View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 1992 civic hatch backseats for sale
- 91 ls swap into my 93 del sol help!!
- Pic request.....custom throttle cable bracket
- ZC(DOHC) question
- CEL code:::43
- **jsw 1986**import shootout
- Will an intake off of a 91 crx si fit on a 95 ex?
- I can't decide what to do next
- Engine Swap HELP!!!
- remember the v-8 civic?
- 90-93 integra seats in a 92-95 civic
- Mini Me vtec wiring
- no spark, need some help.
- obd 1 conversion
- tanabe sustec sway for EF on an EG??
- D15b7 cam swap help!
- Coolant and Transmission FLUSH
- Replacing B16 syncro?
- Help Pics
- What to do with parted out car? socal
- Disengaging the "eee" sound when headlights are left on?
- DFW FOR SALE: trying to get read of things.
- missed a gear.... compression test results
- trancaxle noice can't figure it out help
- Sputtering while starting engine
- Uploading videos on we-tood-did-racing.com
- p1163(air/fuel ratio sensor) code in my 1998 Hx, please help!!!
- rough acceleration
- Starter problems
- Car pulling right on exceleration..... Bad axel, hub, etc.?
- gsr swap to eg can't pass emission please help!!
- Gsr Throttle Body on B16a???
- Help with Idle problem
- b16a3 will it work?
- d16 swap info
- How do i take apart my defrost button?
- Best Riced Exhaust???
- ...92-95 Hatch Angeleye headlights...
- Does Anybody know how much...
- does anyone have a how to remove ebrake cable off old trailer arm to new trailer arm.
- How to fix a dent?
- A little help here please!?
- short shifters for sale???
- Tail Happy Hatch
- del sol side skirts
- CIVIC CLUSTER PROBLEM
- how hard is it to put on a new throttle cable?
- 02' civic groundcontrols work on a eg????
- d16 swap problem
- oil pressure gauge y8
- what muds to do next
- nitros quest.
- Compression test on a motor out of car.
- HELP!!!! Code 67 61!!!!!!
- pistons and rods?
- car club help
- Cooling system?
- searched.. my idle surges checked anything i could think of.
- need quarter mile times
- Knock Sensor D16y8 high octane fuel
- question about power steering
- which cams?
- NEED TO SAVE SOME GAS
- another good review from import auto salvage
- CEL LIGHTS only when engine is cold... =/
- Problem starting car...
- auto and manual difference effect on alarm?
- Screeching sound when starting the car
- Were to post this?
- 1998 Civic EX Keyless Not Working correctly.
- searched, cant find.. Video
- What is YOUR turbo setup.
- a DIY fuel pump replacement?
- real fast question
- I hit a freaking curb tonite.
- is this ok?
- 1989 4dr question
- deployed to iraq, need help helping shop finish k20 swap
- new to honda's
- CRV knuckles on civics
- EG or other... what would you do?
- Cluster/Taillights blown
- swapping
- Auto to manual TB question....
- j's racing intake vs. password cf intake
- Act clutch trouble...
- spoon ecu..........good next step??????
- weird clunk noise from passeger side when at low speeds and braking???
- got jacked twice this week
- Which locking lug nuts for OEM rims?
- quick ECU question...98 DX
- Purple Headlights Bulbs Legal?
- please help me!!! vtec spasms---searched already
- Electrical problem with turning siganls and light HELP
- EG9 Ferio Trunk Lid
- Powdercoating an N1 MUFFLER? Is it OK to do?
- civic si clutch problems&whistling sound
- oil brand for turbo
- What is the compatibility of an EG rear swaybar on an EK??????
- What should I do......
- Clunk sound from the front
- rpm problem please help
- questions about rotors for stock eh2?
- OEM Fog Light wiring
- will these fit on my car
- civic
- D17 PArts HELP
- All you Newbs and NewComers read this!
- OBD2 b16a2 into a 94 civic cx... HELP
- HOW MUCH SHOULD I SELL MY 1990 HONDA CIVC DX 3DR?
- Dual Bend Short Shifter VS Single Bend Short Shifter
- Flashing CEL?
- best crank and rod combo for high reving crvtec?
- V2 intake bypass valve?
- ? about GSR into EG and the hoses
- New to the dallas, fortworth, plano area where's the racing scene here
- need help- asap
- Type R swap into my EK ... ECU issues
- how hard to replace front subframe on jackstands?
- Trottle body?
- can a d16z6 tranny fit a d15b block
- Civic Si?
- Will this cat bolt onto my b16a2?
- will this fit????? cat-back related....
- Engine swaps vs handling`
- sd area
- clunking noise coming from the rear
- civic integra conversion
- Pics of underbody??
