View Full Version : Honda Civic / Del Sol (1992 - 2000)
- make sure your plugs are properly gapped............
- EG6 spoiler removal for Duckbill spoiler.
- difference between b18c5 usdm and jdm
- Mugen Twin Loop for 96-00 Civic Coupe: Was $480, now $680???
- what do you think of my eg??
- Best Handling Civic... Your suspension setup ?
- ctr in b16
- For those in the BAR club......
- What HID kits do u have and what the quailty like
- Vtech head on an ls
- civic coupe with ls swap times/mods
- Suggestions on where to find a specific dual/triple gauge pod
- purchase from passwordjdm.com??? (ctr exhaust)
- D15b O2 wiring?
- Gotta question for anyone familiar with the old Apexi Super Intake filter
- do i need a new headgasket
- knock sensor on b20z i searched
- 1999 Civic SiR VTEC Air Filter
- Problems with Windsheild Wipers
- Anyone have a screen or monitor in there 99-00 Civic Climate Control?
- steering column question
- d15 block with z6 head, less or more power with dx vs. so block?
- Wiring scheme D15B2 and D16Z6
- anyone here have a JDM motor swap done in their car?
- Rear disc quest?
- Hayame full SS catback for EG6
- New shots. (56k ok)
- what's the difference between curb weight and gross vehicle weight?
- Lighting!!??
- LS Into a 200 EX Coupe
- gsr skunk2 manifold help!!!!
- when going off the gas, the car shakes
- 2001 civic ground control coilover fit on 1995?
- y8 manifold on y7
- ground control spring rates?
- SOHC VTEC DISTRIBUTOR
- Hayame coilover sys.
- Front Tower Strut Bar
- 89 civic ex b16 swap, tarmac suspension and all that good stuff? How much???
- im lost i need some help any ideas?
- what to expect from turbo?
- Heres something you dont see everyday in an EG
- Honda Domani Frotn end?
- OBDII to OBDI conv. 00'Si
- post pics of ur skunk2 intake manifold
- cross drilled/slotted brembos are not so great for some
- 96-00 ek with 01+ head lights? pix request plz
- wipers wouldnt go off...
- best place to get rear disc conversion?
- Rear strut bar
- will it fit
- ek4 rear shocks fit into eg??
- pics of my four door...
- injectors diff
- GSR Head- Question
- Parked next to my best friend!
- Engines In Australia
- N/A set up weak?
- civic seats
- is wheel horsepower and flywheel horsepower the same
- My New RS*R GTII pics and sound clip
- Tranny assembly d16z6
- WHat Else do I need to do swap?!
- Civic Theft Advice
- STILL...having problems with the dash swap
- EG/GSR Swap FRONT SWAY BAR QUESTION
- EG/GSR SWAP help please~
- Anyone run a throttle pully????
- buddy got new car, no tach! when to shift? ( search used)
- pics of eegeesixtsu's hatchie....
- GC sleeves off the shelf: Teg ones for my EG sedan??
- pics of my hatchie....
- How many of you B16a motor owners have this?
- my coolent gets pushed into my resivor tank only under boost??????????
- !!! LOOK !!! Daily Driven B16 Supercharged Hatch Question.
- How old do you think these springs are? (56k warning)
- 1 quick question bout my 00' si deck
- EG hatch with B18C1.. what mounts to order?
- 92-95 RHD Civic
- O2 SENSORS HELP PLEASE
- EG9 with B18C6 pics and Videos
- 92-95 honda konig yell
- enjo mounts for h22 in civic any good i can get them cheap yes or no
- where do u have ur shiftlight?
- Which motor would u perfer H22a or H23a
- do anyone got some Si wheels for sell (CHEAP)
- alignment
- new engine
- How much is my b16a3 worth?Need objective opinions
- what rims to get for my 92 hb??
- what has more horse stock?
- civic differences
- Crank scraper on turbo d16?
- what happened to accordinglydone.com??
- Inexpensive 1st mods? 99 Civic Hatch DX
- SCAM??? *searched*
- my eg pictures!!
- Cluster Went Out [searched]
- Greddy turbo kits? post your thoughts
- moderator....
- smog question.
- Engines
- Civic Type R motor swap into a 1997 EK
- CTR; how much is too much?
- I need help finding local shops in MD/DC/VA
- Greddy Evo... can I modify it to fit an EG hatch?
- 2nd Gen B16 into EK??
- Install tips for Autopower 4-pt roll bar?
- blown motor
- I picked up some Carbon Fiber Eyelids. Installation??
- stock cd player locked...
- gas gauge/cluster conversion
- EK seats in a 5th gen 4door?
- Mini Me help... (searched)
- anyone have JDM ITR swap in their cars?
- does civic rear upper strut bar for cpe fit hatches?
