View Full Version : Honda Civic / Del Sol (1992 - 2000)
- I have JDM H22a. Need information.
- The time draws near.
- Check Engine Light on: Here's my problems.....
- Warped Rotors... How To Check?
- d series ppl with the maxrev kit
- how can u tell if your recaros are real?
- got my first pair of rims and tires YAAAAY
- [FAQ] Detailed How To: Remove Carpet From An EH Hatch!
- 582 hp civic what do you guys think....?
- Need more flow!!! ? on Exhaust supplement (Stock)
- 92 civic 4dr guages question
- Would this be a strong daily driven all motor Hatch?
- Hey everyone. New kid on the block from SoCal. ? on Paint....
- is hondaautomotiveparts.com down? or just me?
- test
- which steering wheel would u have on ur eg?
- [FAQ] Detailed How To: Remove Rear / Back Seat From An EH Hatch!
- apex header???
- ls/vtec question???
- looking for seeting for vafc for sohc
- carpet what do wit it(94 civic hb)
- restoring my eg/friends sol...PICS
- Nuts and Bolts
- 97 Integra Reat Seats in 92-95 Civic
- Time for a new alternator? Questions.
- Best price for Koni sport (yellow) for '97 Civic?
- Fiero Seats!!!!!
- overheat
- P28 to GSR ECU programs
- Up my timing?
- PInout needed for P28 ( 92-95 Si Civic/del sol)
- what is this???
- a little help
- How do you guys do it?
- Fastest way to 200
- Anyone using motor mount inserts. If so what brand.
- Need help ASAP
- suspension tech.
- Anyone have a fuel pump kill switch?
- 94 dx tar?????
- higher rating alternator
- ran compression again on my d16z6 (have questions)...
- delsol with ls throwing a code 12
- Parts for the d17?
- light bulb part number for ek cluster???
- removing e-brake boot?
- Need 5th Gen hatch... West coast plz...
- heres my car sorry in advance (56k my cars not worth the wait)
- need help ASAP
- let me see ur eg hatch with an N1
- How to advance your timing?
- Chamber?
- Anybody have experience with Intrax ARS coilover system???
- nice_eg newest mod
- low idle really ticking me off!
- My short shifter hits my B Pipe body on my exhaust. Suggestions?
- calling all axel experts!
- Fuel Pressure for 92-95 ex/si
- motor mounts... jimfab or hasport
- Off Topic: Austin, Texas meet (?)
- Engine mount???!!!
- wazup
- scratchy noise
- tourqe sequence for gsr head
- Wilde Motorsports Carshow
- buying new motor this week!!
- skunk2 balljoints are trashed
- Drums on a 98 Civic LX
- Is it possible to run a D series motor w/ JDM ITR 5 lug
- what p28 program would you recommend?
- gsr front breaks on an eg. i have a question...
- Installing Stereo and Programming Alarm Remote
- New pics of my hatch. 56k go die somewhere
- your lsd, my lsd
- OBD II in an OBD 0 car...
- Gas mileage worsened after 5 lug conversion and Mugen springs/dampers were installed?
- EK hatch with spoon spoiler
- need a auto to manuel conversion...
- How to install a low fuel warning light in 97 Civic CX.
- What to set Camber at???
- EG HB got stolen last night!!
- ball joint boot replacement? Prothane/energy suspension
- help with rim/tire offset
- Difference between b16a first and second generation blocks.
- Door Handle removal on 5 gen ?
- I need help fast oil in #1 spark plug tube
- could someone get a car fax for me
- a 95' ls ( b18 b ) into a 2000 civic ex
- Lug nut torque specs
- adjustable cam gear?
- OBD1 motor in an OBD2 car
- mixed D series parts...
- got a d15b7? got a tach? come inside!
- Major Task to convert front end??
- new to h-t...
- Ignition Switch question. How do I know if its bad...
- What should I look for? Please Help!!
- JG Throttle Body, Performance Gains?
- HyTech / SMSP header Q's?
- Opinions... Is it really worth it?
- 94 cx hb yucky blue interior , what to do?
- Comptech or Suspension Tech Sway bar kit to get.
- someone offerin me a obd2
- LOOOK at this...ghetto fabulous
- wheres my ricers at?
- '93 honda civic ex 4dr wing/spoiler?
- How do you break in your brakes?
- post best looking strut tower bar for eg
- Can i use the 90-93Integra LCA on my Del Sol?
- Overheating after getting off lond drive on freeway
- Going to buy AN-R b-series header
- 95 Ls motor in 98 honda civic.....keyless wont work, neither will radio
- help on d16z6 timing belt
- 92-95 auto to manual trany mount
- Ummm...need help
- 45 mph in first gear on EX motor???someone help me
- im getting a code 91????
- JDM ITR 5 lug conversion, what axles 36mm...
- will greddy piping for a 00' si fit on a 00' ex?
- H&R Sport Springs?
