even possible....?
- Has anybody ever changed there hood latch before?
- Performance gains due to advanced timing???
- Help me find the clutch thread by Rocket PLZ!!! (searched)
- tach problem.....searched this one is weird situation...
- Quick question for you guys with boosted sohc.
- INTAKE FOR LX 96 OR 97 d16y7 engine
- huge gash in fuel tank
- PLAYED OUT?
- AEM Fuel Rail fitting
- FYI: Blacked Out OEM Corners (56k beware)
- leaking oil near distributor
- Ahhh wiring guages (oil pres + oil temp) what the hell do all the wires do?
- difference in bumpers?
- strange metallic noise
- Imput Shaft
- using a d16y7 tranny on a y8 motor does the tranny suck???
- Stupid manual driving questions for a person that just got his first manual .5 years ago...
- My hazards work but my turnsignals dont work??? has anybody had this problem?
- airmass
- Help restoring a Spoon N1 axleback on an EK hatch...
- Can a Stock civic si cd player fit in a 97 Civic Hb?
- Freshly washed and waxed EG
- How to remove EG clock????
- how can i remove stock radio
- 92-95 Civic Hatch Pics
- what should times be around?
- 92 eg for sale
- My Civic was Stolen! Lots of Pictures of the Results.
- Mugen Sway bars?
- 2004 honda civic
- Tein HA vs. Tein SS
- oil preasure and water temp gauge help plz.
- TYC 1-piece headlamps.....
- GSR brake conversion
- short shifter
- Overheating problem
- How to: OBD2A -> OBD2B complete hatch harness conversion
- Need some imput fast..thing i bought something that wont work for my car
- exhaust question
- Keep your car secure!!!!!
- DelSol aux lights, Any upgrades?
- *************EK QUESTIONS************************
- any 1 have HKS hiper exhaust on there HATCH?? wanna see pics
- 99-00 civi SI factory radio question. What would i need to hook it up to an amp?
- Will Exhaust work?
- Prothane or Energy Suspension?
- JDM C's racing short shifter for 2k Civic Si
- Moving to So Cal, SMOG question...
- how do you take out the?
- installing a tach on 99 ex.....need some help
- Looking for Mugen MF10's with the mirror face just wondering where to go?
- 1.6 sohc VTEC suggestions (93 civic ex)
- 94-95 ls gauge cluster into 95 dx
- civic ex
- CF hood question (4dr)
- Poll......just some suggestions......
- Wiring diagrams for 92-95 Civic Instrument Cluster
- AnyOne in HERE have a 96+ Civic with A H22 Motor????
- off topic. going to honolulu will be around wakiki beach area.
- bigger brakes??
