View Full Version : Honda Civic / Del Sol (1992 - 2000)
- fuel pressure sensor
- 1993 civic rims offset...
- rsx seats heated function in my EG
- windshield wipers arent working
- need help pls with compression
- TPS N20 heater pad questions.
- switching rims
- car wont start help please!!
- cell code prob
- radiator woes and check engine light. need input/comments
- i need help with a ls swap in a 93 hatch
- Suspension opinions! Sorry for posting here !
- Starting on Hondas!
- exhaust question
- JDM DC 2.5" Header + which cat?
- ls swap in 97ex.....need help badly....please
- car starting problems; no power
- cable to hydro
- h22 swap
- Crankshaft Help
- Is it supposed to be this hard to turn?
- Integra IceBox
- cat. converter rattles?
- Cluster broken...
- My car acts up @ the gas station?
- how does my EJ6 hatch sound like it's coming togeather
- B series... clear up
- I accidently shifted into reverse at around 40 mph...
- Been thinking about this for awhile (automatic lights)
- seeker parts?
- 96 civic type r coupe 4sale $5500
- trying to convert my manual windows and locks to power like eg6 HOW HARD>>??
- CTR carpet, will it fit in a 92-95 hatch!!!!
- (In spokane, need help)Bad tranny?
- B16 Tranny to B18C5 Block?
- Losing coolant..thermostat or blown headgasket?
- what is the difference on a b16 crank and a b16b crank
- help on yonaka seats!!!
- ITR front brake setup ON 95 civic coupe????????????????????
- **Imports vs. Domestic = STOLEN EJ1 [please help!]**
- Exhaust system help
- Looking for Many Civic Parts
- Look at these pics of my 93 HB passenger side tranny bracket
- car dies
- Best Magnetic Oil Drain Plug?
- Throttle Position (TP) Sensor
- cel light
- brake booster hose
- Is there a difference???
- engine question.... fuel or spark?
- help on reading my check engine code?
- New B18B swap. Help!
- wiring harness for my gsr!
- a6 head on b7 block, timing issue.
- parts
- spark plugs??oil??
- WHAT DOES A B16A3 COME OUT OF?
- Two exhaust questions.
- Drivers Side Window Falls Off Track (searched and only found windows sticking)
- shifter rattle!???
- cleaning under the hood?
- PCT ecu and b18c5
- ECU programming or chipping question
- Help out
- GSR question
- Need to find out name on rear hatch window bolts.
- Turbo Upgrade question
- damn idle surging and cold start valve on throttle body question
- D16Y5 tranny question does it have long or short gears? anything like a jdm d15b ex/si tranny?
- What are Valve Clearances for B16 SiR2 (GSR)
- Radiator supprt differences
- coolant temp guage
- Civic R34 front end conversion
- Light Adjustment.
- Blown Motor, now what?
- ECU question..
- wire harness question...!
- "Blox missing link type B"
- 2000 cx timing belt question
- question about motor?
- oil in my throttle body....
- Best Air Intake for b18c5?
- What are the D15B7 head bolt torque specs
- help me out...want more power out of k20a2.
- SOHC 4-door swap
- ecl code 9 and idle problem
- which ecu code do i need for a SOHC NoN-VTEC ZC?
- How much of a drop is this??
- del sol suspension
- Are 92-95 and 96-00 civic outter tie rods the same??
- 97 EX Coupe center dash panel
- LS swap in a Del Sol
- check engine light??
- Coil spring isolators: they sure are pretty, but are they useful?
- b20a6 in 93 4dr lx
- B16 surges at all point in rpm range
- rebuilding rack on eg
- idle surge
- ECL light never comes on
- suspension experts HELP: 98 hatch SPC upper arm problem
- Z6 Oil pump question....
- map sensor
- Rear seat belts locked?
- Ksport or tien please give info Thanks.....
- drain tranny fluid to replace axle?
- ? of stock casette player.
- Fog lights.Yellow?
- eK Round fogs
- New! :D
- building a car with rear frame damage
- eg hatch exhaust on ek hatch?
- Muffler shop in San Jose or near it
- CEL 4 and no rpm signal problem...GSR motor in EJ1
- Found a del sol...good price?
- Dash Light Problem
- i have the slowest car in the world
- cluster gauge pod
- Civic EF, EG, EK etc.
- quick ne clutch question
- honda ecu chips
- 98 Hatch: tranny swap, clutch release folk SPRING! how it should sit PICS!
- EG tie bar question.
- Which rear sway... suspension technique
- Engine mount question
- Seat Issues...
- I'm no electronics expert.
- Wiring VTEC Oil Pressure Switch Quick Question
- taking out back seat in ek coupe
- i need your guys help-radiator support!!!!
