View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 94 del sol si mini me swap
- 1993 Civic No Spark, No Fuel.... Some Progress Made
- 97 civic - clutch won't disengage
- 25-108BK AEM fuel rail - will D15B fuel injectors fit?
- 94 civic cx - How to remove lower ball joints?
- D16Y8 into 2000 civic lx
- Heater hose question.....?
- Type r spoiler maybe? Honda Del Sol.
- '92 Civic VX: rainwater entering hatchback area
- D16z6 build
- B16a3 Vacuum line help
- 93 del sol with b16a 20 tooth water pump help
- EK PS pump on B18 using B20 PS bracket?
- intake manifold
- 93 civic d15b7 temp gauge doesn't work
- D16y4 Rpm not even Past 5200-5500😣
- Fixing Turn Signal Sockets & Pigtails (solved)
- Help with overheating issues 98 Civic
- EG Dash Harness
- Need help on bleeding brake lines - 96 DX
- 99 Civic LX, Replaced brakes but still making noise
- d16y8 idles but wont drive
- [help!] Power Window Pinout '00 EX door in a '96 DX
- Del Sol sounds like a lawnmower
- Gas tank fuel vent tube
- Swapping fuel tanks
- Awwwww...93 Auto civic 1.6 nothing...
- Eg hatch/b18b1 swap - temperature fluctuation/hesitation (solved)
- Ej9 swap ej8 intake manifold .
- 99 Honda Civic EX. OBD2 monitors not ready
- D16z6 no start
- Esser's 2000 EBP EM1 Build
- 99 Civic HX CVT Stock: First no crank, and now cranks but won't start
- wtf is up with my reman steering rack
- Block Rebuild Question *URGENT PLEASE HELP*
- 96-00 civic coupe oem window visors?!?!
- 1997 Civic How to replace Radiator Support
- OBD2b harness on obd2a motor....?
- Weird no start issue on a 96 civic non vtec D16y7
- 5th gen steering racks
- EH3 w/ ABS - Power Steering Rack Replacement w/o Dropping Sub-Frame?
- 2000 Civic EX misfiring
- High idle and speedometer going crazy
- EG civic wiper arms?
- Cant get the transmission mounted to the engine!
- Cleaning products for engine block cleaning?
- 98 civic ex shutters below 3k rpms
- Civic lost power and died whilst driving
- German Del Sol ESi model - Fogs only come on when brights flipped on
- new beginnings (build thread)
- 99 EM1 - Another passenger side floor water leak thread
- 2000 Honda Civic si vss problem
- Eg coupe/hatchback main floor harness plug C590 (PIC HEAVY!)
- 99 EM1 - No check engine light
- D16Y8 Just sheared off key from 2 Cam gears (solved)
- New member - New 6th gen
- Will these rims fit on my stock eg suspension?
- Finch's Daily Driven Double D's
- 1996 civic dx to ex exhaust conversion questions
- Headlight Fuse Repeatedly Blowing
- Are pillar posts from 95 and 96 civic dx coupes interchangeable?
- 1998 Civic LX crank but no start?
- 99, fuel gauge and solenoid questions
- 1992 Honda Civic Cx hatchback brake lights not working.
- Remove Engine Oil Dipstick Tube - 99 Civic EX
- WONT START! Need HELP W/ WIRING AND ECU
- d16y8 not holding idle
- 2000 Honda Civic DX Car shakes when the AC is on.
- Best wheel size for a 96 Civic cx
- Ignition Switch Key Reminder
- 93 del sol m/t - starter won't crank with key
- 99 EM1 - OBD1 Alternator question
- 96 Civic EX - Puttering with no power until higher RPM's
- 97 Civic - P0705, P0135 and P0155
- 94 Civic D16 - valve cover bolt hole broke at cam hold down
- EM1 secondary o2 sensor wiring
- 98 coupe, engine swap, pull tranny or not
- 1999 civic si seats
- 98 civic lx - Passenger side front bumper bolt is stripped
- 1998 civic ex/d16y7 block/d16y8 head engine bogs and sputters (solved)
- 92 civic vx/b18b1 swap - shifter bushing replacement
- questions about D16Y7 head/D15B7 mini-me swap
- 92 civic - Position where bolt holding timing belt tensioner is stripped Help
- 93 eg hatch - main relay clicking while cranking
- 95 Civic ex 2 door coupe Automatic to Manual 5 speed conversion Issue
- HVAC Blend Door Actuator Testing (solved)
- Car won't start (Help with cabin/under dash wiring) PICS
- 96 Civic - axle problem
- 94 ex rough idle d15 z6 mani
- No Leaks but car smokes!?
