View Full Version : Honda Civic / Del Sol (1992 - 2000)
- ENGINE FELL OUT!!
- idk where to post this but
- Driver side Mount bracket
- lightwieght pulley
- Which bushings in the energy suspension HYPER-FLEX SYSTEM Complete Master Bushing Set PN# 16.18103 a
- Please help...have a serious problem with alternator I believe.
- where can i find this
- Anyone heard of this suspension?
- honda noob
- What to do next? Improving handling...
- STOLEN CIVIC HATCH! Bone Stock!! South Bay, Ca
- Which Engergy Suspenion Motor Mount Inserts for JDM RHD SIRII EG6 with B16A?
- motor mount problem!
- CX, DX, VX Honda Civic Hatchback Questions??!???!
- Oil pan gasket removal
- Slightly bouncy idle on occasion, B18B1 swapped hatch
- Alternator or Battery?
- Honda del sol subwoofer box.
- power steering is it true more power
- PAINT CODE?
- transmission weired probs please help me im noob here
- honda del sol radiator problem. please.. need all your help!! I will appreciate.
- Someone help me please! d16y7+440's+hack, way rich!
- Clusters in Ek civics?
- Car wont turn on, has power and checked fuses and relays
- b18 question. oil change
- B20B block with EG6 SIR B16A VTEC head various questions
- took my car into Bumper Doc to get it estimated
- burning smell that i recognized
- Bad smell.....HELP ME....
- Fuel leakage.......
- transmission; how many quarts for your civic?
- Civic DX cat relocate help please.
- Simple turned complicated...
- how much should i lower it
- ITR (B-series) or K swap
- J's Racing Replica Intake, Where can I find one?
- having some problems with my coupe... help please!
- vtec head
- First civic questions
- EG roll bar fit EK
- buy or not to buy
- Throwing a Knock sensor code (CEL #23) Help needed
- new cluster,now engine wont redline at 8k
- 96-97 itr swap 96-dx need info
- no start??
- water valve and a/c issue
- Will she tear it off.
- please help !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!
- doing a vtec swap, some questions id like answered, please help
- cheap quiet exhaust.
- d16y8 d16z6 cam lift difference
- Fuse box picture
- im needing alot of help with my engine swap
- Pictures of EK with Eibach Pro-Kit?
- 1996 civic 5 spd stuck in 3rd gear
- jdm Type R lsd into a hydro b16 tranny what do i need?
- will any other motor fit F20/F22 tranny?
- How do i fill tranny fluid?????
- Starter Issues
- i dont know what to pic
- EG/EK Civics better than 2001+ Civics?
- Rear Wheel Drive Del Sol
- Which tires for 14" rims?
- Wire-tucking picture request
- average price on a d16y8 tranny and labor
- 99-00 fuse box in 96-98?
- Help Please! GSR Swap, Problem With Pedal Assembly Install!
- Ek Right hand drive.
- 94 civic b18c crazy probs
- del sol problem
- UAX listed as the model on my Civic title?
- auto tranny power flush bad??
- 97 EK with LS Vtec
- 1998 Honda Civic Shaved Front Passanger Door, Driver Door, & Trunk Lid for sale
- 1998 Civic EX 4DR, 5sp...clicking coming from the front end...
- Code 14 and 41, Causing bad gas mileage. LOOK HELP!!
- HOW TO FIX MY CLOCK
- EK Gauge cluster help!!!!!
- 98 civic w integra type-r suspention !! PLEASE HELP !!
- drag dr24/rota jspl/work's rsz-r pics
- d16y8 build please help
- WS2 question
- 9,000 rpm.. suggestions on head work??
- Autozone Wheel Studs..?
- Weird electrical problem... please help, car won't start!
- Car Battery
- rebuild or swap?
- stud problems...
- eg to ek ac swap
- EK CHECK ENGINE LIGHT PROBLEM!.....
- Wreck Repair: Paint or Rubberized Coating?
- True Coilovers or Sleeved Coilover?? - Suspension
- unkown Fuel Tank help please
- car throwing code 14
- Do I have lsd or its broken? ahaha
- Goin turbo
- OEM Tach inconsistent.....
- neep help building d16y8
- how do you import a car to canada from the US?
- check engine light, help?
- HELP SPEEDO&TACH NOT LIGHTING UP [fuse?]
- Installing CD player - Honda civic 1998
- best motor for gas?
- i've searched but couldnt find anything
- JDM 1.5 SOHC Vtec
- Engine Swap (Vtec)
- type r transmission
- RSX wheels on EG?
- ls/vtec quick question
- speedo problem in 93 si
- $1,000 to spend on upgrades. What do you suggest?
- help with installin a d15b into 99 civic help plz!!
- WHATS BETTER ??????
- Exhaust
- Can't retrieve CEL, car runs like garbage
- B20B with Gsr Tranny in a ek
- need pics of inside eg...
- no00obie question
- 96 civic dx disc brake conversion HELP!!!
- should i get open or close ended lugnuts??
- ok this is a good one..honda del sol radiator problem?
