View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 98 Civic a/c compressor doesn't engage at high temps
- B16a2 acceleration problem - runs like a dog after it warms up
- B16a2 - how set ignition timing?
- 98 civic ex/b18b1 non-vtec/b16 tranny - which ecu am i supposed to have?
- 1995 civic h22 vtec oil pressure switch question
- 2000 civic si - cluster and climate control lights don't work?
- Motor bogging on a 92 civic cx
- THump, thump, thump. Noise rear drivers side 99 civic.
- Help with brake rotor selection
- 99-00 Civic Si: What are the two hook things called by the third brake light?
- How many o2 sensor in 1996 Civic Ex D16y8
- HELP ASAP! tranny to chasis mount doing 5spd swap
- 2000 civic si cluster problem mileage and trip stuck
- Ej1 Roll Cage
- 2000 civic overheating
- (92 LX) after brief operation, it's hard to start again
- Letting car sit for 6 months
- what is this green plug on the back of this ex cluster?
- New Member / 99 Civic DX coupe - mod plans
- '00 HRV/D16W1 - Idle Fluctuation - IACV & TPS Changed
- Timmy Em1 Build Thread
- Where can I find Del Sol CF doors?
- Lowering Question
- D16y7 auto - d16y7 manual swap
- B16a Engine Issues(injectors, codes)
- 1998 civic dx head swap cel problems
- COOL GAUGES! ------->>> Can I do IT??
- where to put cd player in del sol?
- OBD2 B16 -- can a throttle body sensor make a car run slow
- freeing up coolant/oil passages in headgasket
- Modifying '99 Honda Civic Si
- Cluster swap, a light doesn't seem to be working.
- 94del sol starting problem helppppp meeeee!!!!!
- Ebay OBX Racing Headers Tri Y b18c, too low? (pics)
- car won't start, help needed
- Erratic Idle. Air in cooling system?
- IACV hose leaking, anyone have a diagram?
- 95 Civic EX runs poorly after timing belt and water pump replaced
- P1337 - wiring problem? need help!
- Honda part number question b16 injector riser thingy help
- Civic 98 DX Hatch Temperature Problems
- Rubber boot on shifter?
- D15B/D15B2/7
- Rear Disc Conversion Question
- Custom Gauge cluster - questions ????
- Short throw shifter out of a del sol?
- blowing white smoke? Needs Help ASAP
- I feel like a idiot! 00 Civic EX cuts out
- Half shaft problem! Help!
- 99 civic dx hatch vtec swap
- Identify these seats!
- Please suggest an Exhaust for my Del Sol
- 1990 integra seats fit 2000 civic?
- AC Blower wont shut off
- 92 Si HID Conversion for Fog Light Housings
- Vtec doesnt kick in! Why?
- whats a gud steering wheel for an eg
- HELP! 99 Civic Oil & Batt lights always on.
- Coolant hose location
- D16Y7/D16Y8 IM swap - Coolant hose location
- Radiator Question! [1994 Civic CX Hatch]
- 99 si Na Build ( jdm b16 obd2)
- 96 Civic transmission fluid and timing belt
- 98 Civic LX - New Member/Introduction
- K swap in a 95 eg?
- water got in my motor-_-...whats an ok engine swap?
- Stolen engine/trans - Rebuild or Junk?
- Removing aftermarket deck from 98 civic
- Has anyone done a d15z1 swap into a 96-00 Civic before?
- got window 4 drivers door at junkyard, and it does'n have any mounting holes ???
- Ugh, '92 Civic VX won't start or crank
- Fuse box: cooling fan radiator?
- Couple of questions
- Is it possible? ..
- Trouble Starting Car
- b18c4 no vtec need help
- 2.5" collector to 2.25" piping?
- How much power would turbo add to the D16Z6?
- code 41 oxygen sensor?....still running 5 wire o2 problem?
- B20 block/gsr head - how many quarts of oil do i need?
- Random fuel question
- Car wont start after changing cap and rotor
- d16z6 swap to yz8 manifold
- 02 HB bumper...................?
