View Full Version : Honda Civic / Del Sol (1992 - 2000)
- will integra type r exhaust fit eg hatch with b16 swap?
- can i trust hondautomotiveparts.com :searched:
- CIVIC COUPE
- EK Seatbelt light/beep
- Engine Off, Headlights On - No Warning Beep?!? HELP
- 99 CIVIC SI(B16 CAMS) VS 95 GSR (B18C CAMS)
- Part differences on Canadian vs US Civics
- Relocating Battery
- whats the catch. need help please
- is this dangerous?
- Quick release hub... wobbly?
- EK side skirts on a del sol...
- oil filter
- PLEASE HELP!!! Need Recall Clearance letter to Import car from US to Canada
- Just put a b20b in my si. Questions.
- HELP? alternator fuse location?
- all d series trannies r interchangeable right
- FENDER QUESTION HELP!!!!!!!!!!!
- Options on an EG Civic VX
- 2001 Civic LX Custom Intake question.
- Water + All up in my Engine bay = Bad? Yeh.
- why wont this transmission come apart?
- airwalker bumper
- hmotorsonline
- Rough Idle, (bogging) when cold. Help?
- alternator or starter problems
- newb question please help
- overheating problem
- Oil Feed Line
- ecu code 22
- speed and rpm not working...
- d15b mpg
- EM1 Stock Catback E. Would it fit my Ej1?
- d15b jdm
- my car is making a whistling noise ?
- Tranny case HOLE!
- Parts for upgrading to 4 wheel disc on hatch.
- NO CEL, tuneup just done, car bogs and stutters under load... WTF!?
- Fuse for fuel pump...where is it!!!
- Budget Header Comparison
- JDM Del sol headlight Bulb question
- ITR spoiler on my civic
- HELP HEADLIGHTS...
- Need Help
- Do you have a "whishing" sound coming from your tranmission? Inquire Within!
- problem with my ek
- lifting an b18 engine
- european hatchbacks 1992-1995
- anybody ever use obx camber kit?
- TPS PROBLEMS
- HELP!!!! REMOVING SRS SYSTEM!!!!!!
- How do I tell if I have ABS??
- getting new motor need some info
- Del Sol Question
- Tune Up
- window wont roll up
- Lights on warning buzzer help.
- fuel pressure reading?
- 96 civic cx 1st gear takes a lot of gas
- Parts!
- Need help with civic and swap
- del sol....truth, or myth?
- How much do HX wheels go for?
- what should i do?
- Car just dies?
- Educate ME please!
- Loose suspension??
- Fuel pressure regulator
- Drop piping?
- itr quick release????????
- about to buy 05 civic ex special edition coupe, what engine swap is available for it?
- antenna help
- ahhh, im rubbing!!!!
- DEL SOL SEATS
- Reverse doesnt work after swap.
- civic interior lighting
- Compression test
- Del Sol seats in to a EK?
- bad injector????????
- i just installed it ... now what ?
- How to rewrap door panel inserts??
- How low can I go with 42 offset 205/50/15 ?? on EG Hatch
- Stock Offset for EG DX 13" Rims
- how many shock tower harneses ??
- Greddy cat back from 92-95 hatch fit Del Sol????
- My 2000 civic lx has leak on the exhaust manifold
- fitment of si/sir 2000 on 4-door
- Upgrades to brakes???
- 98 civic ex dc header trouble
- New to the board.
- d16y7 to d16y8 exhaust (hatchback)
- problem with EX tranny
- Car door is stuck!!!
- Good tuner shop in GA/SC/FL area
- coolant disappears..appears under car???
- SOCAL H-T Mechanics Get in Here!!!
- I have no brake lights or turn signals.?
- HID kit for sale ???
- K24 mounts same as K20 mounts for EG???
- Rear Sway bar on EK
- SOME AIR NOISE INSIDE BEHIND ME WHILE DRIVING
- already searched!!! ek rear seats in an eg hatch
- I can't gert the tail lights off...Help me
- B16a2 Crank pulley!!!
- Headlight problem, please help!
- need help fast lpz
- swapped ecu(p28) in vx and now cel
- Some one please help me with my problem
- Mini-me swap in obd II civic?
- 89-91 Motor Harness
- O2 Sensor
- Electrical system possessed!
- omni coilovers...asked in suspension, but am not getting a response..
- difficulty of replacing short block on sohc?
- Civic Alloy wheels
- Injector problem.
- Rear sway bar on my eg..
- one of those throttle response question
- Throwout bearing failure???
- A nice done Civic Hatchback [pic]
- battery dies, searched, newer alternator
- Civic Blowing Parking fuses
- Need some help GSR_EK
- Any advice for shock/strut replacement?
- B16A2 into 5G civic
- which on before which?
