View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Humming sound coming from around intake mani...
- squzzing noise from right left.. timing belt?? or tranny?
- distributor problem ???
- Wiring Issue help : update.
- will d16a1 pistons fit in an d16z6?
- pics needed!!!!
- 99-00 civic climate control swap <HELP PLEASE>
- How to Hook up the Horn with a Nrg Quick Release and momo corse wheel?!?!
- password JDM question
- Engine install trouble with main relay!
- Trip to get oil changed at Jiffy Lube, blew engine 30 mins afterwards
- civic ek sedan taillight question
- Starting Problem
- having engine trouble with a new D15B7 motor
- will cel code 1 and 7 prevent vtec to kick in?
- what the hell is this noise?
- Looking for spark in spark plug wire...
- Chosing Exhaust
- Check engine light on but no codes, any ideas
- Has anyone priced a 2005 Civic Si?
- Help: Portland area Swap Shops?
- FS: H&R race springs for 00 si
- 96 2dr 00 si front end...
- T-body advice for newbie
- Any popular website to buy a set of OEM red/white 99-00 2dr Taillights?
- sputtering
- No Power Steering
- CEL code 61, Primary o2 sensor question
- help help help help help
- Attempted Thievery (San Diego, CA)
- good price for a tranny install?
- compression test results.
- need help Ecu swap p2p - chipped p28
- wht the difference between a b18c4 and b18c5
- Discs brakes dimensions
- Jasper Performance Parts
- wtb: civic 2000 side skirts, prefereably painted red, if not that's fine.
- Loud click when turning right??????????
- Want ITR 5 LUG with rims or big brakes for sale!!!PLS.
- Car doesn't want to start!!!! Help!!!
- 90-93 integra rear discs fit on an EG? Some say yes and some no
- Need to find a Kamikaze header...
- its cold outside...
- which ecu do i need? * i tried a search but was unsuccessful
- will this tranny work
- post up pics of cf hoods half painted on sides !! eg
- Does D15Z9 exists?
- dc2 gsr cluster n eg6
- Is everyone stumped?
- Intake Manifold/Engine Bay tidying HELP!!!
- headgasket gone?
- 40/40 proportional valve
- Low oil = high rev.....
- oem brake upgrade
- Hard coolant line.
- Super-loud SQUEALING noise coming from the engine
- need help with dash....
- EH/EG Cluster short/Burnout Help!!!
- which tranny for boost?
- Please Help!
- simple question of suspension double checking
- HLEP: Gsr swap in Civic EK
- Does anybody know...
- I'm going to change my radiator, have some Qs
- My EJ1 takes FOREVER to heat up. Thermostat?
- What to do? Brake upgrade poll
- Changing Wing Mirror
- difference between jdm d16z6 vtec and jdm d15b vtec
- Won't start when hot...no power...
- hot shot header. (link inside)
- Differences between 92 si and 93-95 ex civics?
- is this normal? or is my clutch broken?
- wrong gas! ahhh
- Blower Motor sound..
- Can wiring and light bulb sockets get wet?
- parts needed for a D16Z6 head swap
- EK cwest front bumper
- need some help on vtec d15b eg wont start:(
- hole in my 4-2-1 header
- can low resistance peak and hold injectors be used on 92-95 civics????
- need some help with poorman type r buildup!!! HELP. PLEASE
- Crushed oil pan...95 LX daily driver....
- d16z6 powerband?
- ls head question
- Another What Camber kit for my Civic.
- HELP ON TIMING PROBLEM....FIX MY MISTAKES...THANKS.
- i want to extend o2 sensor...what are the 4 wires?
- CRANK PULLEY NOISES??
- Bunch of Problems-HELP ME OUT
- Can someone please explain these sensors to me?
- Help Yes or No or Your Sentence (Sensor)
- YES!! Should be getting another EX!
- Power windows on 97 hatch with 4 door floor harness
- Did I kill my engine? My poor EK...
- what engine came in the 97 dx hatch back
- Low end power for b16a EK
- the last time iacv trouble please help me!!!
- Need help with my swap ASAP!!!
- 415 area shops
- h22 eg s/c question
- clutch woes?
- Q for eg owners with a z6 or y8 transmission?
- bomex mirrors?
- 92 civic power door lock problems
- Another 3rd gear grind
- got a question for 96-00 civics
- d-series hybrid tranny built and installed (DOHC ZC custom transmission)
- 99 em1si and 99 ex
- Need help ASAP. Wiring issue
- b20/vtec head
- Question for EK's Gurus????
- whats that smell??!? help
- manual rack for 98 coupe
- How much are headers worth
- Head Unit Questions
- d16 wiring harness
- HELP ME ... PLEASE = (..
- ASAP! Throttle Body cable adjustment.
- Would Honda civic type r breaks work on 93 civic hatch vti?
- 2004 Honda civic type R front and rear seats in 93 eg?
- help does a eg hatch have a fuel pump fuse;;;;; HELP;;;;;;
- EG shocks and springs onto an EK, washer placement question.
- how do u install the release fork on tranny?
