View Full Version : Honda Civic / Del Sol (1992 - 2000)
- heat, but not hot
- 02 sensor question
- exhaust
- diagnostic hook up
- Help with power steering pump ona 2000 engine in a 1995 body
- Vtech problems
- NEED SOME TO SWAP ENGINE!!
- Where can I get some OEM endlinks for an OEM swaybar, and some other questions.
- Help car keeps shutting off
- low compression i need guidance :)
- Civic CX Struts
- wierd tansmission noise
- 94 del sol tranny
- ok another problem
- Dead cylinders??
- 1999 Civic EX
- IOSUA's EK BUILD.....
- engine swap
- transmission
- Piston ring top/bottom
- B16 rebuild kit.(searched but couldnt find anything)
- 00 EK Coupe Tail Lights Questions****
- coolent leaking from head after rebuild...
- Someone Help w/ Raybrig
- Cylinder spark plug strip
- I have a bad bad leak. Help please!
- getting my timming right..
- Interior del sol si lighting issue....
- what is the most GAS-EFFICIENT D-series motor?!?!?
- b20 vtec swap
- em1 radio in eg
- E-Brake Need help ASAP
- 98 civic with aftermarket header CEL Q?
- how to fix DOMELIGHT
- Bubbly water in radiator
- Car's Rpm's are racing it in the first intiatal start up.
- axle boot broken?
- E-brake HELP.
- pcv valve
- idle hop problem
- remove tie rod end
- Short Throw Shifter Question
- My delsol S
- HELP!!!!!!!!!!!!!!!
- y8 question (how mauch powa?)
- Password JDM lip
- need some color codes for some plugs. IACV, IAT
- Changed distributor..car wont start
- Code 19...
- turbo in my stock engine
- Replica Mugen lip: bad fitment????
- Would any one PLEASE help me???
- H4H Harness
- Idle/Overheat Issues Civic Si
- changing tranny oil
- automatic axles in a 5 speed
- I belive i have a fuel problem?
- Front brakes stuck. 98 DX
- NOOB Clutch fitment question!
- What are the stock Color in a JDM Headlight?
- ABS rotors
- New throttle body gasket, but now it leaks?
- NEW UPDATE TO THE CAR
- LS Exhaust On an EG
- Tein Basics Weird *Thump* Sound
- What are the odds of a bad motor?
- Aftermarket Intake vs Stock Intake
- TEIN STECH Question
- climate control problem
- rear disc brake swap. use eg6 ebrake cable?
- ls vtec problem
- front camber kit for 94 civic coupe
- b16a2 swap help
- ls vtec problem
- wierd suspension squeek noise
- coolant problem - need help
- which header
- How To: 1999-2000 Power window conversion w/ functioning rear wiper
- does anyone know if i can use a z6 head and dizzy PLEASE HELP
- 97 civic coupe power widow Q
- Need fog light wiring diagram
- car dies
- Engine speed output?
- FPR?
- do u like ur es oval muffler?
- I have a CTR Intake Cam in my b16.. What about an Exhaust Cam?
- HELP?! zc motor confusion
- combination light switch?!?! HELP!!!
- Is it a steal and does it work ? getting a new A/C
- rough idea on the price?
- 4-puck or organic clutch?
- b18a1 help
- Will this fit?
- B16 help!!!
- car bogs when givin gas and tach. flips out
- Crank Position Sensor help... Please (searched for 2 days)
- A random question
- 2.5 to 2.25 lose power?
- Making weird noise ?
- Del Sol clutch safety neutral switch
- 94-01 integra caliper and rotor on eg6?
- clutch installed no start
- power steering bearings
- life is a bitch
- [DIY] Removing Car Window Tint
- Opinions on boosting my 93 Hatch and other.................
- Urgent question: 94 civic vti, what kind of engine?
- OEM 99-00 fogs install question. Hole saw size
- A couple questions
- RED 2000 CIVIC SI FOR SALE!!!
- Main Relay?
- Looking for a quiet exhaust. What do you have?
- I need pro advice with my b18c1
- JDM Eg 3000?
- clean seats?
- What parts for quick release steering wheel
- 99-00 Front end conversion
- i need help!! need Vtec senser
- Wiring a battery switch, anyone know the proper way?
- NO HEAT SHIELD
- JRS question
- *********REPLACED VSS, GUAGE CLUSTER, CHECKED FUSES STILL NO SPEEDO!!! HELP PLEASE!!!***********
- CF hood/ hood dampers question
- del sol gsr brake upgrade
- '93 Civic DX - Reverse Lights Constantly On
- 20-21mpg... and im tuned
- No rev limiter
- Strange question
- 96 civic EX GSR swap problem!