- 00 Civic SI cd/Radio into Eg civic
- civic sideskirts
- headlight question mang
- will a d15b7 header fit a d16z6??
- spark plugs
- J's Racing Tschuniko Chamber Intake
- upgrades needed when doing a camshaft??
- B16 main cap question
- Carfax account up to 26/12
- Question on delsol supension.
- Intake Swap...No fuel
- B16 IM on D-series
- Interior dye
- Is there a better clutch master cylinder upgrade?
- VIN Number?????
- Quick question about cats
- 91HB lowering springs on 94 dx coupe will it work?
- squeeky springs
- front lower tie bar question
- Switching JDM climate control face, with USDM Climate control....Help
- Prime fuel system before starting car or not?
- tidying up engine bay (hiding stuff)
- a cat back exhaust question.
- 2000 d16y7 -> 2000 B16a2 swap, harness swap Q?
- help with rear brake swap
- cf/fiberglass "spoon" duckbill: another annoying weight question
- TechGear
- Clutch Problem!!
- CEL #13, Baromtric Pressure Sensor HELP
- should i install brake shims on new brake pads
- whats wrong?
- steering wheel jerks on start up
- temp sensor sender help
- D16Y8 OBD2B Air Injection > OBD2A
- Swapped d15b problems after 4500 rpms or so..
- i need new belts for my 95 dx
- VIS CF w/ B18C in EG hatch (searched ~ wanted recent actual fixes)
- ideal B16A fuel pressure
- 02 sensor
- D15B, what timing belt to use?
- 3a Racing Seats.
- EG starting problem,charging problem electrical problems
- 98 EK help
- Skunk 2 Short shifter
- Windshield wiper/washer problem?
- weird fuel tank problem
- My 96 Coupe just hit 100K
- How much Honda charge for diagnose engine?
- b20 vtec build... fit a $7k budget?
- B18c + B20 block???
- Where can I find...........?
- LSD
- SiR Bumpers
- K20 into a 98 civic EX Coupe....
- Injectors???
- D16Z6 stock cams
- Wheel opinion!!!! would u trade...
- Help deciding on a Header (2000 Si)
- neverending air in my brake lines!@#!
- Parts needed for b18b LS?
- DIY: Radiator Flush?
- help with parts for B18b swap
- 92 EG almost stolen
- Noise coming from motor driver side
- 2nd Gen ZC Help (Transmission)
- Brake light problem, please helppp
- SI(EM1) Strut Difference?
- dizzy problemo, searched and still had a question!! HELP PLEASE!!
- Any K20 swaps in EGs or EKs pass ref and smog in Cali?
- New paint Job im SO STOKED
- chip my p28 or p72??
- Code 4 still...need help from ol'g's lol
- (ANY ADVICE)My first swap B18B1 into 92 EG hatch
- Need help!!!! my car is slow as hell....
- Right rear suspension squeaks when I hit speed bumps...what could it be?
- need help with cluster
- 93 Civic Si HB MC size
- how to fix engine? please, serious help
- manual steering rack in power steering car NEAD TO KNOW
- whos rockin the 14" steelies?? tire size?
- Need jdm 1peace and got body questions?
- Omni Power Coilovers -- weight
- Does anybody have the ECU Codes for a EK Civic?
- energy suspension master kit, need some retailer links
- 92Si w/ B16A3 just installed idle is stumbling and bouncing 1.2k - 2.9k
- D15 turbo
- JDM CLIMATE CONTROL HELP!!!!!
- FREE ITR HEADER
- GSR > Skunk2 Manifold > 96 Civic > Which Intake?
- b18c5 or b18c1
- 2001 f23 vtec into EG
- Anybody Looking for Parts
- DX to VX
- flywheel question,
- High flow cat converter
- NSX calipers with EK9 5-lug possible?
- wtb: power windows and door locks
- state referee checklist
- d15b vtec swap...alt wire harness doesnt match stock harness
- Airbags
- 95 civic vx
- Brake Problems
- 92 Civic SI brakes compared to 94 GSR brakes
- rattling noise from front passenger area 92-95 civic
- Cold weather causing knocking noise?
- car moving left after spring,struts,wheel, tire, alignment
- wheel lug question need answer ASAP [96 lx]
- Got a d16y5, what computer and what can i do with it
- What type of ECU is in your car?
- need help with window please
- 99-00 SI info
- Transmission Problems
- chipping!!
- alternator symptom check (has this been seen before)
- Apexi world sport exhaust
- 1996 D16y7 into 1992 civic cx
- Cryogenic intake system
- anyone ever dye there seats?
- IT'S DONE!!! 10.3" EP3 Rear Disc Conversion on EK + MC EK Info!!
- Hi-Flow Cat or Headers
- K20 going into a Del Sol?
