View Full Version : Honda Civic / Del Sol (1992 - 2000)
- will 99-00 climate control fit on 96-98
- Clunking sound/feel (front)
- where can i find rmf headers......already searched
- 1st Gen intake or P30?
- RS Racing Coilovers GOOD? OR BAD?
- help with axle replacement.
- Sounds like a bad bearing....but new bearing sounds the same...
- clutch and flywheel
- Front lip questions
- ek with GSR trouble shoot questions.....
- So Cal, side marker install
- roll bar that works with back seat for eg??
- Blox intake manifold
- headers
- rough idle
- what throttle bodies can i use?
- (Another 1 of Those ) Noise from driver side suspension area threads (Chk Inside) Search performed
- loud rattle from timing belt side....PLEASE READ!!
- quick stupid question to prove a point
- BEST SUNROOF FOR CIVIC?
- i need a DIY for this....
- I have a question!
- Solved the TPS problem(CEL) now idle is weird,and "humming" noise
- Please Help!!
- test pipe just showed up... 3 parts?
- intake not working?
- Bluish smoke coming out of the engine bayy..
- eg radio wiring harness and ek?
- skunk 2 camber kit problem
- Are these lips even the same?
- workshop Manuals online
- ADJUSTABLE SHOCKS????????? HELPPP
- help!!!!
- Linkage?
- 99 coupe - need help stripping interior
- fuse problem
- stock civic exhaust swap? integra?
- another one bites the pavement... or legend (w/e)
- Another EK Radiator support Quick Question?
- Be nice to the noob...and help a girl out...please!
- b and c pillar bar
- What weight tranny fluid for b16
- How much do civic seats weigh?
- Getting a Civic
- short shifter
- Wiring vtec to d16z6 engine
- Low RPM Engine Miss Turns Into a Glowing Exhaust
- Where can I find complete fog setup for 97 Del sol?
- Stubborn Lugnut question....
- starter trouble
- 97 B18B Swap Into 95 Eg help
- eh,ej,eg interior question????
- uncheckable check engine light
- chip ecu
- would a 94 ex stock muffler fit on a eg9?
- Steering wheel not straight
- I will paypal $10 to who ever can answer this swap question.
- switching tranny.....
- 1st Gen B16 In My 98 Ex Coupe
- Civic Coupe camber kits
- DOes anyone have a....
- Please help Red hatch with spun wheels PICS
- water temperature sensor
- Red and White Tails
- code 15 + speedo is moving with rpm??
- is it possible?
- Paint opinions......
- 93 civic ex running strangely (video)
- Urgent...quick shock question
- What is this and is it needed?!
- Will a 98 ITR Brake Master Cylinder bolt right into a 99 Civic Si? (Did a search and found two contr
- ITR in my civic swap.
- Weird vibration?
- help my blinkers always blink!!!
- EK Headlight Bulb Clip
- LS/VTEC Longevity
- EG d15.... why do I blow up so many power steering pumps ????
- please help! sway bar question
- What do you think of this setup?
- Things to do while a motor swap?!
- 92-95 civic si tranny
- Specs on a ZC
- Need some help on a 92cx with LS
- where to put o2 bung?
- 98 civic lx high idle
- V-Tec WAYS TO TELL IF WORKS????? not sure if its working
- When you clean your K&N filters are they still a little black afterward?
- Whats a good price for a P28(stock)?
- what can civicGX pistons do for our jdm D15B
- cluster not working
- E-Brake warning light doesn't come on?
- 92 hatch with 00 ITR swap. Which ac system does it need?
- Intake setup, Wat you guys think ?
- ALL parts that can be used from an integra front end?
- Holley Thundermuff
- Do they still make the tein RE's for EK hatch?
- passanger airbag problem
- 2000 civic Si Wheels
- fuse diagram + lighting problem
- 1997 Civic / 99-00 Bumper
- 2000 Si camber kit
- Civic 96-98, 99-00
- omni power lcas
- Need Help
- tranny question
- searched and searched.... been covered several times.....
- Viper alarm question....690XV and 791XV????
- redline mt90???? whoops??
- gas gauge
- idles wrong
- EK Hatch weight ? And what causes the difference
- EG maplight pictorial
- getto rigged ecu?
- no dash lights!!!
- which d series cranks/rods are interchangable?
- Audio Question
- GSR Cluster Question
- fuses
- Short shifter Install
- cooling problem
- slow ride
- ITR Sway in EK hatch?
- Intalling rear sway bar on EG
- Idle Problem?
- How do u check the tranny fluid level in a 5spd B tranny?
- starting issue
- OEM foglight installation on 92
- Steering Wheel Problems.... help!!
- Need Help ASaP. Oil pressure and temp gauge install....
