View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Radar Detectors
- If you were going to start over
- Engine swap question
- hmm someone enlighten me....
- Got some new shoes..........
- (archives down) help installing Energy Susp. trailing arm bushings please or link
- Whats wrong with my duckbill?
- Need Help On Bolt Size
- just a question....
- New to HT. Here's my car
- going from v-tecE to regular v-tec
- If 'teg parts fit on a Honda, I assume the reverse is true?
- Changing Master cylinder and booster?
- RSR headers?
- axles and linkage when dropping tranny?
- prices?
- Vtec Head Swap Questions(tried search, question not found)
- 8lb wheels installed :)
- Which Radiator Do You Prefer (base on cost and performance)???
- 4-puck clutch
- Type One Exhaust
- Routine Maintenance/Tune-up questions
- How can I tell if it is an Si fuel pump? Visual cues?
- buying a civic
- Quick Tip...
- HELP Car will NOT Start!!!
- is there any way to adjust where the clutch lets out on my 93 SI?
- clutch makes a scraping noise when i let it out ?? why?
- Suspension Techniques 18mm Sway Bar - does it fit other cars?
- How do you remove the rear seats?
- Cross Drilled Rotor Opinions? I need stoppers.
- Pinout Diagram d16y8
- white hatch years
- 99 b16a2 into a 96 EX coupe?????
- '02 Si seats ?
- Does any of the 90 Integra suspension/brakes fit 93 Civic?
- pics of the 94 eg from last year
- h22 and h23 tb on b series heheheheheeh
- help with block question....
- camber wear after raising car back up?
- s80 to ys1 coversion??????????????
- Here is a good question for ya...????
- Youre a Honda pimp if you can figure this out!!!!
- stock fuel pump
- Spoon N1 rear Axle ?'s!
- Who lives in Rochester NY
- Dome light bulb replacement?
- can i sawp a F23A1m 2.2L sohc vtec (accord 98) to my D16Z6 ??
- cf hood with scoop
- We WON!!!
- Going to buy this hatch, is this a good price?
- anyone know how to install underbody neon?
- how to improve responsiveness on my eg?
- How would you know if you have WARPED rotors?
- pics of the ricey hatch - check 'em out 56k - (maybe)....
- Debate H23a or b18b?
- HX Exhaust
- Header Tech header questions
- More EM1 ¿?¿?.. NEED HELP!
- del sol AT to MT?
- Factory 1/4 times for a SIR II ?
- *UPDATE* On my Emission ticket!!!
- Shock Recommendation
- throttle body size?
- H Motors Online Kicks Ass.....Agian!!
- B16B Idle Problem!! Help me.
- water Leak in eg
- why does my motor whistle?!?!
- Swap Info
- legal color lights??
- Got rear LCAs, got GSR swaybar, what else do I need?
- 95 eg hatch w/ ls(b18b1) swap track times
- H&R quality
- how do you install....
- Has anyone swapped a 92-95 D15B7 for a 96-97 D16Y8?
- hybrid revolution
- auto ECU to manual ECU
- fuel pumps
- Si Master Cylinder Questions??????????????????????????/
- Install help on ITR to EK non abs sedan
- Strong Fuel Smell
- HOW TO: Change from stock exhaust to JDM Bling (56k warning)
- 1999 Honda Civic Si with 4 wheel disc breaks??????? wtf?
- Apexi N1 rattles?
- a non civic owner question
- H&R cup kit
- My Clutch is High
- squeaky clutch
- 02 si seats into a 00 si?
- which springs to go with??
- Mugen Wing on an EG sedan
- Any websites for OEM wheel weights
- lowering spring question.
- another EK question
- SI Suspension Vs Cx Suspension
- help need on type r manifold install...
- How do i remove the gauge needles? HELP ASAP
- Archives are down... D15b7 possibilities????
- Uneven height
- distributorless ignition system
- **Going NA: Is it worth it?**
- ECU reset
- black widow 1 body kit
- 96 Hatch on Ebay, DX motor has GSR rods??
- Anyone out there with turbo have the Thermal 3'' exhaust , pics please
- GSR Hatch chasis options
- need help deciding between the 2
- SOHC vtec ques(last one)
- My EG Stolen in Northern Cali 209 Area!!!!! :(
- tornactive.com - anyone deal w/thier customer service?
- Tech Help!!! Tranny Grinds in 2nd Gear
- Q's about broken Si lip
- Help with shifter!!!
- Me and a Mail box (need help)
- First time pics of my g-ride civic, taKE A LOOKSEY! 56K WARNING!!
- Inspection ?
- awww shit. f##in snow!
- EG/EH rear lights technical help needed...
- Anyone here from TEXAS? got ripped off.
- brakes???
- EG9 pic
- Nipon Formula F1
- D series lovers....
- Seat Question?
- New Motor Question?
- opinion on skunk2 camber kits
- Where do all the D16Y7 motors go after swaps??
- ITR header on B16EG hatch???
- head swap question
- SKUNK2 harness, 96-98, 99-00???
- are there any difference between obd1 usdm ecu and jdm ecu ??
- ES Oval Exhaust question
- Integra brakes on my CX
- What interior Integra parts fit in a civic?
