View Full Version : Honda Civic / Del Sol (1992 - 2000)
- I properly disposed of my oil...but how do I properly clean my drain pan??
- cluster help
- How to get a spare key made when you have lost every copy...to copy from
- intake?
- Need Help with a P2K intake manifold..
- is this true about ek and eg momo hubs? link inside...
- guys, i need help with my honda civic lx 98
- for sale b series stuff in NY
- rims and tires...affects mileage?
- Speaker dimensions
- civic wheels on a 240???
- quick question!!!!!!!!!!!
- How would you go about buying a motor with no papers?
- custom wiring harness question
- In search of a Honda
- should i use b18b head or b16???
- dx or ex?
- springs/shocks
- good places for sleeving???
- ca smog test...
- fuse/electrical...need help
- are b18 and b16 ac compressor same?
- 92-95 Ex brakes on B-series EK
- Help with power lock issue on my 00 Civic
- Piston rings replacement D16Z6 motor
- **Bizarre Crank No Start!**
- 92-95 fog light ?
- body work
- question about mods to a 2000 civic cx
- Looking for boosted EK coupe...
- Car wont start first time, I have to start it a second time. What could this be
- 2000 Civic Si CEL
- rhino camber kits
- will an ek autopower street cage fit into eg 4 door
- quick question
- Jdm foglights installation 94 civic ex.
- Time for ECU to reset?
- vx ecu???
- REAR STRUT BAR INSTALLATION ON EJ8???
- does tein sell replacement springs for coilovers?
- another IACV question
- I want to put my OBD1 B18A1 into my 93 EG and I dont know what mounts to use can someone help me
- AEM Intake and Fuel Rail
- RPM servic throttle body question
- junkyards
- del sol vs. civic window
- headlights for EK4 Model 98
- Inner Del Sol Lock
- gauge cluster swap question
- OBD1 92-95 B16A SiR2 TO Honda civic sedan 1.4 4-point injection 1999
- engine stalls when... (I've read all 34 search results)
- Ignition coil help
- How To: Skunk2 and Omni Power Camber Kits.
- Air Conditioning blowing warm air
- testpipe help
- Help with search
- engine hesitation/bogging since swap
- rotors causing car to wobble?
- help with lights?
- Help me decide the motor to get!!! built d16y8, stock b16a3, or built b20vtec
- Is this engine mount the same for for all Civic models? Anyone know the Honda part#?
- questions
- Lock the flywheel when changing the clutch?
- Civic wont start, PLEASE HELP
- My motor leaking (high quality pics!, 56k go swap a motor)
- tint on eg what %?
- speedometer??
- Best Clutch?
- ecu pin picture (or description at least for vtec a4 and d6)
- zc engine swap
- Cooling Fan has never turned on....
- just bought a 1996 Honda del sol 86k miles red, stock everything b16a2 black interior
- NEED HELP ON B18C SWAP
- what tools do i need?
- Bolt extraction thread!!!
- 95 si head
- Missing obd ii connector
- DOES ANYBODY KNOW THE COLOR NAME AND COLOR CODE FOR EK CIVIC?????
- Intake 4 99si?
- 00 si engine swap??????help!
- distrubitor burned!!
- disassembling outer tie rod: 97 civic dx
- Ticking/Knocking noise... What the hell is it???
- Everything electrical is failing.
- del sol slicks sizes?
- Relocating Battery
- Question about syncho hub and sleeve (any tranny experts out there?)
- Electrical Problems On my EG 1994
- Well, a civic noob with a few questions.
- new to forum need help with a sawp
- h22 into a 96 ek what ecu?
- Failed smog (94 Civic EX coupe)
- MY NEW K20 BUILD
- 92 civic sedan...wheel adjustment???
- z6 head????
- Wheel Spacer/4-100 to 4-114 adapter?
- How to adjust the a/c belt tension
- 92 civic...?
- d16z6 Timing issues
- 92-95 REV SPEED TURBO KIT GOOD?
- Proper Maintenance on my car
- obd1 conversion and manifold swap, code 43??
- What's the word on these Omnipower Full Coilovers ?
- civic si or rsx s muffler
- WHEEL AND SUSPENSION
- Wrecked My del sol, couple of ?'s
- black smoke=way rich
- Stupid Question!
- check engine light on in my 96 hatch
- ek sideskirt fit on eg coupe?
- new here, quick question with hopes of not getting flamed or banned.
- I Need Some Help
- Spoon parts for an EG8
- 96 civic HX O2 plug conversion? Swapping in 2001 Type R motor HELP!!!
- Spoon chip
- My 350whp engine build thread...(I think my old one got deleted so heres a new one....)
- wiper motor
- Apexi GT Spec Exhaust System Help!
- password jdm = hmotorsonline ??
- resonators for deep exhaust
- not fully warmed up... vtec?