- Timing will not stay steady
- 97 DX Coupe No Climate Control Lights
- Civic LX 93 a/t check engine light takes 20s to turn off
- I need radio code for 00 Civic
- EM1 or B16b EK for track?
- Just picked up a Del Sol
- EK Swap Help
- clutch & bearings shot?
- 2000 civic power door ??
- 00 Civic LX - overheating
- Del Sol rack & pinion
- 99 Civic ex- What size NRG quickrelease do I buy?
- 99' EM1 - Rear Sway Bar Question
- 1997 Civic gas gauge problems ( does not accurately tell fuel left in tank)
- noise coming from stick shift?
- 92 civic dx - blown fuse 15 and speedometer issues
- Will D16z6 cam and rocker assy fit in d15z1 head?
- Quick Basic ATF question 2000 Civic LX (solved)
- Window molding
- 97 civic si viper alarm door lock problem (solved)
- d16z6 weird rear main seal housing?
- d16y8 swap on a 1997 civic dx
- D16Y8 and D15Z1 - same water pump, timing belt, and valve cover gasket?
- Del Sol Right Hand Drive Conversion - Can I rewire JDM harnesses?
- 2000 civic d16y7 to d16y8
- 93 Honda Del Sol Si 1.6L SOHC 5spd || Clutch Slipping?
- How to reinstall power steering into a 2000 Civic CX?
- Honda Civic 2000 DX will crank but no start, and stall
- Clunking Sound on Decel
- 99' Civic EX - Vacuum leak from intake manifold
- 99-00 Civic Si Power Steering Pump - non OEM reman OK?
- 95 Civic - turn signals are really dim
- 00 Civic - Puttering with no power until higher RPM's
- AC works, Condenser fan doesn't.
- Front Brake Rotor Rubbing Something? (solved)
- 99 civic CX - CKF CEL code P1337
- 98 LX driver seat rocks
- 93 civic CX (CDM) - d15b7 idle problem?
- Identifying parts; seats, steering wheel, strut bars, and LCAs
- 97 civic b16a2 shift linkage bushing
- '98 Civic Ex Speaker replacement?
- 98 Civic DX - 2.5" Exhaust?
- Em1 - ECU P2T-A11 vs P2T-A12?
- Brake Issue, Car won't Stop when brakes applied!
- D15b1 z6 minime help
- 99 civic/b20 swap - No start and main relay clicking, but will roll start
- Deep knocking noise while turning
- swapped transmission and now electrical short?!?!? (solved)
- D16z6 Valve Cover torque spec
- Is there a difference in EK USDM and Type-R shifters?
- Wheel hub assembly for EG6 hatch
- 00 EX coupe high and low beam headlights dead - inline fuse blowing
- 97 civic ex D16y8 head/ZC block - bogging down under 3200rpm?
- 94 civic/d15 - Can you run without piping from cat back safely?
- 00 Civic -- idea for valve cover bolts
- car turns off right after I turn it on
- OBD2 D16a VTEC JDM ECU with Engine swap?
- 99 Civic - 3-wire iacv wiring diagram
- Multiple Electrical Problems, Some Intermittent. Common Denominator?
- 1997 civic brake light problems.
- 5th gen brake caliper issue
- D16Y8 - Dirty Valve Train?
- Upgrading Del Sol Si Brakes & Rebuilding
- 98 Civic won't shift to 1st/2nd with engine on but does with engine off
- 95 civic - a/c problems even after Meineke replaced almost everything
- Honda/Acura Shift Pin "B!tch Pin" Removal; Alternative Method
- AC system open for over 4 years - what needs to be replaced?
- 94 VX hatch - Bare fan switch wires and speedo/odo don't work
- 92 civic - turn signals work when headlights are off but not on
- civic eg - cluster lights don't work but climate control lights and taillights do
- Automatic transmission range sensor location (solved)
- 95 Civic - Auto Transmission Shifting problem
- 98 EX Boiling resevoir and leak by throttle body
- 98 EX civic - whining sound at or above 5k rpm
- Stock pipe intake with cone filter?
