View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Carpet
- help! 99 civic Si ECU pinouts please
- New engine...turbo??
- what is the diff. between the green coolant and orange?
- d16y8 knock sensor tech question/4 wire o2 conversion question-just need to clarify
- gas mileage in ek...
- lost a lot of power in a matter of days? help...
- how do you know if v-tec kicks in?
- s2000 motor in a EK?..... ewwww
- need a pic of insideof EG door without door panel on it
- same short shifter - short on EK, not on EG??
- bought new axle - too short
- quick question for 95 civic coupe please reply
- Bumper paint
- skunk2 intake manifold ... is it ...
- Mean Ass intake...for all civics............Read and find out!!!
- Pics of my EG
- ECU HELP????
- which stock exhaust system for EK? (thats not a pea-shooter)
- Need good cat back exhaust
- water coming in...???
- Tein SS question, eg hatch
- Anyone here with H22 Type S engine?
- will this fit in my rear?
- JUN Stage 2's or Toda Spec B's?
- Beginner Question for you Normally Aspirated GODS on HT
- How to pull codes in 92 Civic? Any online service manuals?
- Got new ECU, plugged it in and now my idle is all messed pls help
- WTB 92- 95 front bumper
- Whats the best Tranny for N/A D16z6 motor?
- for u guys with Clean cars with Swaps..?
- 92 Dx rear speakers?
- help
- tech help
- what is a good place who sells b20/vtecs already built
- Brakes ,any suggestions here
- $300 a good price for JDM climate control and clock???
- Sunrise Florida thieves!!!!!
- Engines for 95 DX?
- lip kits for del sol??????
- last night my car died. i don't know why
- Clear Corner Bulbs
- "engine working to hard"
- i wanna prep my car for paint
- Help this slow civic.
- someone help with cam gears please
- picture of my ek hatch.
- Pics of my car....FINALLY Lowered.
- testing a o2 sensor
- Question about clutch for 00 Si..
- need to adjust my idel! how do i do it?
- Transmission blueprint
- Integra Combination switch?
- B18c Swap, need a little a help
- b16a hard starting after long hours parked
- DIY carbon fiber disscussion
- Spoon and Mugen bushing questions!
- FS: GReddy SP Catback Civic Coupe 92-00
- best way to ship a tranny?
- Cat. Converter Problem
- what you gusy thi nk og my suspension?
- Chicagoland pick-n-pull
- wanted ls/vtec
- i finally have pictures of my sol.
- how do i remove teh steering column?
- I am having a hard time installing my RC 550 Injectors...please help!!!!
- WHere to get dents fixed?
- Just installed HKS Hiper on my eh
- EG Air/Fuel Gauge Install Question.. PLZ READ
- 99-00 Civics
- b20 cams?
- 92-95 Racing wheel install...
- how do you do a compression test?
- HELP!! I can't open my glove compartment?????
- Air bag problem
- cheapest sohc greddy turbo kit????
- i hate driving my car///damn that tranny...
- Wat Kind Of Tires On Blade Rims
- NEED HELP!!
- help gauge holder where to get
- integra forsale!!!
- 98 Civic EX MT
- MY LAST POST FOR NOW ... THANKS H/T
- motul dot 5.1 bad for honda brake system?
- wrong fluid, or snycro really bad? its long, please help!
- What kind of shortshifter are u guys using?
- Minime in a 92 cx? (searched already)
- GSR throttle body
- b18c35 specs?
- This would be nice for a project car
- Lightest sport compact wheels?
- This sound like a good investment?
- Experts: need USDM P28 auto ECU resistor values: RP17 & RP18
- Carfax needed please help
- Help with mexi painted plasitc trim
- comptech ice box ???
- Mounting ex lip on eg hatch what do i need?
- gaskets for a z6
- obd2 distributorquestions
- valve clearance spec's for d16y7?
- how much are JDM Doors for 92-95 hatchbacks worth??
- b16b?
- CEL Question & Free Cell Ringtone site?
- Sedan Front & Rear Bumper work on Coupe?
- Installing Suspension On Del Sol Any Tips?
- P2P Stupid Question
- 1st time at track, suggestions/tips welcome
- Clutch Squeeling!! Need Help
- D16Y8 intake manifold on a D16Z6 head?
- 2.5" cat-back exhaust systems?
- Whats a good clutch?
- brake swap ?
- tint
- Fan only blows warm/hot air.. normal?
- Put motor together made dumb mistake
- Install Integra gauge cluster in EK??
- Compression test results
- door panel insert recovering
- del sol w/ type r 5lug conversion
- EG tail lights.....??
- problem finding a fuse
- FS:GReddy SP Catback
- tire squeeling
- compression test end stuck in!!!! HELP!!!!
