View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Question about oil pan****
- broken speedometer
- Searched and nothing helped .. IACV problem - please help
- BOUGHT AN SI!!!!
- Life span of stock springs
- z6 into ef?
- dc header gasket??
- toronto area swap???
- Adjust Lifters?
- car wont start
- Overheating and a/c problem in 2000 Civic EX
- high pitched noise from clutch
- lowering question
- delsol antenna
- smoke at hi-revs
- h2d how to ?
- Autozone Ball joints/tie rods vs OEM
- swapping in Si LCA, change height?
- Climate Control Problem :(
- headlight & brakelight problem
- 96 ex price, what do you think
- Hey i need some convincing!
- hi new member is this a good?
- Value?
- 7 days and im still a trial user....?
- need help with swap
- will gsr leather seats front and back fit 96 civic ex coupe?
- Manual transmission fluid change.
- need help
- New Catalytic Converter
- my setup
- obd2 to obd1 swap???
- replacing 96 d16y7 with 98 d16y8 longblock help.
- axle
- What's missing for a mini me?
- Can't hear vtec, opinion/advice needed
- Piston questoin? Please help
- b16 dsm injectors
- what is wrong when my rpm's is way below
- so i adjusted the rear camber with washers.....
- JDM SH*T carbon fiber products....hoods, spoilers, etc.
- Quick ac question..
- 96-00 civic tein super street damper
- ? bout trailing arms
- Yes another smog question
- i dont know if its my tranny or the bearing
- does all dc headers fit the same d16
- Quik bumoer Q!
- supertech valvetrain
- what happens when my streeing wheel shaks
- car stalled on dyno? wtf PLEASE help
- SKUNK 2 CAMS yayyy
- throttle cable on a hatch back
- diagram reading help
- automativ shifter getting stuck
- Can you run a walboro 255 intank on a stock internal motor..??????
- Hey All!!
- smogging my gsr
- Integra A/C into a 95 coupe.
- jackson racing in a b16 HELP!!!
- will jdm h22 282mm prelude calipers fit a 2000 ek4 ???
- Rear Disc Swap - Having Problems Need Ideas
- k swap?
- 98 Hatch..Power to everything, no fuse's are blown. Wont even try cranking
- buddy club cam gears
- EX GAUGE CLUSTER Q's. please help. need answers ***********************
- 95 civic with JDM Fenders
- B16a2 questions....
- jdm password eg foglights bulb replacement what bulb does it take.
- 98 Civic HX, AC isnt workin! help!
- OEM LCA Bolts
- should i bore over
- are VX wheels worth anything?
- 93 dsol ls swap. ECU problem. PR4 doesnt fit
- Unknown Rattle
- Acura Legend Calipers... 2 piston? can it be bolted to ITR? is it better than a ITR caliper?
- question
- 94 1.5 no start
- Head Swap
- ZC DOHC release bearing HELPP
- 97 foglights dead.
- need help with swaped ek civic
- H22 clearances
- Hey i need help with my brakes, it is still spongy yet i bled the brakes
- rear trailing arm bushings
- 4 bolt type r OR 5 bolt type R into 1996 Honda Civic Hatchback (CX Canadian)????
- Quick & dumb question about pressure plate bolts...
- 96-98 Civic Foglights Problem...
- D15b VTEC head/ D15b7 block QUESTION
- P0420 cat problem- test pipe?
- ***Swap question Z6 into a CX***
- no clutch pressure Help!!
- Speed Bleeder part# for the Clutch
- Lookin for opinions or tips
- Fuel Pressure .
- ANY SUGGESTIONS?
- intake manifold leak?
- Rear T bracket HELP!! bseries into ej8/ek?
- engine swap help
- power steering
- D-series Tranny Help!
- this a reputable site?
- Will EG hatch catback exhaust fit EK hatch?
- b16 b18 fuel rails
- wiring vtec jdm d15b
- 92 civic hatch rear brake conversion (from 91 integra) some help needed
- stock drop
- Axle Grease
- 99-00 front end conversion
- look at this
- stock springs - front or back?
- b16 valve cover gasket
- 96 civic dash
- What's the idle Air/Fuel ratio supposed to be on a B16?
- How to install a Rear Type R Lip on a 96-98 civic ... ? HELP! Any DIYS?
- obx products?
- Low down on Headlights
- 1992 civic hb cx for sale
- jdm (1992)b16a valve cover gasket??
- need some help!!!!!!!!!
- clear coat for cf hood?
- NEED A FULL A/C SETUP!!! HELP!!