- gsr low rev limit at 2500-3000 rpm...throwing tps code...need help
- megan racing header question
- Throttle Body for B20 Vtec
- wheel hop=broken axles
- need help fast
- bad bushings for a while....any major damage?
- 5 lug conv help
- power problem =/
- need help on the b20vtec arp head bold spec
- del sol dash in a eg hatch
- reducing NVH (noise), and bushings
- Headlight blinker question
- 2000 Civic Si question
- compresion ratio?
- need help
- need a cat.
- My trunk is allowing water inside my cabin!!!
- Clutch Problems in my 95 hatch
- Mini-me w/ Nitrous??
- Need pics of SK2 IM installed
- anyone know the difference btwn obd1 b16 intake manifold and obd2 intake manifold?
- Leaking Head Gasket? (Quick Easy question)
- What Should I use for tuning my car?
- CEL 45 Fuel system too rich or lean (Civic d16y8)
- 95 civic swap
- Question about bulb wattage
- 99-00 SI (R) shift knob / boot Q
- Car sounds like a diesel
- 2000 integra gs brakes and rotors onto 95 si
- Yeah voltage regulator maybe?? underdrive/ altn. probs? suggestions?
- b16 in a eg - items that is needed
- Question about EM1/Si Climate control bulbs?
- idle jumping
- 90-93 integra springs on 95 civic ex?
- CTR prop valve part no.
- TURBO??????
- So do I have a Dx/Cx/Vx tranny?
- FROG vafc harness??
- Filter.................intake
- Big Up to LostMyBoost!
- Head Unit Has No Power
- Radiator question
- eg track time
- It is possible use the B16 head with the B20 short block????????
- D16Y8 headbolt question
- window rubber rail thing
- new exhaust question
- My own vafc2 wiring diagram..........
- F%!& am I screwed?
- What should I look for in a used civic???
- Why the coolant need to be drained for Timing belt replacement ? Honda civic 97
- Help w/ pics in another forum...
- A/C and Recirc. buttons don't back light!
- 2005 civic si odometer bypass?
- 99ek coupe, fuel pump issues after swap.
- Anyone have their Golden Eagle LS/ VTEC plate not thread on?
- ebay mufflers?
- Open Header??? (I searched)
- any one herd of omni power
- looking to build a turbo daily driver
- where are good and reliable info sites
- DIY Carpet and 97 Hatch with 03 Si Muffler
- Something knocking... how do i fix?
- Anyone heard of JDM EK9 Projectors???
- Edelbrock turbo kit
- hub question >_<
- what del sol came with a b16
- auto sir gauges into manual eg
- Quater panel
- not gettin spark???
- 4 thoughs that want a thinkin challenge
- Brake Problems 4040 prop valve HELP!!!
- MY HATCH GOT STOLEN!!!!!!!!!
- 98-99 FRONTEND CONVERSION
- Easy way to wire vtec without a vtec computer ......
- ST Speedtech rear sway bar on 92 cx question
- WTB: Clutch
- Did a swap in my EJ8...now no power to fuel pump..please help
- Battery light on but still charges
- dont know why my car wont stay running alternator problems
- Startup Problem: Weird Check Engine Light Issue
- 2000 Civic Si Suspension Opinions
- D15B VTEC WITH P28 HELP...!!
- EK Grill
- MAP sensor wires
- Patching holes in plastic
- ECU chips
- im confused , please help wire it up .
- Cleaning Block and Tranny
- 95 LS swap in a 98 Civic EX Coupe??
- ground wires
- leak in my car...
- differences between the jdm sir-g and si-vtec
- Before I buy a new tranny, would FM Synchromesh help?
- B16 header in 2000 Si for >$500?
- my first post. go easy yo. atlanta
- Something wrong with these numbers?
- Swapping an SiR cluster into a VX
- How do I change my fuel filter?
- We need more mods to help our current mods!
- sketchy CF hood fitment
- Need help with installing EK shifter console and armrest into EG Nor cal bayarea
- b16 fuel rail on dseries?
- 98 jdm itr distributor cap question (searched)
- 2000 Civic Si Door vs. 2000 Civic Ex Door
- found a b16a2 for my 96 civic, a/c still workie?
- Found a spring / greasy little motor inside my door! *2 Pics*
- Valve lash for ctr cams
- HELP! Torn between hatches......(Sorta long)
- grind when putting the car in reverse..can someone help?
- Sleeving the D
- Radiator support
- need help
- Cel 6,10,41 on B16 swap into EK..help..
- help with A/C (searched)
- SOME ONE HELP ME
- where can i find something like this
- Sub Please help anyone know?
- doing a swap this weekend, any hangups i should know about?
- HID Help
- slight grinding when shifting to 3rd??
- Prelude motor and sportshift transmission into a civic
- ZC header fit d16 non vtec
