View Full Version : Honda Civic / Del Sol (1992 - 2000)
- MY BIG PROBLEM..... can anyone help?
- 92-95 civics with gsr swaps help
- Coolant leaking... could it be water pump?
- Hybrid Civic exhaust question...
- driving the Si
- what radiator should i get?
- 04 civic, need help hooking up a tach
- ---Air cond. Help needed, Live in Florida!!--
- Manual to Auto
- Lowering + camber Kit = MAJOR RUBBING
- SOHC ZC into an EG
- 94 DEl Sol down shifting sound need help??????????????
- Oil Change drian bolt won't come loose????
- 2004 civic radio removal
- Rims
- Loud klink sound coming from head on 96+ jdm sohc vtec, also wiring help..
- oem part numbers for honda genuine ek9 grill ???
- help: fuel cutoff at 3000rpm (searched already)
- wuts the best ebw site?
- I think my main relay is gone...
- b18b w/zex times.
- Exhaust / Engine Question
- 92-95 civic swap help
- Check this car out, we just got 191 horse out of it on our dyno
- 5th gear grind
- 97 Civic Ex
- header questions!!!
- ::project 38::sound deadening tar=gone!!
- car won't crank now...help!!
- AC troubleshooting...
- WTF can't even hit 14 BTC
- Rear disc brake swap, wheels cambered too far out?
- Can i install a low temp thermostat without replacing the fan switch??
- Turbo HX
- All My light PULSING?!?!?
- My intake air temp sensor is turning on the CEL...
- alil help changing cap and rotor
- info on painting rocker panels....
- Tire Jack in 02 Civic Ex
- knock sensor/motor mount
- 96 civic dx changing the brakes
- New guy, couple of questions ( OBD, B18C5, Turbo etc )
- I Must Be Stupid!!! Please help. How to wire VTEC????
- You know the stripes on the del sol seats?
- what should i do?
- question about tail lights
- Civic EX EJ Chassis vs Civic Si EM Chassis
- How do I program keyless entry remote on a 99 Civic EX?
- S15 front end on an EG9
- wide body
- My best bet for a turbo engine would be to keep the D17a2 or swap?
- emission testing in texas?
- old skool Catz Zeta H4 Headlight Kit
- throwing code, please help!
- WTF!!! I can't send a effin PM and I tried Pm'ing a Mod too!
- Will a stock Del Sol or 99 Si exhaust/muffler fit on a 95 DX?
- GSR ABS brakes on dx 96 civic?
- GREEN 4 DOOR 99 CIVIC STOLEN,909 HELP!
- head swap
- S2000 seats in my 97 coupe?
- jdm ctr headlights...
- 96+ Civic window keeps coming out of its track???
- srs light always on?
- carb legal...?
- auto gage tach
- Which rates should I get?
- Can you Turn Vtec-E into Vtec?
- Vtec Vs Vtec-E Whats the Difference?! (Searched)
- JDM D15B head on z6 block
- Front LCa's / Camber kit install
- neuspeed race spring owners
- 96-98 4dr civic tail lights
- will h22 vtec injector fit in my car (95civicd16z6)
- Will an integra clutch pedal assembly work for EG?
- Bad 1st gear or clutch??
- anyone selling a aftermarket tach?let me know
- red honda emblem...
- VTEC solenoid ?
- Good place in Atlanta to get an alignment?
- new car to me needs reapairs, maybe
- apexi N1 question?!!
- HELP PLEASE!!!! MY B16 WONT TURN OVER IN MY COUPE!!!
- "Del Sol" radiator?
- Would you like a FREE iPod!?!
- HX Wheel Makeover
- test pipe pros and cons
- code 14: iacv
- weird problem on b18c1 ej
- Wich OEM seats should I get for my 97 Civic EK?
- 99-00 Si Lip on an EX.
- power window problem (97 coupe)
- Help with transmission
- Help with Integra Dash Swap in NC
- WIRING PROBLEM WITH 97 CX HATCH TO EX CLUSTER
- mani swap in a cx?
- sway bar question?
- ABS on ek civic
- 2001 civic 4door
- b18c1 lacking low end power...
- retarded timing/ advanced
- Newbie looking for advice
- out of no where my cat begins to rattle?
- engine codes
- del sol ac question
- same a/c after engine swap
- b16a ignition timing
- What are some really aggresive cams?
- help engine code
- HELP! sparks plugs fouled
- Map and Barrel senor-car is running rich???
- can integra strut/shocks fit egs?
- obd0 engine with obd1 IM, what ecu?
- B18swap whoas in the new EG
- H22 ek swap questions
- I CANT FIND MY IAT!!!!
- Car almost dies when idling with AC on
- Need ASAP: D16z6 Valve Lash Settings
- need HELP quick!
- Engine cranks, Gets fuel, but NO SPARK
- After swap. Code 22
- Can i wire a Primary 02 to Secondary o2 the SAME????
- problem when starting...