- help, Shifter into plate
- 2nd gear slip...EK
- oxygen sensor, cat. converter
- Almost Forgot. Drivers Mirror assm. replacement
- New to the site but not to hondas
- 95 civic power window help... thanks
- Boat Paint Paint Job
- Vtec at 3800
- poly rear sway bar bushings make a diff?
- crx coilovers
- Real JDM Type R headlights?
- b18b1
- HELP! want to know if theres any civic 96-00 that came stock with leather interior!
- Has anyone ever changed out ther expansion valve?
- Adjusting the rear brakes- drum
- do i have to pull the axle to replace alternator? 99civic ex
- 92 civic overheating
- z6 vs gsr build up
- Rear Brake Drum Rubbing? Help me out please.
- do i need another flywheel?
- JDM doors EG6
- b16 backfires
- what is the fuse for the foglights?
- 94 eg couple swap (need help)
- GSR wiring question
- 92-95 civic 2dr and 4dr door glass the same?
- pistions set for D15b
- JDM B16A CAMS!!!!!!!!!!!
- Weird brake problem!
- 1998 Honda Civic erratic running at Low rpm with no codes
- Should I get a USDM transmission?
- CONFUSED ???
- Paint Color Code
- gsr brake booster
- GSr popping outta gear... PLease help soon
- NOT HOLDING IDLE AFTER HOT
- Something I didnt know...
- Trouble with my VSS (CEL 17) YAY!!!!! Advice please...
- map sensor probs.(searched)
- cold air intake
- car want start when it rains
- car lost power and now wont start....
- Where did I f#@$k up the timing belt?
- Trailing arm removal (compensator arm bolts) ek
- fuel pump question
- need help? wiring issue?
- turbo timer harness
- question about del sol automatic transmisson need help adjusting throttle cable
- 92 civic looping power steering lines
- Engine keeps dying
- Insuring a highley modified honda civic? Can you get it insured for 15-20k?
- D16y7 headgasket with d15B7
- Question about Axles
- slim fan install help
- carbon roof skin, ek9?
- Trying to get the JDM d15 vtec striaght
- need help with EG
- should i swap or sell
- mounting oem del sol spoiler
- ctr back yard special spoiler risers WTB
- cam help
- Intermediate shaft won't separate
- What endlinks to use with Function 7 LCA 's (Lower control arms) ???
- 99 civic hatchback, Exhaust question? will a WS2 exhaust from a 95 integra fit the civic
- improper idling?/ engine hesitation when started
- eg differences
- Is this actually a converter or test pipe?
- Need Help with Ek9!!
- 99 Si...OBDIIA -or- OBDIIB?????????
- Swapped cams and now the car is running like shit need some help
- 1997 Civic Coupe 1.6i LS Wont Start !!!
- 99 Si door swap on a 96 DX Hatch
- muffler help i dont want ricer sound
- Help - LS Swap Runs Sluggish at High RPM!
- SUSPESION PROB???
- 96-00 Civic Maintenance Question
- clutch pedal issue....totally stumped
- want to see clean swap for mini v-tec
- Looking to...
- Question about Hood Release
- Anything else I need for brake conversion?
- Calling out to DIEHARD (92-95) civic Gurus/supporters - JDM Civic Ferio AWD
- b pipe for 92 civic hatchback
- guage cluster not working in my 94 si eg
- b20 build
- Silicone Hose Fitment EG EK
- ANY IDEA?
- Bumblebee? Muffler swap?
- bad day!!!!!!!!!!!!!!!!!!!!
- Replacing struts/shocks in '92?
- Cruise Control being "knocked-off" in '92
- 200k for 6th gen Civic=HIGH???
- Fuel System Issue Help
- Engine Bay Rusted
- S2K CLUSTER INTO EG HATCH
- Wanted: under Dash Fuse Diagram
- relocating the cat
- D2 coilovers
- Short shifter decision
- Aftermarket stock 99 Civic SiR bumper order in canada?
- Suspension Prob *Pic*
- b16 or lsVTEC
- ECU convertion didn't work at all!! hurry need some help1!!!
- kinda a dumb question but still dont know
- Mud Flaps/Guards?
- sun roof wont open all the way or close all the way
- noob question. how do i take off my door panels? searched but pictures if faq dont show up
- Suspension DIY
- Ek Sedan Mirrors?
- vtec con
- Brembo pads frt, Hawk rear any problems??
- ---importing J-SPEC to the US (what needs to be done!!!----
- proportioning valve
- 94 sol d16y8 antifreeze leak
- Is changing from normal to synthetic oil in a older engine bad?
- 99 Civic- Shut off while driving?? Won't start right back up.
- oil leak
- b20 turbo in my four door
- I need some help???
- Code question
- Ctr ecu?
- just got my Tein's
- EK EK EK!!!! aftermarket horn install
- Missing O2 sensor in my D16Y7 on header
- power to manual window swap......what parts can stay.....95 Civic
- Rough idle!!! HELP
- fuel regulator
- Exterior body help?