- Purple ek with bronze wheels?
- Please help me decide. I need H-T guidance. B20 vs D16
- jdm gauge cluster
- Whats going on?
- swappin a ob2 motor into a ob1 car?
- Civic Ex 97 ecu question?
- jdm type r powder coated....
- Street racing show last night. I know someone has a link
- smog a k20a EG?
- mushy clutch in eg
- Quick!!! Dash help
- Got in car accident..
- JUNKYARD motors...anybody have them????
- Can Some one PLEASE help ME with head Questions!!!
- will obd1 distributor fit on d16y8?? need help please
- how to make low end power ?
- Are si rims heavy?
- Oil smells like gas.
- O2 Sensor Melted
- dead pedal...again after bleeding
- Questions on lowering my car.
- Hasport K20 swap photos!
- Hissing Intake noise
- Exhaust clips
- J's Racing Products?
- spun bearing
- ecu question
- ~ EK Civics Steering Rack Ratios
- taking the cluster out
- throttle body sticking question.. already seachered
- VALVE SPRING ????
- Name of the 96-00 SI spoiler
- Pic request, Gunmetal Rota C8s on EG Hatch
- gsr oil pan fit ls b18b motor??
- HX tranny to dx/ex/cx?
- Aftermarket ep3 suspension compatible with em2 suspension
- Cutting cat. when converting from OBD2 to OBD1
- Tranny noise
- ...:::Hood Difference???:::...
- quick coilover Q.
- Thread being grinded down
- **** Testing Fuel PUMP ****
- Tire Size Recommendation
- Houston Tx and a little Fun Run at night Video Inside
- Rough Idle after vafc install
- Do you have imitation parts on your Honda or the real thing?
- Radiador Support Change labor cost?
- AEM V2 Cold Air Induction System
- JDM D15B cam and header???
- custom front lips howd you mount yours?
- Problem with lights
- what would you do? B-16 or B-18
- b18c5 in a 92 civic need help wiring the cluster HELP ASAP!!
- anybody have a h22 coupe?
- exhaust question ??
- couple of questions about some EG hatch mods......i did search
- are projector headlights worth it?
- Need to pass inspections and Emistions testing. Anyone have hook-ups?
- Ebay Mugen strut bar for my EG..lol....
- Weight Distribution of a 95 civic coupe??
- USDM GSR motor in an EK
- Camp1320/Ingals Camber kits....
- Can someone run carfax please!!
- Del sol and Civic cluster connectors
- turbo type-r
- Legit import shops in San Antonio, TX
- wiring?
- throwing IACV code
- hi guys im new here
- Greddy SP2 or EVO2
- Carpet question.
- Z6 parts on a Y5(HX)
- iacv problem
- eg tie bar
- vafc on stock d16y8 motor install or something else?
- help knocking noise from the intake - civic
- shift light but no tach
- front window
- Would a bad distributor cause difficulty "cold start"?
- ur thoughts on obx products??
- 95 GSR Swap hatch...Idle...WTF? Need help ASAP...
- H22 into EK !
- cel and vtec?
- Muffler shops in San Diego?
- stainless steel dc header needs polishing.. help! how to?
- New cat? shield or honey comb?
- B&M FPR, need quick help
- VX wheels on EK hatch
- 02 or the cat
- plugged cd player in, turns on... no sound ???
- thepartstrader........cparts@hotmail.com
- vtec controller on a d16y8
- built Ls Up for Sale or Trade Let Me KNow ``
- skunk front camber kit collapsed
- VAFC on stock motor?
- broadway mirror
- wtb: used apexi N1 dampers
- sell or keep
- Discovery Channel Show??
- clock no display
- Cranking Car problems.. need Help !
- mini-me swap!!!!
- Pic Request: I need to know what a SOHC head should look like...
- Compression???
- Auto body???
- a/c
- Hatch Lever question.........
- manual to power windows
- is it possible to fix poor bumper allignment?
- Spinning Ball Joint
- distributor help
- S tech's on Eg hatch (Ride quality?)
- NEW H-T member..
- NEW GUY NEEDS SOME HELP!!
- SURGING ENGINE
- Any good junkyards to pick up a wrecked car to fix back to working order
- need clock!! 92vx! can i put one in!
- What kind of MAGNAFLOW exhaust do you have?
- tranny compatibility ???
- **Integra dashboard into civic couple of Question and Anwser's**
- quick axle question
- can someone tell me if ..
- toda killer cams
- head lights
- axle questions
- noob question.
- Help!!! Distributor problem, I think
- everyone post your exhaust pic here !!
- Gas question
- GM Synchromesh (FM) / AC Delco Tranny Fluid
- SOHC motor pics post!!!!!!!!!
- Del Sol lip
- $5 buy tonight :)
- can a valve fall in a cylinder?
