View Full Version : Honda Civic / Del Sol (1992 - 2000)
- installing steering wheel/hub
- Project Mini-Me
- EK rear lca bushings FIT in EG lcas?
- Map sensor wiring help
- rear disk ???
- help with my o2 sensor question
- gsr brake swap question?
- Very sad... can't identify my car..
- CV axles bent..
- d-series oil squirters
- Sputtering when cold
- 05/06 RSX-S Exhaust
- IACV cleaning question
- Help with ECU Code...
- creaky suspension / general advice
- need 00 Civic ebay foglight wiring help
- d15b swap info pls.
- What is this part called and what is the part #? B18c1 GSR motor in EK
- can you bleed brakes through the banjo bolt?
- Cooling fan wont turn on.
- VSS issue's
- PIC REQUEST EGs w/ Ek side skirts
- Car wont start after sitting for a long time
- Which CV axle do I replace?
- help with AC unit in del sol!!
- what spring rate are you using?
- Changing Power window motor
- 92 civic lx swap problem
- Where can i get lca bushings for my eg?
- SI sunroof on 98 ek hatch, dx
- what kind of rear lip is this?
- b16 idle woes
- use civic AC or integra AC?
- Cleaning that fowl odor from the A/C system, where to put the foam?
- Picture Request: 5th gen - Need a picture of the trunk release latch cover off!!
- B16 & GSR oil pan the same??
- Identifying a motor
- 92 eg (stock) problems runnig
- civic AC or integra AC?
- Vacum Line?
- 99-00 Tail lights, turn singal color
- Bypassing VTEC oil pressure sensor
- camshafts into ek4
- 95 civic door panels
- Sould I buy this 96 civic?
- full size radiator in 96 EK!
- Need Help with b18a1 obd0 into 96 Honda Civic EX
- sohc swap question?
- Pinging/Detonation with AC on!
- NRG Engine Damper
- ...Searched Already...Will 94-01 Teg' LS,RS,GS AEM CAI fit a b16 in an EG hatch?...At All?...
- Easy Way To..
- H3 Fog Bulb/Safety
- 99/00 si grill
- *HELP* New Drop with proper offset but rubs!!!
- Push button start
- Tein S-Techs of Stock Struts?
- good price on ek
- safe to drive on 3 lugs
- switch cat for smog eg and ek same?
- speedometer/ mileage
- brake lines. GS-R brakes all around on 93-95 coupe.
- Engine not starting
- Glovebox handle broken off, anyway to pry open or something?
- Headgasket/taking apart engine
- needs help with a swap
- anyone using these and how good are they?
- RESURFACEING HEAD
- ek fog light bulb HELP ME!!!
- shipping
- D15B7 Bosch Altenator Question
- Best place to mount siren in Del Sol??
- Swap done need some addtional help
- header wrap on cat to pass emissions...good idea? or bad?
- Is it easy to install a walboro fuel pump in a civic????
- throttle body for b16
- may have radiator problem
- Timing Belt Replacement? How Much including Labor??
- Oil filter Question for SIR B16A
- mini me swap
- Del Sol SOHC unorthodox under drive pulley... HELP
- Canadian 99-00 SiR comes with 15/16" master cylinders?
- Are Integra Shock Forks Bigger than EG Shock Forks?
- Is a mini-me a worthwhile mod?
- Power Steering Fluid drain/refill
- Too Loud! Pond Rescued EJ1 needs sound insulation!
- shifting problem
- where's the main relay?
- how to define the 170 hp b16a?
- 90 integra shift linkage ?
- cam gears off by a half a tooth
- need ideas, extra d16z6
- is it bad???????
- Which flywheel for b16
- got an engine what do i need on the loose ends
- Shifting Problem (Searched)
- d16y8 help please
- 2 Questions - Emissions and Additional Parts - 98 JDM ITR Swap into 97 EX Coupe
- will 88-91 civic lowering springs fit a 92 civic 4door??
- ahh problem found
- People with HID's and casper shields-need help
- radiator fan turns on when decelerating / decel
- Might be a dumb question but gota ask
- having a little trouble with my civic..
- will 96-00 civic suspension fit 92-95 civics?
- Can someone suggest some rims for 96 4 door civic?
- BLEEDER VALVE
- stay b16 or turbo d16, ls?
- door ajustment
- alternating turn signal/side marker
- speedo problems
- power window help!! (99 civic ex)
- Suspention Compadability..??!?!?
- B16 B18 Idle Air Control Valve Block-off Plate question
- steering wheel fitment question
- D16y8 compadability????
- replaced head gasket; won't start - WTF
- y8 intake manifold on y7?
