View Full Version : Honda Civic / Del Sol (1992 - 2000)
- RPM low at idle WHY? Help please!
- valve springs for 92 b18a1
- suspension sqeak?
- need help removing passenger airbag...
- STOLEN 96 DX Civic
- spedo stopeed working in my 98 civic
- b20 b18
- '97 Civic emission problem.....HELP
- ecu chip advice.
- NRG thin quick release
- MidWest
- Replacing an aftermarket Radio in 1994 Civic
- Stock SRS Inflator
- Rear washer hose clogged
- Loss of power (acceleration) in car
- Half shaft differences?
- car is slow to warm up
- Transmission Drain Plug
- Too much oil in a 95 del sol
- headlights
- <<STOLEN 00' CIVIC SI>>
- Need help plz
- Looking to replace my axles
- seat rails for prelude seats
- Apexi ws2 exhaust
- code 11
- timing on gsr
- SI Gauge Faces (will it matter)
- i need help asap. intake mani. SEARCHED
- Need Help with a honda radio code model nr 39100-s02-A000
- 543hp build done
- wut should ii buy?
- Gsr into EG exhaust problem
- suspension done
- 96-00 Hatchback guys- rear sway clearance for exhaust?
- Sideskirts
- transmission noise.
- HELP WITH! 97 obd2 ls into my 99 civic
- 99 civic climate control in 96civic.
- Transmission Prob? Or Speed Sensor?
- quick front end question...
- JDM EG power folding wiring diagrams anyone know ?
- 1994 LX erratic idle, overheating, dies at idle
- Will I Overheat?? Radiator issue
- horn not working
- Mini me timing
- Getting ready to relocate battery to the trunk tomorrow EK Hatch
- vents blocked?
- rear camber (toe) and code 43 help!!
- ppl in northwest indian/chicagoland area look!
- 7.5" wheels w/ 225 on eg?
- HAAAAAAAALP!!! I have a leak I cannot friggin find... 95 Civic CX
- troubles finding 93 prelude vacuum junk
- del sol parts?
- WHATS A GOOD EXHAUST FOR AN EM1???
- Need advice
- HORSE POWER...
- Where to get an ej1 front end?
- stolen eg!
- A question for Midori Green EK owners...
- strut bars
- *HELP/ UPDATE ME!!
- Replacing chassis....
- Instrument Cluster, Turn Signals, and First Wiper Setting Died (searched... sucks)
- parting out 2000 si coupe for my 2000 hb
- Exhaust Rattling
- removing a 96-00 civic dash...please help
- k20 question /swaps
- Sohc v blown?
- Civic Mirrors Question
- gauge cluster
- LMAs changed and still knocking
- Sluggish unless at WOT..???
- no power when accelerating
- wiring on minime help!!
- sway bars
- D16y7 Tranny
- knock noise help
- what is the best d series motor to turbo?
- ***HELP!!! 1998 Honda Civic Shuts OFF***
- Motor mounts
- tach acting crazy... whats happening?
- 1996 civic ENGINE problem ( need help)
- tire recommendation..
- Rear defroster wire popped off
- Vtec solenoid won't plug in
- 98 civic hx--help
- TA bushings? cost?
- whats this part called???
- iat ?
- o2 Sensors Dilema for Emisions
- Floor Mat Questions
- which is easier
- 92-95 EG door panels question
- what could cause computer to blow???????????
- what would you do?
- ignition output signal CEL #15
- Engine sawp questions
- 99 civic si
- fs or ft 94 civic coupe
- Problem with car wont crank over
- 92 EG VX looking for ECU
- Ticking noise!!help!!
- wat u think bout a h22 swap
- having problems with speeddomitor.
- ***Front strut bar, throttle cable bracket issue!*** HELP
- New to Tuning my 98 Honda Civic HX (Stock)
- '96 EX issue...
- why does my 1994 civic si...
- ??? Gauge Cluster fitment
- EX/SI Engine Problem
- Gauges and turn signals won't work
- Blown head Gasket. But..... it fixed itself???
- how do i convert my rear drums to discs?
- Not Quite a Noob
- what's the advantages of upgrading from z6 manifold to y8?
- Thermostat Hose, where to connect?
- stuck
- 96 cx hatch with ex swap exhuast help
- engine issues
- Aftermarket Steering Wheel Help...Pointers.
- Anyone remember this commercial?
- Tranny stuck in 3rd, 4th or 5th gear
- VSS not working??
- My h22 swap is on in the 97coupe
- Electrical Load Detector Question
- spoon mirrors?