- 00 civic dx - cotter pin for ball joint nut keeps breaking
- 1997 Civic key lock problems
- Omni-power s2k clutch master cylinder (cmc) on 95 civic ex
- 00 Civic cranks but won't start
- 92 civic radiator fan
- Knock off rear em1 lip
- EX intake mani on a D16Y7... idle issues, I'm lost.
- Overheat/ Now Rough Idle at Start Up
- Replacing Air conditioner thermostatic switch - what/where is it?
- Coolant bleeder valve
- Stuck without a key!
- Need Insight. Valve Cover Gasket Replacement Difficulty -
- Window regulator question.
- EM1 dipstick tubing keeps coming off with dipstick!
- Distributor ears broke off inside engine
- 93 Civic LX - questions about possible engine swaps and mods
- Double Locking Seat Rails for ITR Seats
- 97 civic/b16a2 swap - speedo doesn't work
- Bike roof rack suggestions?
- e brake button hard to press (00 ex coupe)
- del sol w/ d16y8 - low idle and buzzing noise
- 00 Civic EX Project for My 16 yr. Old
- Can I replace the D block with a B?
- D16Y8 - Where does the crank pulley timing mark line up?
- EK3 overheating
- 00 Civic EX D16Y8 - Air Intake Hose Vacuum Line Question and Idle Issue
- Harness Swap - No crank
- Cant shift into gear after new clutch (solved)
- Hacked together wiring harness?
- 99 Civic - A/T CEL code p1753
- b16a3 swap into a 95 civic 4 door questions...
- 00 EM1 - Steering wheel shakes at 60MPH+
- Please help. No start 00' Civic
- looping power steering 96-00 need help! got lost
- Engine overheating and burning metal smell
- D16y8 non vtec high idle issue.
- Test tachometer for adjusting idle
- Park brake Cable issues. 95 Civic EX coupe drum to disk conversion
- 99 civic ex/d16y8 - Charging system problems
- 95 Civic D16Z6 Bad Injector?
- My turbo Honda build story thus far...
- Del Sol 97 Suspension Replacement
- Installed Fuel Filter on 1996 Hatch, experiencing hesitation and loss of power
- D16Y8 oil leak
- Which rear ACURA emblem will fit Del sol trunk?
- Squeaky clutch - Honda Civic 95 1.5l LSi EG4
- Need Help re: 1995 Civic DX Tune parts
- y7 block/y8 head swap into 95 Civic w/ D15B7
- Possible ignition issues in a 94 del sol
- EM1 rear bumper sagging
- OBD2B D16Y8 into 96 Civic auto
- Del Sols - Are OBD2 and OBD1 connector pin outs different?
- 96 Civic Coupe EX/HX Door Wire Harness differences
- 2000 Civic Si - Which A/C Idler Pully Do I Use?!
- Obd2b-obd1 conversion p30 codes (solved)
- Stock+Stage 2 cam Worth it ????
- 99 Civic Ex - Leaking Coolant, overheating, and melted spark plugs
- Intake Manifold Hose question
- 98 Civic EX D16Y8 - Bad head?
- Del Sol: Auto D16 swap for Manual B16?
- 98 Civic EX - Fel-Pro HS9915PT1 - Incorrect exhaust flange gasket?
- '94 Civic - Can I drive without Power Steering fluid?
- 00 Civic - auto transmission code P0753
- Is the European EJ9 Civic Immobilizer in the ECU?
- 98 civic cx/d16z6 swap - no fuel pump prime
- z6 y7 wont start.. need help!!!
- 93 civic vx with jdm d15b vtec- need help with cel
- EM1 - Would this be keyless entry?
- Speedometer not working in my 98 Honda Civic lx
- Y8 swap into 97 Civic LX - searched, can't find my wiring harness answers
- 00 Civic EX died while on highway
- 99 LX dies continuously
- '97 Del Sol - Cold air intake and catback exhaust
- 97 Ex civic hard shift final gear
- Will the type r grill fit on an 00 civic coupe?
- oil pan mounting mounting brackets
- Rough Idle @ 2500 rpm and CEL code P0122 - Are all 92-00 Civic TPS sensors the same?
- Fuel pump/main relay problem
- Manual rack and pinion creaks
- 96 Civic LX STOCK - Overheating and Losing Coolant
- [Won't Start] EJ1 D16Y7+Z6 Head
- D16a? P2j-1 head? Well i got an answer
- 98 Civic RPM dropping to 0 and jumping back up (solved)
- 95 del sol si - High idle with no brake MC attached
- 97 JDM ITR Cluster into 99 DX Problems
