- installing aebs intake manifold help!
- really quick radio que. just need a answer
- Hey noob question? any advise is helpful.
- Stainless Axle backs?
- accelleration
- 97 civic power Window Problem
- VIS del sol carbon fiber trunk lid...
- how can i install my JDM EK navigation?
- ls vtec rod bolts question
- any experience with cheap ebay headers??
- civic door checker?
- HELP civic door install!...door checker?
- how big of a shot can i run on my setup??
- Wierd Noise
- 1983 HONDA CIVIC WAGON ON EBAY NOW
- how poor do you have to be to steal a car cover?
- obd2a-obd1 Conversion harness problems....
- too much oil?/?
- Brake kits?
- gsr cams vs. b16a2 cams
- h22 with 5 lug swap.. Quick axel question
- quick engine question question ...
- need help adjusting jdm eg headlights its too low
- someone tried to steal my em1 tonight
- DA brakes on EG
- whats the best bolt on cat i can get for my 99-00 civic si.
- vtec solenoid cap
- jdm automatic swap
- Installing a ZEX Dry Kit (n00b)
- Last straw with the sol .... so fed up .. help
- p1182 or p1183 fuel temp circuit sensor code? what is it?? PLEASE HELP
- where to buy new mugen lip?
- 96-00 civic arm rest bracket
- compression and torque
- cel problem
- Check Engine Light Disables Vtec Right?
- like my custom lines?
- Camber Kits
- Si hatch
- Help needed with stock stereo harness pins
- Help check engine
- Distributor
- idle jump !?
- B16a2 helppppppppp!!!!
- I NEED HELP !! No power gauge cluster is dead ?!!?
- how do you identify a d16y8 intake manifold?
- aircon stress?
- quick header/gasket question
- PCV valve location EK ?
- where can i buy the radio block off plate?
- 1994 Honda Civic Dx
- spark plug wires stuck !
- intercooler sizes...
- Iacv Probs
- YES I've done a LOT of research but still need help. AT JDM b16a into USDM AT hatch.
- fuse question
- Video of my B16....gimme some feedback...
- installing air condition into 95 eg
- clunk when letting off gas in first ger...motor mounts?
- Cannards/Splitters for 6th gen Civic
- injector wires!!
- ????? does a z6 dizzy bolt on a y8 head for stock p28 ?????
- abs on 93 ex coupe
- D16y7 Excessive oil consumption
- 95 EJ1 Radiator Fan Does Not Come On... Help Please
- code 91 fix, electrical gurus, I NEED YOUR HELP
- How Hard is it to put pistons and rods in? d or b series?
- What sensor is this?
- Need to makle an obd2 ingition work on a obd1 harness
- Nitrous KIT ? 's need answers ASAP :)
- swap problem
- car won't start got fuel got spark weird noise????
- Seat Swap Question
- Dropping fuel tank easy or hard?
- Will EK Coupe and Sedan Axle back fit Hatchback?
- Tuning problem on turbo b16a2. HELP!@!!
- Caliper piston not retracting fully?
- ordered new lowering springs height ???
- Is it easy to strip proportion valve / lines when removing for paint?
- Passenger side door lock problem SEARCHED..
- d16z6 & d16y8
- b16 swap?
- Grinding sound in rear. HELP!
- 2000 si oil pump same as 95 b16a3 oil pump?
- (HELP) no heater
- maxspeed springs good bad
- header leak
- NOS
- ek shocks
- Buddy Club N1 Spec coilovers?
- HELP Fast
- where to get a b16
- Idle Air Control Valve
- Why does my thermostat keep breaking when I drain my coolant?
- b series clutch and flywheel
- HELP PLZ
- po6 needed for this swap?
- jdm 18b into EK
- where is the MAP senor wiring?
- Nextel Gps/Locator to find your stolen car!!! Please Read!!!
- Mugen airbox
- For all the b series tranny gurus... Hoping I can fix my tranny instead of buying a new one
- Headers Dented!! !!
- Aftermarket Steering WHeel Hub Fitment Question.
- 94 SOHC INTAKE MANI ONTO A 97 sohc HEAD
- idle surge worse after cleaning iacv, throttle body
- broken hood latch !!!
- throttle get stuck! help!
- does anyone know if ek springs fit a ej1?!?!
- HELP: how to open a door from the outside?
- timing belt for b series
- H22
- help!
- Having some issues with my Del-Sol
- Tranny Problems D16Y8
- Anyone ever heard of or used "Flowmaster/Magnaflow or Hooker AeroChamber" exhaust before?
- OBDIIA to OBDI dizzy wire colors????
- y7/y8 MM ... what basemap to use?
- how to install EK JDM foglights?
- intercoolers...
- installing 91 civic si cam into 98 DX engine
- 92-95 fogs
- Do they sell these by themselfs or will i have to buy the whole thing?