- Carbon Fiber Gauge Bezel at Inlinefour good?
- B18B1 into my 95 Civic DX coupe...IT'S DONE!!!!
- ITR cams in a B16...
- Pic of my intake (tech ? inside)
- RPM activated switch for vtec... HELP!!
- Blown Shock
- Integra side view mirrors
- 2.25in piping on stock exhaust?
- will rear speaker panels from a 95 ex coupe fit in an eg?
- Cutting Integra Springs.
- Which hood would you rather get *pics**56k warning*
- something just occured to me...
- Exhaust.....need input
- Contest for Free Decals and Discounts
- Problem with Door Locks (did search)
- LSD trans owners!
- just a fyi: have ek/eg thin moldings and eg visors available now and some more other good chit
- 205-50-15 tires on stock 15x (6 or 5.5)" wheels on 95 ex coupe
- b17 crank in a b16a block
- is there anybody from the toronto area on here
- Does the Apexi WS come in an axleback or just the muffler?
- what motor is in the civic breadbox AWD
- What other Civic fuel filters are direct replacement with 93 Cx's? Pic of Cx inside!
- bDel Sol suspension brace
- calling all si(sir owners)
- H22 prelude power in del sol
- JDM front lights for ah 92 + coupe Honda civic...
- A/C compressor took a shit, which one should I get?
- Just got my Tanabe Super Racing Medalion.. Got a Question..
- Strut Disassembly
- Need help with s2000 seat install...
- Wheel Spacers?
- Pics of the hatch with my new Nikon.
- help!!!.....will my springs fit??
- tokico shocks
- Post pics of you LCA and Swaybar, ITR prefered (this is actually technical I swear)
- Sell, Mod, Go all out... YOUR SUGGESTION?
- Help!!! Tailights on 92-95 civic screw locations?
- I need used parts for my civic, need help on finding them!
- My euro civic finally "finished" !!!!!!!
- Pinging or intake whistle???
- What (brands) Front Upper Strut brace(s) fit a 99 CX hb?
- rsr exmag gtII.....where can i get it?????
- what the difference between the p28 and p72 ecu
- EG's with USDM/JDM ITR interior need some help.
- anyone know if you can flare fuel line on 92' DX hb?
- Someone Please Help Me!!!
- Quick question...'96 dx hatchback
- Please Help!!!!!!!!
- wight
- My 00 Si was smashed.....
- quick question about es muffler
- what about the del sol??
- 95 civic front sway bar clunking?
- Alignment Spec Sheet
- Selling price for EK
- 02 s2000 steering wheel on a 02 civic ex coupe
- Pedals
- Can i get 94+ Gsr door panels and back seats to fit my 92 EG???
- have u cleaned your TB and manifold?
- price 4 cams
- eg - 6 speaker set-up?
- EK front hub broken. Will any 96+ hub work??
- Anyone have any good/bad comments about Venom400 chip?
- dome light isn't working!
- Should i swaps my D16z6 head 4 a D16Y8 head ?
- silly question: changing 3rd brake light bulb on an eg.....?
- do i need longer bolts for my Z SPEED tie bar?
- Civic HB engine swap
- dumb questions from a noob...
- Honda Civic RX LE
- GSR Skunk2 exhaust fits EM1 coupe?
- Will a roll cage or spot welding the entire body of my hatch hatch eliminate body noise?
- GSR Seats OR SI seats in an EG?
- question about radiator
- what's the difference between hp and whp?
- A cupple of video clips that should make you civic guys happy, A must see
- STUPID S.O.B thieves!!!
- beaks or bsq??
- building up a B16A with R internals, is it worth it?
- Short shifter hits exhaust?
- Black Racing Pro N-1
- replacing CAM SEAL
- ls rear sway bar on 95 civic ex?
- 130-150 whp on d16y8?
- CF Hood question
- hatch sideskirts vs coupe sideskirts
- RHD civic Eg hatch, what will happen?
- Just swapped a JDM B18c(gsr) into-coupe
- quick question for a motor swap (h22)
- EK master cylinder upgrade options???
- engine pinging
- Tein HR
- where can I buy exhaust rubber hangers?
- Confused about catback-exhaust
- H22A Type S in a 93 Civic DX Coupe... please help.
- Replica Twin Loop?
- Need help wiring 4-wire O2 Sensor to ECU
- how to tell if thers a lsd in my tranny?
- CX w/ CRV motor - gas mileage?
- Removing/Installing Speedsensor
- 5zigen header
- mugen stud patten?
- Honda manual transmission fluid
- 225/50/16 on a '93 Civic Si hatchback?
- GSR cluster gauge into EG problem PLS HELP
- all 92-95 CF hoods universal?
- Air bag removal?
- Code 22 and 23, i know what they are but why are they on!!!!!!!!
- Wanting to trade my 88' dx hatch with ls vtec for 92-95 hatch.....
- Tein EK SS coilovers in an EG
- Red coupes w/ bronze/gold Rims!!
- 2000 Si rims..??.. **searched**
- Wrecked the hatch tonight...
- Ferio Back Seats?
- What all do I need to do a 5 lugg conversion on a EK * yess I did a search*
