View Full Version : Honda Civic / Del Sol (1992 - 2000)
- LS swap.
- Is my alternator done?
- civic relay problems
- Need help installing Circlip onto new balljoint
- black bosch plugs
- Shift linkage problem, shifter bolt not lined up? wtf?
- A/C doesn't blow ice cold air
- were to buy distributor
- I NEED HELP!!!!!
- Trying to figure out what these front spindles are from *pics*
- calling all spark plug pros!!!
- ball joints
- eg hood and fender question?
- can i use prestone dex-cool antifreeze in my 92 civic?
- Strange CEL
- Which o2 sensor is primary
- Getting a turbo for my d16?
- OBD Problems
- 92 honda civic b18c1 manual trans
- Tenabe Medallion vs. Apex WS II
- gsr swap into ej1(what all do i need)
- speedo problem
- i got a Ls Swap in my Hatch.but Thinkin i should go Ls-V or Turbo. advice?
- I could REALLY use some advice...
- Quick question about ek
- Espelir springs?
- NEED NEW ENGINE A.S.A.P.
- eg radio rear speakers wiring question?
- Civic teaser video??? Anyone know where to find it?
- ABS??
- Spoon stroker kit for b16
- Rear disc brake ?'s
- What head swaps are possible?
- changing out manifold and fuel injector problem.
- helpful ideas for a b16a problem child broke block
- 92-95 Fog Light Wiring Harness where can i purchase?
- Rear disc install ????
- radiator cooling plates
- Slowed down by Falken RT-615???
- Just need a quick answer. Automatic swap onto a B series?
- Hatch ecu
- mud guards
- Having a hard time closing my hood.
- ASR subframe brace with BLOX sway bar
- tires for 15x8?
- timing?
- my high beam lights is going crazy on me
- ????????CEL 12????????
- First things to do to a Sol...
- ej1 vs eg9
- Quick header question
- speedo works somtimes on EJ1 vehicle speed sensor?
- wire tuck. need help.
- i have a 94 ex coupe and just got a b18b1 obd2 automatic
- where are 98 civic ex airbag sensors?
- Car won't start
- WATER IN CAR
- tranny swap... I need some help.
- is a 94 civic cx obdo or obc1
- too much for a hatch?
- A/C Kills Car...
- 93 civic ex prob plz help
- motor size?
- obd 2 a , obd 2 b question
- Bad gas milage and no vtec... help!
- Vibrant flat black exhaust. good bad or what? let me know
- NEED HELP!! Transmission wont shift into gear from park (automatic)
- FOg light dont work
- Which o2 sensor to use???
- Pic request
- Replacement exhaust rattling against stock shifter...(not short shifter)
- Car is lagging
- HAVE QUESTIONS HELP!!!!
- Turbo B16 Vtec Problem
- Getting an intercooler and piping for free
- right time to shift
- still hot
- JDM thin side moldings
- HELP!!! swapped intake manifolds and car idols up and down drasticly
- Losing oil, no blue smoke, no leaks
- Looking for Skunk2 Pro-C Coilovers
- ACL rod bearings.
- Honda Part Number
- EG6 Rear Disc Brake Pads?
- Pic Request: M3 Style spoiler for a 2000 coupe
- ecu help
- possible blown head gasket? these are my symptoms....
- Piston Ring Gap? Main and rod torque specs?
- code 1-1 on SRS
- Will a half core radiator from 6th gen fit into a 5th gen hatch?
- Which coilovers---PIC Apex or D2???
- power window conversion
- damn... really need some help.
- dash light swaps??
- Full F & R NSX caliper conversion. Anyone have this setup on EG or DC?
- State Ref on Bar'ing JDM Motor
- not throwing codes....
- JDM d15b vtec
- cheap reliable turbo kit
- Blown out struts
- I just wanna dot my eyes and cross my Ts with MY FIRT SWAP. YAY
- What all can cause a code 43 (Fuel Supply System)?
- EG6 Side markers....
- failed emissions
- Bay area state ref locations?
- civic ex cel
- Here Goes....probs with zc swap
- Rear Shim Kit vs. Rear Camber arms
- will an EG automatic transmission go into an EK
- b16 blowing white smoke, water on the ex manifold, oil is muddy =(
- civic 94 dx overheating
- Headers = not able to pass emissions?
- quick question on cable to hydro conversion??
- Need some opnions...
- smog + aftermarket ecu
- Skunk2 Exhaust Problem
- CEL code : 10 IAT - intake air temperature sensor
- My SOHC D16 acting funny.
- Type-R throttle body.
