View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Cx Question.
- Anyone know if any sensors are affected by MAGNETS?
- electric cord from the block?
- need help installing a spoiler
- what could have cause my ecu to burn up like this?
- Oxygen sensor question
- Can someone verify this information
- Question For a Friends Del Sol..
- jdmcarboy ek sir bumpers
- axle question
- crank TDC
- Civic H.O.P Audio/Empty Slot Center Console
- quarter mile
- H22A into a 1994 Civic EX Searched.
- high flow mufflers
- exhaust question
- S2000 Gauge cluster in a 98 civic
- wats the differense
- Anyone know a good place for oem bumpers?
- Has anyone had any problems with their low beams?
- Engine swap for 93 civic dx
- Neutral to D4 - Trans/Gas problem
- weird timing problems with a ls timing
- S/C in EJ1 zc-1.6 vtec need coolant hose diagram
- d17a1 head gasket
- will a 92-95 si gauge cluster fit in my 94 dx???
- Mugen Knockoff
- HELP!?!?!?!
- tdc crank cyl sensor ?
- Help, Throttle Body Coolant Lines
- Tein S-tech springs..?
- EG hatch duckbill
- engine swap
- 94 civic ex with b20b having trouble....help
- need help solid check engine light
- civic type r and integra type r
- LOCKED MY KEYS IN MY TRUNK!!!! F#$@#%!!!
- tranny question
- Need help!!!! what does a MINT EG body go for.. IN/MI/WI/IL/OH
- just completed my first swap (d16y8 into eg) but very confused (iacv) still searching*
- MPG Engine swap: DX chassis VX engine?
- d16y8...ITB's?
- primary and secondary ob1 and 2 civic 4 wire o2 sensors same?
- need info on people who have already done this
- Knock Sensor D16Y8
- Spark plugs torque B16A2
- what's the best for this
- K24 w/K20 head question
- testing waters with my eg hatch.
- EG chassis feel my pain
- Distributor Problems
- ls/vtec eg with no ac....should i use the ac/bracket or not?
- Motor mount problem.. PLS help..
- vacume leak...
- Tear down and rebuild of my EM1 (Pics inside) Other car pics..
- Anyone using Civic Type R springs?
- low idling
- what P/S pump for swap
- 93 cx hatch -- swap questions
- D-series has 2 different kinds of L bracket ?
- WTB: 1992-1995 Civic EX/Si, DX, VX shell
- intercooler piping
- 99 D16Y8, (OBD2B engine in OBD2A car) question!!!!!!!!!
- newbie in here...need help...
- performance header for 180-200whp?!..
- all coolant leaking out right when i pour it in
- One last starter question
- How to get climate control out?
- HESITATION!!! Can anyone help figure out why???????
- It Happened Again....Thieves
- what kind of time do you think i will run with a b16a in a 92 civic hatchback dx with lsd in the 1/4
- in need of parts (help)
- is there a squad for this?
- CIVIC HELP PLEASE!
- Motor blew... swap coming n need some insight
- eg climate control
- lost keys and pager!
- Civic With GSR Dash... No Key???
- Ebay (Thunderbolt) Spun Cat? Good/Bad?
- Civic Picture Thread!
- Picture thread?
- Engine Hydrolock?
- how much could i get
- 00 Si High Rear Brake Wear?!?
- Rear Suspension Problems on 99 Si
- Things to fix
- Aluminum Radiators
- s2000 into an eg
- 99 civic trouble code
- big problem with rear drum, need help finding new one!!
- Motor Dies After Rebuild
- EG cluster question
- Catalyac converter????
- Door alignment help
- difference between H&R
- Help plz
- Gsr swap what radiator hoses do i use?
- Problems with Avid rear mount H22 in civic
- WTF this is gay
- Any pictures of phantom grey with bronze wheels 15's??
- Intake CEL
- B20 Block...B18 or B16 HEAD????!?!?!?!?
- Post your offsets!
- Another ls/vtec questions & concerns
- Tranny troubles on a 98 civic ex
- WTF!!!! yo i need HELP ASAP
- eg hatch or ek hatch?
- Ls Vtec Question??????????
- turn up boost or not?
- Eg city light wiring question..
- climate controll ?
- slave cylinder 'bracket' issue with b16 swap, pic
- Civic running really rich after Ls swap..
- CA turbo?
- Crome and ITB ???
- VTEC QUESTION NEED HELP AND OPNIONS
- whats the torque specs and how to adjust drum brakes
- [OT]How do I post in the marketplace ?
- B18a1/b18b1
- vafc II
- turbo
- car won't start
- pic request: has anyone got pic of em1 w/ eg fog lights
- Is there a diff between 99-00 SI and 96-98 DX SPINDLES?