- ok, i'm driving home and my axle falls off? wtf?
- Ran open header today!!!!!!
- cheap site for lips???--eg hatch
- what strut bar can i use
- what to do with my rims?
- *** How Much Would This Go For? ***
- when u wash your car does this happen??
- D16Y8 Girdle pics?
- eg radio block off plate
- Wut Rpm 2 Launch at??
- Wut Rpm 2 Launch At?
- water barrel meets front of my sol on interstate...
- Question about oil pressure sensor
- need opinions on which hatch....93si or 98dx?
- switching tranny internals? experts only please!
- ppl with b18b eg's
- When does VTEC engage on a 97 EX???
- mini me on 96 civic
- Oh my god..... you guys are gonna die laughing!!
- Tein SS owners (setting)
- EK-EG cluster bezel fitment
- Tuning cam gear!!!!
- somebody with 96-98 civic ex.......can you check....
- axel question..
- ok.... All motor... B18B or B16A
- weight of 91 civic si hatch back vs weight of 93 civic cx?
- Clicking sound...
- Is there such thing as a OEM White civic Si (SiR in Canada)??
- Suspension Techniques Integra Swaybar/TieBar on Ek Hatch Need Help.
- wiring harness for a 99cx
- Putting calibers back on
- My new eg, rims, and suspension.
- y8 Intake Manifold and AEM ITR CAI
- opened up blown type r motor
- eg helms manual?
- Pics of my white ek with wheels and suspension.
- dash swap
- transmission metal type.
- B16 head specs from Helms
- Suspension choices?
- will itr rear seats fit a ek9
- OBD 2 confused as hell
- That annoying beeping when doors are opened...I want it GONE-How?
- Help with EK hatch suspension.
- ITR sway Bars on Ek.
- Removing Cruise Control in a 99 Si
- Would you guys paint your new ws exhaust?
- what do i need to know for ws install on eg?
- Those who run EX+ITR sway bars
- NeedHelpWithGSRsuspensionOnAnEKhatch
- Quick question: What valve covers will fit on a z6 head?
- koni reds
- i have a question about a/c, or the lack there of
- VAFC on non vtec?
- S or Si
- valve adjustment
- Need help fast...
- Yikes, did I redline?
- anyone hear of "cometition engineering"? (searched)
- Coilovers...
- upper mount
- OEM code for 93 hatch green
- The OEM silver paint code?
- b18b1 in a gen 5 4 door
- ls/vtec ?
- b18c1 EG owners
- Here's the ride comments are welcome!
- how much would you guys & gals pay?
- if i install a str rear diffuser will i get a ticket?? post pics if u got them on ur ride plz!
- B18B v-tech
- Pics of my ek civic hatch... first time
- highest compression for street?
- Factory wing Install...
- engine ?: whats the difference?
- hmmmm.....would you pay $5,000 for this???
- Simple Brake Job Turned DISASTER!
- Popped out of first?
- i need better 60 ft times
- EM1 Suspension
- B16 question
- New pics of my car
- rear quarter panel
- 92-95 Civic Red Carbon Fiber Hood
- Anybody running Sportlines from Teg on your EG?????
- mini me Q
- will this fit in my civic?
- 94 civic dx B15B7 turbo question
- Anyone have experience with RS-R Front brake rotors?
- Lack of information? 7th gen SiR
- wtb: 90-91 ls 5spd ecu, manifold w/sensors/injectors, wiring harness
- b18c1 gsr longblock price quote??
- Where to buy quality body kits???
- y7 and y8 Headgasket question...
- Del sol rail
- more horsepower
- looking for someone who can run a carfax
- oem armrest & audio console
- need about .3 seconds for free!
- b16a/nitrous ???
- octane or kaminari?
- OBD-2 to OBD-1 / Service connector problem
- My race with a Civic Si
- Plugs w/nitrous on d17???
- 99 civic fuse box diagram please help
- Installing AC/Power steering??
- Circuit Races
- Walbro fuel pump for del Sol
- Dynomax Ultraflow on a 96-00 coupe/sedan – pics?
- Integra Passenger seat conversion to EK drivers? (is it possible??)
- B16 - EH2 - Help!
- Engine Swap Shops in Tampa Bay?
- Daily Driving
- race seat in a 92-95, who has one what to do about stock seat belt??
- D16Y7 Cams
- gauge holder for 96-98 civics
- freshly swapped b18c overheating - only under certain conditions... help!
- Eibach springs installation into EK.....
- Compresion ratios
- ZC tranny onto a d16z6?
- im new
- tein vs. gc w/agx's
- ???? who is the better company (mugen,toda,spoon,jun,etc....)??????
- Swapped the SOHC out! in with the LS motor **(PICS 56k go away)**
- where to get 195r red light bulb
- civic si power steering problems, please help!
- AEM or Injen
- gauge cluster lights
- b18c1
- 99ek
- installing integra brakes on ek Q