- Skunk 2 Intake Manifold help
- JDM exhaust problems
- Hottest Automobile pics ever!!!!!!
- help!!! wiring problem
- +++ HELP .: BIGger rotors on my si +++
- improve brakes on civic
- HELP!! GSR intake manifold
- Secondary oxygen sensor circuit ? and code 64???
- EG to EK exhaust swap?
- Hybrid Intake Question
- 5ZIGEN ProRacer A-Spec exhaust on Ek4
- help, please. need opinion on swap. 95 civic coupe ex
- b18c swap into 98 ek ---what parts are needed?
- hood hinges
- Si wont start.
- Yet Another Newbie.
- TURBO VACUME LINES
- Rim curbed anyway of fixing?
- b18b swap problem
- Mini Me
- ? about 99 si
- b18c or h22
- wanna get her started
- Wont Start. fuel, spark, compression...WTH
- Honda's Suggestions for Storing Your Car
- 1996 to 2000 Civic Maintenance Schedule
- How much would you pay for this civic?
- Kind of a stupid question , but.....
- I need help
- evo8 recaros in EK?
- ECU Help!!
- CF HATCH GLASS
- this sucks
- saved enuff for an h2b swap but...
- ac question any help welcomed
- Power steering+h2b
- would an oem factory EG exhaust fit a 00 EK hatch?
- AutoPower rollbar install Q! NOTHING sitting flush!!
- vss trouble
- Changed and checked oil, oil is low and no leaks!
- cut dizzy wires on 96 ex.... need help
- 93 civic dx
- I dont have bolts for my LS tranny can I use the ones from my D series
- Anyone know how to adjust EK headlights?
- Solid CEL
- d16y7 timing problem...
- Stainless steel header maintenance
- my Si stumbles in vtec
- engine compression reading what does it means ????
- Best Susspension Set up
- New to the site, i have a couple of questions?
- swapping in vtec, help me!
- code 1
- my new 93 civic ex
- *sigh* bad vibrations
- jdm shit
- h22 swap in my EK
- tranny...
- 1994 honda civic lx
- My Final Set Up
- Few motor questions
- 99 civic si tuning program
- h22 into eg
- Manual swap parts list (help please)
- energey suspension shift linkage bushing help
- GSR Rear leathers into an EG hatch
- 93 GSR Seat in 99 Civic coupe?
- B20 Install problem in my EG. Help!
- EG HATCH AFTERMARKET Lower control arms..... pro and cons
- Where can I order the 99-00 Si OEM lip??
- New daily ride....
- Calling SRS airbag experts..............
- debadging my civic
- Distributer Question?
- Spraying nitrous??
- 96-98 civic wire tuck?
- New Head!!!! need help
- D15B7 Head On a D15z1 Block...?
- D16Z6 1993 Civic EX Distributor Wiring Diagram?
- Cheap modifications?
- 1992 dx sedan with 94 ex motor
- non vtec dizzy on vtec motor??
- eg cluster
- ----------> I NEED 99-00 CIVIC SI ECU PINOUTS.....
- studdering issue...
- D series trans makes grinding noise with fidanza LWF
- Timing question on my build!
- cel code #9
- keyless entry
- Drive without a cat converter ????
- body shop (paint)
- rear drums vs disk brake
- d series trans
- d16y8 ( help)
- H22A Swap Help
- need help with spoon mirrors?
- Head gasket or no? Need opinions!
- Eg and Ek
- smog check in socal
- what looks better
- EM1 boosted, running obd1 hondata?
- Motor missing on cylinder 3
- Civic and integra axles
- gsr motor clearence problem?
- need help in removing wiper switch on 98 civic
- new and in need of some help
- DIY: Moon cut valve cover for GSR, ITR heads.. Very detailed!
- obd1 to obd2 conversion harness
- eg8 sedan (brake n suspension questions) miami305
- k20a3 in 99 ex
- New Color Pic
- Tuner Toys D-Series Rods
- 96 civic lx door lock problem
- Duralast vs. Brembo
- Not a huge problem, but so annoying
- Too much rear camber, which LCA could I buy?
- Drivers LCA pivot bushing...
- Stock D16Y8 fuel/air graph?
- Steering wheel slipping on 95 Civic SI
- random high idle
- overflow tank spitting out coolant
- crazy tach
- DOES THIS SOUND RIGHT? MODS MOVE IF NEED BE!
- Thieves
- K-series Swap for a EG
- car dying when push in clutch
- A header question regarding to b16 swap into a eg civic
- convert to obd1?
- Ebay Aluminum Radiator Review.
- how to wire up EK power folding mirrors
- can i get a confirmation on these fog lights please?
