View Full Version : Honda Civic / Del Sol (1992 - 2000)
- h22a map Sensor
- Best place to buy Greddy EVO Catback???
- post pics????
- JDM power???
- EG won't run
- I need a SOHC wizard to help!!!
- GSR Plate System. Please help me.
- WHP for stock B18b and JDM B16a1 ???
- Anyone know exact measurements on EK sidemarkers?
- MAP Sensor, funky idle now
- What ECU is used for the D15B 3 stage VTEC?
- please help armrest/center consol question
- New Member
- aftermarket cats...
- HELP!! which ecu pin primes the fuel pump...?? situation inside...
- question
- Timing belt woes after new valvespring install....
- Please help with ECU problem
- camshaft tech
- Purge Cut Solenoid Valve????? what to do with it.....
- Got my Tein's on. :) but i also go more then i needed :( (25 pics)
- Tips for removing side moldings on an EK?
- what is a good asking price for a gsr civic
- 92 Hatch, Best Swap?
- Tranny and axle question
- Any GOOD tuners in NJ/NY that tune street car?
- removing sideskirts?
- help needed
- CAM Questions???
- 96 ex auto to manual, NEED intake manifold and tb?
- help
- Need a little punch...
- matching up parts for ctr suspension?
- integra forntend swap
- Cutting hood reinforcement for weight reduction?
- If u had to pick Apexi N1 or Apexi Dunk
- need turbo
- ingall's install price...
- What axles are needed for h22 into an EJ2?
- Civic VX 02 sensor and B16B engine.
- suspension ?
- help me out if you can...looking for a pic of....
- Engine computer replacement -- difficult?
- non platinum OE replacement spark plugs
- what parts are needed for itr sway bars?
- Temperature gauge on si cluster.....
- idle problem????
- Yokohama or Bridgestone???
- sound clip of an exhuats
- Tyres question...
- Who makes and/or sells rear X braces for 96-00 HB's?
- ecu is throwing code 9, No 1 Cylinder Position ?
- ?'s about rotors
- does gutted cat increase power/performance?
- Hub Centric Rings ? Same for all wheels
- looking for d16z6 dizzy to test with
- Oil leak, where I don't know.
- Ferio
- wow being a good guy paid off
- NJ people can you help....i need someone to look this guy up!!!
- What kind of Side Skirts are these?
- how long will factory shocks last with coils?
- ek shocks on an eg?
- MSD vs. Stock
- More stupid questions from the new guy
- post pics of bliz fronts
- 2000 civic si OEM socks/struts fit EG?
- adjusting skunk2 coilovers
- Help!
- Question about intake manifold
- integra (ls/gs/gsr) rims on 96-98 coupe
- will a b20 head fit onto a b18b block????
- Where to get replacement fog light lens for 2000 civic?
- Honda OEM parts website?
- Whats qt size of radiator?
- are any mounts diffrent on a automatic 95 civic than a manual
- brake problems
- b18c1 hb
- How much should I expect to pay to lower my car?
- Type R Cam in SOHC
- external coil for h22?
- JDM aluminum a/c mount ??
- ACT four puck with stock pressure plate
- ITR muffler on EG?
- 99 Civic Si ( question about grill sorta thing )
- Engine Swap Question
- 92 vx with b18 how much to....
- Fastest Daily Driven Civic / CRX?
- Anyone have pics of a SI(SIR) exahust on a EK??
- Why do people hate B16a's???
- 275$ AEM cold air Intake vs 30$ cold air intake on ebay
- Compression results....is anything wrong with them??
- EK HATCH: Benen Lower Tie Bar Vs Swaybar
- Can a civic ex 95 beat a Integra ls
- t'Does it really matter
- I am slow again. (Hey 56k, yo momma)
- ECU P28 ? wtf
- What exhaust do I use? EX?
- honda resister
- It`s Tuned =)
- what do u think of the plans for my car?
- how much of difference will i notice?
- need help change fuel filter...
- take a look at this!!!!
- What offset do you run on your 16"? +38 or +40?
- Weighed my hatch. Light or not?
- 99-00 Si Climate control - 96-98 climate control conversion
- hi-rev tuners rear disc brake swap
- strut squeaks maybe springs?
- brake pad's ..what to get?
- 14.5:1 Comp Pistons
- What do you guys think of my ride?
- from the SI to the CX
- 99 Civic Hatch seats, Fit In 88 Civic Hatch?
- Bogging real bad??
- 98 Civic Si (Canadian) EX (american i think) got $400 what do i do???
- Illumina Shock Problem!
- best springs for eg?
- bought a 00' hatch yesterday & had accident today :( - lucky tho
- Cover for the rear seat area in civic coupes, like the teg?
- Installing Indiglos
- engine swap
- Small dent in intake pipe hurt performance?
- Question about SRR rear camber kit
- do non-vtec cars, have resonators?
- d16y8 Crower equipped head install complete... pics & questions...
