View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 92-95 hatch plastic removal
- '01 ls motor into '95 cx hatch
- gsr idleing high
- a breather on a tranny ???
- Idle problem help me solve
- 99-00 Civic 3dr HB. tire size?
- civic 00 si for sale with 38k miles
- cluster ?
- can i use regular wire in my fuel tank for my pump
- Transmission Fluid for 99-00 Civic Si
- Help!! Car doesn't go in gear!
- b20
- b20v vs. All Motor b16a2 ..
- blinkers not working
- ITR Camshafts or Skunk 2 Camshafts
- Z6TB on a LS
- SRS Light ON after momo steering wheel removal and stock wheel w/airbag reinstalled
- how to drain fuel out of the gas tank?
- Need Suggestions on B16B build
- wiring??????
- keep or sell??
- swap
- Wheel Stud Length
- b20z idleing in my em1
- SAFC Tuning...
- 02 sensor help
- CYP sensor?
- New JDM Cluster... Brightness Issues??
- Staggered wheel set for EG ?s
- wiring woes
- STUCK THROTTLE CABLE PROBLEM SOLVED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Lower strut bars 00 civic si
- Change CV boots or just replace the whole axle?
- Motor Swap Help
- Intake for eg with type r
- coil resistance
- I need help with aftermarket headlight...
- Throwout Bearing
- ecu hacker?
- Wat Color??
- best way to clean engine bay
- Starting/idling problems with the EG
- bleeding brakes !! (searched)
- i have a 1992 cx hatchback, i need a little help
- Which way does cam gear point on compression stroke...
- !!!!!!!!!! wanted 98-2000 b16 or b18c5 tranny !!!!!!!!!!
- Sir-S rear interior eg6?
- Tweeter options for 96-00 Civic sedan 4-doors?
- fuel pressure gauge
- i think the lsd is the source to my axle problem....check it out
- throttle problem?
- modacar.com?
- 94 civic ignition quick question
- oil pressure question
- Z6 to Y7 tranny swap
- lookin at buyin a 94 civic ex
- hid conversion?
- dc sports manifold collector size ??
- Prelude and Civic....Interchangable Suspension parts?
- Relocated my IAT
- ignition/ starter problems
- B16A3 into a '93 civic si
- Car acting weird...
- Ametech Engine Restore anyone tried using this.
- urgent! Spark plug question before 600 mile drive
- hard starting
- ES Technical Roadsports?
- beliave i broken a tranny
- Need help finding the right stuff for my new car
- SRS light keeps coming back on after resetting it
- painting rear bumper with bottle
- axel nut
- EJ1 Interior question *searched*
- question on skunk 2 coil overs..
- replacing civic taillights back to stock ... gasket?
- srs light
- d16y7 alternator on a b18b motor?
- How to fix hood latch?
- help with clutch installation please.
- What pillar bar do I need????
- What donor car has the 1" master cylinder?
- Ok when adjusting the timing on your distributor...
- ***BOLO*** STOLEN S2000 05 SILVER
- <><>< OXYGEN SENSOR QUESTION !! ! !
- Hey, Is the NRG hub for 92 - 95 a different size the 96 - 00 ?
- oil breather chamber cleanout
- Weird a/c problem
- legalizing your jdm itr motor for emisions in northeast
- Need Suggestions/Brake line related
- 94 coupe or 88hb?
- Just picked up a 96 hatch!! 1st Honda for me.
- for all of you that removed your power steering
- Question about LS/VTEC with auto transmission?
- Wiring harness and Ecu question
- Just Got My JDM Cluster.. Some Questions..
- fiberglass out of the exhaust
- d15b running rich w/ p28, need help
- Need help.. Can't find the 98 honda civic power window relay part anywhere
- swapping a gsr in a 93 do i need shift linkage?
- What shifter i have gsr or b16
- Looking at 92 hatch. Wondering your guys thoughts.
- Maybe you might know.
- passwordjdm fender fitment
- OEM Si Grill Part #..
- DIY HOW TO : Drum To Disk Brakes conversion for 97 civic great pix & info
- dang... why did i even put the lip on !!!!
- Very Wierd! Car Just Shut Off!
- VW flip key
- need help!!!!!!my motor took a poop
- How to take off a 2000 civic shift knob :(
- What would be a good swap for my civic hx
- why doesnt honda make a large displacement engine?
- ok so i have it narrowed down- apexi N1 or Invidia N1
- something wrong with tranny
- exhust question
- bar`d h2b
- matienence required light?wtf
- b16a second gen with ctr pistons and cams???'s
- i want a full coilover system.
- need somr help with a cutting out problem
- Few quick Questions
- EH2 and tein s tech
- WILL 90 CIVIC DX D15 LONG BLOCK WRK IN 95 DX???
