View Full Version : Honda Civic / Del Sol (1992 - 2000)
- need tips on how to remove primer off wheels
- Looking 4pt harness
- Eg projectors
- 93 Civic
- eg gauge cluster looking
- PIC REQUEST: Eg rear interior and yes I searched
- Engine Swap Help
- How do I remove valvestem seals from B16A2 - SEARCHED
- final answer re: gs-r swap
- any airbags for sale?
- Energy Suspension engine mounts
- itr manifold on b16
- What else to do...?
- 96 ek hatch dx weight
- EK 96- Honda hatchback b16a Gen 2 Questions.
- JDM b16a
- overheating 92' civic 4dr
- Mysterious coolant leak...Im so confused!
- 06 si seats into an ek?
- The Final word on 6th Gen Keyless remote
- A/C only blows hot????
- HELP: Taillights stay on
- seatbelt ?
- ES o-rings
- deck wont turn on??
- what are they and where do they go..(sensors, plugs)
- D16z6 Tranny
- converting manual windows/locks to power
- ignitor question
- Picture Request.....
- EF EG DC Steering rack swapped onto EK
- somethings wrong with my car.....can anyone help me diagnose?!?!?!?!?!?!?!?
- Attempted theft, key stuck in my ignition.
- Can Del sol parts fit on my EG?!?!?!?!
- 99-00 civic back bumper on 92-95 eg coupe
- EG Hatch/coupe rear bumper
- Highway Crackling
- Which camber kit is better Skunk2 or ingalls?
- D series swap for my sol, please help!
- pic request: bronze black or polished rota's on a red eg hatch
- looking for trade?
- oil leak coming from somewhere need help
- whats a good 92-00 civic clutch
- eg/ek?
- is this a good deal?
- 92-95 shocks fit 96-00?
- HELP!!! NEED CARFAX BEFORE BUYING CAR
- new here, need answers to a civic
- HKS Intake
- how are vtec and non vtec dizzys different?
- camber kit?
- Another DIY Door Panel Insert Project Sucessful! with pics!
- technical vtec question
- rpm guage reads zero
- what does it mean to roll your fenders?
- Wiring problem ( e-brake & check eng. lights reversed )
- horrible gas mileage
- adjusting headlights
- Will 94 Integra rear seats fit in my 99 EK?
- quick question
- EG BUMPER
- Spoon Vtec controller
- Hatch Hood on a Coupe????
- Steering knuckle spindle assemblys
- Will these wheels fit on my ej1????
- Eagle rods question?
- Gas Gauge HELP
- lost oil pressure. spun bearing.. look at what i found.
- Master Cyclinder Right..?
- Strut Tower Bars?
- cam gear question. ls cam gears fit other b series engines?
- 96-00 oem stock Jdm ek navigation unit
- bad luck with my new car
- Need rebuild guide
- Jdm lights problem
- looping power steering
- stock tire size for a 96-00 ex
- HELP PLEASE
- ball joint or control arm?
- D16 engine rebuild?
- Can u run B18C1 with skunk2 I.M. wit stock GSR ecu?
- Whats the direct site to order OEM parts from honda?
- muffler hit my LCA
- for a friend
- D16 build up 300hp?
- D16Y8 ('00 Civic EX) Gearing?
- Steering column problems
- SHIFTLIGHTS, TACHOMETERs OR MONSTER TACHS????
- Post pics/setup of your 1998 civic lx 4 doors....
- 02 sensor, TPS, throttle body....quick question, HELP!
- will these rims fit a del sol?
- need help choosing a muffler.. greddy muffler packing is coming out..
- just baught a jdm b16a swap!!!!
- **PLEASE HELP!!! 97 CX WITH 96-98 EX ENGINE HARNESS QUESTIONS
- 2 step rev limiter thru a/c output
- tyc with hid
- Damaged Hatch
- eibach springs sag
- Questions on turbo w/ Air conditioning & Full radiator
- how to make a sohc 1.6 into a 1.8?
- Cluster swap question?
- FUCKING NOOOB A$$ DRIVERS
- Differences between a EG6 Lip and 92-95 ex/si lip?
- a little off topic..
- 15x7 wheels?
- Whats the 411 ON THIS WIRE? !!! PICS PICS PICS INSIDE!
- Crazy stuff
- JB Weld and body work?
- Flood damage repair?... anyone?
- omni power rear lca's, problems? failures? other issues?
- y7 head swap effiencey questions?
- what would cause my tach to move all over the place?
- Axle replacement on auto trans, does fluid have to be drained?
- dx eg coupe with b16 no vtec!!help
- Radiator Problems
- big chubby
- Arospeed Hi Flow Catalytic Converter!!!
- Is lighter flywheel actually better?
