View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Whats the darkest you can tint your car and be legal?
- Info on P70 Ecu please
- car stolen in so-cal -escondido-please read.
- spark plug wires?
- B20 Block==== Need to do the CR-vtec ASAP
- 92-95 manual to auto climate control swap (and a general hello)
- h/i/e
- Installing JDM power fold mirrors mine look different than inst.
- Adj Camber Kits?
- Armrest for Ek 96-00 is there a soft top swap for this?
- 92 to 95 civic with abs
- fenderwell lining?
- Final pics of interior/integra dash/door fitment...
- automatic reving?
- Foglights dont work
- right hand drive question//////////&looking for front clip for eg
- how much do u think i can get for my del sol?
- need STOCK del sol 1994 wiring diagram!
- replacing suspension bolts
- y8 and z6 cams interchangable?
- Which bulbs do you change on EK cluster?
- 93 del sol exhaust
- EG cluster plug question
- What bolts are needed to install AC Bracket and Tranny Mount?
- $100 bucks for all windows on a civic tinted, good deal?
- A/F guage showing lean after tranny swap?
- Locked out of gear
- nsx calipers on an eg
- adjusted valves... car is louder and idles harder
- itr suspension with aftermarket lca's
- extended wheel studs?
- please HELP A.S.A.P. - Head Light / Tail Light problems
- Yes another Noob here
- interior question
- jdmsh!t Fenders?
- 99ex no abs converting to itr abs
- SYLVANIA SILVER STARS - Which to get?
- Jdmcarboy seats question?
- Look what happened to my baby
- Power steering question
- need to see pic. of 93 civic with 17"
- MAP sensor not on Firewall and not on engine bay harness, HELP!!
- Eg itr w/ 99=00 civic si rear disk conversion
- Engine Surging at idle
- Any one no how many litre in a full tank in a 93 civic dx? (Fuel stabilzer )
- Fan Switch
- OEM style fog lights from JHPUSA
- need help with a fuel pump issue
- ITR steering wheel
- Braking System Swaps
- Thermostat question
- i got a code 41 on my p28
- Quick Linkage QUestion
- starter wont crank over my motor
- type r sway bar conversion
- Alternative(s) to the cheap made OEM plastic screws??
- b16 AICV
- Test my p30 ecu?
- I'm looking for the JDM EG fog lights made out of CF. Have you seen them?
- Nitrous install on d15b?
- >>ITR rear seats in a EK9<<
- Fuel Problem
- quick intake install question...
- valve adjustment needed?
- 92 civic dx underdash fusebox wiring issues..
- skunk2 lug nuts..
- Cheap estore parts / S4C
- 00 type R swap in ek smog question in ca NEED HELP!!!!
- Confusion about exhaust piping...
- EG bumper removal
- timing with an aftermarket cam gear
- Help, 93 civic will crank but will not start.
- Exhaust and Rear Bumper Advice
- 99-00 Si Carbon Fiber Fog Lights
- Diesel Engine Transplant
- Throttle body?
- civic involved in a crash on drivers side - cant open hood - cable appears broke
- anyone with 99-00 civic si cluster? (searched)
- looking for fuel filter,pump,etc
- Horn doesnt work
- 1992 civic hatch dx 250k: Part out or sell as is?
- When axles click
- 1992 civic parting out v.s. selling whole thing
- low idle after warmup
- del dol suspension compatibility
- post your pictures of headlights painted yellow?
- internal parts for a eg5
- Question about distributer and plug wires, need help PLZ
- How to change out E brake handle?
- Another help car wont start thread...
- Question?
- FS: KENWOOD IN DASH DVD PLAYER
- Leak or condensation? Please help!
- Very Low Mileage on 98 Civic
- Repainting exhaust
- Clunking Noie when hitting the brake pedal???
- my car is farting...
- is this header for a d series?
- 95 del sol options
- del Sol exhaust systems
- FS-Almost complet turbo kit for 92-95 civic sohc engines only (LOOK)
- FS: 94 Civic DX with upgrades
- Got a problem...
- ITR muffler on eg
- Bleeding air from cooling system,can't seem to get it 93 civic 1.6
- transmission/clutch issues
- Best wheel offset on a 2000 civic dropped aprox 2in
- EK navigation?
- car idle problem, under 3500 rpms
- hey newbie here
- Swap: OBD2 ECU & B18C1 into OBD1 Civic
- No spark whats the problem?
- map senor CEL and can't fix it
- Where the crap is my starter??
- rebuild kits?
- wtf car wont stay on
- removing crank pulley
- exhaust pipe rubbing rear sway bar.
- sohc zc vs. d16z6
- braking problem
- Just quick question on tyre pressure
- Looking for feed Back about Iceman
- Knock sensor question
- CEL code 21
- momo steering wheel + smog test
- 97 honda civic heaD question......
