View Full Version : Honda Civic / Del Sol (1992 - 2000)
- b20z in a hatch
- one motor sports got raided?
- EP or DC5 steering wheel into the EG
- boost bottom end?
- carsound cat for $49
- eg6 civic sir
- sohc port and polish
- auto to manual tranny?
- ek cable or hydro?
- where can i get some good stock 92 civic axles?
- anyone with d16y8 head pics? how do you know if a head is vtec?
- what size/ part # bulbs for the climate control? jdm city lights?
- part #???
- Broken gas pedal?
- My intake keeps.....
- 200 civic: reset ecu after disconnected battery?
- Check Engine Light question
- Heat Wrapping My Header...
- Codes, Fuel System stuff? Need help!
- How much improvement should this guy see?
- Tech ADVICE!!!
- Whos the......
- Looking for exhaust gaskets, can anyone help??
- car not starting, need help.
- Jdm vs. Usdm
- 94 civic HB with GSR, what intake do I buy?
- I need info on swapping a b18a1 into a 00' cx
- Whats a good Service Manual for EG??
- HOW TO: SHAVE AND PAINT VALVE COVER (56k? don't think so!)
- need help with O.E.M. fogs on EJ
- Any DIY want to do an auto to 5spd swap
- sohc turbo kits
- 99-00 Si ECU pinout??
- d16y7
- jdm motors and vtec pressure switches??
- suspension for 92 civic
- brake line question?
- any one no what time the 2004 subaru sti does the 1/4 mile in
- my baked lights
- Hx rims on eg with gsr brakes who has done it????
- Tech Tip - Chipping a OBDI P28/PR4/P06/P05/P91/P30
- Drop in K&N or CAI
- T.O.O. striked again
- Best Street Tire For Drag???
- How to wire a Cruise contro switch like a toggle???
- How come I haven't had to go for emissions yet?
- JDM civic right hand conversion
- Extending o2 sensor wires
- Will 92-95 civic suspension fit on a 00'teg??
- Help, My car shakes allot when it is warmed up.
- Idle at 2G!!!!
- where to get racing gas in S. California
- Anyone interested in faster ratio rack for manual rack cars?
- people come look at my car! an dont wanna buy damn on lookers!
- JDM EK folding side mirrors, different options?
- My car's first battle wound...
- I need HP from an 1.4 civic engine!
- proper way to break in a new clutch
- New user intro.
- resonator or not`
- Guess what I found in my trunk!
- Getting alignment after spring install, I may have a camber issue...Can NTB help???
- Do i need rear camber kit, or just do the washer trick?
- Chat Room for who ever wants to hang out ** i know this is off topic ***
- srd b-series crankshaft pulley
- Civic EG with 4 wheel drive!!!!
- Questions RE: 1' GSR master cylinder in 96 civic EK
- which car should be faster?
- Curpier Motorsport Civic EG Race Car Photos
- I need help fast, installing throttle body on D15 del Sol!!
- KYB GR2 or Tokico HP(blue)
- Tire size...
- swapping transmission on eg
- ugh more theives
- Check engine light coming on 99 Si, restricting RPM to 6500 help!
- EK Shifter fit in EG linkage????
- LoOkInG FoR CaRbOn GrIlL fOr Ek?
- Went to get the resonator replaced yesterday....got a crappy suprise.
- Installing Apex WS on 99 coupe this weekend...
- Cold Air intake on Eg! Tire hitting splash guard when turning. Anyone else? 2 Pics!
- running rich with stock fuel system... little help please!! :)
- pic of n1 tilt
- What are Unorthodox Pulleys and what do they do?
- Rear disc swap + adjustable camber
- Tranny Leak Question (I did a search...)
- Front Wheel Bearing Install!!!!
- how do you tell if you have real jdm corners?
- gsr tranny
- skunk stage 1 cams w/ turbo
- 3G integra Suspension on a 5G hatch
- 97 B16a into 92 VX
- How hard to change timing belt?
- Fuel line bleeding?
- result of theives
- 92-95 Hatchs running Apexi Dunk...Need pics...
- Super n00b ?
- Cleaning CAM Covers
- Pics of 92-95 HB interior....
- Pics and a tech Q?
- N1 exhaust cheap!
- Opinions wanted on cam for D16Y8.
- Veilside kit shipment times...?
- ETA times...anyone but mostly EK w/gsr!!!
- blinker help
- wich are the best brake pads
- Any advantages in the JDM Type R SRS steering wheel other than looks?
- Ex / Si Tranny question
- retard timing?
- aftermarket headlight bulbs
- Steering wheel shakes @ highway speeds!
- Recommend any good bodyshops in S.Cali?
- stock si exhaust size
- PIC REQUEST: eg hatch dropped on eibach sportlines and apex' N1 cat back
- Neuspeed Race ?
- tein damper adjustment
- How to: Installing 92-95 civic projector wiring harness...
- Hit A Hydro Pole
- 92-95 Hatch's-Anyone else's rear window rattles?
- New digital camera = new pics of car, plus a tech ? (56k no)
- swapping into a cx, help wire 02 and vtec!!
- B18C swap??
- Alarms? civic owners u got good ones?