- Timing Belt
- any idea where my coolant is going?
- obd2 to obd1 conversion no spark
- Will a 96-00 auto transmission fit a 92-95?
- Magnaflow muffler
- 96 del sol fan problems
- 98 DX Pushing coolant to the overflow
- power window door conversion
- 98 civic lx tranny swap NEED HELP!
- 1999 DX exhaust manifold gasket Q's. Re-installing after being welded.
- civic Si oem tweeters in civic sedan
- Reccomend me some brakes
- 97 Civic HX/D16Y8 swap/P28 ECU will not start
- NEED HELP: H2B EG Code 22 (vtec oil pressure switch)
- Gauges in my Cluster won't work. 95 civic.
- Electrical - Dash board Fuse Panel questions
- Another Moroso pan thread... Leaky, bending...help.
- Introduction / 3-stage VTEC questions
- 98-96 99-00 Civic EX d16y8 P2P compatibility question.
- 95 civic smokes... when hittin vtec it sputter
- 00 Civic Si Custom Dash questions ??? "Custom Steering column "
- cant rev over 3000 to 3500 rpm
- 00 civic gauge lights
- OBD2B B16A2 w/P2T ECU swap into EG hatch
- b16a starts on "bad" ecu but not on new P28
- flash tuner
- Help 93 civic jerks at 1300 rpms???
- Need help with wiring!
- My 1995 Honda Del Sol S build
- Whats your biggest pet peeve on a civic?
- Intake for JRSC?
- d16z6...bad head gasket - will jdm d16z head fit?
- 99-00 Civic sunshade won't close or becomes jammed.
- d16y7 - will clutch and flywheel for a d15b2 engine work?
- Please help with value: 98 Civic HX Coupe w damage on drivers side rear quarter panel
- Integra sedan supersonic blue w purple fenders and rear bumper stolen in 707
- 98 Civic EX w/ D16Y7 swap - idle and possible ECU problems
- How to fit EG HB Wing on Del sol
- Part number for Vtec pres. switch?
- Is it possible to install A/C?
- CKf bypass trick safe?
- 95 D16 turbo cracked manifold
- 94 civic starting and engine problem
- 93 d15b - bluish smoke under load in 1st and 2nd gear
- EK4 Shifterlinkage into EG
- k20a or k20a2 engine or B18 type r?
- Project NoName (eg sedan)
- Federal vs Cali spec P05 d15b8 difference
- EH2 harnesses question
- 94 Civic wont start, not getting spark or fuel
- Engine oil still dirty after change
- EG hatch/B16A swap/JDM P30 ECU - TPS & KS codes
- Where to buy seats rails for a 97 civic?
- Del Sol Auto to 5sp help
- 95 Civic EX/B18A1 VTEC swap - How to test reliability of this engine?
- JDM B18C swap engine harness questions
- what is the name of this hose?
- Make my car blow cold?
- Fuel Injector and Fuel rail HELP***
- pwjdm kevlar intakes
- 99-00 oem radio harness diagram
- Car barely wants to start.
- OBD1 Harness question
- apexi ws2 ?
- z6 bottom end
- Sensor doesn't detect trunk closed.
- B20b with serious gas problems
- d16z6t intermittent no throttle response
- 92-95 Civic automatic to manual transmission conversion (parts and helpful notes)
- Can I use mobil 1 to top off my trans fluid?
- Weird A/C issues - 1994 Civic si
- How do i remove a EK glove box?
- 98 civic lx 4dr power windows problem
- IDENTIFY THIS ENGINE
- Spoon twin block calipers on my eg6 -- any clearance issues?
- 92 Civic DX - only 12,000 miles, what problems >>
- SI climate control swap issue
- Water was in ZC1600 torque converter and i flush it for two weeks
- Stock del sol. B16 swap?
- 94 civic engine overheating
- wiring up vtec on a d15z1
- eg gsr swap questions
- 99 Civic A/C Compressor won't engage
- Where can I get hardware for a SI/EX Lip?
