View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Will LS header fit 00 si?
- cel code # 3 but my map is fine?!
- 93 dx not fireing in cyl 2 or 3
- dyno
- .010 Over???
- brake booster
- 96-98 CTR OEM GRILL
- Boosted EG W/ EK Foglights??
- 96-98 civic jdm round fog lights
- where can i get oil from for a pressure gauge?
- Do parking lights and headlights get power at the same time?
- F20B into 93 sol
- Oil pressure Gauge
- Installing A Tach on a 96 dx
- ***NEED HELP CIVIC FUEL PUMP PROBLEM****
- leaking coolant when car is off but doesn't when running??
- HELP A GIRL OUT! pretty please?:)
- What Headgasket to use on d16z6 for nitrous? Y8? Z6? aftermarket?
- NEED HELP
- One wheel locking up?
- Bullydog for Civics?
- loud ! noise
- What do do with engine check lights
- looking for hood
- Clunking help please
- Water pump very noise?
- Belt squeak when shifting gears.
- lost motion assy
- b16 type r internals
- transmission?
- obd2 knock sensor compatible with obd1 ecu...
- Haveing clicking problems
- choice of springs
- h22 powered civic si
- Swapping Axle! How much should Snap Ring be out of Groove?
- Help 99 Civic Ex not starting
- passenger side axel in my 94 hatch
- '92 Civic 4dr
- will a d16y7 tps sensor work on a y8?
- HELP!!! JDM B18B In 96 Civic EX... OBD2>OBD1 Idle problems until warmed up?
- engine knock? code 23
- How do i build to handle boost?
- eg with crv
- 97 prelude seats?
- ebay
- net weight of front bumper
- JDM b18c gsr
- Question About Gauge Cluster?
- Brakes bleeding off?
- is tehre a website where you type in your vehicle and see what stock size wheels your running
- jdm climate control is AUTO and stock ins't - how to swap...what to get...?? =]
- Terminal arrangement for VAFC2
- EX door Panel into DX?!?!?!?
- Question regarding exhaust
- single cam into si
- hooking up aem wideband, need help please.
- rear bumper support
- V6 Swap in-to Civic
- how fast? what cam?
- EG dash removal.. need help.
- Want to buy bolts to mount front plate, what size/thread/pitch
- 98' civic ex AT "jumping" at shifts
- B16 Install quote
- CEL Help
- ELD, Fusible link, fuse box. Help Appreciated
- installed new pan and gasket. strange whining sound on start up
- B16 Swap
- no gas
- Found this in my oil pan... can't be good?
- Apexi ws2 from EM1 into an EG?
- what should I do? I got no help in body and paint forum
- my ej1 got stolen please keep an eye out for my parts....
- Oil Light question...
- brake conversion
- Boosted D16
- Bringing a head to a machine shop?
- Heat Intake Tube
- h2b questions
- im bored
- What are these plugs for?
- Fuel Line Mounting Stud
- H22 in Civic 95 with Air conditioning
- Car Meets
- supercharer with nos?????????
- i need some opinions before i start my project!! plz look and help!!!!
- I WANT TO KNOW WHAT MOTORS FIT IN MY CAR???95 CIVIC COUPE HELP PLZ!!!
- test pipe/high flow cat help
- quick question can ne help me
- D16a turbo
- quick question?????
- turbo help
- Quick question - 95 si swap, could i use vx harness
- tranny popping out of 5th
- D16Y7 Header and a few questions
- pr3 pistons in b18 block?
- 00 Si front disc bigger than 93si
- When buying a transmission from a junkyard .. ?
- B16 Head
- ITBs
- head gasket
- Str8 Pipe
- gsr trans with a type r lsd
- Car drifts to the right under acceration
- Throttle body bypass on a D15B7
- EK calipers
- turbo oil drain question
- MSD
- what are the best spark plug wires
- how do I restart my ecu on my 93 civic?
- how to convert PO8 AT to MT and make chip??
- Project : Type - R Turnover!
- the best clutch for the buck?
- check engine light question???
- handle on glove compartment broke. how do i open?
- how to fix vtec pressure valve?
- Code 22?
- ARC Magic
- swap wire h22/f20b help
- Turbo K20 in 92-95 civic hb
- wheelhop?
- CX to DX tranny swap input
- EG6 Dohc VTEC part number?
- A/C Compressor is out
- where is the antenna opening?
- eg6 front end
- when do i need to get my ecu chiped and car tuned?
- 3 Questions
- Estimate cost for painting wing?
- b series swap radiator problem
- 93 civic ac help
- need help on b16 tranny..
- what should i do ???