- Valve cover grommet spark
- What oem intake for 92 Civic with B16A2 swap?
- cluch problem
- crank swap question?
- how much oil do you put in a bseries tranny?
- Boosting D16Y7
- Modify a 94 honda civic del sol
- Gift for Christmas.
- ZC intake Manifold...
- 92 CX Exahust Question
- low fuel light?
- Voltmeter stuck
- cam gaer and cam in d16z6
- Alternator: 1994 Accord --> 1993 Civic DX (will it work)
- need help finding out this problem....
- CODE 9? WTF
- A big tune up for first time....need suggestion
- trying to reach fuzzie
- a headliner question.
- obd2 mani in obd1 car...sensor questions
- VTEC PROBLEM!
- Civic 92-95 DX Hatchback EG6 rear wiper???
- WHAT IS THIS LIP CALLED?
- need advice with engine
- what do i have to watch out for?
- why cant i post?
- Steering wheel vibrate
- Do I have the Right parts for my b16 swap? please help..
- can i replace y8 head and dizzy with z6 head and dizzy in obd2 car
- small swap big problems PLEASE HELP
- My new hatch rebuild
- can you change mileage on a aftermarket cluster?
- 92 eg
- Alternative for Spoon Duckbill
- D15B in 95 EG WILL NOT START, PLEASE HELP.
- won't start when its wet out
- New to the forum
- looking for headers for sohc
- Tachometer in a 1997 Civic Dx coupe
- TURBO HELP!!!
- CEL question
- Place racing???
- NEED HELP JDM D15B NO START
- ground wires? any good?
- quick ecu question
- has anyone converted obd1 to obd2?
- how to prevent Tow hooks from being stolen?
- help what is this 19 Automatic transmission lockup control valve
- Vtech head
- 94 civic si climate control dash dead.
- Clutch issue.
- floor mats
- kygb shocks question
- Upgrades for my car
- Tranny Problem Please Help
- Header = no passing emissions?????
- Flywheel cover. Please point me in the right direction.
- coilover question
- wheel stud problem...
- b18c5 question?
- VERY STRANG ENGINE PROBLEM
- Were to get new internals?
- Strut Removal problem Frozen BOLT?
- It happens once again, car is laggin hardcore...
- airbag question
- anybody got a christmas list for their cars??
- Light bulb code?
- QuICK: What is the PERFECT tire size for 14" HX wheels??
- front upper control arms which ones???
- car revs up to 5k by itself after swap
- noob question about signals not working
- reasonable modifications for a b16 that are worth the money.
- ITR suspension.
- picking up b16 block today
- MEMBER TAG AS TRIAL
- D16Y8 Mini Me Swaps
- b16a2 mains torque spec? help please
- exhaust question
- Market / insurance value of early or late model built and modded Hondas???
- Timing, Timing, Timing..........
- the type r grill
- LCA question
- invidia springs lowering springs 4 ek
- disabled air bags & inspection??
- what causes low voltage to the 02 sensor
- Dizzy Help!
- Getting a new motor
- iat sensor 96- 98 d16y8
- does it really mess up the transmission to drive auto like a manual?
- Cable to Hydro in a Auto EG coupe?
- I am throwing code 6
- ITR Air box / intake, modded for EG's w/ B Series motors (warning, lots of pics)
- h22 questions need answered
- power loss around 4k
- chrome p28 on sohc vtec not popping
- How do you wire power mirrors into a non-power car?
- car boggs at 4,600 rpm's
- NEED ECT PArt Numbers
- What to do about type k discontinued fog light switch
- question: ctr cams; whats the difference between exhaust and intake camshafts
- why would v-tec not hit?
- whats the best throttle body for my gsr in a eg?
- ls swap in a 92 cx
- D16y8 distributor difference between years?????
- What do you guys do when approaching a stop light? Downshift, stay in gear, neutral?
- show off your drop on your car.
- Anywhere I can order wiper arms for my 00 Civic si besides Honda
- eg6 power interior and AC
- 99 si front bumber
- Anyone know how to defrost a keylock?
- 99 si gsr swap
- Greddy Turbo Carb Sticker NEEDED!!!
- Fuse panel info
- 92-95 civic how many seats
- Overheating only on highway
- 98 CIVIC EX , B18C SWAP?
- heat problem
- Transmission Bearing issue
- LCA bolts on backorder. WTF?!
- what is chamfered bearing??