- What other stock suspension will fit a 99 civic si
- 93 del sol bad gas mileage after new o2 sensor.
- No start, Fuse blown possibly?
- which map sensor do i use??
- Air intake sensor, what is it?
- Broke the gauge needles off... ugh, not having a good day.
- Roof Racks on a 98 Honda Civic LX
- K20a2 in an Ek... AC hook up question?
- EG with h22 swap - code 22 and low power problems
- just need to clarify something...
- Exhaust install price qoutes?
- First Civic, Suggestions?
- starts and dies witthin half second
- i had an accident, cut a few too many wires uninstalling alarm? now car wont start
- NEED HELP 2000 Civic Bumper support bracket ???
- Car intermittenly stalls//bogs (b16 swapped ej6)
- bad 02 sensor?
- 93 hatch auto - no crank
- b18b1 swap into a 97 dx hatch need help
- b16 transmission problem
- Civic 97 EX, D16Y8 motor, P1362 error code
- exhaust sspring and bolt...99 civic face towards cat, or forward muffler?
- Erasing error code! Help!
- whats a good test pipe??
- Best engine swap tutorial? (b-series into 6th gen civic coupe)
- 92 civic auto ecu fuse keeps blowing help
- Ignition system opinions!! Need help input for you guys.
- Del Sol Sohc Dohc Manual racks the same?
- cruise control doesnt work--93 del sol
- Gray integra type r wheels on red em1 pic request
- 95 Civic EX - A/C blows warm a week after refrigerant recharge
- Rear LCA Inner and Outer Bolts
- wobble from the front at steady speeds
- b18 turbo ACT issues
- YELLR Yellow Box speedometer calibrator installed w/JDM EG cluster
- 15x8 offset 0 vs 15x8 offset 25
- need help!! b18 engine swap into eg coupe no vtec
- 99 Civic SI - Things I should check out before purchasing?
- fix my rattle??
- 95 D16 turbo loud backfire
- act stage 3 clutch
- LS VTEC - Have concerns with tapped and plugged oil hole (pics)
- Can I use these b18b1 parts with b16b2 in EG hatch.
- possible bad block? (see *large* pictures)
- HELP! b16 into my 96 Sedan NO Spark!
- Thinking of giving 97 EX coupe a facelift-need some part related questions answered
- Odd A/C Problem.
- will a hatch catback fit a coupe??? 97 civic
- b series shift linkage
- Code 15 Ignition Output Signal help
- B16A 93 EG Hatch, Vtec cuts in and out.
- Strange stalling problem 2000 Ex?
- Del Sol B16 - Radiator that doesn't hit hood?
- Error Code P-1337
- My HX rims painting help
- 94 hatch - electric help please!!!! fuse 19 problem...HELP!!!! THANKS!
- civic lags, stalls
- how to adjust timing
- Looks like tapping noise is in valve train - advice?
- Getting ready to swap my 1.6 sohc vtec for b16b. 95 civic ex
- Which ECU?
- Is the part of the transmission suppose to be exposed???
- Bought a used Del Sol with full of surprises! Weird Problems i need a big help plz :l
- CRV ELD for Civic? Electronic load detector
- Need Quick help and cyl.1&2 Misfire
- 94 Civic EX - New fuel pump wayyy too loud......
- Del Sol - chassis strengthening mods
- help overheating ek.
- Auto Shift Logic... or problem?
- Basket case ek si with b18c1 swap
- Y8 intake manifold or a z6 intake manifold?
- running a AEM fuel rail??
- Civic spitting, making crazy noises with VIDEO!
- 08 evo turbo on a b18b1 engine?
- 1993 LX sedan won't run
- h22 del sol... vtec wont work
- doin a b18a1 swap into my 99 civic hx need help!
- How many miles before going back for a Smog test?
- '95 EG Cluster + Cruiser Control LED HELP
- is legal to buy a car with right driver side?
- Rear seat conversion.
- idle not consistent and ac is not compressing
