Do i need to get ANOTHER set of new bushings?
Hey techs,
i had a quick question. I recently about 2 weeks ago i installed new bushings for my lower control arms for my ek.
fast foward to today, i bought new gsr rear disk to convert from my old drums. the new rear disk was attached to the lca. so basically do i have to use this gsr lca in my car (with old bushings) when i install the rear disk?
or can i still somehow use my civic lca with the new bushings with the gsr rear disk?
Re: Do i need to get ANOTHER set of new bushings?
You can use your EK trailing arms. You will need to take the hubs calipers, rotors, caliper brackets, and the integra e-brake cables off of the gsr trailing arms and swap them over to your EK trailing arm. The hub is held in place by 4 torx bolts located on the back of the hub. They can be a PITA, but if you want to keep the EK arms (which i would) then you will want to do this.
atc5
08-09-2004 06:30 PM
