View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Trans Top not working!!!!
- B16 trans mount holes pic: wtf?
- 98 Honda Civic DX Sedan spring question?
- exhaust
- Unknown Idle Issue (?)
- Electrical craziness 98 civic
- electrical problem plz help
- 93 DEL SOL PLEASE HELP
- couple questions about a d15b2/y8 combo
- Just came back from smog!
- Hardrace bushing kit install: 93 Civic Hatch
- Compression test results help!
- Replacing bottom radiator hose
- need help with a/c!!!
- Civic dash bezel, HELP
- 98 Civic LX: P0240 code and smog
- front left caliper problem
- What Motors are Plug and Play With My Car ??
- Removing Engine Wire harness
- B series shifter on d series linkage
- problem with swap! b16a2
- Timing belt + water pump replaced, car will not start
- 92 eg d15 HELP!!!
- 93 EG B20b! Help please!
- D15 vetec e egr?
- b18b1 cps swap into ek helpp
- Removing intake manifold question
- foglight problem...
- Help!! Mini me swap problems!!!
- ej8 vs srt4
- ls swap on ej8
- 96 EX Coupe Bad Gas Milage Mpg
- Del Sol Si rear speakers screws
- Civic mb6 (ukdm b18c4) steering rack swaps?
- 1995 del sol d16z6 starting problems. HELP!!!!
- steering boots
- *NEW TO HONDAS* how do i make my d15y7 faster?!
- Need help understanding this: (Electrical Problem)
- b16 throttle cable and bracket question
- Another p0505 thread, 99 HX M/T
- What cars come with B series?
- D16 wont run. Help?
- grounding my wires
- 94 civic dx erratic idle and hesitation
- Key keep sticking in ignition.
- Honda civic 1999 hatchback dx
- Water leak in trunk
- Dash lights, radio, heater not working. Ground issue??
- Radiator questions
- HELP!!! ENGINE SWAP HONDA CIVIC EX
- Really low idle
- D16 swap?
- accidently bought dx tune up kit for my ex
- 15x8 0 offeset help on ek
- HX trany in a EX
- Guys, I think I just blew my motor... Video inside
- should i do this trade
- identify itr cams help
- New member
- Cruise Control Mystery (solved)
- New!!! Need help with a few things!
- 1999 Honda Civic Hatchback engine temp gauge
- H4H and R702K bullbs
- 2000 EX Civic Caliper Interchangeable ?
- My little white hatch build part II
- New to Honda scene
- Need direction with my del sol
- CEL 12, 21, + 41 on 92 hatch
- 1999 CIVIC SI CLUSTER PROBLEM!!! NEED HELP
- Civic 1.4 Wont Start, Immob Issue?
- Help with wiring fuel tank pressure sensor 96 civic.
- rattle under engine
- Mystery engine rebuild- what to include in rebuild?
- 96-98 sedan interior door panels interchangeable with 99-00 coupe?
- 2000 civic lowering suggestions
- motor doesnt idle when cold, dies out! &abs & gas mileage &mirror Question
- d16z6 my build in process
- Dents in valve cover.
- Raspy v-tec ! Help Please
- Dysfunctional Radiator Fan
- Wheel Info (13in GSR Blade look-a-like) ????
- My new '93 Del Sol Si d16z6
- 95 coupe door confusion!!
- Help on my b16a2 civic si
- bad wheel hub?
- 93 civic problems (wiring)
- 93 misfiring help
- ball joints
- need help with doors. 99 civic coupe
- Confusing D16 missing/skipping?
- spark plugs wet with fuel
- My 94 Ej1 Build
- 97 civic door lock problem
- Driveshaft problem
- How much torque for valves?
- d16 hydro to b18 hydro?
- anybody have experience with truhart coilsovers?
- New harness help! Misfire/check engine light
- 99 Honda Civic EX Engine questions
- DIY- Radiator Repair
- fluctuating idle
- Two newbie questions for a Civic 97. [Thermostat & Fan]
- my 95 coupe
- axles !
- Power door lock / keyless entry problem
- tires and torque question.
- Caliper brake fluid leak and brake pad brand question!
- 96 Honda Civic. HELP!
- Tie rods and power steering pump.
- **Build Thread-EG Civic Hatchback**
- '95 Civic DX Sedan, someone put a different alternator pivot mounting bolt on...
- '95 Civic DX Sedan, Does Honda still replace bad seat belt retractors?
- Having an issue with my heat
- Motor Mount help
- EK Hatch Thread
- What the hell happened to my car?
- Upstream oxygen sensor 2000 Civic HX
- Steering won't center
- idle problems?
- whiskey bottle overflow
- grounding kit
- Shift linkage problem
- ITR calipers on dx hatch
- blown motor:(
- obd2 vss vs. obd1?
- Bosal Exhaust OEM?
- Bad axle/bushings & mounts
- Eg hatch Si electrical problems??