- What are the effects of running lean and also a bad cat?
- light wheels suggestions
- d16y7 turbo questions????
- Is there any way to make my a/c blow HARDER?
- CX and DX?
- Is this ringland bad?
- how much does a 94 civic coupe weigh?
- Stock suspension problems
- What to do , dilemna
- ran with nos anf then car broke help!!!
- should i build a d16 or crossover to a bseries swap
- Valve clearances for a b16
- first time at the track.
- Simple Swap Questions
- Some definitions....
- Friend sold his EG and bought this...........56k no way!!
- s2000 front end on EG
- ::finally. the new wheels are on!!::
- Uneven height
- H22A in 93 Civic Coupe
- DC Sports Header
- HX wheels or 14" steels?
- final swap list-please check and tell me if i'm missing somethin
- Can a 96-98 EX header fit into any 1992-95 civic?
- what's wrong with my brakes.. mc, brake pads, or brake booster.
- HELP - how to fix impossible exaust leak
- How do you reset the maintenance light.
- How should I spend my money? Jun Stg IIIs vs Toda B's
- Alabama B18b find
- someone tell me what this blue plate means on my car,its to the left of the hood latch
- ripped boot on passenger cvjoint
- ATTN VA Hatch owner. Tag# JBA-7877
- Damn thieves!
- cans someone help me? please =(
- Friends car won't go into gear!!
- del sol seats in my civic?
- Turbo Timing? What do i do?
- front STB placement.......
- axle help
- Best OFFSET for EG Civics? +35 or +45.
- My Car, Almost Done!!!
- car dying when i first crank it up.
- can you use the spoon kevlar piping in replacement of the metal?
- Autometer tach
- Updated Dyno w/my b18c1 hatch - J's Chip and Skunk2/Mugen Chip
- what seats are light and comfortable?
- 03 si seats in to 94 coupe..
- b20 block with b16a2 head
- check engine light...please help.....
- removing dash piece ??
- Dx dynoed today... What do you think
- first post
- b20 non-vtec cams?
- b20 block?
- skunk2 cam shaft
- ground designs screwing me! help
- stock civic HX or SI wheels
- Proud new owner of a 92 hatch cx
- Best sounding custom exhaust...??
- Anyone know where to buy O2 sensor extensions?
- b20 handling
- What is the ECU code for a 93 B18a ECU?
- Whos is running a ls motor and ls turbo here in eg?
- why cant i reply to topics
- 1990 civic si coilovers
- Alternatives to Apexi World Sport
- Tinting tail lights illegal in oregon?
- hatch vs coupe
- ECU question with LS in EG
- HELP: high idle
- What suspension set up for smoothest ride
- What Is Code 54? (cel)
- Mysterious Fluid spraying.... do motor mounts contain fluid?
- civics with leather
- Integra Dash into EG Hatch
- help
- The days of my EG6 ar numbered!! 1 week
- Suggestions
- What would you do in my case
- I figured you guys would like this
- blown diff in a EX trans turbo civic
- well i wanted to ask this question before i buy
- mini timing belt
- CTR Fenders.....
- Whas the deal with my idol after a hard run??
- ::opinions Benen rear tow hook??::
- Are all the inspection stations connected ???
- ek coupe callout
- AHHH didnt pass inspection!!!
- how do i know what code my ecu throws?
- sohc civic tranny swap
- delsol shifter into EG?
- what is this sensor??
- NEW HIGH BOOST JSRC
- apex'i N1 pillowball mounts?
- Finally some pics, after a wash and wax
- B16a cam shafts VS. B16b cam shafts?
- Suspension Techniques Drop/Lowering Fork???????
- Trunk cover for 2000 civic hatch??
- ABS plastic DUCKBILL???
- Kenwood stereo HATES ME . . .
- What D-Series Cranks Can Be Used In A D16Y5.
- B18b vs. B16a?
- b18c5 in del sol?
- my car shakes, help
- The real question is.......
- Suspension problems need help quick!!!
- best motor swap for 2000 si.
- IS it possible to have powersteering with a hybrid eg?
- B16a2 plug gap... quick
- Code 43
- Where's te Sol?
- 68 mm Throttle body On ITR????
- POST your TIMES and MODEL here
- Remote Controlled Fuel Cutoff
- Swaping Springs on Teins??
- sohc vtec head
- Has anybody heard of www.rpmrons.com?
- Look what the man in brown brought me today!
- Pics of my car....poor quality
- Need help: How do you convert nonpower lock (1995 DXHB) to power locks (1995EX) with just using the
- What car/country is this from?............
- Suspension Question
- some pics of my car....yeah it's dirty
- Is It Possible
- How to Fix my window
