View Full Version : Honda Civic / Del Sol (1992 - 2000)
- headlamp problem
- Which 3'' AEM intake on a an ek w/ itr swap?
- Search not working on my computer, keeps saying temp down please help
- gas light no going on?
- Disabling O2 Sensor?
- I am thinking of buying a used manual del sol.. How is it?
- mugen pedals!!!!
- Search function is down yo. Anyone have the specs for sidemarker install on 98 EJ?
- CKF question
- shift light not working
- Question about my B18GSR (92 EG) with a Jackson Racing Supercharger
- bah... search down, mobile 1 synthetic, or regular?
- B18c1 or obd1 b-series spark plug firing order
- What size threads are the O2 sensor bung?
- filling tranny
- 99-00 Civic Foglight Help! Wiring Harness!!!!!!!!!!
- O2 wires melted, is my ecu messed up?
- what to use to cut carbon fiber plates/sheets??
- h22 civic dyno
- odd noise from rear brakes. cant figure it out, help?
- Help with Instrument Cluster Lights
- Question about EK Climate Control Benzel
- Compression test that leaks down???
- EF shocks on an EK?
- wtb 96-98 civic door panels
- b16
- installing oil press gauge (question)
- question on a b20 block
- Dremel experts please chime in!!
- LS-VTEC vs GSR motor
- question
- Has anyone put a ITR IM and TB on a B16a2 OBD1?
- question for people who have Cusco coilovers
- DC custer into EK how to???
- 2001 honda civic mint con headlights
- PLEASE REMEMBER!!
- Lots of oil where it shouldn't be
- VIS CF HOOD
- arp headstuds?s
- d15b vs. d16z6??? heeeeelllp.
- Civic Nation Stickers? -=- Easy Horsepower?
- problems with motor swap
- DEEER! need new fender and stuff
- anyone willing..??
- Cluster Problem!!!!!!!!!!!!!!!
- vtec wiring/ engine smoking
- Apexi version of buddy club spec 1?
- storing motor for winter, any suggestions?
- will a civic exhaust fit on a del sol?
- WHEELSTUD Help...???
- need help car wont start "very werid"
- obd?
- Engine replacement
- Aftermarket Radio killed my Dome light!!! Any one have a solution?
- Maintenence Light Tune Up?
- code 14 wont go away
- how to get rid of rust on my rods?
- how do I become an unrestricted user
- Missing these 2 sensors where to get them from?
- 96-98 jdm window visors
- is there a difference between a 93 civic si from the states and a 93 civic si from canada?
- rev connecting rods?
- lip installation (99 ek)
- D16Z6 head on D16Y5 block - what headgasket to use???
- jdm ecu
- Is there anything can be done to improve engine response?
- Can anyone spare two ECU connector pins?
- Installing CF Spoon lip/ CTR Rear lip : What size Bolt to use?
- 96-98 city lights
- BFgoodrich Vs. Dunlop's help me out please.
- to anyone with installed EK navigation. [56k no]
- Running lights dont work-- its not a fuse either??? WTF is going on
- houston engine swap ?
- Any ideas what this is?? (d16y8)
- 92' Si Hatch $3000?
- help...installed cam seal...now car won't start!
- D-Series Trans interchangeable?
- itr lca..on a ek hb
- walbro 255lph fuel pump after effects
- HVAC Removal
- how to break crank pullie loose?????
- VX or CX?
- Fuel Pump wont start when Hot, bad relay?
- NEED HELP WITH OBDA2 TO OBD1 DIZZY WIRING
- B7-Z6 Mini-me question
- Help with timming belt and water pump. SOHC 1.6 vtec
- 92 hatch roof rain gutter.
- Distributor Plug pinouts-help
- Ticking from head....need some tech help.
- Timing belt replacement interval?
- Aftermarket Throttle Body?
- D16Y8 Price?
- is vtec better in ek(96-00), if so can i swap ek vtec to eg(92-95) vtec
- Oil pan Hybrid?
- ITR Block Vs. LS/vtec.
- Ricey McRicerton
- replaced tps sensor. need new bolts
- Torque Specs
- Need help!!! damn ecu codes!
- 3rd gear popping
- Anyone have a silver hatch stolen lately?
- How to start car with NO key
- ITR spec b16 TB...which tb gasket do i need?
- Hood props
- quick question
- Anyone have a fuse diagram for main fuse box
- 4 door eg owners, I need a passenger side morror
- My window is stuck...again(1997 Civic)!
- anybody ever drive with kind of tranny???
- *** Stupid retard mechanic quotes***
- Exhaust on 92 vx hatch
- 2 wires left after swap
- I replaced
- Im Stumped!!!!
- My DD just died.
- torque specs
- Gear Ring Holder?
- jdm front clip on EG?
- 4DR rear seats into 2DR?
- LCON traction bar review - 92-95 civic hatchback
- I am screwed - cross-threaded axle nut
- Quick ? - EG Brake Conversion - Do I NEED to install the E Brake Cables...