- Can someone give me tech on dome light for EJ?
- idle surge?
- looking for info on MSD Window Switch
- strange sound when turning
- Question about H&R Sport Springs i ordered.
- Honda Civic that.......
- Good price for HX wheels?
- My '94 honda civic lx
- tranny gearing and clutch fitment
- Pics of the B16 CX
- steering problems
- Tein SS on EG ?
- building and EX
- b20 swap route; need advice
- I need help with exhaust please
- Tranny Q, please help
- which cat to buy?
- is it worth it?
- side effects of running a shot of NOS
- how to swap a b18c1 (gsr) into a 92-95 or a 96 hatch
- Airbags
- Question on back up lights and car running rich
- For anyone that has JDM Stanly lights on their eg, help!
- Video of my Turbo EG
- what is needed for a 5 lug conversion on a 99-00 coupe. Pics if anyone has????
- Did a search...Need help on late night project quick!!(Cluster removal)
- fiberglass doors
- EG Seats
- Airbags.... how much do they go for?
- best EK4 replica spoon lips (did a search)
- b16a -> 1.8L with adding crank, rods, and pistons?!
- Koni Struts
- Idle problem Please HELP
- b16 TB install to d16 intake mani. question (spade)
- Post pics of ur egg
- Boot Leak Problem? and Oil Leak? Help
- which cat back for my hatch
- RSX Shiftknob in Civic Si (99-00)
- Can I have a Carfax Please!!!!!!!!!!!!!!!
- ITR or GSR is there any difference in the Clutch?
- 3rd gear grinding?
- ecu ground?
- N20 w/ VAFC
- 00 teg auto to manual
- Is my friends car a 1.5 or 1.6.
- manditory upgrades for adding a bottle?
- 93-94 Del Sol leakage problems
- N1 style Mufflers on ebay
- Anyone got views on universal N1 style mufflers (fake) on ebay?
- Japanese 94 SIR hatch
- Weird *creaking* sound coming from suspension
- How to make 2003 civic SIR seats sit lower in a EG
- Got my throttle body today!
- no idle when it's warm??? somebody know???
- aem CAI v2 eg b18c
- Difference between header piping
- Bad shaking in h22 eg
- Anyone Have pics of Apex N1 exhaust on a 96-00 coupe?
- Q's about after market fuel pressure gauge..
- stock trailing arms?
- DIY/HOW TO: Rear Strut Bar - 10 Pics - 56K Friendly
- Changing the Hub
- FF-SQUAD WEBSITEZ 05-15??????????????????
- HELP. aem filter.
- State Ref visit, need some help now...
- Gauge cluster swap success--1 problem though...
- another cv joint/axle question
- Shipping out the Lips
- Where is the cheapest place to buy JE/SRP Pistons
- Going to look at a 93 eg sedan...
- LSD question?
- Loose door
- Mirrors
- Quick question (already searched)
- hood wont close with b18c in 93 hatch
- Need help!!! Emissions Guru's..
- what is the engine code for del sol S model?
- Ok I CANNOT get the drums off my 99 civic.
- Need A wiring diagram for 92-95 civic projectors...
- JDM ITR Pistons questions
- Will a Cat help quiet my ES muffler??!
- New Pics... More Cars.... (56K NO WAY, 18 Pics)
- 92-95 Airbag Question
- How do you remove rear spoiler/wing from 92-95 hatch? And...
- EMERGENCY help!! wiring a 99 SI engine harness to a GSR swap...HELP!
- Strange Rattle coming from driver's window
- Cheap strut bar
- p72 OBDI into EG TECH may help you out.
- biggest size wheels with front camber kit?
- How to chip and ECU??
- Rotor "cracking" question
- Lowered Alignment...
- Help! My car is having trouble with emissions inspection!
- 240 air box
- Trouble code help - fuel delivery
- Wiring a 99 civic SIcluster in my 98 DX(already searched, please help!)
- Has anyone converted their 96-00 EX motor to carbs?
- STR can gear help
- SAVE or LOAN for gsr
- odd power loss
- callin all 4dr's.....(pics)
- 7th gen ?
- Suggestions for Audio system in 00 Si trunk>>>
- Speedometer or VSS problem?
- Will a MOMO steering wheel hub work on my 2000 EK?
- Post pics of your Gauge Pods! Getting some for the Eg!
- Rear Wiper Removal on EH3 Si.
- How would a 92-95 civic hatch drive with a h22a? Any comments or pics?
- What do i need for Cruise Control?
- Non-Tech: 92 Civic with 600cc Yamaha motor
- sway bar
- hey everyone
- Help:93 Civic EX will not start if temp goes above 80 degrees
- My poor civic......
- what computer can i use?
- JDM B16 engine
- EK sunroof malfunction
- Wheel Clamp?
- Brake Pads 93 cx
- alignment question
- [FAQ] Tie rod end removal
- conversion harness picture 99-00
- 92-95 civic owners,ne1 else have the dimmer switch problem? how 2 fix?
- header for b18b in hatch
- Paint Shops in No. Cal S.F. Bay Area
- Air restrictor ?!?
- Carlisle Del Sol Meet!!!
- Pivot earthing system...Cant read Japanese, need install help.