- 1993 civic wont start
- speedometer is way off
- timing belt
- CTR front ends are wider then USDM non ctr front ends??
- obd0 b16a parts question...
- temp went up and down again
- del sol mugen bumper? real or fake? help
- GAS PEDAL HELP !!!!!!!!!!!!!!!!!!!!!!!!
- 92 hatch back bumper
- eg with ek si cluster. anyone got pictures
- Cost of wheel alignment?
- How to install S300 board in a P28 ecu?
- 95 Del Sol Aux Light problem!!!
- LS/VTEC Engine harness question.
- 1993 Honda Civic DX
- quick after valve adjust help
- window question
- Chocolate milk on the dipstick...Need help for 95 Civic EX
- How much for a b16 swap?????
- what are specs of 2000 si coupe wheels
- 1998 civic hx/ls engine?
- need help with axle
- Help with swapping a LS in my EG
- I need help
- My JDM 92 Civic SiR
- D16Z6 MAP AND TPS Connectors
- 02 sensor problem?
- CD player and clock aren't working....any thoughts?
- How do i go lower?
- S20 Axle Seal Part Number
- Valve Adjustment?
- speedo
- mold on radiator
- hesitation/ bogging/ burning oil after head swap! (searched)
- b20 b16 vtec head gsr tranny
- Need help and ive searched
- HELP!!! eg d15 failed for NOx HELP!!!
- Import meet in Nashville this weekend????
- Fog Light help
- rear discs 92dsedan install
- K Swap Build Thread (NEW)!!!!
- HOW CAN I GET MORE HORSEPOWER?
- cat bolts
- 92-95 body parts
- 91 4dr EX Master Cylinder on a 00 Civic DX hatchback??
- cat converter/carbon build up
- 3rd Generation Prelude Steering Wheel into EJ2? Possible?
- Car DIED!!! no power to fuel pump, no spark, no codes!!! HELP
- need help with JDM side markers
- HELP!!! MANUAL STEERING RACK FOR EM1 99 00 CIVIC SI...??
- new injectors?
- K SWAP DEL SOL!!!
- need egr help
- 92 civic brake light on dash on, but brake not used?
- gsr rear seats in an ek?
- Knock
- car jerks
- where to find these corners ???
- 96 to 99/00 conversion
- B20z
- Headight switch help
- map light/homelink
- jdm d15b vtec plans??
- FOR TRADE: Probe 84mm dish pistons for ANY 82mm low comp pistons
- v tec wireing help
- LS SWAP IN A EG!
- Frustrating Idle/Stall Problem
- first time boosting, few questions
- assembly lube ??
- How safe to drive on 3 studs?
- battery relocation.. what do u think?
- Help!!! Two of the speed sensor wires touched!!!
- need advice setting timing on '93 civic dx m/t
- 1999 Civic SI Problem :( HELP PLEASE!!
- weird noise when i back up
- replacing rear passanger side window
- any 1 got a kill switch??
- oxygen sensor in the catylitic converter
- I THOUGHT my suspension was back to OEM
- Basemap Option 450cc/440cc Input please
- droped a b18b into 97 civic...wont start
- auto to manual swap - 2 map sensor plugs?
- 98 EX Keyless Entry
- EG head lights. Which ones you find have the best out put. No projectors or one piece.
- Eg idle- Tried new IACV
- megan oe muffler??
- stock jdm d15b question??...
- Civic Eg Cf trunk... need light for licene plate? help!!!
- my new little full race 4 door project
- what suspension pieces are a must for the EG chassis???
- what bride seat will fit in my EG(H) cause im kinda fat lol
- Grinding/Howling noise Help?
- Running 390cc Injectors on a STOCK B16a
- Starting Issues!!!!!
- need help on d16z6.
- red gt3 ft/fs
- seat belt alarm
- thicker head gasket on gsr block
- What is a reasonable price for an engine rebuild?
- Can I use a bolt instead on this stud?
- side markers on eg civic
- Honda Civic 1993 swap b series HELP!
- ek rack
- eg door panels?
- quick question
- rims and things.com?
- cabin air filter
- wheel cylinder help!!!
- engine doesnt start like it should be...
- not sure on how to do this...need help please
- I hate stupid people....
- electrical problem
- Recaro SRD brackets and rails?
- 2000 4 dr civic
- stock shift boot will not fit on my h22 swap
- how much LOOK
- shoft shifter install
- JDM doors on USDM. will the power windows be able to work look within anyone
- B16A in 95 ex problem...
- itr hub conversion?
- EK brake locked with gsr set up?
- Pic request JDM DEL SOL SEATS ALL BLACK
- civic starts but stalls right away
