- I'm looking for a engine torque damper
- Motor Selection Thread #12930923149238419023491238490
- crackling sound when starting out????
- EG Front Bumper under cover?
- Rack and pinion questions *withpics*
- I need a wiring harness for a vtech d15b
- Car will hardly start (help)
- Anyone care to run a carfax for me?
- Lets talk about the E46 M3
- HOW TO INSTALL NRG QUICK RELEASE?
- after market steering wheel with cruise control??
- stupied question on low beams. they stopped working WTF?
- Sticky This Whats Really Needed To Do A 5 Speed Conversion On A 92-95 Civic With D Series Motor And
- coolant system flush question
- wtb a motor.........
- Affordable turbo kit for b and d series $1500.00 shipped complete kit
- need new wheels
- nsx brakes???
- GSR Swap shaking under acceleration only, NEED HELP ASAP!!!!
- D16z6 swap
- Airbag Replacement question
- itr brake conversion question
- 96-98 coupe guys
- b16a or b18c
- Mirror swap
- so i just looked at a good friends motor and.....
- rear lower tranny mount: same on 94-01 teg as 92-95 civics?
- I HAVE HAD A HORRIBLE MORNING!!..
- civic stock tire size ?
- TEIN S-TECHS ON TOKICO ILLUMINA STRUTS
- STOLEN HATCH KEEP A LOOK OUT!!!!!!!!
- Engine pics, work still in progress.
- RobearRacing 99-00 OEM Style Foglights: Good Or Bad?
- valve tapping noise
- ????which rear lower tie bar????
- JDM Rx Pedal in EK.
- Possible to pass smog?
- Is this a sign of a thief?
- 92 civic dx wont start
- obd1 gsr ?
- HELP!! My new Swap!!
- Question: OEM Spoiler fitment.
- how fast is b16a in a 92 hatchback?
- VX to CX Transmission?
- EK Owners: 96-98 front end on a 99-00 rad support?
- HCP Mounts
- gutted rear hatch ...
- [FAQ] The Fog Light General Questions Thread - OEM DEPO ESSUE RAYBRIG PASSWORD:JDM EBAY
- Anyone running a B20?
- what do 99-00 tail lights go for now days
- Kswap?
- removing air conditioning....
- H2D adapter plate/kit? Who knows of anyone that makes and sells?
- d16y7 exhaust HELP!!!!
- any1 tuning nearby
- clutch, flywheel
- Complete list of differences in an EM1 and EJ8
- distributor questons....
- obd2 b18 ls in a 96 ek wanna go obd1
- serious question for all b16 owners
- motor swap question?
- 97 Civic Hx Mechanical Help!
- cel code 21
- 93eg2james' Del Sol Progress Thread
- need help: installed omni clutch master
- Orlando body shops?
- which intake and headers are good for a 2000 civic si ?
- scratching noise?
- Ok Guys Maybe a good cheap Turbo Kit....YOu help me decide
- Help: 96-98 Rear Lip Install
- y8 head
- HELP me pass smog
- hydro vs cable tranny parts for auto to manual swap
- ecu help ?
- FUSE KEEPS BLOWING
- b18b into ek Hatch
- wut type of axles do i use
- Canadian exhaust bigger than US exhaust?
- Climate controls switched around
- *Quick Question About (99-00) CIVIC'S
- First time Honda owner
- 93 Del Sol Si For Sale !!!
- USDM B16A2 Where to buy (So.Cal)
- Paint
- FS: body kit in PA
- looking for a civic shell
- Del sol engine bay picture request (please help)
- '93 Civic 4dr Restore Project
- Civic engine bay and 01 gsr engine bay ?
- battery part number
- Just got a 93 civic....
- Best places to buy honda stuff?
- D16B Just Stoped Starting!
- what do you guys think 95 Del Sol Vtec
- How much could I get for my '97 Civic?
- Check engine light confusion
- Fuse box layout for fuse box next to battery in 92-95 civic
- obd II 1362 TDC sensor circuit 1 no signal
- driver side axle question
- anyone have a 99-00 civic coupe window diagram?
- Automatic to Manual Transmission - 98 Civic
- would these head light fit my hatch
- weird clutch issues
- WIRING...HEAD ACHE!!!
- Would a Z6 IM/TB Fit on a Y7 Head?
- new here
- HELP! Running Lights and Dash Lights wont turn off!!!
- Trying to get the R exhuast sound
- any post just for coupe pics?????
- high alert
- newbie
- WIRING HARNESS??? WHICH ONE???
- How to put X brakes on your 96-00 EK Civic (revised) Upgrade Chart - UPDATED
- Question?? My car is throwing a code 19? ecu is p70 jdm d15b Y???? Do I have a auto/M ecu?
- Important Passenger side frame mount difference between auto and manual??
- HERES A QUICK QUESTION FOR YA
- whats the easy way to take out tint?
- looking for a silkroad diffuser..help please
- car makes vibration noise and loses power after 5k rpm
- Where to get harness clips rewired
- HELP WITH TACH!!--- SEARCHED!
