View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Low beams don't work???? Help
- Will a ITR lsd work in a Del Sol VTEC tranny?
- distributor cap!!!?
- K SERIES ?'s ABOUT INSTALL IN EG
- Rota wheels
- red and white lights for a 93 ex
- 4-wheel disc brake conversion? Solo job? How long? [est]
- whats the best motor 4 a 4 door
- Do you think this is worth/reliable??
- Timing on D16Y8
- - --96 EK W/ B16A2 speedo and tacho question-
- 92 Civic Si Hatch, Headlight and WindShield Wiper Problem Need Help
- valve cover
- camshaft problem
- DO I HAVE A GOOD START........ AND what i should do
- "washing" an engine out
- ls/vtec need help!!!!!!!!
- valve dropping
- 99-00 coupe springs fit on an 2000 integra? need a quick response
- something is clicking...
- theres no forum for this car so i put it in this one its technically a civic
- eg door handle
- Conversion Harness Obd II > OBD I
- 95 civic ex Vrs 2nd gen Rx7
- meet in richardson tx
- too much oil??(56k warn some pics)
- I need pics of D16Y8's
- throttle body question
- Help please Obd2 gsr in Obd1 94cx hatchback????
- WTF.. "25th anniversary" seats?. I dont think so..
- my motor is acting up. bad gas milage, jumpy idle.
- Backyard Special Carbon Fiber Spoiler????
- best power @ 6psi
- How to get rid of stained carpets?
- Springs or coilovers
- HELP W/ TRANSMISSION FEELING "FUNNY".. !!
- b series transmission problem
- Trying to loose some road noise...like completely?
- no start, continuous clicking, bat & starter tested good... JDM ZC DOHC
- good or bad turbo kit? and will a STOCK d16 handle it??
- guage cluster
- 1999-2000 Civic SI front end conversion
- emissions (chicago)
- car idles funny
- how much...
- Wheel spec for EG
- Motors
- just showing yall my build up....
- Radiator fluid problem..
- B-D interchange question?
- no spark, new cap/rotor/igniter. bad distributor?
- Innovative b/d mounts for ek?
- car bucking
- escalade headlights on 95 EG
- FS/ Great daily driver 94 acura integra
- V-TECH SOLENOID?
- Engine Selection Help!!!!!
- Did i push my axle seal too far?
- no vtec no cels
- i need a measurement from "EG"ers w/ rear upper strut bars
- Will these wheels fit?
- Can wheels be refurbished and/or resurfaced?
- Quick ?
- Civic Owners
- ------- ES mount inserts a good idea for family car ? ? ? ? ? ?
- What is this gunky stuff?
- DB8 rear seats fit in an eg coupe? (searched)
- Help with Cx to Si Conversion
- Removing EK Passenger Airbag
- no juice to my injectors
- Master, Slave, or Neither
- CEL Codes, Someone help me fix them please
- wiring issues
- Gauge light, side corner lights, tailights delay, What the ????
- In Need Of Pics
- HOOK-UPS Tek
- Starting out a project
- ECU codes - OBD1 - searched
- EK/EG rear upper strut bar compatibility/interchangeability?
- My foglight relay is buzzing? (93 civic hatch)
- change clutch, now something knoking
- Installing Civic Grille
- '95 civic lx vs. ex brake systems
- what jumper harness for the ecu do I need!!!!
- Mystery hose on JDM B18B
- 98 Civic Battery
- additional help on set up....
- Car Starting prob. Relay? help me diagnose..
- anyone have a p28 or a p72 laying around :D
- si spoiler on eg
- Honda Civic 94 EJ1 4 Sale!!!!!!!
- Antenna block off plate?
- go turbo or not
- Smog Legal Bolt-Ons
- GSR ECU = D16z6?
- Stolen in San Diego
- need a helpful decision quick!
- Weird one for ya
- rattling stock muffler please help
- Cluster QUestion for my DX?
- About to buy a 96 coupe.. need to figure out trim.
- Part Number for Ctr Crank Pulley Belt
- which is better
- Oil in D17
- Greddy Turbo Install, D16Y8 - Suggestions/Tips?
- PAINT help!!!
- Power Window Keeps Rolling Up
- help!! fix rust
- Single Cam ZC + Turbo or LS Vtec
- How to..rear main seal!!!!
- Body trim
- a bolt that will fit in the o2 sensor
- Help
- Stock Camshaft color
- HELP NEEDED SOON
- do i need a new transmission?
- h22 no it alls quick question
- Lightened Crank Pulley
- Prewired for AC? 92 DX
- 02 sensor question...codes?
- 92 b16 sir-11 swap
- Pulling D15B7 engine out of 93 DX hatch with AC
- Any idea how much a complete shortblock weighs?