- Exhaust Piping
- Let the build begin
- Good Venders?
- what do i need for a d16y7 obd1 conversion
- how much faster would hondata make my stock ls hatch
- Cleaning, painting, semi- wire tucking. EM1 need opinions.
- Need advise
- what it takes to run 14's with a D15B?
- Headliner 97 civic EX
- glove box ????s
- Question regarding Fuel Economy on b16 del sol
- Looking for an opinion on a car...
- Question about frying my starter
- slave cylinder
- GSR distributor question= me nub
- loss of power when tach drops down
- What Next?
- Heat problem, quick question
- aftermarket adj. FPR?..
- Exhaust Question
- civic catalytic converter/exhaust size ?
- mini me distributor problems
- is this what every thing I need for my swap?
- a/c problems
- blown timing belt repair: What else could be wrong? Cheap fix
- Oil fluctuating!
- URGENT) Putting stock springs on my car
- IS THIS A BAD BATTERY??
- Civic Driveshaft
- can someone do me a favor and give me these measurements form a DC reat tranny mount bracket
- brake upgrade question. DA fronts onto EG?
- where to find cheap jdm parts lights, seats etc..
- jdm eg8 gauge cluster problem
- Flexplate/Torque Converter Question. HELP!!!
- blown motor :(
- HELP got a problem
- info on trial users
- Anyone local to Quincy, IL? I need your assistance please....
- distributor problem or what? HELP!
- How to check your tranny fluid on a 99 civic si
- Tranny code? what tranny is this?
- Steering Wheel compatibility
- civic door handles....
- Shift linkage problems.
- I need Del Sol Seats
- Head lights
- DTRL how to?
- Comptech??
- shifting
- CEL code 21 and 22 Vtec- HELP!!
- Single Slam The video 12s sohc
- HELP. Smoke in Vtec?
- how to check codes, sensors?
- My new Ride!!
- noob need help searched everywhere help !!!!
- spedometer help
- need help with 96 civic head lights
- Del sol guage positioning
- acl bearing kit ?'s
- S2000 Gauge cluster in 94 civic
- OBD1/OBD2 Ecu's with knock sensor?
- head stud / bolt question
- rear disc conversion for ex 99
- HELP! my civic cuts out at high speeds! why?
- EG6 sidemarkers placement
- Piston rings
- b16a swap wire harness (?)
- Speedo connection help..
- Question: D15b2 block with D16z6 Head
- Auto Turbo
- throwing code 6, 10, & 14 after B16A2 swap in 95 EX
- Help Needed..I need a ROTOR that will fit a JDM DIZZY!
- EG hatch dash help
- vtec not kickin
- Rear disk on Ek?
- whining noise, coming from timing belt area.
- 99-00 front end on 96-98 coupe.. Fitment issues w/ bumper
- One little question...
- What do you guys think?
- fuel map for '98 b18c1 w/CTR cams
- exhaust question
- Need Help With Hooking Up An Air/Fuel Gauge To My ECU!
- please take a moment to look need some advice
- did a pull and lost some lights. fuse blows.
- Couple of exhaust questions for my 98 dx hatch
- -----NEED HELP BUYING TURBO KIT!!!!
- Question about fuel tanks
- ecu pin out sheet
- Car stall's out when low on gas??? HELP!
- How long can you leave an alarm on?
- I Need tire/steering wheel help
- Tuning with Aem compared to Hondata s300
- will a h22 fit in a civic/integra/crx??
- fan switch sticking
- swap shifting trouble
- Coolant boiling out my Reservoir-Please help.
- Weather - 1, Turn Signal - 0
- Help With JDM Rotor!! Can't Find New One....
- no map sensor?
- D16z6 to JDM d15b?
- pw jdm whale penis sound clips
- my list
- location of pgmfi on a 98 civic
- 95 civic dx b18a1 swap
- what ecu should i use for my car
- Ls tranny Linkage
- vtec pressure switch ground?
- steering wheel options?
- how can i tell what transmission i hae?i bought a
- help with dizzy probs!
- New Axle Play?
- about motor oil
- Civic hatch shifting problem plse help
- how do you load pics?
- Huge Parts list 92-95 civic!!!!!
- Returning check engine light - Please help!
- What do I need to do for this motor to fit in my car?
- More info about radiators
- b16 shift linkage
- 96 civic ex Throttle body Vs. 00 civic Si TB? help
- code 500 today
- chep engines
- HELP!! VIN#!
- Z6 Intake manifold and coolant return
- swap troubles
- ITR pistons..?!
