View Full Version : Honda Civic / Del Sol (1992 - 2000)
- ITR B-pipe on EG?
- anyone mount a 5" tach on the steering column of an EG?
- p28 wiring question?
- what to do?
- Carbonfiber Duckbill
- Stock del sol rear bumper for sale
- What would you put in a EG?Turbo,LSVTEC?
- Tachless
- Just wondering what the going rate for some internal parts installation are.. thanks!
- Help re: Front suspension install on EK civic hatch
- anyone running a vortech sc?
- Brake Booster Check Valve - Anyone have one go bad?
- WTB: Red Bumper, Red Hood, Red Fender for SI
- b16a sirII emisions question???
- new to honda-tech
- grill and trim
- Does Spoon offer a whole tranny w/LSD setup???
- Got my RSR 4-2-1 header!!
- b18c5 prices?
- Hey I was wondering if you all like this her del sol..................hehe
- 93 civic B Series Swap Question
- What do the block #'s mean??
- g-tech pro II
- Replacing engine mount
- what suspension for drag racing a 9 sec car?????
- Need help w/ H22 conversion!!!!
- Which 5th gen Civiv Hatch backs had sunroofs ?
- Swap Question: Which Throttle Cable?
- best swap for 96 hatch
- Cooling system problems
- Temp problems....need help
- CTR N1 pulley, JDM FD & pistons, etc in stock
- what kinda times are you NA 1.6 guys running?
- Need exhaust for 93 Del Sol Si
- Noise when I let off the clutch
- rod question
- shift linkage question
- headlight problem
- which sway and strut bars????
- Turbo on a b16a in 1995 civic
- exhaust adivce/question
- 94 si hatch track times
- Part number for rubber guard????
- eek! 911, need OS rings!!
- itr muffler on itr hatch? fitment?
- Couple of newbie engine questions...
- 98 civic coupe, headlights and dash lights flicker.
- torque spec for a ls.
- Si Fog lights....H1 or H3
- Altezza or Clear
- Noob question about G-Tech
- buddy club p1 racing wheels
- General questions about small CX / EX Compatablity
- 1992 civic Hatchback.......will HONDA INSIGHT SEATS FIT INTO my HATCH???????
- which cam with nitrous
- Anyone using the SPC Front Camber/Caster Control Arms?
- Picked up some Cusco suspension
- 80 Shot Wet Direct Port on a Stock B16A2 ?
- what wheels are these???
- Tokico Illuminas or KYB AGX? which would you get to match with OG skunk coilovers?
- spoon or rota??
- Got the car tuned *dyno plot inside*
- swap pictures....
- cx is dying fast, engine fund is still low
- AEM CAM gears?
- Need some swap info
- konig greenlights in 16's??
- 96 HB turbo (let me know what you think)
- My next mod
- civic 1997 engine convert
- noob question
- amber it up!!
- 98 civic dx swapping in a 00 si b16a2
- fluidyne radiator
- My car is on the road again!
- Oil Filters
- Back from Sears Point...here's my time
- My project EG once again
- need help
- what cluster is this
- Check out my friends CrAzY AZS H4TCH!
- 2000 Si wheels...watcha think?
- Got a question bout b18c swap???
- HELP: Rear disc. conversion
- SSR comp. fakes
- tire recomendation?
- Wheel/tire/spring combo question
- Taking offers on built swap details inside
- H22 EG 4dr?
- Anyone have CTR headlights on a Milano Red civic? pics??
- 99 red si (for sale)
- Eat brekafast/ anyone wanna let me follow them to nopi?
- Lets see some 92-95 Black Coupes.....Nice Ones Only!!!!
- CAI Question
- New Honda site i need you to submit your best
- sticker removal . . . help please . . .
- What cam for D16Z6? GUDE head package good?
- test pipe question
- Found amber 194 bulbs (Wal-Mart rocks)
- Want to sell D16Y5 Full Swap And Some Aftermarket Parts For This Motor!!
- 5 posts?
- rota mantis?
- Greddy EVO exhaust
- Cusco Catch Can - EK
- estimate my 1/4 mile time
- Clutch Problems
- Removing the rear emblem pt.2
- Stupid Question about Spoon Shift Knob
- Auto tranny installed, how do you make it worK?
- Dyno Day in the Tri-state Area!!!
- Susp. Question
- cx distributor on si
- tranny guide?
- Which Engine?? Please Help!
- Civic Type R Rear Lip Bolt Size
- Who sells Zex cams and crower valve springs the cheapest?
- good how-to sites?
- i need help plz ! ! !
- Great example of jdm rice...
- 99-00 Si and G3 Integra parts compatibility?
- Crazy Civic Mods.
- Track Days in the L.A. area??
- I'm a moron...How do you check codes on 92 CX?
- Code 9.. No. 1 Cylinder position?
- buying an exhuast for my eg hatch which should i get?
- Greddy / DC header O2 bungs for D series
- give me some sugguestions.....