- Crower camshaft question
- how do u get this off???
- Rollcage for my EK civic
- F22B1 Accord Vtec ECU skematics!?!?
- FYI: swapped a DX 96+ cluster for a EX 96+ cluster...
- Hems. What is it and where would I go.
- JRSC Compression
- would a 99 si lip fit an eg ?
- replacing my window....
- Question about intakes
- windsheild wiper problem
- squeaking coming from steering column...help
- What are my spring rates? I am confused...
- general HID knowledge wanted
- civic underdrive pulley
- AEM Hyper 2 Rods?
- question if i ran 40mm offset and 45mm offset on another rim
- modded 99-00 Si stolen in SC
- Wheres the map senson on usdm t/b's???
- Which tyres???
- buying a new car
- aftermarket tie rods
- B16 or B18?
- Falken Azenis for 16's
- MD/VA/DC thieves caught by me and Fuzzy logik!!!
- es oval painted black.. need pics
- Install of gsr cluster into a 95 hatch cx?
- WTB : SOHC vtec head
- should i get this exhuast
- suspension question...please help
- ok ..im installing a catch can in 45 minutes and its my first time id like to know the correct way..
- Going To The Wreckers Tommorow
- Civic Clock
- what's the difference between p2e and p2p ecus?
- Question for all car enthusiasts
- my story of the trip to tampa (lots of pics)
- will they fit???
- Best products for .......
- eg/ek front lower control arms?
- what is better d16z6 tranny or the d16y7 tranny???
- Stock Hood vs Carbon Fiber- Worth it?
- VSS help
- Our Day at the AutoX
- wiring O2 sim
- Oxidation on battery + terminal
- weighed the hatch yesterday
- will a 96-01 aem cai fit a 92-95 civic?
- 96' DX hatch power locks power window's question?
- Any advantages?
- apexi safc? questions please..
- header type?
- well i ran my car at the ne meet at etown!
- B16A first gen head questions.
- Pics of Reverse glow Gauges anybody?
- Engine Build Up
- wiring diagram for Greddy blue box on 92-95 sohc
- 92-95 civic nose on 93 del sol....?
- Pics of the FAL rear window install...
- 1/4 mile times with Del Sol Vti (dohc)
- where to get es oval mufflers/exhausts?
- yay, finally got my car!
- JDM h22. Legal process (smog, DMV, blah blah)
- Well, my motor has gone to heaven....
- my eg...
- please help!
- painted my EG headlights today...
- Question to JDM eg6 enthusiast! true JDM only apply =)
- tryin to post a pic
- How do you post pics?
- axel question. help fast please
- Fender Lining Glue (?)
- 16 or 17 inch rims...
- My planned setup: Comments, suggestions and advice welcome.
- Noob ? - how to remove rear seats in eg hatch.....
- Shifter Question
- cutting fenders?
- sorry, desperate "wtb" post
- electric supercharger kits on ebay
- anyone have a p28 ecu i can borrow sunday?
- how can i get fire to shoot from my muffler?
- I wanted to thank everyone!
- ExmagGT2 + EG hatch = some questions from me...
- Got a little problem-Need your help...
- Suspension Damage?
- Look what my girlfriend did to my car....
- what mounts do i need for a93 ls in a 95 civic automatic
- is 27lbs per wheel and tire heavy?
- Removing Sound Dampener?
- Tire Size
- what bulbs for denji projector lights?
- tuSuspension Civic EK4
- d15b8 power steering
- How to remove a sohc vtec head?
- p13 ecu question ?
- dropping my 2000 civic coupe!
- Phantom Grip Reliability?
- EG guys..Integra dash..Has any done this?
- URGENT - electrical problem - in the middle of a swap
- carbon fiber mid wing
- Welded Diff. / Posi... Does anyone here have it???
- Engine died while driving
- ok, gay question... in need of quick answer on intake manifold bracket.
- Any Bay area shops that do H22 swaps
- Caliper bracket problem.....need help
- WTB. 96+ hatch in the DE,PA,MA,VA,DC area, 5spd With a motor or without!!!!
- H22a Civic EK pics?
- It's not the rotor! What part is this?
- HELP with oem 00 foglights
- Idling
- Brake light comes on when I accelerate.
- a tribute to do it yourself
- 2000 EM1 questions, NEED HELP!
- Detailed directions on odometer rollback or speedo swap
- Will GC coilovers for an integra fit a 96-00 Civic?
- Bad wheel bearing, dangerous to drive?? Accident waiting to happen??
- Cluster problem w/Speedo and Tach
- Ever Hear Of FLIK Wheels???
- VSS, speed senor problem HELP!!!!
- weird ticking noise
- rear disc swap question????????
- Reaffirm my belief on this subject!!
- throttle sensor wire on ecu?
- Need help with clutch line for del sol vtec or 99-00 civic si owners..
- Jdm D15B Usdm D16Z6
