View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Maintence Q's
- how do you guys get the air out of the cooling system?
- idle stumble under load(a/c)
- help new memeber!!!!!
- torsion mount question
- Header installation, O2 sensor?
- battle of the d16 blocks: d16a6, d16z6, d16y5, d16y7, d16y8
- oil light...
- Help with fixing car, What is this piece called?
- NEED HELP!!!! WHERE IS MY PCV VALVE. D16Y8
- Need help wiring my M3 Mirrors!!!!
- will this fit?
- Need help diagnosing problem...
- (quick help) is it me or...
- anyone know where to get the egr valve block off plate?
- Gear Ratios
- toggle activated vtec
- b16 computers
- lower main question....
- ecu problem!!!
- dyno in or near MA
- Car Won't Start Some Help Please
- 96-00 Newb Questions
- how do you fix an exhaust leak?
- is Midas trying to screw me over?
- Spark Plug Question
- starting prob
- Question on GSR Swap
- bring my power steering back to like
- Compressed thickness of OEM Headgasket??
- pics request jdm eg sir(white faces) at night
- 99-00 Si complete brake swap on EG, what exaclty do i need?
- Spidir your
- Still have running problems with the EG6. Help required !
- PLANNING TO CHAGE BELT/PUMP
- any ideas?
- Upper control arm install
- 96 climate control....
- internals on high mileage motor
- V-AFC
- F/S 96 hatch 4500
- ratchet size for vss
- new distributor, car wont start...
- Car bogs and now runs like crap... HELP!!!
- Chipped P28-> P08 (JDM D15B Swap)
- Compression on a b18b dont make sense
- Remanufactured axles....
- will 195/60/14 fit on my civic wothout rubbing??
- How do you shave letters off the valve cover
- Theives suck.
- Mid section for exhaust..
- 2 Step and 3 Step
- Car won't start, fuel pump not priming.
- Why is my Car misfiring/sputtering?
- overheating
- sunroof drain tubes? Rear floor wet during rain.
- M3 Mirrors?
- Interior painting?
- help a blazian brotha out
- APEXi S-AFC 2 on D16y8
- transmission
- is it totaled or not?
- PLEASE HELP! Unable to power up HID. Wiring?
- 98 ej6 st sway bars f/r
- i have been using an LS ecu with my b20 motor, it ran fine!
- code 22 , change the oil pressure switch or entire solenoid ???
- Are these ITR cams judging by the rings. Plus other questions
- ej1
- 95 civic si b20vtec idle problem
- Strut bar, pillar bar, H brace, Floor bar, etc.? Stabilizer bars.
- anyone know what kinda rim this is? pic inside
- aftermarket alarm install
- STOLEN CAR----NORTHERN VIRGINIA----DC AREA
- another tranny fluid thread! lol.
- citylights in usdm eg headlights?
- headlights wont work
- Post pics of your clean motor here
- ls question on o2 sensor
- turn signal going buck
- Adding a remote (electric) trunk release to your Del Sol
- jdmshit vs kenji chip for h22a with p28?
- Climate control in an eg6.....
- Wiring question........
- SiR-G
- SS Brake Lines - Useless or Useful?
- boost gauge question
- Searched to no avail: B16A question
- Need a set of good brake pads - Suggestion?
- Anybody interested in helping me do a wire tuck?
- help ... reputation of prostreetimport
- rear disk brake dustshields- ? on install
- LS VTEC
- i need your help!!!!!
- Suspention mixing and matching...will THIS work?
- Engine that hasnt been started for a year.
- How much/hard is it to replace wiring on and 97 ek?
- at 1500 rpms car surges?
- WTB: del sol or eg
- sparkplug wires
- Signal and brake light problem Help!
- tisk tisk BigDon..
- 23mpg on 95 civic
- Del sol Power window all screwed help!
- 94 civic coupe with b16a
- o2 sensor in different spot?
- Throttle bodies, d15 to gsr
- eg with b18c
- 92-95 with d15b vtec and jrsc pulleys?
- Possiblewrong forum: 92 cx hatch JDM Rebuilt Hssa/M2B4
- This might sound stupid!!!!
- ok what happens when ur done with a clutch and u dont go anywhere in 1st gear
- WHAT IS INVOLVED???
- 17 inch Rims For Sale
- Where do ya put the Pedal locks?
- A little info!!!!!
- Need help!! running problems
- Clutch for 01 GSR
- Spoon Exhaust clip???
- Checking ECU codes
- HX or EX Timing Belt?
- USDM Del Sol engines..which ones where?
- d16 motor with d15 tranny
- preferred clutch setup?
- obd2 to obd1?
- retapping headbolt?
- HID into my 2000 si
- ex/si cluster in my dx, tach is mess up
- has your ECU gotten WET by RAIN?
- Seibon carbon fiber front fenders
- DA Skunk2 coilovers on del Sol
- black ek interior
- How involved is doing a half-shafts on a 98?
