View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 95 civic cv axle
- 97 y5 swapped 99 y8 upper o2 sensor help (Please take a look)
- 50A Ignition Fuse Blowout
- Information needed on manual tranny refill
- IACV faulty? little help.... ?
- 99 civic tack not work
- New to Civic, Need some suggestions
- Speedometer Issue
- radio cuts out when clutch depressed.
- ** STOLEN VSM EK HATCH** NORTHWEST AREA. PLEASE BE ON THE LOOK OUT!
- 93 Civic SI *Canadian spec* Seats
- em1 traction bar problem
- 2000 civic lx plug wire fell off while driving now wont start
- 93 EG Need Help Please!
- Intermittent Misfires. Possibly Coil or Igniter?
- Safe to drive with oil in radiator reservior??
- who has a pdf repair manual for 96-00 civic
- US car into Canada
- gas guage on cluster not working ek hatch
- CAR WONT START!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- fuel injector ?
- 99 Civic b16a2 wont start.
- Help on my 99 Civic
- 93 civic si wiring diagram
- leaking fuel injector few questions
- obd2 live data questions
- Can You Identify This Black Box?
- Struggles to start after sitting. Not main relay.
- Civic VX Tune Up D15Z1
- Fuel cutout?
- user name
- d16z6 in 96 civic problems
- Battery dying.
- is it necessary to run 2 separate wires from battery?
- cant rev without it dying
- would it be alright if..
- Gas gauge bouncing around!
- 99 Si possible injector problem.
- eg civic b18c sir-g conversion
- Del Sol Compatible Parts...
- the salt is to much to bear
- My First Car ^.^ BUILD
- Heater problems!!
- new here
- 1999 civic lights flickering
- D16z6 swap wont rev over 2800 help
- EG/DC cruise control actuator compatable with EK
- no dash lights after fixing fuse 19 short
- Please prove to my friend theres no such thing as a non vtec b16
- do I need a cat?
- BDL-360 Inj Battery Offset
- turning over wont start 97 ex coupe
- 2000 Honda civic lx wont start
- is this a big deal?
- parts for power steering in 95 honda civc ex
- Carbon Fiber interior
- Squeaking noise when turning steering wheel
- vin location on d16y7
- Honda is burning up too much oil!!!!
- Fuel Injectors flooding engine
- ej rear disk converison problem!!!
- civic 98 lx 218 miles per full tank?!! HELP
- obd2a y8 head with obd2b I/M and ECU?
- OBD1 to OBD2
- sohc zc ecu
- Is my motor mount bad?
- b18b1 swaped em1 speedo off.
- civic seats to integra seats
- 92 Civic Lx; Auto reverse wont work
- getting keys made
- 96' Spec B18cR swap questions(EM1).
- D15z1 help
- changed throwout bearing now check engine light is on
- Brakes make noise
- Make my 95 Civic lx a tuner?
- Stolen - B16B civic Eg from Fullerton area
- Car would start and die now wont start at all
- help.. car runs bad once it gets warm
- How to change your waterpump on a D15b
- Vibrant Cat Reviews
- Need help quick plz, no start
- Best Hondata tune?
- Help with 93 Honda Civic - no start issue
- Battery Light goes on and off
- excessive play in steering outter tie rods
- Cabin filter 98 dx
- what mudguards to buy to fit 00 civic
- EG Sunroof Question
- 2000 Honda Civic sedan - interior fitting
- I need help with a cable to hydro ej1
- This is how I converted to a manual rack
- 1992 Civic EG(cx) No spin, no start, has power
- PLEASE HELP- GSR WON'T STAY ON!!!
- power doors on a civic DX how to?
- B16A2 swap into EK wiring issue
- 97 del sol si/d16y8. check engine light.
- Help: 2000 Civic dx power door conversion problem
- D15B8 hesitates under load?
- Need help on my swap.
- top rad hose to engine
- No speedo an no cluster lights
- Looking for quick b16a head answer.
- is this sapost to be like this?
- Honda Civic 1994 Horn Relay
- y8 head, y7 intake mani, y8 ecu, iacv question
- EG Fender Liner / Splash Guard
- Everything About my 1999 Honda Civic EX
- Optional audio install help
- for sale 95' EG hatch
- doors only want to unlock once and awhile??
- hey all , new looking for what civic to get to turbocharge
- Building your Dream Car 101
- Clutch Issues
- had no fuel, now no spark
- Sway bar feedback...
- Timing Belt off sprockets/pulleys by 3.8mm
- How to tell TDC on b16a2?
- 98 Civic Cranks but Wont Start
- Wire Gauges, a few questions.
- possible bad pcv?
- 95 civic fuel gauge problems?
- unknown problem frustrating
- 98 Civic EX d16y8 - vacuum line (i think) question
- 1st Gear Shudder Problem. Suggestions/Solutions? ('95 LX 4dr 5spd)
- D16 v-tec engine with a D15 non-v-tec ECU?
- radiator advice on 99 civic
- Might do a b series swap
- Civic VP issues
- Engine breaking up sputters help?!!!
- 97 dx Power Conversion without Floor Harness. Help!
- 96 Ek Hatch with b18c1 looking for this seal...