- Car dies after starting only after it sits
- Does anyone have a P28 or P30 ecu FOR SALE?
- conversion harness question on hx?
- how do i know when is 3 teeth when i turn the crank case for 3 teeth?
- just changed my distributor...oh no..
- Whats this Stuff worth, part 2
- si lip and grill?
- shift linkage question
- Where is the paint code located on a 94 civic
- CF hood with no Washer Plugs
- age of drivers?
- Help: Carbon Fiber Hood Fitment
- Fender lining
- Richeeee's hatchback visit's the emmisions center
- automatic cable?
- Swapping a Autp trans EG to Manual? Yes I search, is it worth it? and a question on mounts
- engine good?
- question about fuel rail
- Idle/ Electrical Problem
- angel eye headlight
- beyond redline
- ac question
- clutch master and slave cylinder questions
- H4H HID
- ECU PINS
- Question on boring TB's , power gains & intake sizes
- What is this guy smoking?
- Middle Winshield Wiper Setting?
- Can construction lids damage your car?
- Timing belt question
- Del sol VTI (front+) rear disc swap on EK?
- I dont think i have a FITV...Help me find it, I have pics
- Will Si cat, muffler, and B pipe bolt up to my d16y8 and fit right?
- Pics of my first and newly purchased 93 cx hatch!!!! Pics inside!
- Del Sol fitment inquiries: Air conditioning and Gauge cluster
- Rebuilding suspension in a 92 Si... what parts should be replaced?
- Where can I get bulb condoms?
- Radiator Fan placement..
- Do all DX 96 Hatchbackes have armrest?
- sigh....vtec solenoid
- ECU check code question
- 92-95 D-series trans mount the same for auto and manual?
- SOS I NEEEEEEEEED HELP WITH MY CIVIC
- I need a carfax 1HGEM1152XL05837 Civic SI ANYONE?????????
- 93 eg engine bay question
- Any member here from NH? I need Help!!!
- door squeeks
- NOOB here, which civic can handle better?
- Whats the next closest bulb size to DE3175?
- Towing Help, Need Help/Ideas ASAP
- removing del sol window?
- E System 02 Sensor
- buddy club n+ spec or tein flex?
- anyone know what after martket fuel rail will fit euro r intake manifold to make it fit right in?
- ItsOEM
- fenderwell rubbing on my eg... wheelspacers?
- i need a measurement from a EG hatch w/ rear upper strut bar
- GSR block or B20 block???
- si cluster
- 98' Civic LX exhaust problem... Need Help!
- RSX seats into an EK Civic?
- Honda reflash software?
- Quick ECU
- is this bad? ECU
- wiring up mirrors to signals???
- AIT
- Is the Integra power mirror switch compatible with the civic plug?
- Fixing my AC 2000 Civic
- weird alternator prob
- Civic Type R
- Swap Running: But Horrible Popping Noise
- ENGINE BAY PAINTING!
- New Guy Here.. Come Welcome ME!!!!!...
- What do i do with the accelerating cable?
- WOW talk about good gas mileage
- exhaust recomendations?
- Climate control and fans stopped working...
- Anyone ever install a set of H&R Coilovers on their EG/92-95 civic?
- how involved to put 99 heater controls in 96
- stupid check engine light question
- oil fillter is empty when changed
- Run 14" steelies on a em1?
- b16 ctr pistons?
- 2dr front on a 4dr
- VTEC question
- stock bore size for d16z6 and d16y7
- Help me get my 99-00 center radio/climate console out
- i got my car stollen again!! in san diego.
- does non srs type r fit ek?
- WILL 94 DELSOL STRUT/SPRING ASSEMBLEY FIT A 96 CIVIC HATCH??
- Help installing REAR speakers in a 1994 Civic EX coupe
- Windshield Wiper Question...
- Brake problems.
- delsol body flex. opinions on fabing some braces
- Will the stock exhaust from an EK hatch fit a 94 hatch .
- need help wiring msd 6al
- axle problem
- TSX K24a2 + extras for sale
- 98 civic swap
- SUGGESTION?
- 2002 Honda civic EX W/ bodykit N' rimz
- New Memeber, check me out
- LMA question
- ok searchengine dont work and i have a question
- 16X7 on 00 si
- Selling Honda Civic DX Hatchback
- Lowered Honda
- cracked header by o2, bogging.....anybody help?
- Pic Request: 96-00 Civic on GSR Fat-Fives
- Mugen Twin Loop Gasket?
- SI climate control help
- weird sound from passenger side front
- unknown manual tranny leak, 95 Civic LX
- Gauge Cluster Problem
- Weird Problem
- How much do P30 OBD I ECUs go for???
- Who is running 215/??/16
- Will the rims rub?
- valve adjusting: is it .21 on intake and .19 on exhaust
- for sale/chicago
- whats a good 1/4 time on a ls hatch
- Rebuilding B16A2
- Steering wheel shaking while braking..
- My Gas Gauge wont Go down
- need help with k series into an ek9
- GSR Wiring into EG....
- JDM B16B/Catalytic Convert