- eg seat question
- Rsx Wheels in a EK
- shifting problems
- Basics Help
- Civic DX
- No Spark,Engine light always on, dont start
- NEED HELP p28 chipped ecu with skunk2 program...need a basemap for a b16a gen 2 P30
- Eclipse stock turbo fit b16?
- lets get an ek/eg picture forum up!!!!!!!!!!!!!
- pics of '92 civic si - black
- Trial user......make it stop
- turboing an automatic sohc d16y8t
- B16a help...
- disappearing problems in my 97 civic
- Picking a paint colour
- Idle problems
- jdm d15b vtec solenoid
- jdm d15b
- car is acting wierd.
- how easy should it be to put trans into reverse with housing off?
- deburning a fuel map???
- need help car just dies
- DA susp on EJ1
- car won't start 97 civic. cel 15
- engine gets overheated when pressing the accelarator hard
- Superchaged- which oil weight?
- Bleeder screw size?
- Civic noob engine question
- having fuel pressure problem im getting too much fuel
- 93 Civic Starter
- Will a coupe or sedan exhaust fit a hatch?
- 95 civic 4dr LX alternator wont come loose.
- I have a question
- Coil-Overs for my del sol
- antenna block off / ipod question
- Does this let air into the brakes?
- Throwing a misfire code
- HELP! cel 10 car wont start
- Seafoam creepin down, into my engine sector, answers or no?
- short question about brake prop valve
- EG = DC2 ( race springs ) ??
- Wiring....
- block off antenna plate installation
- idles at 2000+ when cold
- Installing a quicker ratio gsr power steering rack onto a non-power steering 92-95 civic.
- EG Shock Fork Bolt Question.
- drivers side door handle broken?!?!?!
- Sunroof problems 97Civic EX
- do i need a new ecu if.......
- AC fan doesn't shut off
- New to Civic's and the site. What do you think?
- GSR Skunk2 IManifold with GSR TB?
- Stuck acclerator
- sub harness question
- Engine mount play...normal or not?
- Signs Of Failing Slave Cylinder
- parts needed for ac (searched)
- where to buy cheap mounts
- Chipped ECU or No?
- Electric Fuel Pump
- SIR doors on a 96 ek hatch
- what transmission could i use for this motor?
- zc won't fire up...can't figure out why
- Pre-Cat and Post Cat 02 sensors
- Car almost passes BAR any help plz
- ex d16 octane?
- Purge Solenoid Valve for '99 Civic Si
- QUICK QUEST. 4-1 OR 4-2-1
- b16 with b18 pistons
- Which is better?
- skunk2 manifold on a 94 ex
- Suggestion for a header back exhaust system??
- n00b question, exhaust bung..
- ECU not getting constant power?
- Speed Bleeders?
- LS REBUILT FOR A EG6????
- OVERHEATING PROBLEM!!!!!!!!!!!!!!!!
- Weird pinging noise?
- rear disks on a civic ex.
- The difference between a DX and an EX....?
- sway bar
- Will a Recaro slider fit a Torino?
- Motor Help Which ONE should i pick??
- Gas Guage way off
- gsr and type r trans mission
- PLZ HELP ME!!
- After changing the input shaft bearing.....wont go into reverse and is alot harder to put into gear.
- How do I advance my cluster?
- weird rota question Iknow...iknow....
- 99-00 fog light problem
- vtec engagement question
- 92-95 hatch, ingalls torque damper
- headgasket bolts??
- D16Y8 worthy of a turbo? Got some questions.
- Syncro's going at 102,000?
- 99 dx gauges
- overheating...searched and some questions
- JDMB18C MISFIRES
- bodykits....in or out?
- anybody running nitrous on a h22 eg?
- weirdest problem ever (atleast i think)
- weird idle?????
- Why do stock shocks blow out if you put lowering springs on?
- how to put in a nrg engine damper?
- d15b vtec solenoid
- wheel/ nosie question
- p2n basemap?
- What the heck is up with my Intake Manifold?
- INtake air temp sensor?idiling really rough
- seats layout design?
- BLeeding clutch...searched
- non-vtec cam fitment
- Spoon Sports Lower Front Tie Bar [HELP]
- Need help making a decision (keep a car or not?)
- How to tell what kind of tranny is in my car?
- HeLp! code for 95 stereo?
- honda noob questions
- Help buying a transmission
- Brand New Power Window/Locks and Mirrors for an EG hatch?
- 4th runner of the IM
- Main Shaft Top bearing question? How do i remove from the trans. housing?
- lowering springs
- Looking for a EG Si hatch
- exhaust question
- '96 Civic air con trouble
- clear turn signal piece?
- Finished MINIME but no compression???
- car running hot
- can i use a 95 gsr ecu on my 00 civic
- cv boot quick question
- foglight install 92 eg hatch
- 00 fuel pump
