96 Civic DX/OBD1 conversion - random misfires HELP PLEASE
so i have a 1996 honda civic dx wit a d16y7 i changed the manifold did a 2wire iacv got it done the write way changed the gaskets nice wire job etc. but when i use the obd2 to obd1 jumper and plug in the obd1 ecu it kinda misfires only from 2200rpm to like 3500rpm WHY IS THIS. I CHANGED THE MAP TPS AND IACV. i also changed the plugs and wires cap rotor etc. help me out please THERES NO CHECK ENGINE LIGHT
The Grumpiest
Re: random misfies HELP PLEASE
Let's try English. Why are you using a chipped P28/P06 on an OBD2 engine? Are you boosted? Why did you change the manifold? Changed the manifold to what? Do you have a P2P or P2E?
I changed the mafold so I was able to do a 2wire iacv and the manifold is bigger. But I need to fiz this problem so I'm able to run the obd1 ecu and get tuned
could be the base map u have.. where did u purchase it? if u run a stock p06 your ignition is retarded 4 degrees at base. as y7's and y8's run 12* base timing and the p06 and p28 are running 16* base timing at idle. its also been known that the y7/y8 don't really like a lot of timing because of the head design.
The Grumpiest
Get a basemap for the mods you have. You're not supposed to run a generic basemap and then modify the car. The basemap does not take these mods into account and will run like crap.
hatcht9x
07-29-2009 11:13 PM
skate_volcom2006
10
08-28-2008 12:53 PM
EGsixer
10-31-2002 11:12 AM
