View Full Version : Honda Civic / Del Sol (1992 - 2000)
- engine swap, REALLY rough idle and then dies...
- Do anyone know this Civic?
- 3 month act clutch and pressure plate SHOULD I KEEP or resurface
- What is this from? :: Compensator arms ::
- Z6 Intake Mani on Y7 Head?
- Need help ASAP..short ram install
- LOOK, crashed civic last night, walked away fine (56k....lmao)
- What should I pay for 94 EX coupe w/ Blown Head gasket?
- Power mirror help
- 1992 vx distrubutor change
- $17 o2 sensor?
- Removing mudflaps
- can i keep this harness?
- bought a car, turned out the car has alarm. help!!
- help with unknown problem
- "Stuck" moonroof on '95 EX
- 92 civic dx horn location?
- Size of hose from heater core - 98 DX
- JDM parking pole?
- CARBING real lower tie bar
- If I go from 205/40/16 to 45s will they rub?
- k20A2 into 99 SI
- EVAP/Charcoal canister removal
- del sol aux lights wiring help?
- EG how do I loop the power steering system?
- NEW TRANSMISSION???
- bent rim :( will i be able to straighten this?
- tranny leak
- Cruise Control inop after MT conversion.
- catback exhaust system for 4door eg
- Axle Problem
- STOLEN HONDA RECOVERED!!!!!!! PICS INSIDE! (NASHVILLE B-WARE)
- swap
- car having trouble starting
- DisTributer???
- wiring up my side markers...how to?
- Help!! Can't remove oxygen sensor on my 95 Civic
- Brake Bias on a 1996 Civic EX?
- Tranny Problem?
- Cold Air Intake into Short ram?
- wierd noise coming fron drivers side..any help appriciated.
- Dislocated / elongated axle repair mini-howto
- ST front sway bar on EG question...
- motor mounts
- EG Cluster help!
- difficulty of replacing rod bearings on d16y8
- Side Skirt Removal
- check this out
- 5 lug conversion Help
- exhaust issues
- oil leak!!!!
- B18a1 v.s. Mini-Me ...
- AEM Fuel Rail help!!!
- What year did air condition switch over from r12 to the r134a system?
- Sway bar shifting side to side
- HELP! code 22: vtec oil pressure sensor.
- doing a swap, ground wire locations?
- im tryna install fogs,but..
- why doesnt my intake fit?
- New intake manifold when doing at/mt swap?
- New Throttle body - No FITV?
- H22a swap wire harness question..
- My car almost got stolen
- Recaro rails (in civic)
- HELP: ANYBODY KNOW WHERE TO WEIGH CAR AT
- where did you mount your PLX wideband w/display?
- Tuning Shop??
- my gf has a 2002 civic and wants OE cd player
- mugen lip
- pinout diagram for ZC (D16A8)
- How much oil can a leaking cam plug/seal leak?
- fuel pressure on a d15b vtec, what do i set it at?????
- How do I roll FOWORD my Odometer so it matches my old cluster??
- oil pressure gague question
- wilwood vs rotora? vs other?! daily driver 99 si
- tps sensor...
- does an obd1 cat have an o2 sensor bung?
- inline or intank fuel pump!
- Distributor failing-works with hammer
- vtec solenoid???
- 93 Sol w/ ZC swap, is it worth it?
- VAFC worth the money or no way
- any one use enjo motor mounts? any feedback??? let me know
- Which harness..?
- D16A6 oil pick up in Z6
- How to tighten Jackson racing belt on 99 civic ex
- gs-r head installation???!!!!
- uninstall of vafc
- What Part Is THIS???
- LSD Noise (((( please look))))
- CEL came on today when car was low on gas..
- Civic Length?!?!?!
- MIX AND MATCH FUEL INJECTORS
- iacv question
- question for d15 vtec owners
- Searching for EK4 OR EK 9 fender
- water temp sensor
- 02 civic SI cluster into 92 hatch?
- welding rad support
- need help with a 97 gsr in a 95 cx hatch.
- ECU Pinout for IACV...
- wiring issue
- Car dies when low on gas, starts up and runs fine, help???
- p1259 code
- RSX Conversion
- got me a quote... check this out.
- delsol popping out of 5th gear
- D16Y8 idleing too high
- blew my motor
- Bogging problems sort of
- Re
- Idle Problems With My 96 Ek due to old battery???????
- Throttlebody problem
- braking problems
- type r 5 lug in an eg
- Help Needed Install apex Turbo Timer in 92 eg hatchback
- 98 honda civic dx header question
- Engine dies while driving
- 2002 Honda Accord Brake Pads Issue, help please !!!
- eg dashboard
- $38 intake off of ebay:Minor problem
- STRUT BAR
- what cat to use when BARing a swap motor...
- just time'd a b16...confirm me if i did it correctly...
- how will it sound muffler upgrade over stock?