- Car dies out AGAIN! Please electrical people help out.
- How to adjust my 96-98 fogs?
- civic tail lights question
- Timing Belt write-up?? (b series)
- help with running b16
- Tach problems
- front end shake constantly almost
- Civic Coupe SS fit on Civic Hatch?
- eg b18c5 question
- ? on h22a swap into a 97 EG
- body styling question
- cleaing engine bay ...
- Missing bracket... b18b front trans
- C.A.R.B legal Exhausts for Ek hatch.
- o2 manifolds wires question
- Which E-Manage?
- Cruise Control
- How to time car?
- INTAKE
- stock injector specs?
- tokico shocks and springs ...
- Did't know where to post this but i was just wondering when the end of trial member ends?
- need help
- Quick Ratio Steering Rack
- 96-00 shocks fit on 92-95 civics?
- Brake Line Question
- Del Sol Tach
- Eibach sportline question on 1995 Honda Civic DX
- EG's with Spoon-Style Mirrors...Report!
- Installed short shifter on 98 civic...too long.
- CEL help
- How To: DIY Roll back or Forward Odometer (When swapping Clusters)
- cam keepers
- T_T my car......stupid guy ran a red light
- tach
- Painting A Fender
- Vac. box question. Do I need a aftermarket?
- EK4?
- Passing Smog with CTR parts and VAFC/SAFC
- hid help
- No heat when idle.
- Which brand yields you the bets mileage in your D16Y7
- Axle nut torque specs for 92 Civic Si hatch?? Reuse axle nuts?
- Car cranks but doesnt start...i did a search..
- Del Sol suspension into a 99 Civic
- k20 swap questions. .
- Failed Oregon emissions. Had questions on how to solve it
- What websites can i find chips for ecu's?
- Will this tower bar fit into a DA??
- power window
- wierd knocking
- draining A/C ?
- Where to buy? Stanley glass housing headlights with city lights???
- cluster.
- What mounts do i need....? (already searched)
- B18b in an Ek power steering problem
- Puzzling ignition problem
- Brake Line Fittings Question????? Please read.
- An F22B1 Vtec Solenoid work on a D16Z6?
- a few n00b(-ish) ?'s
- disk brake swap
- 1 more problem to solve
- d15 turbo
- car STILL WON'T start had no spark now i got it????
- 96-00 passenger window problem???
- EM1(Civic Si) = EK? Suspension and all?
- fuel and spark but still nothing!!!!!
- Need Help With My EK.....whys it overheating?!
- EG Type R Help!!
- ecu code 45??
- OVERHEATING PROBLEM!!!! Need some secondary opinions
- will SRS light turn on?
- EG Headlight Differences
- Da integra brakes on cx ek hatch?
- Spark plug wires
- lets just say my car got it(check it out)
- B16A or B18B With wierd situation......
- Lets Try This Again
- so i am still ahveing trouble
- Buddy Club exhaust?
- Quick question plz asap
- 99 Civic w/ intermittenly pulsating lights
- 99-00 ex harness on b20z, need help with wiring
- JDM D16A SOHC vtec swap for D16Y8 in 97 Civic EX cam problem
- headlight retrofit question?
- skunk2 intake manifold for h22a in EGs?
- Hey Nice to be here! I need help!!!
- lamin-x or other headlight film
- front shock to lower arm bushing (ek4)
- Head Oil Control Orifice - Missing o-ring?
- want a good laugh????? check this out
- oil pressure sensor outlet fittings question
- Winter Tires *VS* All Season Tires (Are bigger better aswell?)
- QUESTIONS ABOUT 99-00 CIVIC SEDAN TAILLIGHTS ON 96-98 CIVIC SEDAN
- what motor shall i get?
- skunk2 camshafts
- front end conversion civic cx 1992
- Torque mount the same for B and D series?
- Car stuttering at low rpms, good idle...ignition module???
- Clutch pedal adjustment
- Boggin Problems
- short shifter !
- ok i have a d16z6 block wit a d16y8 head ARP HELP!
- My 98 Auto EX Sedan, go or stay?
- Muffler sizes???? Stock ones need to kno
- 92 hatch w/gsr swap v-tec not engageing
- Are these 99-00 Si mounting brackets?
- trying to clean this engine. that i have on an engine stand
- check engine light
- boost
- Info please help!
- d16 vs. b18b
- Specifications for civic parts?
- Weird problem with my door not opening
- piping
- I NEED Torque specs for D16y8 Cam Shaft Bolts
- Code 9?
- dimming lights
- clutch selection
- Newbie Questions Ek short shifter
- Looking for a JDM importer in So. Cal. Need a trans for a '96 d-series.
- good header for my egtype r
- mugen exhaust twin loop
- What Tranny Is Shorter?
- b16 vs poor mans r build question??
- bad rotors?
- cv joint trouble
