View Full Version : Honda Civic / Del Sol (1992 - 2000)
- How to check my ECU? Eg with swap
- Grinding trans = bad motor mounts?
- auto wiring harness on manual engine
- Replacing headgasket, why is one piston extra clean?
- Leaking oil like crazy
- 97 civic LX automatic throwing 2 COdes
- 95 eg starting problems
- Taking off pulley where timing belt and alternator belt are?
- Honda Delsol throwing evap code P0441
- More info about JDM D15B Vtec
- 94 del sol vtec ac control
- Ek squeaking from passenger side front
- b16a3 rod bearing
- SM-302-25 del sol starter work in 92 to 95 civic?
- rear lca, suspension lower bolt
- b18c1 into my eg help..
- how to pass inspection obd2 car with obd1 stepdown harness in b16
- b16a2 into a 1998 civic ex
- Energy suspension mounts inserts
- ***Looking for part name or number***
- 99 EM1 - unplugged sensor & vacuum hose, popping when hit bump, replacing brake pads
- Hx civic question
- WIRE TUCK .. TWO BIG PLUGS.. do we need?? HELP!
- ek power option
- axle legnth problem...
- Will an EK hood fit in the back of an EK hatch?
- Few issues after b16 swap... del sol
- Del Sol Amp placement
- D16 94 Del Sol SI wont crank
- Rear Strut Bushings
- b16b b18c oil pan
- '93 civic 1.5 - air leak + loss of power
- How to change timing belt on 92 civic non vtec 1.5 motor?
- Civic clicks when trying to start,whats wrong?
- 96 civic dx b18a1 obd2 to obd1 (iat keeps burning up)
- OBD2a-OBD2b Question
- B18b into 2000 hatch - Not running right! PLEASE help! WATCH VIDEO
- Intake manifold for Dx series ek? (1997).
- where can i find this pillar bar setup 4 ek?
- 95 civic hatch dx
- 98 hatch, Low compression, losing coolant.
- rear sway bar on del sol questions
- will a 92-95 PS bracket fit on a 96-00 motor
- Hose loose, did I get the wrong one?
- Help with fuel filter job
- EM1 fuel and temp gauges don't work
- Calling ALL Ignition Experts, Help is Needed!!
- 93 civic vx runs poor after 2nd start
- Can't find horn wires.
- 96 EX clutch choice & LSD?
- single cam build! your opinion!
- 92 civic has broken fuel line - Is it 5/16"? What thread size? Does NAPA carry?
- oil pressure guage help
- OEM Power Steering pump
- obd2b - obd1 dizzy and alternator help
- Manual Rad. Fan Switch wiring diagram
- Funny Idle and car dies sometimes??
- Fuel line leak....help!!
- Del Sol Wiring Question OBD2a
- Power steering or Belt??
- b16 low rpm hesitation
- b16 with s2000 throttle body idle problem
- Will a full integra interior fit in my 96 civic?
- H22 overheating.
- Idle high with no descent?!?!
- Can anyone recommend a good brand of aftermarket radiator for my eg hatch build?
- USDM vs canadian p30 ecu
- 1992 F20b Honda Hatchback Won't start?
- lots of white smoke on start up
- D16Y8 to JDM D15B complete swap!!!!
- 92 EG Project
- tranny won't go into gear..ideas why ht?
- H22a/eg swap wiring questions
- help identify parts on 95 del sol
- del sol roof wings?
- speedometer probs Need help
- CEL on! 96 EK with obd1 p28! tried everything. Help?
- Shifting Problems
- engine swap and tranny conversion
- 96 D16Y8 swap to a 00 D16Y8 Help
- map sensor code/problems
- Clutch slips when the car is cold, then goes away when it warms up..
- 93 civic on vw mk2-mk3 coilovers?
- Are all SOHC AC compressors interchangeable?
- Autometer gauges
- D Series Mini-me No Start, but clicks once. Have Searched and tested, results inside!
- Headgasket, timing belt done, car wont start
- 97 ex timing issues
- Del sol y8 trans axles?
- 93 si hatch is throwing codes 22, 43, and 9
- Severe hesitation at part throttle b18c
- B18B1 in civic code 9
- Faulty Lock up control solenoid valve
- 93 del sol S-hard start, hesitation, radio turns off after kill switch install
- hatch power option conversion
- civic b16a2 swap
- D16z6 ignition and mechanical timing
- Question about my del sol roof
- Liquid out of Rack and Pinion boot, help!
- SOHC tranny problem
- valve chatter and white plumes of smoke?
- How to tighten Harmonic Balancer bolt with out special tools
- Swap Help! In desperate need!
- Brake light malfunction
- Aem short ram vs civic oem box with kn&n filter vs integra box with kn&n
- help indentify parts on 95 del sol
- 93si gas guzzling problem need help! asap
- Can I swap a 95 Del Sol VTEC engine into my 00 Civic EX?
- Engine Won't Stay On!:(...Please Help!
- 95 EG With a ls/Vtec Help???
- D15b7 to a B18 is it worth it?
- mini-me swap, obd2a to obd1 help
- b16a3 swap into a del sol si questions.
- honda civic heads not receiving oil/ any ideas on why the heads are not getting oil
- How to change auto tranny fluid in a 98 civic dx?
- Ecu reset
- ECT Sensor Connector, what is it really called?
- 1995 honda civic tire sizes
- Installing stock heat/ac control panel
- Ignition Key Problem
- A question about engine timing
- 4 door GSR Seats into 4 door Civic LX?