- mid shifted and over reved
- Hello civic owners
- civic dash color
- Civic DX questions
- 15" or 17" rims
- Bigger tires to fit? 215/40/17
- DSM injectors on my d16y8
- cat question
- Dilemma (Little advice? :) )
- 92 Si prop valve or a 90-93 DA prop valve?
- buddy Club Spec III on a EJ1
- HELP on electrical question
- Quick timing question
- Best suspension set up for 1.5 inch drop on EG/97 Civic ex?
- Oil Leaking From B16 Gaskets....Please Help... And where can i find a Johnny Racecar Intercooler?
- Wierd no start problem
- 96-00 civic tail lights!! how to make thim clear like and 99-00 si ??? I Seen this right up
- ls vtec lock up
- speedo buggin out??
- my nos systéme purge
- DUH head
- Headers
- Installation
- Good shop in Tucson?
- D16z6 engine with automatic tranny.... will it work???
- slow start up
- Main Shaft Bearing....Help...
- What are some good sites to look at mods for the civic?
- THERMOSTAT HOUSING
- overheating
- Help: Bad Idle and Oil Leak
- Rant about Xenon Depot HID kit
- 99 ek y8 intake manifold swap , tps prob ?!?!
- building a 94 DOHC VTEC Del Sol's low end up?
- B18B compression test results
- ZC static timing
- FS: 99-00 Si rims
- Auto tranny from TEG?
- Governor on 99civic Ex??
- opinions on the red and clear tail lights??
- TB size in inches
- roll back mileage
- Primary and Secondary o2 Sensor Questions
- Steering wheel shakes
- Would this year lip fit on this year civic???
- My car is DEAD!!!
- Fun mods for a d-series
- Clutch problem in Del Sol
- Tachometer Problems Help
- engine swap info 2002 honda civic needed !!!!!
- 93 civic si suggestion on maintenance
- newb read around HT, has wish list. Opinions?
- MDX motor in a civic....
- Installing Remote Start + CD Receiver
- door conversion help!
- Carbon EG Wings West RS Lip?
- Nitrous good idea?
- spoon exhaust clip
- OBD-2b harness question
- buying a used civic
- Just got tranny out of car...bearing work...need some HELP please!
- Will a D16Y7 tranny work with a D16Y8?
- Valve Cover Fitment
- 95 gsr
- JDM climate control installation.........
- how much did you ppl pay for you eg's?
- Cupping on tires....HELP....
- HX's come pre-drilled for beaks kit/itr sway bar?
- RICE OR NO RICE
- Another Del Sol "?"
- Will an EX harness work?
- Suspension troubles
- Which throttle cable???
- jdm gauge cluster milage? **SEARCHED**
- What do the 1st and 2nd runners do in a stock gsr manifold?
- Selling A Jackson Racing SuperCharger
- P73 CHIPPING OR PROGRAMS???
- radio wiring diagram?
- difference between a black knock sensor vs. a green K/s
- Civic EG 2Dr/HB Window Visors (JDM)
- pcv location on 00 y7?
- HELP!!!!! JDM D15B VTEC Water Pump
- Brake line removal
- Any recommendations for painters in SoCal?
- oil temperature reading really high...?
- can anyone help me identify what this noise is?
- Throwin 21 and 22
- 92 si rear disc's on my 92 cx.. just a few quick questions
- I need answers quickly
- Stolen civic in Illinois, please be on the look out
- why is it so hard to twist the collar things on coilovers
- I have to replace a rear side window what parts do I need?
- My 01 Civic coupe is too high in the rear
- b16 for my 98 hatch?
- EG GSR Brake Conversion--HELP!!!!
- 94 EX Coupe - Hesitating during acceleration from stop, mostly in hot weather. Help.
- missing sensor??
- Official TPS Adjust Thread. Code 7 . Throttle Position Sensor *HELP*
- does anyone know part number for OEM Honda spark plug #
- mini distributor help
- help
- distributers
- Redline on a D16Y7?
- About that time !
- Power window on an EG
- good battery to get?
- EK Hatch OEM Exhaust Axleback Un-bolt questions...
- Are headlights from coupes and hatchbacks the same?????
- 96 civic ex Harness ?
- MOTOR OIL??
- Would this civic be worth buying?
- Will the new civic si vtec engine fit in a 98 civic hb
- exhaust for my ek hatch
- Clutch Chatter Vibrations?
- IHI TURBO?
- sanding... a question
- weird electrical problem
- oem ek9 navigation system?
- Help with rod bearings.
- Best P28 ECU program for bolt on mods for the street?
- Valve adjustment necessary
- Mini me is almost complete
- CRX del sol decal question
- Yet again.........this crazy M/C and booster issues....I wish there was a specific rule for this.
- friggin CAT!!! help?
- CTR rear lip + Exhaust?
- Ordered Koni Yellows.. Got Koni Reds.. NEED HELP!!!!!!!!!!!!!! ANYONE WITH KONI SHOCKS
