View Full Version : Honda Civic / Del Sol (1992 - 2000)
- HELP please 96 civic 4d transmission light flashing
- B-Series Alternators Interchangable?
- State ref ticket! positive input always a +
- my optima battery just died wtf!!!!!!!!!!
- Knocking coming from engine bay
- need help with 95 GSR cluster in my 95 civic
- cancer on my car...
- does a 98 civic ex cable reel fit a 93 civic ex?
- i got skills, i got game YEYAAA *gangsta voice*
- S2000 Seat's in 2000 Coupe....
- b16 block gsr head what timing belt to use
- what better b18c1 or b16 from the si
- will a chipped(xs ennginering)d16y8 (stock)take 8000rpms safely
- tires for rain/dry weather
- Bumpers of a 98 and 99
- d15b questions...
- GSR tranny problem EXPERT KNOWLEGE NEEDED (swaped into eg hatchback)
- 95 Hatch...Magnaflow Cat Exhaust System...Hi Flow Cat. Converter?
- will this obd2 plug fit on an obd1?
- quick question about 96 civic...please help
- complete 92-00 engine swapping guide
- what areas on a civic should u add ground wires..
- what clutch to use
- REAL MUGEN FRONT LIP QUESTION???
- please help!!
- Not to be a noob but..........(Pucture Thread)
- Help with B-series motor mount
- question
- will 1999 integra type r calipers bolt onto 1997 civic cx steering knuckles?? help
- real quick question do all EX's come in Vtec?
- del sol front sway bar?
- mud guards vs. splash guards
- Gs-R rear sway bar fitment on del sol
- power problem
- OK Car wont start after valve adj. and fluids?
- hx rims wouldnt fit on my car? wtf?!?!
- How to install EG6 rear interior....
- Car making clicking noise when turning!?!
- Still loosing power to one cylinder it seems.
- gsr swapped si annoyin revs
- Water damage in engine
- Ebay projectors..?
- Where can i find civic mirrors?
- What version of OBD is in the 01+ Civics?
- 2000 Civic Hx coupe
- Y8 tranny on Z6 Del Sol engine
- how much can i mill a head, to be safe
- I need some help deciding
- new suspension bumpy harsh ride agx ground control
- Mugen twin loop question.
- Stock Compression test numbers?
- Headlights? 4200k 8500k???
- mini me
- symptoms of bad cylinder walls???
- Need help
- 97 ex civic rich
- Thanks to Tony Jackson at WWW.JHPUSA.COM
- EJ7 rice grille??? with pics of car too
- flooded si motor? help!!
- Is there a shock strut mount kit from honda parts available??
- 02 civic msd ?'s
- few del sol videos
- Have radio code. Dial In. Wont work!!
- Canadian 1995 civic 2dr DX does it have air bags or not?
- first run with castrol syntec 0w30....
- Volk TE37 Fakes
- d16 swap to b16
- Question for all the veterans
- JDM B16 into a 92 Civic VX; Need wiring info.
- 95 del sol won't start.
- Ek air o2 sensor..
- p2e ECU
- why is my idle all weird
- My '98 Civic Hatch (DX non-vtec D16Y7) is missing at different RPM's...
- Cold engine problem
- Quick Exhaust Question
- best shop in Northern Cali?
- mastercylinder issue
- stock dseries crank pulley sizes?
- b18c1 TURBO vs. H22 euro R all motor
- Honda civic headers
- does vtec-e valvecover work on a z6?
- can an inline fuel pump make the car run to rich?
- anyone know where to get a preformance ecu and destirbertor for a d15 japan motor?
- header questions
- put in new O2 sensor but still cel
- Ls/v-tec turbo OR GSR/v-tec Turbo
- d-series tranny ?
- header torque specs
- throwing ecu code 1
- Free Korbach Frame Locks & Beta Testers Needed
- Please hepl (weird noises)
- h22 eg
- My RPM GAuge (Auto gauges) 5", Not Read Correctly in Civic 2001
- Can i use my new clutch in my 93 dx when doing a si motor and trany swap?
- 02 vw turbo for free what should i do
- fireing problem
- 99-00 Si fog light kit switch: Which wire is signal??? *PICS!*
- ECU question
- little plate thing on the dash
- should tie rod dust boot have grease in it
- gauage cluster
- idle problem with my 96 EK
- extrude hone porting a stock IM on B16A2
- Auto transmition question (I know 99% of guys in H-T have 5spd but if anyone know please help me out
- Jegs Fuel Pressure Gauges for Honda
- Trial Period: Moderator asst.
- Idle Surging.... FITV question???
- changed injectors and now more problems
- Engine spuddering
- Let's all help improve the forum
- new development.... rear disc swap
- Eg side maker wiring
- bad clutch
- strut tower bars
- How much weight would this remove?
- What motor mounts to use?