- quick answer please, valve cover gasket
- Crankshaft pulley question
- JDM vs. USDM gsr cams
- D15Z1 QUESTION
- my car runs bad its trowing a tps engine code is that a problem ?
- Help with Wheel and Tire Size for my EG...
- Easy way changing bulbs on climate control
- what kind of tires and rims give me better handling and stability?
- tenzo r springs
- help reco cams and gears and springs and retainers for my d16
- dc 4-1 header from a b16...will it fit a type r?
- Power Steering Removal Quick Question. (CIVIC 96 EX)
- quick question
- tapped oil pan?
- rear hatch ?
- How do i remove this fuel hose?
- Dash Harness Problems!!!
- 4 door?
- Problems with running Rich and poor idle
- pic requested: Tanabe Super Medalion on eg sedan
- custom exhaust question?
- How do i wire up eg sidemarkers to blink with corners?
- How to run Vtec Wires, Where to go through firewall
- Jackson Racing High Boost System, thoughts ???
- vtec not working
- side molding
- Steering wheel hub w/SRS/AIRBAG????
- Painted my valve cover, now give me a cookie! Pics inside!
- gc/koni, itr suspension on 99ex
- how many of you have that emissions and ref crap?
- timing
- 96-98 to 99-00 front
- Newest Problem Help please!!
- need head cam cap bolt torque values
- Timing belt maintenance and Cruise control intermitent
- Just thought i'd share..
- help with DSM injectors
- Engine swap question
- Civic SI Rims or GSR Twisties??
- Painting Valve Cover Question..
- 92-95 civic apexi n1 catback
- dohc d-series
- trying to find one piece cf or fiberglass front clip. anyone know where to go
- Starting / Stalling Problem
- Question About Pm's.
- D16y8 VS. LS non-vtech
- 92 oem fog light install
- h22a1 motor diaghram
- Chicago Import/export engine supplier??...forget the name
- swaping 92 vx hb
- BEST SOHC ENGINE???
- speedo stopped working---- free miles!
- FRONT BUMPER
- Master Cylinder Question
- '92 Civic Hatchback Si Brake Questions
- Need cluster wiring diagram.
- EXTREMELY LOUD SQUEEL!!! TIMING BELT AREA!!!
- cel code 16 ect..
- State Inspection? How do we get around this thing?
- Is there anyway to modify the 93 ex coupe moonroof to open fully instaed of halfway?
- Has anyone used a Greddy EVO 2 exhaust? how does it sound?? lmk
- Another Exhaust Q
- fuel rich?
- Civic Control Arm Bushings
- Help me make a choice
- do i need this bracket?
- Running Lean
- Name for this pic?
- Windshield washer spray...
- sunroof visor on eg's
- -[[ Just swapped Motor... what is this, and where does it go to?? ]]-
- 96 Honda civic ex fuse display
- what spark plugs for high comp and nitrous?
- steering wheel help
- 93 del sol 4 sale
- rev stoping?
- does all the HP from nitrous go to wheels or is there a loss?
- peice under the intake manifold
- corner light harness/clip ?
- SOHC ZC motor gear ratio??
- blinkers dont work but hazards work 99 civic ex what can it be??? fuse are all good!!!
- 99 civic ex motor mounts are all good when i punch it the shifter comes back>?
- hx wheels
- 94 civic catch can...
- Identify a EX/SI trans????
- alty keeps dieing
- need help with swap
- s2000 seats in 95 civic
- good price range?
- tuning recos for d16
- ek9 motor mounts problem
- Just bought Catz Zeta (poor mans HID)
- jdm d15b in 96 civic
- Need help installing seats!!!
- Spun rod bearing, replaced everything, same problem again
- hard fuel line fittings
- Only 2 timing marks on the y7 head?
- Suspension Question
- rear window strut bar?
- does the d15z1 (92-95) civic VX come with a lightened flywheel?
- SRS light...wtf
- Bellingham, WA...Need parts for ej1!!!
- EG disc brakes on EK --- NEED INFO
- LSVEC
- oxygen sensor help
- Help? How do you install JRSC Map Controller?
- tranny problems....
- Turbo timer
- Tein basics
- Wheel Hop
- 97 civic coupe rear disc swap
- 99-00 Civic HID OEM Fog light install?
- oem alarm hood switch part # or pic
- Are all 92-95 Civic 5spd ignition switches the same?
- header for ZC. what other models will fit?
- Is this a b16a2 thermostat housing, or D series?
- Hydro to cable, conversion
- accident in mass... i was run off the road
- ITR injectors...
- how to?
- fast blinkers!!!
- Noobie in need of help "OIL BURNING!!"
- WTF are IABs????
- ek hood latch work on an eg? ?
- Is there anything I can do to pep up my 92 cx civic engine without doing a swap
- Side marker Electrical Help