- 94 DX mini me swap
- 96-98 civic d16y8 exhaust gasket between Header and cat????? PLEASE HELP
- need help fast
- Clicking When Wheel is turned??
- Will d16y8 auto manifoldwork with manual transmission y8 long block?
- anyone have EG mount diagram?
- Hi, just a simple question.
- question about how to remove wheel hub
- c-pillar on coupe??
- Looking for the best quality EK Mugen Replica lip.
- Blowing Over Boost! HELP!
- HELP! Power Windows in my civic without Floor harness?!
- jdm side marker how to
- Carbon Cleaning? what's tHAT?
- smoke still comming out of my exhaust after seafoam??
- emissions question
- opinion on wheels
- Brake Pad Replacement Question
- Problem with IACV (VIDEO)
- how many points can I boost with my single cam V
- Water and oil Temps
- coolant problem
- Skunk2 intake mani Install problem..
- D16Z6 / ZC Oil gallery question...
- Bad gas mileage
- Motor swap for friend
- Corner light question
- *****94 Black EG6 stolen from upstate NY*******
- Coilslap... is this supposed to happen?
- fender rolling help
- i NEED my Honda radio code!!! HELP PLEASE!!!!
- OBD2 Harness Thoughts?
- Help me find whats wrong with my car
- .Hondata question
- Any good electrical shops around northern San Diego?
- EG suspension techniques rear sway bar help
- farewell to my system...
- 93 VX engine into 96 EX?
- How many belts? D16Z6
- locked up tranny
- Tranny Gurus please help....not wanting to shift into 3rd,4th or 5th...B series
- 99-00 CIVIC SI bseries shift linkage sleeve part number
- anybody deal with CROWER before?
- 96 front end swap on my 93 civic dx
- side marker location on jdm civics
- wierd ps problem
- JDM D15B tranny and ex/si tranny the same?
- gsr hatch quarter times
- Project EJ2 Progress
- carbon fiber dash for ek?
- Alternator?
- Recaros in Delsol
- Safe to run cx ecu on 99 b18b?
- 99 Climate Control Conversion Harness
- Exhaust System Bolt Sizes
- EG N OTHER pARTS c add ???????????
- JDM cluster in KMs
- TRACK 1/4 mile
- temp gauge stuck cold after tranny install
- D16Y7 question????????????
- RSX seats in to a EK?
- new swapped tranny making whine noise, is it input shaft bearing or something else?
- JDM Side Skirt question
- Swaps for my Ek
- Tranny for singcam turbo
- hood problem
- what suspenion components to get?
- GSR seat help
- Just moved to Costa Mesa (OC)
- brake fade, what could be causing it?
- EG with tein s-tech springs?
- h22 swap
- ITR 5 Lug Conversion onm 94 EJ Coupe?? HELP!!!
- which tb
- d16y5 swap for d16y8 problems with ecu
- B series Integra / Civic eg swap b18b1. This is my swap, check it out.
- URGENT... PROBLEMS DROPPING THE TRANNY.
- Engine Rebuild Questions D16Z6 DD Turbo
- lx dizzy Q
- my civic blows white smoke when i pop vtec??????????????????????
- Power window regulator difference between integra one?
- CTR Intake Manifold stamp
- Weird noise out of my turbo'ed d16
- D-series Ignition Control Modules, are they all the same?
- Carbon Fiber and fiberglass interior
- Need help ASAP:Will 99-00 Si seats bolt onto my 93 civic coupe brackets?
- new tank
- gsr dash swap
- When to change t-belt for 98 civic? 99xxx on it now...can i lay into it? drive it even?
- horse power issue please help
- Compression 180, 200, 200, 200 Engine OK?
- Intake ?
- Heater Core/Evap Core Removal
- no kitty CAT!
- slanted mufflers on EKs
- LSD how do i know...
- Lightened flywheels
- greddy evo 2 full catback for $200 good deal?
- Car is NOT starting
- Do I need a 'center in-offset out' ES Oval muffler?
- Alarm diagram (viper 791vx)for a 95 civic dx?
- optioNs...
- squeeking sound while idling
- bolt sizes?
- Stage 2 Comp/zex cam Help
- O2 Sensors Help!!!!!!!!!!!
- Whistling coming from under the hood?
- Throttle Cable Snapped
- Auto/Manual Intake Manifold Differences?
- Which linkage for a B-series swap on a Del Sol???
- what size?
- Time for a new Alternator....is DURALAST ok???
- eibach and intrax sway kits? anyone got this? good/bad?
- DC2 Springs fit on 92-95 4 door civic?
- where can i find EK rear bumper heat sheilds??
- projectors install
- Just did a b16a swap into my 99 civic ex..which AC belt
- Headlight question....
- what would you do/has this happend to you?
- What Alarm Is good???
- New wheels/tires, do I need a camber kit?
- rear ended someone ... front radiatior support problems
- ls rods in a d16a6
- milled head, timing off....
