View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 2000 Honda Civic DX Sedan question
- 2000 Civic D16y8 ECU
- b20 swap crank pulley question
- 2000 Honda Civic clutch won't engage
- b18c swapped ek hard to start!?!?
- What Should I Use On This Steering Wheel?
- Honda Civic circa 2003 5 speed transmission HELP
- Civic 98 Continous undetectable knocking sound while braking from rear brake shoes
- D16z6 Alternator Belt
- Gsr swap in to eg hatch
- Need quick answer bypassing heater core on B20b EG!
- b20 swap cant what iacv for ls intake
- Intake manifold Fitment
- Right hand drive civic, needing a few parts
- Crank pulley came loose..
- catalytic converter on 2000 civic
- Decat and O2 sensor?
- The never ending Low Idle Issue
- 96 Honda Civic EX speaker issues.
- Eg rearquarter panel weird gap
- Speedometer issues
- my car cannot start civic 1992
- 1997 honda civic coupe EX (EJ8) alarm issues
- My Honda got stolen, then recovered
- 94 civic stolen in Tacoma
- Really loud muffler kit for 92 cx?
- D16y7 confusion here...
- 96 Civic - gear shifter jerks when accelerating
- Stalled car in 1st gear and now transmission won't engage.
- B20B swap...
- D16z6 help. Completely stumped
- Question about C551 connector for EJ6 Sedan
- Quick Release in Del sol - SRS LIGHT! 4Pin Behind Cluster?
- Del sol build
- 92 Civic - Obd2 Si motor swap
- D15b VTEC connecting rod
- wont start!!!!
- 95 Honda Civic EX; Wiring issues
- B16a2 automatic in 1999 honda civic
- hood clearence
- 94 Civic D16Z6 turbo - Mystery overheating problem!!! PLEASE READ!!
- front end noise ej8
- d16z6 build
- Bogs and accelerates slow at WOT
- Muffler Recommendation
- What engine?
- 2000 ex civic
- 92-95 Civic ELD - Removable?
- this normal 4 a distributer? D16Y7
- NEED HELP WITH INSTALLATION!
- obd2b to obd2a Alternator Swap
- B16a2 ecu and b16a3 ecu
- Soooo, I removed my bushings (pics incld)
- [Suspension] What is the cause of this? EG Hatchback
- 1996 Honda Civic - cranking Issues
- windows tablet dash install.
- code 0? code 1?
- low oil issue/mushy coolant in reservoir
- I need help diagnosing power lock issue 96 civic hx
- B16A2 oil leak, please tell it's not what I think it is...
- Starting problems on 94 civic with JDM d15b
- Timing correct?
- oil pressure sensor
- B16A3 Timing help after head gasket change
- SCREW SIZE?
- 2000 DX Hatch with HX D16y5 /5 Speed - Work in Progress
- Idle/starting problems
- What kind of header???
- ZC swap into D15B..possible problems...
- Ej1 Build. Need some advice!
- Super annoying squeaking?
- Obd2 b20 swap
- The painful 93 EG build thread
- When the Purge Control Solenoid Valve opens ?
- Del sol suspension Q
- Help deciding on what to do with older engine in DelSol
- No spark on D16!
- Correct OEM Lower Ball Joint?
- EG5 to EK1 turbo swapover??
- 2000 civic ex y8mani help!
- Next Best Option for OEM headlights
- 00 Civic/b16a2 swap in limp mode
- 00 civic ex idle from hell HELP
- About to install an xtd stage 4 on my d16 turbo
- 98 Civic EX Driver Side Mirror undetectable annoying rattle
- b16a dizzy cap different from b16a2 dizzy cap?
- 92 vx egr not engaging - what sensors does ecu need to engage the egr solenoid?
- Headlight Restoration?
- 97 del sol - D15b7 engine swap and auto to manual
- h series slave on b series trans
- Weird noise in the front.
- 2000 civic si - losing antifreeze?
- 1992 radio harness missing?
- 96-00 civic coupe exhaust fit a 92-95 civic coupe
- major oil leak! help!
- 2000 Civic EX- p0505 still present after replacing IACv
- 1996 Civic oil leak..what else can it be?
- 94 del sol S rear disc swap question
- Check Engine Light Code p1381
- d16z6 rebuild questions
- Car Alarm Problem
- EG 8 trans swap question
- Newbie Here.....How to replace connector under intake manifold?
- Time Sert thread repair kit
- C101 and C136 Connector diagrams for patchy
- B18 b16 swap
- Does The Grade of Gasoline affect emissions?
- What is this bracket?
- Why won't my speedometer work?
- Will EG Hatch outer window seal trim fit an EJ1 door?
- 98 Civic cranks but won't start
- Brake Proportion Valve
- throttle body hose
- Fuel Pump Wiring Diagram
- transmission
- Battery dead or Alternator?
- 93 EG Odd Popping/Creaking Noise
- [FAQ-DIY] OEM 5G 92-95 Civic Security Systems and Keyless Entry
- Horn Stopped Working.
- brakes locked while driving. caused glowing rotors.
- Alternator On its Way Out? 00 Civic EX
- Parking brake
- 98 Civic LX: Repair or Ditch
- D16z6 next ideas
- Burning smell after steep hill climb
- Any rack rebuilders had good luck...
- Timing belt/water pump service
- How do I identify a factory Del Sol SiR?
- 99 Civic LX D16Y7 - Only when in reverse does it make this sound
- Civic rear squealing/squeaking
- No Cat w/ OEM Muffler Rattle
- '92 Civic Charging issues at high RPM
- 00' civic w/ no power??