- Can i expect any gains with a new header on a stock civic EX
- Bronze wheels on Silver Car PICS please.
- ***Anyone know if Lowcash is still chipping ECU's***
- went to the track(sohc power)
- Does anyone have that clip of HX_Guy's car idling with 62404 cams?
- ? on power steering pulley
- YOU build my car for me...
- ? on oil pan
- Insight seats in a 99 Hatch
- Can I rev my shit?
- Are my eyes playing tricks on me? *speedometer problems*
- Turbo charger for a JDM b16a2?
- i need a wiring diagram!
- SOHC clicking? No idea what this is
- best master cyl and booster for 97cx w/gsr 4disc swap?
- Camber Kit ?
- pepsi blue copying??
- Clicking from brakes when stopping??
- Farewell Run?
- What is the max redline that you can raise a moded Dseries vtec motor to?
- How do you make a D-series VTEC pop like a B-series in VTEC?
- intake manifold
- Decent cheap exhuast?
- High compression SOHC motors hp output
- Headlight adjustments 1996-2000 Civics (we all need them none of us do them)
- Technical info on Car auction and government seized cars??
- Is buying used 60% tread tires any good?
- What do u think of my car?
- eg w/b18c ecu question???????
- what ss brake lines are you guys using?
- SOHC cam gear "rules of thumb" ?
- will a gsr master cylinder and proportion vale bolt rite on to my 95 cx??what eles im i missing for
- Need to remove valve cover
- 92-94 EG questions.
- *help!!* gas tank pressure....
- Resistor Box
- is it possible to put the integra radiator and a/c condensor on a EK????
- changing axles......broken crv boot
- SRR control arms for eg !!!!!
- Does anyone know what bulbs I would need for the dash?
- My project EG.....
- Distributer
- Over or under the axle?
- What stock fuel pumps are different?
- Spraying a 00 Civic EX
- What shops would you guys recommend up here in Northern CALI..
- Installation
- 92-95 Complete Civic Front Clip and Full Interior for Sale. Check for link!
- check engine light on
- 2 1/2" exhaust
- New in town
- header install
- 01-02 civic short throw shifters
- Hello i,m New!
- radiator from an automatic civic on a 5speed...
- removing pin striping
- Who has installed Integra GSR seats into an EK?
- do, but i am just curious Cold Air Intake For Winter!!!
- need help with v afc
- civic headlight problems-help
- internals. what do you got???
- Will my compression get fu*ked up?
- S2000 seats in a civic
- D series pistons and rods
- GB: JE Pistons $500 shipped
- New to Forum
- DSM go Honda. need opinion.
- Two questions in one.
- my car ! finally dropped !
- My car has problems.......help please!!!!!!!!!!!!!!!!!
- SS Clutch Line Pictures - EK Hybrid
- what do you think of my ride???
- how do i post pics of my ride
- Can you make a 12 sec. motor with honda only parts???
- Odd problem need help
- Seattle area peeps...
- Motor mount question
- B16A, T3, JRSC, Bullfrog??
- mount location for 3 point harness
- Will GSR Comptech Icebox fit a GSR EG?
- gapless piston rings
- Jackson Racing Superchargers......one person's tale of HELL.
- anyone have or heard of a skid plate for an exhaust?
- HCP mounts Kit, please help
- aem intakes
- Anyone need a new OEM Honda Del Sol VTEC alt belt? (pics inside)
- New proportioning valve install
- 96 Civic LX Brake Conversion
- Where to find if a Block is legit?
- My car's height???
- CEL i get a 6 and 7 quick short blinks reapingtly!! HELLLPP
- Gude Heads????
- what wire is this on the clockspring? *pic*
- Just recieved ITR sway bar as a gift
- 92-95 ex/si tranny vs. 92-95 vx
- Canadian/JDM 92-95 guage clusters
- 92-95 si tranny help!!
- EG 1992 civic lower arm bar.....JIC for 90.00 the way to go??
- Integra GSR short shifter? Whats the best short shifter and is smooth?
- HELP! Clutch Problems
- how much is it worth
- type r mirrors
- Just got my new SPOON shift knob installed........
- Master cylinder and proportion valve same in the 99 Si and EX???
- Web site to get D16's off of?
- Roll-Cage / Monkey Bars for EG civic????????
- My A/C
- Do You guys think if i took out my A/C unit it would be less work on the engine and get something ou
- Advantages of a B series to a D series
- What is wrong with my clutch!?
- New Rear Bearing Hub or just bearing???
- Virus warning!!
- keyless entry question
- I Need help I am broke what are some engine tweaks I can do? For cheap?
- Advice on Buyin a used exhaust.
- Leaky Roof
- Will 5th gen 4dr fenders fit 2dr/3dr?
- Side Skirt Question...
- wat u guys think about turboing a automatic
- Popping noise when depressing brake pedal?
- My oil pan bolt!
- Stock airbox with ram air works?