- help please..d16y8
- ***AWESOME! New exhaust SCRAPES driving on FLAT NEWLY PAVED ROADS. I'm effed. A little help here?
- My EK4 from Argentina
- eg brake/suspension question
- CEL Problem 93 Civic HATCH
- EM1 Rear Lip
- What would you recommend!?
- p72 on a d16
- vtec wiring
- Door Locks
- Battery kell switch.....
- Testing waters...how much?
- Biggest cam for stock springs?
- z6 trans in 00 ex question
- hamp oil filters
- B16 & D16 Alternators what is the difference?
- Assembling EG dash. Need ID of this wire ASAP!
- My Car Shakes When pressing on gas
- wheel well patch panels...
- connect vtech d15b
- ej1 pics gallery??
- K series question....
- knock sensor boot
- D16z6 motor, upgrading motor mounts, 2 bolt or 3 bolt rear mount???
- anyone thats intrested in rhd conversion in southern cali(chino) heres info!!!!
- What Is This Body Part Called?
- New to Honda Tech....
- Distributor Problems
- i got really big problem with my honda civic lx 98.need help
- 92-95 honda civic
- QUESTIONS about brakes
- gauge cluster lights
- BYS -Other parts?
- 96 honda civic dx hatch wire harness question????? need help
- 00 EX front lip on a 99 Si?
- ITR cams in b16..again
- Swapping a b series in my ek...few questions i needs answered
- manifold swappage
- New Guy in the Forum
- will 99-00 si shocks fit my eg?
- Team AirForceD's Turbo build ***56k GTFO***
- Idle Problem (d16y7)
- Question about a relay.
- not spark or gas
- how much is a b16 (y21) tranny worth? (w/ bad 3rd syncro)
- turbos?
- will h22a auto fit my civic?
- Civic pricing question??
- port/polished head or swap????help!!!
- 1994 d16 vtec vs 1989 nissan 240sx
- Am i getting a good deal?
- whats wrong with my b16 hatch help me
- H22 + EG +Shiftlinkage
- Anybody know anyone that will pass smog for me in the OC
- Heater Hose Removal, Remove Distributer?
- oil filter
- injectors not working after b16 swap HELP AHH
- Hello Everyone - a quick question about D16Y7
- Need Help With EK Fogs
- can i install a 255 fuel pump to a bone stock 97 ex and have no problems??
- apc clear corner issue - wth?
- d15b head gasket questions
- Camber kits
- I got a few questions about timing belt/waterpump install
- i need some little oem parts.
- 95 EX Manual - Needs Overhaul - Decisions
- which should i do cat-back??
- EK rear lower anti-sway bar / tie bar / subframe brace | what do you have?
- vortex generators......?
- Vtec hook up
- Check engine light code 91
- ATX rediator on MTX car?
- obd2 ... 2 o2 sensors..?
- question on compression
- My car won't start
- Door Won't Open!
- my speedometer is off....
- Engine stand bolts? b16
- is there an extra wire going into the ecu..
- d16y8 Crank Question?
- d16y7 headers any avalible??????
- omni power coilovers vs. ground control/koni yellow
- Distributor Question
- '96 Stock Clutch Shudder question
- Koni Coilovers
- '95 Civic Radiator Fan will not turn off
- h22 vs gsr??
- Rear suspension knocking sound
- 99si turbo manifold
- JDMCARBOY Good?
- H22a price check, please help. good deal or bad deal?
- Motor Oil, what is good?
- suspension help
- eg side skirts?
- Car bogs when gas pedal is pushed all the way in? Please help
- 00 civic rotor help
- weight
- Japanese Automobile Sport Muffler Association JASMA
- steering wheel
- fake ebay spoon mirrors
- Where can i buy this?
- She dies... Then she lives... Then she dies
- sohc vtec question
- How is the jack held down in the trunk?? EG
- Over Heating Issue Please Help
- Mirror question.
- timing belt
- back seat question
- obd0 and obd2 b16 throttle bodies the same?
- Thought I'd say hello
- CTR interior carpet
- 93 coupe swap
- EX guage cluster swap.
- SoCal rim shop
- temperature rises and falls
- Rim Sizes
- anybody with jdm part #'s?
- i need
- F/S OR F/T 93 HATCH SHELL
- civic drift car
- apexi noir question
- Mini Me y7/y8 swap to OBD1 hatch
- what head?
- opinions please
- stock internals on a civic T3/T4 app. is it safe?
- racing windshield
- i have a problem and its drivin me crazy brake question
- ecu chippppp.....ya or nah??