- Jumping Idle b18b
- Ripped boot, not CV boot tho
- Two questions
- Turbo my d16z6
- bearing or spindle problem??
- Question for B16a2 experts
- 99-00 civic p2e, p2t etc...
- Might pick up an EG shell. Got questions though.
- front end
- is my lsd shot?
- Oil pouring out on Swap, help?
- jrsc hondata install help!!! Is this injector harness compatible with 99 my civic si?
- Integra Arm rest into 92-95 civic?
- ES Oval Muffler Clearance
- Vented carbon hood plus rain, any experience??
- Fan isn't working?
- ECU upgrades for low $$$
- master cylinder size???
- Did we do this Compression test right? **Vids / pic inside**
- Torque specs on 1.6 VTec head.
- Can A distrubtor effect gas mileage?
- Not sure if engine is sitting right
- Poor mans type r?
- Power Steering Pump
- '99-00 Canadian SiR Color Question
- y8 motor mounts fluid filled?
- Source for OEM UK Honda parts.
- 97 prelude radio
- Maintenance Required in 99/00 DX
- Removing Sideskirts w/o Damaging them?
- What do you think about this setup
- for the socal people
- what could a bad iac be
- cel 43
- EJ7's stance FIXED
- what did they make.....?
- how to tell if an ecu is ob1???
- Should I Be Concerned About Buying These Springs?
- my EJ7's stance
- eg foglights install into stock bumper (template needed)
- Supercharger problems
- recaro srd black w/ color center
- which is better a h22 or gsr for the eg
- Any reason to NOT use all OEM seals/gaskets in head rebuild?
- carbon fiber hoods fadeing
- My JDM D15B swap pics , and a few questions
- swapping dx gauges for si gauges
- pr4 vs p75
- 99 civic si problem
- AEM bypass valve install on a 93 Civic Hatch [ looking for photos ]
- B16a2
- ????? Which Evap Purge Solenoid for Swap ??????
- 94 civic ex problem?
- swap info
- tranny
- roof is leaking
- D16y8 Comp Cam ???
- H22 in EG axles
- Rigging the OEM cruise control switch *pix*
- just got a intake
- naming.............
- Will 02 type s eibach coil Overs fit on my(98ek)?
- My car Dies or Bogs out when I go on the gas !! Help
- tips for a turbo eg
- keypad killswitch
- cel code 16
- noobie question of the day...
- help with EG and shiii like that
- si Tail Lights
- Any FAQ on how to drop engine?
- would stage 2 crower cam(sohcvtec) be over camming the car
- Bulb size anyone?
- Help!!!!!!!!!!! CTR Headlights on a EG
- 97 Ls Tranny Help Please!!!!!!!!!
- Looking for so cal shop that sells trannys?
- EG Hatch Fog Light Bulbs???
- D15b8 not cat!? exhaust question
- just got a gsr swap what's your header of choice
- horn not working.. and SRS light is on
- Fuel pump assembly
- Supercharged Civic EX
- Rod Knock or Piston slap?
- My EG project: the good, the bad, and the nightmare
- Gas tank light indicator doesn't work
- questions about puttin D16a6 head on a CX motor
- hi my ee9
- Water Water Water
- Turbo Timer
- B Swap.....
- How can you tell if its a b16 tranny?
- CEL 1 - need help. P0131 code
- EG Mirrors Fit on EK?
- Valve Clearance Adjustment, now car doesn't start...
- Koni Yellow Question
- B series swap or turbo D ?
- Spark plug wire positions - need real help...
- EG CIVIC FITV HELP NEEDED i need a pic of the location of the EG FITV
- wtb:hks axleback for dc2
- O2 SENSOR WIRING
- Driver side doors leaking..
- CEL 10 help please. new gsr swap.
- Correct Suspension
- Stage 2 Crowers camshaft users..."Question"
- questions on D15b
- swap
- d16y8
- My moonroof only opens halfway *help*
- IACV not working ?
- car won't start...HELP!!!
- Fake J's on JRSC????
- slight hole on brake booster, right below MC
- Knock Sensor Wiring
- ls vtec swap in 94 hatchback
- help!i can't remove my headlights off my 93 hatch
- Quick ??? IJ have search with no results!!
- How do you take out Stock EG steering wheel?
- READ INFO ABOUGHT GAUGE CLUSTER
- 99 Civic Si Ignition?
- Broke rotor stud that holds on lug nut, replace whole rotor???
- Im new but I need some help!
- random misfire in all 4 pistons ... ??? please help me
- OK rust vs bad rust
- XSI?
- CAR WON'T START! AND NO CHECK ENG. LIGHT!!!
- Calling all JRSC SOHC guys:
- manifold swap ?'s
- EK hatch problem!! GSR solution??
- HELP PLS CAR WON"T START
- Falken Hanabi wheels. . .
- Amber corners... for eg9?
- I think the seafoam hurt me?
- rattlin and squeekin noise
- New Civic HAtch for me