- need help!!
- Help!!!!!!!!!!!
- ABS sensor troubles, 4x114 Convers
- Centercaps Question
- best d series carbed?
- Leaking tranny fluid?
- honda codes?
- heat shield for exhaust, nessary?
- del sol non vtec to gsr swap question
- LS, b16, b20 tranny (wanted)
- Shifter shaking??
- Engine stuttering?? PLease help!!
- Squeaking PS Belt
- 73-79 or 80-83 civic info i.e. swap?
- d series: can an 8 valve head fit on a block fitted with an 16 valve head?
- K20A3 swap in 97 civic...
- H22 EG AVID DRIVESHAFT PROBLEM WHAT MID SHAFT IS LONG ENOUGH?
- Not plugged cruise control nipple on the back of the intake manifold vacuum leak possible?
- rattling hood
- Will an H23a fit on an F22b6 Honda Oddesey Tranny
- car starts then stutters and shuts off
- VAFC II question
- hp questions
- How to put Ls rodds to d16 motor
- 96-00 wiring question
- car stalls when stepping on clutch
- Will a coupes side moldings fit a hatches moldings>
- GM top engine cleaner
- Shaved moldings
- HELP upgrading brake system
- Swapped Engine... wondering about my tachomter
- new battery...car still wont start
- ls and gsr tranny question
- new and need dizzy questions answered
- turbo question?
- Sideskirts off 95 coupe to 96 Hatchback.
- Car shut off while on freeway
- difference between 2000 civic dx and si
- Manual Steering Rack vs. Power Steering Rack with PS not hooked up
- anything to get off primer overspray?
- Loud Bang Noise... HELP!
- Weird Shift Linkage Problem
- axle boot...
- should i cut the bumpstop???
- Replacing Clutch slave cylinder
- b18c5 short block b16 head question
- The typical cam seal leak...
- Y8 won't start...spark plugs doused with fuel
- for 96-00 civic need help!!!!!
- wut do i need to do this???????????
- greddy turbo timer install!!!!
- installing 92-95 civic halo projecters???
- AT Transmission problem
- need springs!!!!!
- nees a little help with the good old no2
- Towing a civic with a tow bar... possible?
- Need Clutch Replacement 00' si
- EP3 seats into an EK9?
- will 92-96 prelude tein ss fit a 00 EM1?
- Failed Cali Smog - Was It just Cold?
- ok gsr swap wiring help...
- trans prob
- trying to do a turbo del sol
- type R questions
- Anyone running H&R race on a del sol?
- power steering
- Newbie
- quick question?
- D13B intake question
- state ref in san francisco
- stainless steel braided clutch line? wtf
- Sidemarker Lights
- Help Weird Front Bumper on 99 EX.
- i am having a overheating problem i can't understand, please help!!!
- transaxle removal
- I need an engine...
- z3 fenders
- Crazy problem power locks WTF!!!!!! HELP
- Need help with ECU
- speed proportionate thudding
- 15x8
- ATT:VolpeOwnsU
- Armrest bracket
- underdash harness question!!!help please
- Radiator Support Help...
- help b18c1
- Targa top leak
- my civic smokes a lot, burns oil quick.. it's a d series
- VTec ??
- Mounting Hardware 96-98 OEM foglights
- cam caps
- Dash Help!!
- camshafts question
- help:obd2a to obd1
- how to install brake lines ----
- Have a problem after compression test
- does anybody have a front black bumper for 2000 si
- Problems with idle and missing vaccum-HELP!!!
- Looking to buy a built head, what site?
- quick fix to leaking brake line ( at fitting ) ..
- Need help!! swap searched!!
- Simple motor mount Question
- OPINIONS on how much a shell like this would cost.
- LCAs??
- Quick question
- camshafts
- Bitch Bolt from shift linkage to Tranny please help!!!!!!
- Need advice for port and polish on a D16Z6
- Twin loop muffler in my ek hatch?
- best bolt ons for mpg
- Brand New Hasport parts for sale!
- cleaning my turbo
- Replacing a rear quater panel?
- Does anyone know where to get this cf lip ? thanks !
- vx o2 sensor question
- window visor
- just installed d15b burning oil
- help help help!!!!no power to fuel pump
- HELP WITH EGR VALVE
- Crnk Shaft Pulley Bolt?
- 92 Honda Civic hatchback
- firt time trying the camera out on the tripod
- Vtec head taping problem, need some help here..
- 1995 Honda Civic - PROBLEM in steering
- changing manaul transmission fluid
- obd2a and obd2b dizzy question (simple for those who know obd2)
- need help asap on vafc install