- Integra speedo conversion in eg si hatch ....NEED HELP!!!
- Inter cooler or cold air intake
- 95 civic auto2man swap and 96 civic man2auto swap NOTES
- broken hood release latch
- Rack and pinion help!
- Will 96-00 Ek upper control arms fit EG 92-95
- Modifying
- Problem with my 5 lug on my 94 eg
- Fuse Question... ive searched need help
- need some one to confirm for me...
- Turbo Help
- Help with inter cooler
- NEED HELP!!!! CAR WONT START...
- is this normal? axle question
- WRX POWERED CIVIC SI
- AUTO P28 CONVERTED TO 5 SPEED
- d15b7, shorter stroke than the rest of the d-series?
- 94 Del sol
- 2007 Accord swap into 1997 Civic?
- JDM GSR Tranny problem.....please look.
- Honada Civic spindle help
- honda p2t to p73 jump harness
- Throwing Code 41, Primary oxygen sensor heater, how/what do I fix?
- eg/ek mirrors
- idle control???? 1996 civic ex d16y8
- h22 with 2 knock sensors?
- 1996 civic lx......abs or non abs brake pads?
- I failed smog bad
- 1992 Civic Lx wont turn over :(
- how to install CTR gauge bezel?
- B16 Clutch Adjustment
- mud guards or rear lip
- jdm ignition harness?!?
- 1997 ex getting CSF NO SIGNAL CEL HELLPPPP!!!!!
- Is it possible....pcv valve?
- Where is the master slave cylinder in a 97 Del Sol?
- where can I get HID's for my (92-95 civic) JDM headlights??
- air in clutch line???
- d17=d16 manual stock flywheel?
- 98 civic ex questions
- boosted HX???
- Cold Start problem & stumbling/misfire
- SEARCHED How to put JDM ITR wheel into EK
- got bored painted my wheels. PURPLE!!
- What Exhaust Should I Get?!?!?!
- Idle Problem with swap gsr in Ek
- BITCH PIN!
- Idle surge issue
- EGs (hatches) with weight reduction...post your weights!
- Z6 mini-me detonation !!!!
- GAS MILEAGE! GONE BAD
- apexi vafc sohc
- ECT coolant temperature sensor, CODE 6!! HELP JDM H22A
- front lower tie bar q?
- Timming belt change and crankshaft
- need help on wiring walbro fuel bump.
- swapping 2000 GSR swap into my 96 EK civic
- 5 bolt swap on my 99 civic si
- clutch plate ????
- WHAT IS THE SUITABLE CHIP FOR MY CAMS,B16A2
- Head Gasket & Head Bolt Questions
- CEL and speedo problem
- oil color
- JDM 96-01 EK sedan tail light w/ Trunk
- 95 civic swap
- Is this rod knock? **Vid Link**
- Hasport or other Poly-urethane mounts question about removal of torque mounts
- Are inner tie rod ends a wear item?
- 1997 honda civic
- Clutch swap...
- VX clutch problems? New to hydro clutches
- where to get EG dashboard?
- WHATS MY EK WORTH???????
- Noob help
- few questions
- WHATS THE LOWEST OFFSET I CAN RUN
- Dash Q
- 93 del sol AC question
- What ECU to get?
- oil leak on 96 civic dx sedan
- 96-00 d16y8 civic airbox fitment in hb
- hks twin power wiring?
- Few body question
- any one heard of the SUN Hot InaZma POCKET??
- clicking noise
- h22a into my hatch question Yes ive searched
- Apex'i VAFC V-tec controller question
- b16a sirII, Cold Thermostat??? It doesnt like to warm up...untill at idle??
- 3rd Gear grinding!!
- Resurfacing?
- heater only blows to the floor vents
- some sort of smoke coming from exhaust...help please!!!
- Quick Imput needed
- Honda Fanatic Required.....
- 95 dx swap
- overheat at stop and at speed
- Limited slip question... i hate being that guy...
- kinda urgent: will a B18B engine fit in the backseat of my '99 Civic EX?
- Greddy Emanage
- Red EG tail lights
- tail light wiring
- b18a b18b ls vtec egr valve help
- VX vs CX
- Tach problems... help!!!
- Emission test for a 94 Del Sol
- p13 knock sensor pin?
- clutch noise? help
- IACV qustion........
- turbo timer
- 98 civic turbo or supercharge
- help with ek4 rear seats!!!
- burned valves
- flywheel....
- speed sensor wire?
- EX transmission ratio
- steering column gauge pod
- eg throttle cable help
- replacement motor mounts?
- CHECK ENGINE LIGHT, need help quick. P0420 is the code
- cleaning my tranny?
- Getting a new exhaust, got a cat question.