- What does Antenna screw too? lol
- pilot bearing or something else?
- '97 DX lowering help?
- missfire
- What would you do? (Advice needed)
- bulb is good but no check engine light
- D16Z6 Installation problems
- Radio Wiring Help
- Front lca ES bushing question.
- How hard is it to swap/fix a blown B18c5 in a 94 hatch?
- Help with 93 dx hatch rear disc conversion
- Cracked manifold...replace with header?
- Fuel System Cleaner?
- Driver side motor mount (Civic)
- help identify source of oil leak near oil pump - D16Y8
- What is needed for car to pass Cali smog with Headers
- What intake for 99 si? b16a2
- 97 Civic Dumped Daily Build
- 97 dx sedan passenger window not going up
- 97 civic lx keyless entry
- Problem with 1994 Del Sol S, AT, d16, stalling
- Hello all, first car here.
- type r
- 94 civic. I have an extra $200. what should i buy?
- hytech replica header on eg hatch what test pipe/cat?
- Coupe 95 Main Relay / Bad earth issues ?
- 97 Civic ex only starts sometimes??
- 97 civic dx coupe roof moldings
- Mini-me - b7 block/z6 head and dizzy/y8 pulley - wont stay on?
- 98 civic hatch/jdm GSR b18c swap/OBD2a P72 ECU - Help with Evap Purge!
- Need Help! my car dies when i hit the gas pedal
- spedometer is dead, help please?
- D16y7 Fuel injector impedance
- 98 Civic (b20z2 swap/p72 ecu) runs like a 2 cycle engine - need help and ideas!
- 99 Auto Transmission Problem
- 94 SI Hatchy Sunroof problem..
- D16Y8 MODS
- B18c1 keeps shutting off in neutral while driving
- cab drone too annoying
- Odd idling hesitation problem
- Manual Swap from friend's crashed Acura.
- GSR transmission grinding noise
- Dome Ligth Issues
- Does 10:1 C/R require 91 octane?
- d15 bogging at 3500 what do i do??
- stuck rotor screw
- Moog Rear Trailing Arm Bushings
- SOHC build advice
- antenna
- Need help locating an exhaust leak
- Strut replacement 2000 civic -- spring compressors required ????
- 94 civic coupe with 17" rims/17x7 +40 offset - what tire size that won't rub?
- my eg is running like shit
- Need help?? Flood water..
- yet another car stalling thread
- How do I wire a rz-0159 main relay?
- Cluster lights stay on with key out of the ignition
- Starter Solenoid
- Cruise Control Issues: 96 Civic
- Benen strut bar and extended tophats ?
- Where can I buy a door lock control unit?
- 93 del sol to eg conversion
- rear lower strut fitment
- New pick need some tips 95 civic ex PLEASE HELP!!!
- Civic stuck in garage (Parking Break)
- Ebp spray paint???????
- D16z6 metal on metal noise
- can someone identifiey what headers these are
- 96 del sol si halfshaft or somthing exploded
- Help! idling confusion?
- Stock D16y7 Help.
- header on a civic
- What are your thoughts on this bad alignment technique?
- cant find obd1 plug not where its suppose to be under pass dash
- Squeaking noise when A/C turned on - compressor bad???
- brake lights and buzzer for headlights not working
- header on 95 lx
- New to the site!
- Transmission noise/ Valves ticking.
- Replacing exhaust
- How do I swap a gauge cluster with a tach into my eg?
- Emissions...98 Civic Sedan.
- Windhsield Replacement What's included?
- obd2b gsr swap/obd2b p72 ecu into obd2a 96 civic - Wire harness help!!
- Wrong Flywheel or wrong Cluth kit?
- adjustable cam gear procedure questions for mini me swap
- rear sway bar question!!
- ECU Question
- Brake woes
- Electrical plugs Need help
- SRS/CC problem, horn fine
- 92 Eg Si Hatch Sunroof won't open/close correctly
- Maintenance on a Del Sol?
- JDM D16A What ecu to use?
- 92 vx codes 1, 9, 41 running pig rich, etc.
- CA: Another bar related question 00GSR swap in 96-98 EK
- climate control problems, 98 Civic.
- B16a2 wont start...please help!!
- '93 Civic alternator problems
- B18C EJ8 Clutch shudders when cold.
- EG Si make over
- Targa top.. stuck?
- Should I replace these sparkplugs?
- aux power not turning off with key out
- Secondary O2 sensor?
- del sol fast road cams?
- 1998 Civic speedo stopped and car pulling
- ek b18b swap torque mount question
- ICM replacement
- Water pump confusion
- Honda civic D16y7 swap to what?
- del sol in need of rear frame work :(
- b16 d16z6
- 00 Em1 requires starting fluid to start but runs fine after.
- Changed trans now axle pops out? Eg
- what cluster is this?
- Strange tail light issue and question.
- part number
- My EG Hatch