- Does a ODB1 harness care about
- Mini-me question
- b16a ecu question
- Will a Suspension Techniques rear sway work with ASR brace?
- Helms/Factory Service Manual
- Exhaust Question???
- Gauge problem
- where to cut for front conversion?
- what header
- power steering fluid
- downpipe
- EJ8 EJ9, EM1 EM2? what do these names mean?
- engine and/or transmission noise, '92 EG DX
- Buddy club pro spec exhaust? fitting/performance/quality?
- No Power to Gauge Cluster
- NEED HELP!!!!
- Just installed a DC 4-1 Header, my car went from sounding like a race car to a rice car
- quick shift linkage question
- car wont start need help!!!
- did gsr into 95ex having problems w/ vtec
- how much boost for B16A2 tranny?
- HELP:OBD2a GSR motor into 95 CX hatch (wiring issues)
- d16y8 rods & pistons
- Question about valve lift for B18C1
- Where do I get a Honda Test Harness? : 07LAJ-PT3010A
- idle problams?
- Need help ASAP, parts are not lining up right on OBD! swap
- Suspension question
- HELP...EXAUST QUESTION!!!
- *update* pics of fixing damage caused by some d-bag
- Speed Bleeders? For 92-95 HB
- Gages reading wrong and loss of power
- Center Plastic Console JDM 92-95. Is it only offered in the JDM.
- unknown OBD2 code?
- what is this rattle?!?!
- which wire for rpm output from ecu?
- need help!!!!!
- How much oil is too much?
- car for sale
- check engine light on ls swap
- HELP! Squeaking Noise Coming From Driver's Side From Wheel HELP!
- mini-me reliability
- mounting of fender
- I'm selling my 98 civic w/ gsr swap
- mini-me problems part 2
- Help w/ ITR Intake Mani & Throttle Body
- pic request: white ls meshes on a black EG
- Need help, returning tapped oil pan to n/a
- how to remove trim piece near back window on del sol?
- EJ1 gsr swap....help ASAP
- Power windows stopped working HELP
- exaust question...HELP!!!!
- Dash removal in a 98 civic?
- removing valve breather question...(searched)
- Dumbest Question.... Seat harnesses?
- question for guys with milano red cars.
- HELP! People in Shreport Louisiana
- Rubbing with Azenis
- worth buying?
- need d15 sohc help badly
- Anyone with b20's in Sols?
- headers getting HOT!!!!
- Power window wiring schematic. *searched*
- Simple question!!
- Catback Exhaust Question...
- removal of honda logo on rear of 1995 ex coupe
- Brake Pressure Problem
- NEw to Honda Tech
- rhd conversion ??????????
- WARLBORO PUMP OVERKILL?
- Del Sol Won't Start
- Shaking steering wheel.........Help me out
- Need EG fog light install instructions.
- oil pump question
- Power window switch question.
- dseries fit in the rear hatch?
- h22 civic questions please help.
- Valve cover breather?
- cat differences...
- I know another OVERHEATING ISSUE.
- Cam Timing Troubles
- How Do you install Rod Bearings into a SOHC D16 Block without taking motor
- Performance tuning a 3 Stage VTEC?
- CAR STOLEN!!!!!!!!!!!
- What type of ECU with a turbo d16y7?
- 97 ek FS with 99-00 conversion...
- h22 fuel economy?
- CIVIC ALTERNATOR 97 into 00
- Got pushed into a curb. Need body parts and sympathy. ek coupe.
- Password intake mounting bracket???
- ignition
- OEM 96-00 EK Ashtray/Lighter Console
- EK Power folding mirrors: Need installation instructions/diagrams
- clutch lines leaking help
- whats needed to mount a sparco seat in an EK??
- timing or what?
- D16z6 OBD1 swap in place of D16y7 OBD2
- Full MSD SET UP 4 SALE
- Vibrations From Shifter
- pic request: White 6g sedan w/ 99-00 si rims or volks...
- Shifting gear is not smooth after new clutch kit.
- burning radiator smell.?
- Manual rack into EK
- engine surging under acceleration
- b16 throttle body help needed!!!
- trial mode
- Best way to remove pin strip off my car!!!
- wtf is up with it?
- transmission fluid?!?
- Where to find a ITR engine for swap into EK coupe?
- Installing camshaft
- wtf size are the nuts on arp head bolts help asap!
- b16a into a civic?
- Can u use a D-series O2 in a B?
- brand new 6 puck sliping? help please?
- help!!! need to know what site is the best when it comes to buying a complete swap
- Short ram or cold air?
- Can i use Any VSS(Vehicle Speed Sensor)?
- ECU CHipping p28
- How do u fix ecu code 41? Primary oxygen sensor heater