- gsr sway bar on EK?
- roof rack ???? what size
- EK CTR paint code
- 98' CX brake problems
- Question!!! searched
- VAFC Tuning...
- would the piping from my 93 hatch fit my 98 hatch????????
- Need help
- 99' Civic B16a2 engine swap
- WOULD THE SUSPENSION FROM MY 93 EG FIT MY 98 EK HATCH
- 97 ex tune up questions
- ATTN: Anyone Who Has Oil at Corner of Head Gasket Where Trans/Engine Meet on B-Series...
- Auto To Standard
- radio block off plate.. can it be used in place of the climate control panel??
- recaros out of an EK in my EJ2
- Strange sound when turning?!
- Need help with speedometer in 92 Hatch
- have 98 dx hatch and want 99-00 front end what would i need
- Injectors not firing after swap (LS->92 CX)
- eBay Foggies: Need Input (Link Inside)
- window help!
- new to this
- help installing oem airbags
- window regulator
- Swap Question
- Newb question...I guess everybody's gotta do one every so often...d15b cam swap suggestions
- Are KYB GR2 shocks any good?
- em1 brakes squeek
- Hood Tilt
- is this normal.....e-brake console area gets warm
- Drag track near Morrisville or raleigh NC????
- 92 EG Gsr swapped cant pass emissions
- In need of 93 del sol wiring diagram
- Fuel Filter Change
- D16y8 skunk2 build
- MY CAR IS HOT LIKE A HELL...
- Just wondering if anyone knows if this is CARB legal?
- CenterForce Dual Friction (good clutch)??
- Axle Repair
- Heater control lights on when i turn car on(2000 civic si)
- What is this ? TWM ITB Something ????
- I want to buy hid's for my eg give me your advise
- SRR 4.9 Final Drive
- Loud, high pitch noise when reversing! HELP!!
- Del Sol Wing
- aftermarket intake question?
- supercharger for B10/vtec
- a USDM B16A2 HEAD on a JDM B16A1 block with JDM B16A1 internal?
- 5th gear 82 MPH at 3.9-4.0 RPM is that CORRECT?
- transmission help
- 1994 civic si colors offered?
- The best way to clean and restore valve cover appearance
- 00 Honda CIvic Si
- problems starting please help
- turbo install
- Eg or Ek?
- Emissions on the ek hatch wiht 99 jdm r swap
- can i use a p75 in place of my p72? are they the same connectors?
- i searched but wanna make sure i don't get the wrong one
- gsr guage cluster need help
- idling problem with obd2-obd1 conversion
- Clutch question
- OBD question
- wheel off centered
- O2 sensor
- vtec questions..
- Engine buzzing when I hit vtec
- Off topic bezel Bever in here :)
- Cel 43
- low speed stutter
- I'm looking for a certain rear fog light post, HELP!
- 95 civic d16z6 leaking from pipe going from water pump to thermostat housing
- itr pistons on gsr rods
- Del Sol pics
- Can I swap the sedan headlights to a coupe?
- Noob question (TIRES RELATED)
- Today was a good day :-)
- lol
- How to remove ARP head studs off B16 block?
- 00 Honda Civic Si Help
- quick question: when changing front calipers, is it necessary to bleed the rears?
- IACV question...
- Eg chassis fan always on?
- Weight of 92-95 HB steelies? (13")
- DOHC zc Into a DelSol si *searched*
- 94 civic hatch
- Ek9 Civic R question (brakes, CAI)
- gear ratio
- V-TEC Wiring on a 92 Shock tower B7 Harness
- Noise when releasing clutch
- Car thieves go for fast and furious...duh
- good stock sohc headers
- IDLE
- d16y7...simple question.
- Will Omni Coilovers fit
- no blinkers and two tickets...:(
- timing
- need opinions asap (head damage??)
- fidanza flywheel
- F1 racing clutch
- 2000 Hatch with Autopower roll bar
- HKS AFR or HKS Super AFR?
- does anybody know the honda part # for the optional coin pocket on the eg
- dc sports jdm 4-1 header
- Where to buy pair of DELSOL fenders in ORANGE COUNTY 714/949
- my honda eg6 1992
- CEL: P0420 "Catalyst System Efficiency Below Threshold"
- HERE IS MY NEW SETUP LET ME NOW WHAT U THINK!!!!!!!!
- cel help
- HELP!! 94 ex cluster doesnt work HELP!!!
- Help Installing 99-00 Civic JDM RAYBRIG Foglights
- broken
- Anyone out there making a cowl hood for EG's??
- Is there a difference between aftermarket gauges?
- Jolt when (un)loading engine (throttle movement) .... engine mount?!?
- Tach problem
- Conversion harness options.
- Magnetic Drain Plugs: Really worth it?
- RSX steering wheel
- Are the manual racks in the 92 - 92 civics the same as
- best daily driver suspension?
- CEL wont flash
- what kinda of turbo
- wiring harness question
- axels....
- Anyone know where to get....
- vtec solenoid
- EP3 Side skirts on EK
- Any Mechanics in the northeast?