- Water leak in door?
- How involved is doing a timing belt on a 98?
- Sohc Vtec Chipped ECU?
- help appreciated to find CHEAPEST price for skunk2 shifter.
- any san antonio meets??? coming up soon
- Help findig thread
- smells like oil
- HELP!!! Clutch Problem
- o2 sensor heater?? (search is down)
- 92-95 Jdmsh*t Front Lips...Type R/Mugen...Can be ordered and put on? Or Need To Be Prepped?(Right fo
- LS into 98 coupe
- Quiet Exhaust
- b16 in a 95 hatch...easy question for you
- b16/ls
- b16 - what trans?????
- Gsr into 99 si
- Can I still use my power steering?
- who has experience with phearable.net?
- NEED HELP PLEASE I AM GOING TO DIE
- 96 Civic EX B16A2 Throwing codes 67 and 90
- EG hatch exhuast on del Sol
- Solid CEL (Search down!)
- Civic OEM CD install
- Is my exhaust manifold cracked and causing my CEL (#1 Primary O2)
- AHHHHHH MY LUG BROKE OFF
- Vtec problems stumped
- ball joints
- car height changes on its own???
- Radiator Fan Doesn't Come On
- DIY: EK (96-00) Passenger Side Airbag Removal
- Bleeding clutch master cylinder ... 2 weeks later. Questions.
- will an exhaust for a 2dr coupe fit the 4dr
- necassary parts for b series motor in del sol
- are the compression ratios the same?
- my ignitor or coil fried up again! WHY?
- Tach question
- Bench-Bleeding a Master Cylinder
- Looking for more info/pictures of this EK
- need help now asap! water pump B16b
- 94 del sol, clunking problem! driving me NUTS
- motor mount fitment
- Got an issue here! Ignition lock
- 1993 Del Slow 5 spd conversion work in a Ek?
- NO HEATER PLEASE HELP!!!!!!
- civic headlight \\QQ!!!!!!
- 1995 Civic Ex under dash tach wire?
- putting a bolt and nut in the shift linkage where the pin came out(would it work)
- Car sputtering/losing power
- Integra seats into my EK
- Bswap = Need Stiffer Front Springs?
- apexi safc problem
- SI tranny swap???
- OEM or is Autozone, Advance etc ok for a PCV valve?
- JDM B16 and USDM B16....same or different?
- 92 honda civic h/b springs?
- woodbridge area civic thief caught
- jdm del sol cluster into usdm sol
- prolly a stupid newbie question, but it's worth a shot.... :)
- si cluster in ej1
- Where to get axles???
- EG springs fit an EK?
- 2001 civic
- Valve cover question
- QUESTION ABOUT WATER PUMP/TIMING BELT
- PROPER WAY TO BLEED BRAKES ON 94 HATCH
- 94 civic engine in a 92 civic
- COMPRESSION POINTS ON STOCK CX MOTOR?
- QUESTION ABOUT AUDIO ON 94 HATCH CX
- im a newb i know
- Blinker flasher
- Y7 head on B8 block.. which timing belt?
- NEED HELP ASAP!!
- Newer stock radio in '92 hatch
- help please
- Civic redisign years?
- y8??????
- who's had adj cam gears break, what brand?
- quick question about tranny
- MAKE MY CAR LEGAL PLEASE
- HKB hub adapters
- fet quick release
- about quick release
- EG GSR sway bar install help
- Best website to buy a motor
- hid kit for jdm headlights on a eg6 W/ a H4H bulb?
- Will 92-95 d16z oil pan for a 98 d16y8
- NEED A CATALYTIC CONVERTER CIVIC
- --{SI Gauges in EG}--
- Yet another problem taking out my dash...
- SideMarker Installation
- wire harness help!!!!!!!!
- Reverse light backwards on 92 honda civic
- swap ???
- motor problem
- mirror
- suspension question
- CHIPPING ECU'S AND CHIPPING KITS
- S.D. heads need parts ill get you whatever delivered
- changing crank?
- TURN SIGNALS, SPEDOMETER, TEMP RPM AND GAS GAUGES, HAVE DUENCED!!!
- 98 civic exhaust
- automatic transmission shifting
- jdm civic ek4 climate control?
- code 43 and the engine cuts out what could it be??plz someone help out
- Question about rear disc conversion on 97 civic coupe
- Code 16 - no code 16 before 6500rpm but after it hits. vtec does kick in.
- 98 Ek trunk latch?
- Mugen Cf48 rim question
- looking for a pic of a dark green eg hatch.
- How do you remove the EG steering wheel? Search turned up no results
- piping question
- Strait Pipes / Test Pipes
- Rev Limiter
- Turbo SI pics
- I need some real JDM headlight for a eg
- I got MONEy who has a turbo
- need an answer very VERY soon... before i buy something.