- Are the eg/ek clusters similar?
- i have a problem on my gsr coupe
- h22 ek
- Iceman Has A New Owner Now Bigger and Better
- Where ELSE to buy this lip (pic)
- ctr pistons
- witch engine is best for my 99 honda civic si
- Del Sol Front Conversion
- GSR Cluster
- positive camber in rear after gsr brake swap on ek
- rear motor mount insert 93 civic - how????
- ek h/b cupholder won't open and close no more.
- Loud Noise?
- Hey everyone i'm new
- quick ?
- AEM Hybrid intake have a removeable piece?
- Trans fluid question
- Old Civic - Hood won't close
- Greddy evo2 fitment
- Intake manifold?
- HELP!! no spark??????
- EK dash install/removal?
- 98 Civic: What size bulb for cluster and which bulbs do you change?
- How do i take out my oem speakers?
- FUSE HELP
- Falken Azenis
- EJ1 with ABS problems
- engine temp dont stay up
- real quick.
- relocating climate control to mold 7" in dash - 96 coupe
- How should I replace this piece?
- does any one have pics of this lip on a car???preferably a del sol
- any have a pic with bronze color valve cover in a red engine bay?
- tranny problem?
- B.A.R. question.
- looking to buy jackson supercharger
- d16 crank in d15
- Steering wheel squeaks loudly when turning left...
- Will si throttle body fit on a gsr intake manifold?
- Fast idle control
- Eg6 forntend on Del sol
- 92-95 koyo radiator cap?
- What turbo kit is best for my 1996 ex (with a jdm b-16a) swap? / Intake manifold?
- A petition for those interested in ST Corsa cam sprockets
- i need oem F/R bumpers 93 civ 2 dr
- B16 into Del Sol swap questions - not covered in the archive!
- Looking to buy what can i expect for 13k-ish?
- 2000 hx exhaust
- Need advice!
- eg hatch shell for parts
- cel 17?? vss??
- QUESTION ABOUT B17 COMPRESSION WITH CTR PISTONS
- Stearing wheel come off!
- just finished adjusting valves...now car makes weird noises
- 1997 Civic HX oil pan, D-series interchangable?
- confused....
- ICM Igniton Control Module Bad?
- Y8 oil pan fit on a Y7? yes or no and why? **SEARCHED**
- LsVtec Rev Limit???
- My 94 civic 2-dr would not start, please help
- after market radiator mounting bracket for eg?
- 1994 Civic Sedan EX Master Cylindar leakage. I've a few questions.
- Might get a ek! need info.
- 02 sensor question
- where does this go?
- dash lights problem 96 coupe
- taking off timing belt cover...
- how much to expect...
- Can I fit a header from a 94-01 Integra (non vtec) on a 2000 Si?
- Moving a car around with no lower rad support
- A/C Help
- just installed a cai
- SEARCHED!!! Civic Rear seat Question
- quick o2 sensor quesstion
- eg hatch vtec problem
- AUTO TO MANUAL THEN BACK TO AUTO?
- body kit question
- axle back exhaust hb
- How to tell whether you have a obd1 or obd0 block
- Squeeking Brakes
- Wiper Control Unit
- gas problem in a b16a3
- Where is the reverse light switch located? Searched
- bushings?
- Revved EM1 too much?
- street tuner challenge on Speed
- Dohc Zc Swap harness ?
- leather trim is it a rare
- >>ek9 fog lights and carpet<<
- GSR/Si/Rs Rear disc brake question
- RACING HART C5's...
- DEPO eg6 problem
- Transmission Problem?
- making a 99-00 Si Bumper fit on a 92-95 4Dr Civic... HELP!!!!
- radiator problem would appreciate help, thanks
- seats!!! quick answer please!!!
- omni head package
- D16Z6 - what will last longer, piston rings or valve seals?
- Driving with bad head gasket
- Manual to Auto Windows
- scratching noise when driving
- s2000 motor in 99 civic ek
- quicky... How long do d16y8 auto trannies last?
- LS swap into EG Si
- 92-95 EG swap guru's help needed
- ecu?????????
- what other civics do the 95 airbag fit?
- No power to the ECU
- sputtering
- spoon replica lip
- is it true all del sols are pre wired for vtec?
- GROSS POLLUTER... now what???
- EK bogging at WOT help?
- 93 dx to 94 ex conversion!
- racing chip 97 civic
- i could get a k20a2 block and crank for 300 good deal?
- Trouble STarting CAr pLS HELP!!!
- Driverside Door Wont Lock?!
- d17 rod d15 piston?
- just finished adjusting valves...ticks louder and harder?
- Bought motor with spun rod bearing.. what to do?
- b18b question
- Del Sol seats into 98 hatch
- reverse lights are not coming on ....any thoughts?