- best sounding exhaust
- quick
- head swap info
- Hydraulic Clutch adjustment...:?
- How to adjust when car is running lean
- Dash Lights Question
- FAQ : How to replace and Test Your Ignition Coil and ICM ( Igntion Control Module )
- B16A SiR-II Gas question ?
- Shifting while accelerating
- SubFrame Swap from Power to Manual - Question on Rear Engine Mount >>
- Throwing Engine Light....
- sk2 proseries throttle body
- help cylinder stops firing!?
- HOW MUCH FOR A 95 COUPE
- 98 GSR Swap in a Ek what is need to keep the AC??
- how to prevent cars from being stolen
- What's The Best Cat-Back Exhaust?
- Timming belt help!!!! asap
- DSM SMIC question
- Uberdata or Hondata s300.... You tell me..... ANY EXPERIENCE WOULD BE GREAT
- ahh i need help
- No spark.... whats going on here?
- quik question about stolen cars
- Best Aftermarket Parts for a 92-95 NA Civic w/ H22 Swap
- my axle keeps popping out of the tranny
- wheres the power
- i want to shoot my car... help.
- Need part number for OEM Open Ended Lug nuts
- b16 0r gsr trans
- Whats going on i mean does anyone have a d16y8 dizzy???
- 95 eg d15b7 timing tips
- d16y5 intake manifold question
- car sometimes idles on low RPMs........
- To rebuild or not to rebuild?
- where is the oxygen sensor #1 located at?
- Help using PR4 IM for swap in EG
- Are my cams shot? --- 2000 Civic Si
- mini me dyno
- question on b16 turbo .... which tranny to use
- excellent video here...
- highflo CAT/o2 sensor question
- Ecu code 67(Catalyst System Efficiency Below Threshold)...Please Help
- gsr cams/ITR intake in a b16
- Tranny issues....98 civic hatch
- b16 tranny problem
- clutch problems
- slipstreams?
- Some quick EG transmission questions
- Trouble with MSD SCI On a JDM B16a!!!
- 00 Civic EX Alarm
- weird check engine light, won't flash codes
- help car wont start
- dyno questions
- My first wreck and after.
- Dual purpose radiator??
- Fuel pumps???
- D15 vtec swap
- 2000 honda civic hb turbo for sale
- Throttle body opinions
- OBD2-OBD1 Idle problems, still after repinning the ecu and changing harness plug
- what are these?
- Potential overheating
- new to the forum
- got question on venom manifold..i really need help on this one!!
- Igniter and Coil Question, Oil in Cap... No Spark
- Think this will work on d15b7 ?
- D15B question
- Which plug wires do you recomend best
- Denso O2 sensors from Sparkplugs.com Reputable?
- New 00 Si Brake MC Broken?? Pics inside.
- Skunk2 Pro series full Coils
- Tien Suspension for almost FREE!!!
- shaved licence hole on ek!
- where to find list of all engines?
- A'Pexi SAFC problems
- cant get fron hubs off ????
- Think is civic is worth being a project car
- New civic
- Fixing shops F*ck up, need help with h22
- Forum Rules
- OBD2 secondary 02 sensor fix
- Apexi N1 Sound Question?
- How to do EL cluster in EK
- clutch engages too early when cold??
- intake question
- srs light need help finding jumper wires
- Wiring for heated seats?
- integra cluster in 92 civic quick help
- SI Spoiler
- will DC exhaust fit in an EK coupe?
- Which ARP headstuds must you use for a d15b7
- Can I get better hen that?
- Help
- sols, gauge cluster and climate control bulbs in COLOR?
- need cam gear sugestions.
- Thread size for brake lines?
- chassis codes?
- strange problem, need help please!
- d15b carb - d16a fuel stuff convertion
- i think my valves are tapping
- 96LS non-vtec into 96EK help
- Rear Quater panel
- HELP: nstalling front mugen style lip/ rear type r lip on 96-98 civic
- Friends car almost stolen in IL
- i ran my car at the 1/8 mile and was wondering if i had good times.
- how to run ignition timing on 94 cx
- Rear disk comparison to powerslot rear disk kit
- 95 Honda Civic EX Auto Tranny Problems, Please Help
- battery corrosion
- will the 99-00 si grill fit on a 96-98 civic
- Oil in my roommate's #2 cylinder... WTF?
- Question about exhaust with swap
- 93 4dr civic dx / b16a2 AT for sale
- trade: My b16 a swap for ITR Five Lug Setup with Wheels?
- skunk2 wheelstuds on ek hatch diy help
- stripped lugs .....maybe
- eg cat back systems direct bolt on for del sols?
- fuel pump to strong for motor?
- u wanna see somethin hilarious?
- OVERALL.....IRIDIUM OR NO???
- lifted hoods??????
- Problem with B18c - n00b needs Help!
- car pulls like a turbo???????????
- b16a2 block with ITR or CTR head
- ****ek civic pwr windows going up slow****
- Before a H22 Swap
- 95 eg lacking power
- Passenger Side Window problems