- is a HX rackNpinion same as a EX?
- help!...car wont start
- High Rpm & Bad Shift Response.
- 3 plug alternator to 4 plug conversion
- simulating eg/ek suspension
- 1998 Honda Civic Gas Pedal stiff/ hard time turning on in cold weather
- 98 civic "2" is always lit up
- 94 Civic VX D16Y8 Head replacement questions
- Need bushing for Omni Power RLCA's
- Cam Gear Question
- HELP!!! subframe swap T bracket question
- 1998 civic rear brake line replacement
- 2000 civic ex gsr swap vtec problems
- High fuel pressure issue ( i searched)
- clutch free play
- Has Anyone used Turbonetics Turbos on there Civics?
- EG Carbon doors
- D16z6 overheating issue
- 99 TYPE R INTKAE MANIFOLD ON B16A2
- Replace clutch safety switch? ('93 Civic)
- How to remove 1995 civic front bulkhead parts.
- Rotary IAC valve difference
- d16y8 swap in 2000 civic
- what hangs lower b series or d series oil pan
- Rotary IAC Valve Postion?
- d15b7 exhaust manifold on a D16y8
- 96-98 Civic DX code 91
- powersteering
- Roof Racks for a 2 door Hatch?!
- My hatch story - Daily Driver
- 99 b16a2 rebuild, how should i build this motor? for more power N/A
- fuel trim issues
- civic operating temp
- h2b swap help?
- Honda Del Sol Radio turns on and off
- Black oil.
- Just bought a car, and it stumbles around 2-3k RPM CEL on, changed o2 sensor.
- Car Sitting for 4 months
- please help identify what plugs these are
- Replacement parts
- 99-00 Si gauge cluster in 99 4dr sedan gauge cluster doesn't work in the cold
- Againnn.. distributor leak
- 99 Honda civic running problems
- heater not blowing?
- d16y7 intake manifold
- shift knob thread size?
- Places to put stickers, vinyals, decals on a four door
- intake to throttle body adapter?
- Want to make my honda faster
- flickering interior and exterior lights
- 96 Del sol SI vtec bypass
- WTB: 94 Civic E-BRAKE lines!
- Does anyone know why manufactures do not use split rear main seals?
- civic b16 with cel code 43 need help
- choosing a cone air filter?
- Another civic starting issue and shift linkage
- what is this part (laying in my driveway)
- Vacuum line diameter
- 2000 honda civic si seats
- hood questions
- B series swap build!
- 92 vx. fuel pump starting issues
- Ek rhd inner tie rods.
- Type r shift linkage and shifter...Do I need a weight shift knob????
- '98 LX knocking and grinding?
- No power when passing on 1998 honda Civic EX
- tired d16y5, replace short block with d16y8?
- 1996 D16y7 to 1998 D16y8 Parts Price list
- 2000 Civic EX wont start Power issues HEEEEELLLLPPPP!!!!
- EG6 SIR2 : Project Touge
- This is a weird one - starting issues
- Fuel issue
- Del sol O2 sensor
- 00 CIVIC EX - electrical power is not stable
- HELP PLEASE! 1993 honda civic leaking...
- EG hatch/Z6 Swap - shift linkage installation problems
- !!!!! b20 axle help !!!!
- Cabin harness from ex into dx hatch??
- STR competition fuel rail
- idleing poblem
- 94 Civic d15b7 starving for fuel - fuel pump and sock questions
- Review: 96-00 Civic Optional Ashtray
- 99 civic LX radiator fan
- 99 Civic LX 5 speed - code 6 and overheating
- can someone ID this intake manifold?
- odometer stopped workin
- 1994 Civic LX - Code 6 (fixed issue but code will not clear, not a noob)
- Hub wobble. Bent axle? help. Video inside
- Need advice! 95 Civic EX Coupe!
- 98 Honda has no spark
- 98 CTR, S/C, tuned...exhaust sounds like bass from a sub and bogging in VTEC
- 99 civic lx slow start to no start
- Hazard/turn signal problems with rhd eg
- alternator problem?
- vtec harness for a noob???
- 2000 civic ex with code P0740 - tcc solenoid
- zc sohc head. need help!!!!!!!!!
- please help..bent shift linkage?
- d16 vtec Blox stage 1 valve lash?
- Inner Tied Rod/Outer Tied Rod Replacement
- Single-Cam Transmission Choice
- Skunk2 Intake Manifold on Y8 head
- D16z6 Coolant line help Please!
- 99 EX erratic tach and possible power loss
- Exedy Clutches on eBay Fake or Real?
- Questions about swapping a D16Z into a 94 SI Sol
- Noise from relay, headlights doesnt light
- 94 Civic - What Modifications?
- Exhaust Pipe, plz check pics
- What Benefit do Window Visors provide?
- Del Sol Aftermarket Seat Brackets
- who makes the brightest h3 headlight bulb?
- 95 EX low idle, stuttering when accelerating?
- Converting a 96-98 Civic (4DR) front to a Acura EL/Domani front
- axles and shift cables for k swap into 93 sol
- Rough Idle at stops.
- Jerking/Bumping problem trying to keep steady speed
- My street radical EG6 [under construction]
- Transmission and Engine Swap - how difficult?