- 2013 si seats in 93 eg coupe?
- D16y7 intake manifold compatible with y8 head?
- b series tranny confusion
- Bad ground?
- Intermittent check engine light for EGR.
- Best swaps for a 1994 Honda civic hatch EH2?
- 98 civic ex - clicking coming from the engine bay
- eg 94 for city 02
- Testing the Crank Position (CKP) sensor
- help rad support question
- Obd2b dizzy on an obd2a? Internal swap?
- Help Poor braking after replacing rear brake shoes
- cruise control causes catastrophic meltdown
- B18A1 engine swap into 93 Civic
- obd2 dizzy on obd1 head ?
- Need help location previous owners of civic
- IACV question.
- Tax season and my suspension rebuild: input needed.
- 2000 DX distributor question (solved)
- Honda Civic EK - 16x7 +40 with 15mm spacer fitment question
- 97 civic d16y7 - Replacing bearings in transmission
- 1997 Civic no start.
- B18C1 into a 5spd EJ8 EX Coupe
- Strange (maybe electrical) screech-like sound
- Tach won't got over 4000
- 96 EX interesting lock problem. (solved)
- 98 Civic EX - lost power steering after I changed out headlight bulbs
- Resistor installation for missing pass airbag...98 CX
- Turn Signal Relay Fuse (solved)
- Honda won't start after sitting a few months
- 1994 Civic Hatch head gasket problem?
- AEM EMS start issue
- Del Sol S - Build Thread
- dc integra axleback fitment on eg ??
- Idle stops and goes
- B16A2 question
- need some help.
- 95 CDM Civic CX - Suspension/Brake works.
- POWER BAND LOCATION?
- Who has ANGRY EYES Headlights on their Del Sol?
- 93 civic hatch factory service manual
- Spare Tire Area Leak.
- Hood cable frozen, what do you guys recommend?
- Failed Smog: HC(PPM) and NO(PPM)
- 93 EG hatch with GSR knuckle/brakes
- Intermittent Start
- p28 ecu to p06. help.
- Is my mechanic messing things up on purpose?
- Looking for a rhd clip for my 97 ek sedan
- 99-00 Civic Climate Mode Control Dial Not Working
- D16Y8 auto/manual intake info
- JDM ITR 5 lug on del sol. A few questions.
- 92 civic DX automatic window, how does it stop?
- d16y8 swap ecu?
- Can someone confirm my suspicions on a NO START condition?
- 99 euro Civic - please some help with OBD2 diagnostic tool
- '95 Civic Intermittent No-Start issue (otherwise runs great)
- Rear wheel seized?
- 99 civic obd1 p28 ecu speedometer not working help!
- Should I Change Trans. Fluid???
- Replacing Cat Converter; any precautions I need to take?
- 1993 civic dx B16 complete swap parts list/mods
- Bright cluster warning lights - Anyone ever had this happen? Pics
- (Solved) 95 Civic CX - 99% stock - Metal rubbing sound on reverse only.
- help wiring a amp power cable through the fire wall of a 1992 honda civic sedan
- eg - using foglights as DRLs
- Power Steering Del Sol
- 00 Civic - radio removal
- EK with ex lower control arms and gsr front sway bar - shift linkage has no clearance
- its very cold and now my 96 civic wont start
- Hood/fender gap
- 92 civic -please help identify plug
- 94 ex 4dr engine harness problems
- 99 civic driver side headlight low beam not working
- Have questions about putting a 4th Gen Prelude Console in to a 1994 Honda Civic?
- Can't get your TPS off?
- 98 civic hatch DX, GSR SWAP QUESTION
- Anyone know what this is?
- How do I pull CEL codes?
- 98 Civic ex, Car wont rev past 5k
- 98 Civic IAC-valve code AGAIN!
- 96 DX hatch Firewall water leak - passenger front floor board soaked when it rains
- 99 civic ex intake manifold for auto transmission - need help identifying connectors
- LEDs in cluster issue!!!
- Will EG Civic hood dampers fit on EK?
- 92 civic intake manifold gasket will not seal properly
- A 400 whp Civic Sir for daily drive is possible?
- Need Help Choosing What I Should Buy
- Possibly Buyer's Remorse?
- 93 Del Sol Parasitic Draw
- Passenger window rolls down but not up
- 92 Hatch Cam not spinning, but timing belt is????
- 00 Civic/K24a2 swap - electrical issue with lights
- Will a 1999 civic si transmission be compatible with jdm B18c? (solved)
- 00 Civic - Dash fuse box and wiper motor questions
- Automatic transmission problem
- 96 fog lights wiring help
- What best motor oil for 00 civic si
- 97 Civic LX, crank no start diagnosis
- Want to buy an ek, which route should I take.
- Recaro sliders help
- JDM fog lights installation - In need of some advice.
- door locks frozen 99 civic
- Will manual steering rack from ef civic fit on ek?
- Can someone measure the OEM gap (Hood/Front Bumper)
- Wiring for Daytime Running Lights
- 92-95 Transmission Bracket Mount same as 96-00?
- 99 Civic DX Auto Spins but slow does not start
- obd2 wire harness issue
- 92 Civic SI - No crank, no start
- 2000 Civic Misfire/Low Compression
- Aftermarket horn issues.
- EK4 Headlight Questions, Experiences
- 95 Civic - Fuel pump won't prime (got rid of car)
- guidance for first e.g. build
- VTEC not staying engaged after shifting.
- 96 Civic - high idle