- KYB GR2 sits lower than Tokico blue
- ZC SOHC ECU!
- Replaced rack and pinion and purple fluid was in rack
- Will a 96-00 hatch exhaust rear section fit on a 95 civic hb?
- 93 civic engine swap
- Cruise Control Question
- ebay racing seat brackets
- semi-dumb question.........
- 97 civic ex wont rev past 3500 sometimes
- Help!!! ZC SOHC non vtec idle!
- wtf noise
- HELP !! major idle problem
- running lights not working
- Fully built LS/Vtec del sol wont crank properly
- crunch time need help asap itr valve cotters/keepers/locks question
- D16y7 to D16y8
- Crank Pulley Bolt!
- code 17 b20b 00 civic si
- Code 14 & 22 (94 eg D16Z6)???
- 99 si stutter? Honda gurus please help!!
- Ignition breaking up around 6K...
- Radiator trouble
- WIRING LED STRIP TO DOME LIGHT? EK
- car wont rev past 1500-2000 rpm without bogging after clean fitv
- Mini Me Overheating Problem
- WTB: SI Wheels
- intake manifold????
- idle ajustment?
- Light white smoke from motor- B-series swap
- Seat replacement
- EG Scraping Ground?
- 93 del sol wont start
- Del Sol Rear Quarters
- MPG with Si Wheels?...
- Need some help with BuddyClub spec pro exhaust
- Quietest available exhaust for 95 Civic
- Barely failed smog, need help please
- Quick Question. 95 Sol 1.5 AUTO, CEL: 19(Tranny Solenoid Lockup)
- where to buy windshield and roof weatherstripping besides dealer
- 98 EK hatch BAD IDLE PROBLEMS
- civic has rough idle
- Gas Switch over to 91 to 87
- Help me decide if this EK is worth buying...
- 94 civic idleing problem
- Original spare wheel/jack and tool setup?
- 99 Honda Civic EX starting problems, need help!
- skunk2 lowering spring help
- K or J swap help.
- Bad Wheel Bearing?!?
- quick question about auto to manual conversion...
- Bad fuel pressure regulator???
- Making the GSR Cluster look stock?
- Im thinking about a swap.
- My first B-Series VTEC Swap
- OPENIN VTEC IN D1 OR D2?-B16a
- Oil pressure gauge install question with oil pressure sending unit
- B20BP8R Build Thread/ DX auto to B20 Manual
- Questions about Z6 head on a Y5 block
- will a 96-98 dash wiring harness work with a 99?
- Rear disc brake conversion question
- Auto vs manual harness?????
- Starter Issue
- 93 Civic hatchback - low power and rough idle
- H2b clutch question
- Window motor died with glass up, how to remove to replace?
- 1993 honda civic lx not starting pleassee helllpp
- cable gsr in hydro car worth it? or keep ls
- Mini me Swap timing problems
- low end acceleration
- car dies when its hot outside!
- EK4 roof swap to EJ6.. possible?
- How to fix broken speedometer.
- Rebuild D-series
- Honda Civic LX Automatic Rattle when in 1st gear
- Rattling Cat?
- 97 Civic LX Sedan - Trunk Leak
- front Passenger side door will not open
- Need help identifying my distributor.
- Best Pressure plate for NA D16z6?
- 95 Civic DX oil and coolant gremlins
- ECU for D16Y5 to make more power and no CEL
- Car will not go into gear/move
- 2000 civic automatic code. p0720
- help plz... ac compressor..
- JDM 36mm 5 lug (need new wheel bearing)
- Please Help Me Identify My 1994 Civic Model (First Car)
- ZC DOHC sounds subaru
- 98 civic dx many problems plz read
- 96 ek coupe Gsr swap help plzz
- 92 vx/ first time honda car owner
- Might get this 92. What you guys think?
- civic dipstick with gauge on it?
- power steering removal?
- Radiator Fan switch threading
- Windshield replacement for 96 Civic HB - Is model number 73111-S00-A10 correct?
- No Spark After Auto to Manual Swap
- Differences between the 96-00 Civic LX and EX cluster?
- master cylinder and brake booser install
- Fuel pump stays on. Tdc sensor code
- help power mirrors not workin!!!
- '96 will car start if Crank Position Sensor is bad?
- holy shoot, what is this brand of suspension?!
- help with eg exhaust, im lost
- LS VTEC HELP!
- 99-00 EM1 Transmission
- Help get my 99 civic inspected b18c/ hondata s300
- Need Some Help
- cant figure my ecu out
- Cruise Control Not working after swap
- obd swap 99 ex. sound right??
- Wiring Guros come come help. Help undo a ricer action
- need help asap about to pick up cams dont wanna get scammed
- How to get a smoother ride.
- Need help!
- 1999 Civic Dx: What is all thats needed for an Ex brake conversion?
- itr seats in eg?
- 95 Del Sol Auto trans replacement - Will 96 Civic trans work?
- rhd 94 coupe need help!!!????
- best cams for d16z6 help
- does anyone have the 96 ex power window troubleshooting flowchart
- JDM d15b Question?
- Randomly slips out of 5th gear on freeway?
- Rear hatch window plug?
- Smog failed and car runs poorly
- 99 Civic with 3 Fault Codes, P1298, P0135, P0141
- how to cancel p/s on my 95 civic?
- B16A 92-95 (SiR-II) into 00 ek
- Automatic B series swap