- deciding on cams... need some opinions
- Cruise Control Kit for 94 Civic DX?
- How do you find the LPH your fuel pump puts out?
- PROBLEM WITH 2000 CIVIC EX HELP PLEASE!!!!!!!!
- Car won't start, please help
- How to replace distributor cap/rotor on 96-98 civic??
- Vibration at 3,000 rpms
- Tien S-TECH Springs. Which is front? Which is rear?
- gauge cluster ?
- flywheel wobbles
- everything needed in...
- Difference between clutches? gonna need one soon
- Problem with catalytiv converter
- Jetta turbo Q's(I know this is wrong forum)
- Experiences with Clutchnet clutch on a D-series??
- H2B Questions
- How could retain my stock ride quality and drop a inch ?
- Spoon Sports Chipped P30
- Valve cover/valve train clearance problem
- shift lock???
- Just got headlights. Need help with the lighting.
- Catalytic Converter for a 00 Si.
- Power steering issue
- Problems with the em1.....please help!
- Obd1 code 21
- need a dash
- Do I have to hook up water lines on GSR oil cooler?
- how much torque does a stock 99 honda civic si B16?
- how to prepare an engine that has been sitting for 2-3 years
- brake parts
- any unused pins on a 95 civic ecu connector?
- CEL code 41 - Primary oxygen sensor heater
- installing an oil catch tank?
- d15b tranny vs. stock tranny on del sol
- what do you guys think
- exhaust diameter too big for stock motor - lost of power ???
- C60 on ECU popped... need help with ECU
- quick question about b series headers
- Wheel bearing hub?
- Preload????
- ? budget internals for b16 with boost ?
- Cleaned my fuel injectors and got a problem?
- exhaust coming from radiator
- LSD?
- Wiring Problems.....
- Quick Question
- auto to 5speed
- car is lagging?
- eagle rods and vitaras into a d16 .. do i just drop em in and thats it?
- recomended pistons
- Alignment tech, please help
- Ls swap in Coupe
- clutch problem...help me out!
- wiring emergency lights
- What clutch are you running on a daily drive??
- K20z3 or K20a2 ??
- LS rods in a D series?
- can i use my horn insted of the alarm siren? 97 ej9 clifford alarm
- distributor rotor needs to be changed
- New calipers want some opinions
- problem annoying noise help please
- Which ones to use???
- alternator problems, very wierd?
- 97 Civic stereo/CD problem
- Question on Suspension
- Help, car won't start
- Cometic Head Gasket
- idle issue --- tps maybe??
- Speedometer sometimes works sometimes doesnt...what could be the problem.
- QUESTION: ek sideskirts for my eg4dr.
- Cleaning block out of car
- VTEC pressure valve wire???
- ep3 seats into 96 ek hatch???
- Need a pic from a del Sol!
- password jdm red stitched shift boot (ek 96-00)
- help me find out what wheel this is please
- ITR 5lug conversion in EJ6 ...will i get ABS ... i have no ABS now...also proportional valve require
- Car will not do anyting?!?!?!
- wanted to trade/sell
- Is he full of it?
- where is the knock sensor on a D16Y8
- 99-00 OEM Raybrig fog light color: clear or yellow lens?
- Anybody know a good place in WA state (Washington) to get swaps done?
- d16z6 IM onto a D16y7
- Stock 2000 Civic EX Problem, need help.
- 95 DX mini me swap problems
- rs machines pistons w/hastings rings. what ring gap??? help!
- 95 civic belt squeek
- TEIN S-Tech Lowering Springs
- noob queston. are motor swaps legal???
- Idle acting up!!
- B16A W/ 4.7 ITR Final Drive
- del sol si swap
- Car ran hot, blew the radiator...
- tps sensor
- rear left side is lower than the right side ....
- how much would you sell
- 96 civic dx hatchback rear quarter windows?
- Help With my Eg.
- Head Rebuild / Minimum spring height for intake and exhaust valve springs (D16Y8)
- eg and delsol crash bar difference
- 97 CIVIC EX AUTO TO MANUAL SWAP
- STUPID Q
- Tachometer is messed up need u guys help
- NHRA CERTIFIED H2B KIT, OFFICIAL KIT OF IDRC & BOTI
- CAR WONT START ***NEED HELP***
- Help wiring universal o2 sensor. obd2b 4 wire. thanks
- A mysterious whistling...
- my brakes squeak . . .
- wideband
- Lip
- Power windows/locks/wireless locks on a 99 cx hatchback
- trying not to lose my car.
- D16 into CX Questions
- sunroof in an EK?
- Testing ignition coil?
- car is smokes and bad idle when warm
- EMISSIONS PROBLEM!!?