- Need help on EX/Si Tranny code...
- 2000 civic door inserts
- Steering wheel locked?
- ZC Swap Help!
- Swap Done...Now Comes Problem Solving
- are these headlights any good? EBAY
- CTR Lip. where to get
- Had an odd electrical problem but solved it thought I would share.
- Please Help!!! Oil Problems. Big Time
- POWER STEERING AND AC SYSTEM FOR EM1!
- what timing do I use on this minime
- need advice......sad ek owner.....
- slave cylinder not bleeding
- Oil Pressure Sensor
- how can u tell if tranny is starting to go bad
- sohc tranny question (help)?
- CV boot question
- High compression valves? please explain
- Header Wrap
- big gas tank problem
- ls turbo help!!
- y7/y8 minime
- b16 with gsr head??? what happens???
- stock b16 valve sizes
- '99-'00 Civic Stock Air Box
- help me out????
- how to wire mph gauge?
- HID in EG questions
- Washed the engine bay... think I missed up?
- could you put on a d15b?
- 99-00 Greddy Evo Exhaust Gasket Diameter HELP!
- alternatives to dynamat from home depot
- anyone...
- Alternatives to Rolling Fenders
- gold mesh wheels
- crv cluster??auto ???
- damn caliper
- What brake cylinder for my EG6?
- Rear Brakes..??
- NEED HELP>99 si GAUGE CLUSTER WIRE INFO
- anonoyms button?
- Momo Hub for steering wheel ?'s
- mounting rear sway on 95 ex coupe
- buying a car that wont start
- brake lights not working--need help, search not working
- sticking caliper
- How To Convert to Power MIRRORS for my EK
- shift linkage in a del sol problem b16
- MIL eliminator
- P1399 not in FAQs
- Question about extended wheel lugs on a EG.
- IAB just for the record
- Fuel cut off is 74))ish on p28
- how do you bleed coolant?
- Mini Me Questions?
- what should i do before i take it to honda?
- speedo broken?
- 3rd gear i start to hear bumping.....
- Best Option..... need opinions
- quarter panel liners
- injector clip order
- d15b8 w/d15b7 intake manifold....burning coolant during idle? help please.............
- b20 head
- FS HEADERS AND INTAKE!!!
- UGH!!! PAINT ON MY DASH, HELP!!!!!!
- low/dipping idle *tried searching*
- Whitetish smoke when at idle
- broke a stock cam in half on install last night.......
- Thank You
- ek9 folding mirrors
- WTB:99 civic EX cheap shell ok
- clutch install
- d16z6 dizzy in a d15b7
- Removing key beeping
- Kyle's EH2 Civic Photoshoot
- SCAMMER! ECUTuning.com
- Will dseries fuel rail work on bseries?
- automatic to manual change over installation
- No CEL, car can't go past 4500rpm, and lost of power
- New lights...blew already!!
- Best way to line up my eg headlights?
- something burnt when im blasting it
- One of these is not like the others... you pick
- strange buzzing noise when car is OFF
- Honda parts online??
- How bad is frame damage?
- check engine light problems
- K&N equivalent to AEM Air filter
- My Starter Broke at the bolt
- Does my 94' del sol vtec w/ a Y21 tranny have lsd??
- eg6 with HID in cali is not legal?
- Battery Light At Idle, goes away when u turn on headlights
- compression
- Howto, safely remove old valvecover bolts???
- trans leak. how hard to fix?
- Gsr/ex
- cluster?
- Civic SI Apexi V-AFC HELP need!!!!!
- 99 Civic Si
- check engine light code 43 13 7 14
- stupid question. Skunk2 springs. which one goes where? (97 hatch)
- Aftermarket steering wheel screws?
- VTEC LIGHT
- speedo off need help
- SCAMMER ALERT: SpoonEK253 is a scammer
- EASIEST SEAT SWAP???
- Radiator help!!!!
- Has anyone bought those B-series Turbo kits on Ebay????????
- vtec not working car bogging
- HELP: Check Engine Light
- Megan Racing Exhaust
- break up problem, help plz :(
- More Horses
- Guage installation ?
- will hatch moldings fit on 95 ex coupe
- Universal O2 Sensor Wiring Help
- gsr swap want a good Header?
- 00 si cluster and ac unit not lighting up?
- Oil Weights - H22
- D series Transmission Question
- How can I tell if my main fuel pump relay isnt working?
- help finding bracket
- air/fuel guage wireing help?
- will my rims fit??
- corner lights
- ANOTHER VX Question
- jdm b16a obd1 into a 99 civic ex obd2-b questions
- Door panel removal
- spark plug wire order
- Hawk HP pad fitment issues.
- ***remove motor mount?***