- missing tranny screw......
- 96 civic hatch w/H22 swap. new to honda, wondering the value
- Need a little help Since im a noob
- Whats the exact size bulb for the climate control bulbs ?
- B18b is 00 civic? Help needed, thax
- check engine light code 41
- cheapest EK build
- just swaped b16vtec but has no vtec
- B16 No Spark
- Mods for EG
- Clutch Kit ????
- LS/Vtec with B16 tranny noise
- b20 vtec head
- Primary oxygen heater sensor
- Lost screw for my honda access visor
- Will a B16b stock LSD fit my B16a2 tranny
- Intake leaking coolant
- hatch with a type r
- ebay coilovers?
- If you were going to, or have already, boosted a D16...?
- New ASR Brace
- single v to a jdm single v ???
- Is There a B16 Motor with Auto Tranny?
- wird noise
- Help Need Axle Seals Part Number
- bmw bottlecaps wobbling on my 95 civic ex
- trouble staying running after starting.
- new to the forum
- Car Keeps cutting off if not warmed up need help
- obd0 motor obd1 car
- obd2 motor, obd1 car
- cable to hydraulic conversion..??
- can you put a ek armest in a eg?
- Mount question
- SRS cable reel install..... how?
- new to forum
- Tein S-Tech or Eibach Sportline lowering springs for 96 EJ8??
- Assembly help
- no power!!
- Plug on back of block..
- 98 Civic EX Help, Please
- which wire to splice....
- help how do i get rid of this code
- BisiMoto Headers On my Civic
- help finding good headers for my 95 civic sedan
- compression specs
- transmission sticks (auto) while going from park to drive & vice versa......
- Can bad axles cause vibration upon braking?
- 1997 Stalls after 10 minutes
- del Sol B18C1 Swap Question
- autometer gauges?
- I'm running rich--will it damage my car?
- wireing diagram
- To anybody with a matrix strut bar
- Tranny wont stay in reverse.
- need 91 b18 torque specs
- alright hks hi power catback or apexi n1 catback in the 99 si honda civic
- wobbley ride?
- Is it burning oil?
- running pig rich, throwing code for o2 sensor, any help
- Newer D17 into an EK?
- Dash light wont turn on
- Looking for all motor opinion...
- Air conditioning question PLEASE HELP
- HiD question??
- c pillar bar for 98 civic lx
- What DC Headers will fit a 92-95 Civic Dx Model?
- Oxygen Sensor
- Is This for 2Dr Coupe or 3Dr Hatchback?
- Wheel camber question
- gauge cluster bulbs
- question
- Will a RS Wings West Rear Lip for 2DR fit a 3DR?
- ICM
- QUESTION about CTR / EK9 Climate Control .... ? ? ? Different Styles of 99-00 CTR climate controls?
- what does the VIBRANT muffler sound like...
- b20 on EG heating up.???
- muffler question
- pass. side axle will not go in!!!
- mini me y8 manifold wont work what is this? please help
- p28 ecu
- simple mods
- wheel stud
- gsr obd1?
- Torque for the bolts that hold the cam on d16z6
- transmission problem
- cars getting crushed in so cal!!!!!
- Swap won't start!!! HELP
- WTB 93-00 Hatch or prelude for 3,000 (wisconsin)
- someone help me learn about b series heads
- Making my civic faster
- Quick Question (headed to junk yard tomorrow)
- Built up grease and gunk on my alternator...
- D16y8 problems: overheating, bogging out, etc.
- couple questions.
- CAR JUST STOPPED HELPPP
- I need Your help installing a thule rack
- cel codes i got the codes but need help fixing
- Championship White Dupont paint..
- Anyone that knows the CALI law well, PLEASE help me.
- knock sensor worries
- what is involved to swap b18c5 in 2000 civic si
- Im done with it. Lost power for no reason.
- replace cap and rotor and no start
- black stut coming outta exhaust
- 94 cx running lean (failed smog test) plz help!!!
- do i need to change my ecu
- carpet?
- is this a good buy shifter combo?
- !! HELP !! D16A6 Compression Results - Bad??? Overheating why???
- d16y7 and d16y8 distributor... same?
- 98 CIVIC LX SWAP PROBLEMS! PLEASE HELP!!!!!
- Sunroof / Power Door lock question
- Exhaust???
- charger srt8 or h22
- vtec has a mind of it's own, please look in ..!!!!
- newbie
- Pic rezuest of D16Y8 tranny 4th gear main syncro and gear
- Jacking my car up and putting jack stands--please help!!!!
- PA install in 96 ex
- na or boost??
- surrounded in a cloud of white smoke............
- Honda Online manuals is there any ?
- What Honda center caps fit blades (~2.25 inch)?
- driverside door handle removel
- wiring the afc neo to my b18b swapped 99ek
